How to dim LED lights by nRF52832 PWM?
I changed seqValues variable of the following function from 0x8000 to 0x0010. But I can't see LED light darkening. How to dim LED lights by nRF52832 PWM?
static void _ledPwmConfig(const uint8_t pin) {
    nrf_drv_pwm_config_t const config0 =
        .output_pins =
            pin | NRF_DRV_PWM_PIN_INVERTED,       // channel 0
            NRF_DRV_PWM_PIN_NOT_USED,             // channel 1
            NRF_DRV_PWM_PIN_NOT_USED,             // channel 2
            NRF_DRV_PWM_PIN_NOT_USED,             // channel 3
        .irq_priority = APP_IRQ_PRIORITY_LOWEST,
        .base_clock   = NRF_PWM_CLK_125kHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = 25000,
        .load_mode    = NRF_PWM_LOAD_COMMON,
        .step_mode    = NRF_PWM_STEP_AUTO
    APP_ERROR_CHECK(nrf_drv_pwm_init(&_gPwm0, &config0, NULL));
    _gPwmUsed |= USED_PWM(0);
    // This array cannot be allocated on stack (hence "static") and it must
    // be in RAM (hence no "const", though its content is not changed).
    static uint16_t /*const*/ seqValues[] =
        0x0010
    nrf_pwm_sequence_t const seq =
        .values.p_common = seqValues,
        .length          = NRF_PWM_VALUES_LENGTH(seqValues),
        .repeats         = 0,
        .end_delay       = 4
    nrf_drv_pwm_simple_playback(&_gPwm0, &seq, 3, NRF_DRV_PWM_FLAG_STOP);
  • #include "band_nctu.h"
    #include "error.h"
    #include "led.h"
    #include "nrf_drv_pwm.h"
    #include "nrf_log.h"
    #include "nrf_pwm.h"
    #include "nrfx_pwm.h"
    #define USED_PWM(idx) (1UL << idx)
    static bool          _gLedInitialized = false;
    static uint8_t       _gPwmUsed        = 0;
    static nrf_drv_pwm_t _gPwm0           = NRF_DRV_PWM_INSTANCE(0);
            .output_pins =
            .top_value    = 25000,
            0x0010
            .repeats         = 0,
            .end_delay       = 4
    int ledInit(void) {
        nrf_gpio_cfg_output(LED_R);
        nrf_gpio_cfg_output(LED_G);
        nrf_gpio_cfg_output(LED_B);
        _gLedInitialized = true;
        return 0;
    int ledClearR(void) {
        if (!_gLedInitialized) {
            return ERROR_LED_UNINITIALIZED;
        nrf_gpio_pin_clear(LED_R);
        return 0;
    int ledClearG(void) {
        nrf_gpio_pin_clear(LED_G);
        return 0;
    int ledClearB(void) {
        nrf_gpio_pin_clear(LED_B);
        return 0;
    int ledClearRGB(void) {
        ledClearR();
        ledClearG();
        ledClearB();
        return 0;
    int ledSetR(void) {
        nrf_gpio_pin_set(LED_R);
        _ledPwmConfig(LED_R);
        return 0;
    int ledSetG(void) {
        nrf_gpio_pin_set(LED_G);
        _ledPwmConfig(LED_G);
        return 0;
    int ledSetB(void) {
        nrf_gpio_pin_set(LED_B);
        _ledPwmConfig(LED_B);
        return 0;
    int ledSetRGB(void) {
        ledSetR();
        ledSetG();
        ledSetB();
        return 0;
  • Hi, yes, it should be the same for nRF5 SDK 16.
    I tried to implement your code, and I didn't see the issues you described. Try lowering top_value, and see if that helps. Using NRF_DRV_PWM_FLAG_LOOP might make the testing easier.
