nRF52833 refusing to run softdevices or application. Hardware failure or developer fault?
I've had a lot of success with the nRF51 series but recently came to the conclusion that it isn't suitable for our needs and trying to transition to the nRF52.
I picked up an EBYTE E73-2G4M08S1E module and I've been trying to get it working using CMSIS-DAP and openocd.
I'm aware of the well documented issue of APPROT protection but this isn't the issue as the chip is writable and openocd seems to be working as I expect having worked with the nRF51.
I keep seeing this "clearing lockup after double fault" message which I can't find anywhere on this forum or any other in relation to the nRF52.
GBD keeps returning "0x0001c030 in __isr_vector ()" which makes me think things are failing in the SD before the app even gets a chance to run. I've tried the other available SD's for the nRF52833 but I got the same result.
My question is; does this look like I've done damage to the SoC (e.g static) or is this something I've missed in the documentation and there's a hardware pin that needs grounding or raising?
I've ordered another unit, this time a nRF52811 as I suspect the 833 is over kill for our needs.
It'll take a few weeks to get it and I'm stalled without anything to work on.
I'd hate to receive it only to find I had the same problem with the new device and it was something I could have fixed!
Thanks in advance!
> nrf52_recover
Waiting for chip erase...
nRF52833.cpu device has been successfully erased and unlocked.
nRF52833.cpu -- clearing lockup after double fault
Polling target nRF52833.cpu failed, trying to reexamine
nRF52833.cpu: hardware has 6 breakpoints, 4 watchpoints
> nrf5 mass_erase
nRF52833-xxAA(build code: A0) 512kB Flash, 128kB RAM
Mass erase completed.
> program /Applications/NordicSemiSoftDevice/s113_nrf52720/s113_nrf52_7.2.0_softdevice.hex verify
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
** Programming Started **
Padding image section 0 at 0x00000b00 with 1280 bytes
Adding extra erase range, 0x0001b4ac .. 0x0001bfff
** Programming Finished **
** Verify Started **
** Verified OK **
> resume
target halted due to debug-request, current mode: Handler HardFault
xPSR: 0x00000003 pc: 00000000 msp: 0xffffffd8
> halt
program ~/Project/armgcc/_build/nrf52833_xxac.out verify
xPSR: 0x01000000 pc: 0x00000a80 msp: 0x20000400
Adding extra erase range, 0x00028228 .. 0x00028fff
** Verified OK **
> resume
xPSR: 0x21000003 pc: 0x0001c030 msp: 0x20000f90
> nrf5 info
[factory information control block]
code page size: 4096B
code memory size: 512kB
code region 0 size: 0kB
pre-programmed code: not present
number of ram blocks: 4294967295
ram block 0 size: 4294967295B
ram block 1 size: 0B
ram block 2 size: 0B
ram block 3 size: 0B
config id: ffff01a0
device id: 0xc9c7c9adbbdb6ae5
encryption root: 0x7781719852f3073426d57f6e3a778840
identity root: 0xed3a944b3d6223d0f1bf3c967071277b
device address type: 0xffffffff
device address: 0x88e06807b0a1229c
override enable: ffffffff
NRF_1MBIT values: ffffffff ffffffff ffffffff ffffffff ffffffff
BLE_1MBIT values: ffffffff ffffffff ffffffff ffffffff ffffffff
[user information control block]
read back protection configuration: ffff
reset value for XTALFREQ: ff
firmware id: 0xffff
