There is no output to UART console when I set CONFIG_BT=y in prj.conf
peripheral_lbs sample project in ncs V2.0.2 can't printk anything.
Hell Hieu,
Beside working on my custom board, I also try to learn and compare with the nRF5340DK board. To start with a new peripheral_lbs project with NCS V2.1.0. I got the following warning when creating it with nRF Connect SDK
warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: SERIAL (=n), SERIAL_HAS_DRIVER (=n). See
docs.zephyrproject.org/.../kconfig.html and/or look up UART_CONSOLE in
the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
Just following very lead related to UART like old fashion detective work.
Did you see this warning when creating the application?
JC
Never mind. The warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the value 'n'.
is related to
Hi JC,
Firstly, it is indeed keep digging and experimenting sometimes. In an ideal world we would fully understand the setup and know exactly why the system behave like we see it. But as NCS is very complex, the detective work as you say is what we have to do sometimes.
I have also observed that the .overlay file is affecting the bootloader; and also the child_image prj.conf that I suggested to you might not be doing what I expected it to be.
Another thing is that your custom configuration, TX on P1.01, does connect to one VCOM port, the one named VCOM0 on the schematic.
I'm very sorry for having given you incorrect information and missing the VCOM fact, which might have caused you lost time.
As I am out of office tomorrow, I will get back on Friday/Monday with the following:
- More accurate information on the relations between the bootloader and the .overlay file
- How to ensure NetCore is not using the UART peripheral, or at least P1.01 which you need.
- The answer to your latest question, about the warning of Kconfig being reassigned.
For today, I have been created and verify a step by step experiment to give both of us a clear picture of what is logging to where.
Before you try, please setup your environment as follow:
- Open all three COM ports your DK provide as you experiment. You might need an extra terminal program such as PuTTy.
- Make sure to revert all changes made to .dts and .dtsi files in your SDK. Might be best to install a fresh one.
- On a clean new copy of the example
Here are the experiment steps, with the necessary overlay code and the expected observation:
0. Run a fresh run with an empty overlay file
You should observed both bootloader and application logging on one port.
That is VCOM2.
1. UART0 with TX on P1.01, RX on P1.00 (VCOM0/UART1 ports). Not disabling GPIO forwarder.
&uart0 {
status = "okay";
current-speed = <115200>;
pinctrl-0 = <&uart0_default>;
pinctrl-1 = <&uart0_sleep>;
You should observed only bootloader logging on a different COM port.
That is VCOM0.
2. UART0 with TX on P1.01, RX on P1.00 (VCOM0/UART1 ports). Disabling GPIO forwarder.
gpio_fwd: nrf-gpio-forwarder {
compatible = "nordic,nrf-gpio-forwarder";
status = "disabled";
uart {
gpios = <&gpio1 1 0>, <&gpio1 0 0>, <&gpio0 11 0>, <&gpio0 10 0>;
&uart0 {
status = "okay";
You should observed both bootloader and application logging on VCOM0
3. UART0 with TX on P1.01, RX on P0.29 (your configuration). Disabling GPIO forwarder.
uart {
&pinctrl {
custom_default: c {
group1 {
psels = <NRF_PSEL(UART_TX, 1, 1)>;
group2 {
psels = <NRF_PSEL(UART_RX, 0, 29)>;
bias-pull-up;
custom_sleep: custom_sleep {
group1 {
psels = <NRF_PSEL(UART_TX, 1, 1)>,
low-power-enable;
&uart0 {
status = "okay";
pinctrl-0 = <&custom_default>;
pinctrl-1 = <&custom_sleep>;
You should observed both bootloader and application logging on VCOM0.
4. UART0 with TX on P1.01, RX on P0.29 (your configuration). NOT disabling GPIO forwarder.
uart {
&uart0 {
status = "okay";
You should observed only bootloader logging on VCOM0.
I hope this helps.
Hieu
Hello Hieu,
Just a recap of my debugging status. Now I am 100% sure the bootup message from the
specified in the nrf5340dk_nrf5340_cupapp.overlay is actually came from the NetCore!!!!!!
Notice the overlay file cupapp for the AppCore.
I added one line of code in zephyr/samples/bluetooth/hci_rpmsg/src/main.c
The problem is related to kernel configuration at the very very early beginning in the sw build process, so I will need help to solve. It is a run time bug that I can use a debugger to step thru the code.
Thanks for helping.
void main(void)
int err;
const struct device *hci_ipc_instance =
DEVICE_DT_GET(DT_CHOSEN(zephyr_bt_hci_rpmsg_ipc));
/* incoming events and data from the controller */
static K_FIFO_DEFINE(rx_queue);
printk("Hello hci_rpmsg child from NetCore\n");
LOG_DBG("Start");Hello Hieu,
Thanks for the detailed instructions and help. For your following action plan
1. - More accurate information on the relations between the bootloader and the .overlay file
2. - How to ensure NetCore is not using the UART peripheral, or at least P1.01 which you need.
3. - The answer to your latest question, about the warning of Kconfig being reassigned.
Question 2 is the most important for me.
Question 3 is related to setting CONFIG_SERIAL=n in child_image\hci_rpmsg. It is not happy and gives out warning when NetCore UART is being shutdown by CONFIG_SERIAL=n, so it is not freely reconfigurable? Does it has to be always on and come out at the default pins for UART0, ...etc ??
By the way, I have tried UART1. The remap of UART1 to UART0 of the AppCore
has no problem, but it still outputs messages from NetCore. I got the same message
*** Booting Zephyr OS build v3.1.99-ncs1 ***
So changing to UART1 of AppCore does not get the UART message from the AppCore.
I will try your experiment sand suggestions
JC
