Creating own device tree node doesn't work
I try to create and use my own device tree node.
For that I created a very basic yaml file:
compatible: "bat-measurement"
properties:
   channel1:
      type: int
      required: true
which I use in by dts file as:
    batmeasure {
        compatible = "bat-measurement";
        channel1 = <4>;
Compiling this leads to no error. In devicetree-unfixed.h I found the node batmeasure. But I would expect to find there also something for channel1, which is not the case.
Even changing my dts file to a combination that should not work, doesn't lead to a compiler error (required parameter is not there).
    batmeasure {
        newValue = <5>;
Where is my mistake?
Erwin
  • Hi Erwin,
    The bindings file must be located under dts/bindings. So if your binding is in your application folder you need to have it located like this:
    myapp
     |___ src
     |___ CMakeLists.txt
     |___ prj.conf
     |___ dts
           |___ bindings
                   |___ bat-measurement.yaml
     |___ ...
    Make sure to also give your node and its properties descriptions, or you will get an error.
    Marte
  • I guess you are mostly Right. Only the proposed path cannot be used in our case. We have one application Folder with one prj.conf but different boards.
    myRoot
    |__ boards
    |    |__ arm
    |         |__ ourBoardA
    |         |     |__ A_app.dts
    |         |     |__ A_app.yaml
    |         |     |__ A_app_defconfig
    |         |__ ourBoardB
    |               |__ B_app.dts
    |               |__ B_app.yaml
    |               |__ B_app_defconfig
    |__ PrjData
         |__ CMakeLists.txt
         |__ prj.conf
         |__ build_A
         |     |__ all the build stuff with board A
         |__ build_B
               |__ all the build stuff with board B
    When I Build with west I give the Parameter -DBOARD_ROOT:STRING="myRoot"
    I thought I can put my new yaml file into the same Directory where my board is. But that is wrong as even in docs.zephyrproject.org/.../bindings.html is stated (I overlooked the dts/bindings):
    The build system looks for bindings in dts/bindings subdirectories of the following places:
        the zephyr repository
        your application source directory
        your board directory
        any directories in the DTS_ROOT CMake variable
        any module that defines a dts_root in its Build settings
    So I guess I could use the Folder structur:
    myRoot
    |__ boards
    |    |__ arm
    |         |__ ourBoardA
    |         |     |__ A_app.dts
    |         |     |__ A_app.yaml
    |         |     |__ A_app_defconfig
    |         |__ ourBoardB
    |               |__ B_app.dts
    |               |__ B_app.yaml
    |               |__ B_app_defconfig
    |__ PrjData
    |    |__ CMakeLists.txt
    |    |__ prj.conf
    |    |__ build_A
    |    |__ build_B
    |__ dts
         |__ bindings
    I will try it.
    Thanks
  • My Explanation was wrong. Of Course the dts can be loaded below my PrjData.
    When trying the Folder structure described in my first answer, I got again no error, Nothing.
    But moving below PrjData I get an error, that the description is missing. That Looks promising.
  • I now get even an error when the required channel1 property is not given in my dts file. So yaml and dts seems to be parsed.
    Unfortunately I don't see and channel 1 line in devicetree_unfixed.h. There are 33 occasions of batmeasure. All from the node. But shouldn't there be something for my channel1 Parameter? Later I will use some macros to get the value 4 in my Code.
    Or do I lack some understanding?
  • I have to say sorry!
    There are the lines
    #define DT_N_S_batmeasure_P_channel1 5
    #define DT_N_S_batmeasure_P_channel1_EXISTS 1
    in devicetree_unfixed.h I should have looked more carefully
    So everything works!!
