Access without giving a passkey
 This is a followup of an answered question: " How to get pairing/bonding to work in e.g. ble_app_uart".
The project, ble_app_uart_pair is the ble_app_uart example with added the pairing/bonding stuff from the ble_app_gls example. It basically works fine, however there is one situation where it goes wrong.
When there was no bounding and a connection is made, via nRF Toolbox (UART), the smartphone ask whether a pairing is to be made.
If this request is directly annulled (or not answered at all for 10 seconds) access is granted to the device. This should NOT happen when the correct passkey isn't entered!
When this happens, in the RTT log there is the following:
<debug> nrf_ble_lesc: Generating ECC key pair
<info> app: BLE_GAP_EVT_AUTH_STATUS: status=0x89 bond=0x0 lv4: 0 kdist_own:0x0 kdist_peer:0x0
I think 0x89 means BLE_GAP_SEC_STATUS_REPEATED_ATTEMPTS.
How can I make the device disconnect in this situation?
   Thanks in advance, Sietse
PS. Here the main.c from my project
     * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
     With pairing/bonding from ble_app_gls.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    // added for peer manager
    #include "nrf_ble_lesc.h"
    #include "fds.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                      1                                       /**< Man In The Middle protection required (applicable when display module is detected). */
    #define SEC_PARAM_LESC                      1                                       /**< LE Secure Connections enabled. */
    #define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_DISPLAY_ONLY            /**<  Display only I/O capabilities. */
    #define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
    #define PASSKEY_TXT                     "Passkey:"                                  /**< Message to be displayed together with the pass-key. */
    #define PASSKEY_TXT_LENGTH              8                                           /**< Length of message to be displayed together with the pass-key. */
    #define PASSKEY_LENGTH                  6                                           /**< Length of pass-key received by the stack for display. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static pm_peer_id_t m_peer_to_be_deleted = PM_PEER_ID_INVALID;
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    #define STATIC_PASSKEY    "123456"
    //  instead of a random value
    static void set_static_passkey()
        static ble_opt_t    m_static_pin_option;
        uint8_t passkey[] = STATIC_PASSKEY;
        m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
        uint32_t err_code =  sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
    static void advertising_start(bool erase_bonds);
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        ret_code_t err_code;
        pm_handler_on_pm_evt(p_evt);
        pm_handler_disconnect_on_sec_failure(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
          case  PM_EVT_CONN_SEC_SUCCEEDED:
    	NRF_LOG_INFO("--> PM_EVT_CONN_SEC_SUCCEEDED");
    	pm_conn_sec_status_t conn_sec_status;
    	// Check if the link is authenticated (meaning at least MITM).
    	err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
    	if (conn_sec_status.mitm_protected)
    	    NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
    			 ble_conn_state_role(p_evt->conn_handle),
    			 p_evt->conn_handle,
    			 p_evt->params.conn_sec_succeeded.procedure);
    	    // The peer did not use MITM, disconnect.
    	    NRF_LOG_INFO("Collector did not use MITM, disconnecting");
    	    err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
    	    err_code = sd_ble_gap_disconnect(m_conn_handle,
          case PM_EVT_CONN_SEC_FAILED:
    	NRF_LOG_INFO("Connecting failed, disconnecting: ");
          case  PM_EVT_CONN_SEC_PARAMS_REQ:
    	NRF_LOG_INFO("--> PM_EVT_CONN_SEC_PARAMS_REQ");
    	NRF_LOG_INFO("--> pm_evt_handler:PM_EVT_PEERS_DELETE_SUCCEEDED");
    	advertising_start(false);
    	NRF_LOG_INFO("--> pm_evt_handler %d", p_evt->evt_id);
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_DISPLAY);
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        APP_ERROR_HANDLER(nrf_error);
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
        pm_handler_secure_on_connection(p_ble_evt);
                NRF_LOG_INFO("Disconnected");
                // Check if the last connected peer had not used MITM, if so, delete its bond information.
                if (m_peer_to_be_deleted != PM_PEER_ID_INVALID)
                    err_code = pm_peer_delete(m_peer_to_be_deleted);
                    NRF_LOG_DEBUG("Collector's bond deleted");
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
    	    /* needed ?
                err_code = pm_conn_secure(p_ble_evt->evt.gap_evt.conn_handle, false);
                if (err_code != NRF_ERROR_BUSY)
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            case BLE_GAP_EVT_PASSKEY_DISPLAY:
                char passkey[PASSKEY_LENGTH + 1];
                memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, PASSKEY_LENGTH);
                passkey[PASSKEY_LENGTH] = 0;
                NRF_LOG_INFO("Passkey: %s", nrf_log_push(passkey));
            } break;
            case BLE_GAP_EVT_AUTH_KEY_REQUEST:
                NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
            case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
                NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
             case BLE_GAP_EVT_AUTH_STATUS:
                 NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                              p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                              p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                              p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                              *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                              *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
    	  NRF_LOG_INFO("--> ble_evt_handler %d", p_ble_evt->header.evt_id);
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance = true;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        err_code = nrf_ble_lesc_request_handler();
            nrf_pwr_mgmt_run();
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        set_static_passkey();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • Hi Sietse,
    We would need to look at how you configure your characteristic and service read/write access.
    Note that by default BLE doesn't have any mechanism to terminate a connection if the link is not bonded/encrypted. It's up to the application to decide if it needs to terminate the connection due to lack of encryption/security level.
    However, in your service/characteristic you can configure the level of encryption needed to access the characteristic/service. You can find that in the configuration of read_access and write_access in ble_nus_init() function.
    By default they are SEC_OPEN, but you can change to SEC_JUST_WORKS or SEC_MITM etc to limit the access if the link is not bonded. Please refer to the gls example.
    In addition to that, if you want to terminate the connection if the link is not encrypted you can implement in your application code to check if the BLE_GAP_EVT_AUTH_STATUS doesn't return BLE_GAP_SEC_STATUS_SUCCESS and you can terminate the connection using sd_ble_gap_disconnect().
  • Hello, it is working now!
    I, ad hoc, patched ble_nus_init() to use SEC_JUST_WORKS, with is enough for me.
    In the BLE_GAP_EVT_AUTH_STATUS case I did
                 if (p_ble_evt->evt.gap_evt.params.auth_status.auth_status == 0x89) {
    Thanks for the help, Sietse
