Hello, I have a question regarding to the DTM;
Is there a way to count the number of test packet transmissions or set the number of test packet transmissions in the direct test mode packet error rate test?
have you had a look at our application note on DTM for production testing?
" In receive test mode, the DUT counts the number of test packets received"
Kaja
Hi, Kaja.
Thank you for your reply.
Yes, i have read this document.
But, this measurement method is an expected value, not an actual measured value.
I use two custom boards and want to measure the actual value of packet error rate.
Best regards.
then you have to make the changes you need yourself in the code.
Kaja
