Is there a way to add a pre-build command in NRF Connect for VS Code?
Update - I've partially achieved my goal by adding this to CMakeLists.txt:
execute_process(COMMAND gen_build_info_header.bat .\\ .\\src\\build_info.h)
However, this will only execute with a clean build and I need it to execute on every build.
You can add or customize tasks following this guide: Manually adding and customizing tasks.
Marte
Sorry to necro-post this thread. The given solution for binding tasks did not work for my organization - I need something that'll be configured automatically when other developers setup their build environment.
This works though. Add the following to the CMakeLists.txt file:
ADD_CUSTOM_COMMAND(TARGET app
PRE_BUILD
COMMAND python ../../tools/createversion.py ../src/version.h
Thank you for sharing your solution!
Marte
I know this is an old post, but I was recently facing the same issue and I couldn't find a complete solution. So, I wanted to mention what I did to solve it in case someone else is fighting with this.
Nordic provides the steps on how to create a custom binding task (link), but that was like 70% of what I needed to create a pre-build command. Once you create the binding for your program, the "nrf-connect.taskBindings" variable is added to the"settings.json" file. After this, you will have to create a "tasks.json" file under your ".vscode" folder. It should look like this picture.
On the "tasks.json" file, you need to add 2 tasks. One task for the prebuild and another one for your build binding.
For the prebuild task, you just need to add 2 variables, "label": "pre-build", and "command": "<PUT YOUR COMMAND HERE>"
For the build binding, you can copy the structure provided by Nordic in the link to add the default structure. A quick trick is that if you press CTRL+SHIFT+P, then type "Tasks: Configure Task", and select which one you one, it will automatically create it for you. Then, you need to add 2 variables "group" and "dependsOn". They are going to link your build task with the prebuild task making sure the prebuild task is compiled before this task. I am adding an example below for extra details.
"version": "2.0.0",
"tasks": [
"command": "echo PRE BUILD COMMAND"
"label": "Build: HelloWorld/build (active)",
"type": "nrf-connect-build",
"config": "${workspaceFolder}\\build",
"runCmake": false,
"clean": false,
"problemMatcher": [
"$cmake",
"$kconfig",
"$kconfig_syntax",
"$kconfig_syntax_files",
"$dts",
"$dts_syntax"
"group": {
"kind": "build",
"isDefault": true
"dependsOn": [
"pre-build"
I hope this helps someone since it took me some time to reach this solution.
