I have my BLE Gatt Peripheral application working and running.
I am developing a reader that reads BLE credential.
Application is complete. I flash the .hex file and reads the BLE credential from mobile app without power cycling.
I then added Readback protection to my application.
Once i flash this application, i verified Readback is protected (since i added WARM_RESET after enabling APPROTECT), but my BLE credential doesn't read (although reader sees advertisement).
I have to power cycle the reader and then it reads.
I want suggestion to fix this issue. I want to read the BLE credential right after flashing the application without power cycling.
Thanks.
#ifdef ENABLE_APPROTECT
//Check if Read Protection is Enabled
if ((NRF_UICR->APPROTECT & UICR_APPROTECT_PALL_Msk) !=
(UICR_APPROTECT_PALL_Enabled << UICR_APPROTECT_PALL_Pos))
/* Enable Access Port Protection
* Access through debugger to CPU registers, mapped-memory and RAM will be disabled
* To disable protection ERASEALL command must be applied. */
//Enable HW APPROTECT
WriteWordNrfNvmcCfg((uint32_t)&NRF_UICR->APPROTECT,
((NRF_UICR->APPROTECT & ~((uint32_t)UICR_APPROTECT_PALL_Msk)) |
(UICR_APPROTECT_PALL_Enabled << UICR_APPROTECT_PALL_Pos)));
//Reset to activate
sys_reboot(SYS_REBOOT_WARM);
//Access Port Protection is enabled
#else
// CTRL-AP ERASEALL command will be applied during Flash / Debug Process which makes Access Port Protection disabled
#endif //ENABLE_APPROTECT
