Hi! We are updating our application from NCS 1.9 to NCS 2.1. In the documentation of the HTTP AT command of the 2.X versions of NCS the XHTTPCRSP notification is documented contradictory. In the examples above it seems to be formatted like so:
<payload>
#XHTTPRSP:<length>,<state>
eg in the example of
AT#XHTTPCREQ="POST","/post","User-Agent: slm\r\naccept: */*\r\n","application/json",17 OK #XHTTPCREQ: 1 {"hello":"world"}+++ #XHTTPCREQ: 0 #XDATAMODE: 0 HTTP/1.1 200 OK Date: Tue, 01 Mar 2022 05:22:28 GMT Content-Type: application/json; charset=utf-8 Content-Length: 359 Connection: keep-alive ETag: W/"167-2YuosrP0ARLW1c5oeDiW7MId014" Vary: Accept-Encoding set-cookie: sails.sid=s%3A_b9-1rOslsmoczQUGjv93SicuBw8f6lb.x%2B6xkThAVld5%2FpykDn7trZ9JGh%2Fir3MVU0izYBfB0Kg; Path=/; HttpOnly #XHTTPCRSP:342,1
Though, if you scroll down to the documentation of #XHTTPRSP: itself it lists the following format:
#XHTTPCRSP=<byte_received>,<state><CR><LF><response>
So in the examples the data comes first, and after comes the notification. In the documentation of the command itself, the notification comes first, and after the data. Which of those two is the correct implementation?
