Facing issue of Application Event Manager OOM error in Asset tracker V2
I am working on thingy91, I have created/added a BMS module in the project which gives different values for different data fields.
Everything is fine as BMS is transmitting data and we are sending it on azure.
The problem is that, after successfully sending data on azure like 10 - 12 times, the BMS and other modules stop sending data further. Logs of LTE monitor simply run continuously.
Then after some certain time, the error occurs and the board rebooted itself.
I have set the CONFIG_HEAP_MEM_POOL_SIZE= 32384 <---- I tried increasing its value to some 64,768, then also error occur but takes more time to reflect.
CONFIG_MAIN_STACK_SIZE=8192 <--this is the main stack size set to,I tried to alter it but it shows an error when decreased below this value.
I am working on ncs version 1.9.1
MFW version :- mfw_nrf9160_1.3.1
My application is firmware
2022-07-25T04:53:53.048Z DEBUG Application data folder: /home/keyssin/.config/nrfconnect/pc-nrfconnect-linkmonitor
2022-07-25T04:53:53.151Z INFO Using nrf-device-lib-js version: 0.4.11
2022-07-25T04:53:53.151Z INFO Using nrf-device-lib version: 0.11.8
2022-07-25T04:53:53.151Z INFO Using nrfjprog DLL version: 10.15.4
2022-07-25T04:53:53.151Z INFO Using JLink version: JLink_V7.62b
2022-07-25T04:53:53.168Z DEBUG App pc-nrfconnect-linkmonitor v2.0.1 official
2022-07-25T04:53:53.169Z DEBUG App path: /home/keyssin/.nrfconnect-apps/node_modules/pc-nrfconnect-linkmonitor
2022-07-25T04:53:53.169Z DEBUG nRFConnect 3.11.1, required by the app is (^3.8.0)
2022-07-25T04:53:53.169Z DEBUG nRFConnect path: /tmp/.mount_nrfcon3SmGfR/resources/app.asar
2022-07-25T04:53:53.169Z DEBUG HomeDir: /home/keyssin
2022-07-25T04:53:53.169Z DEBUG TmpDir: /tmp
2022-07-25T04:53:53.171Z INFO Installed JLink version does not match the provided version (V7.58b)
2022-07-25T05:06:16.983Z INFO Modem port is opened
2022-07-25T05:06:17.563Z DEBUG modem << %MDMEV: SEARCH STATUS 2
2022-07-25T05:06:17.569Z DEBUG modem << [00:00:05.666,900] [0m<dbg> modem_module: lte_evt_handler: Modem domain event, type: Search done[0m
2022-07-25T05:06:17.597Z DEBUG modem << +CEREG: 5,"8003","076AB90F",7,,,"00001010","11000001"
2022-07-25T05:06:17.612Z DEBUG modem << [00:00:05.681,091] [0m<dbg> modem_module: lte_evt_handler: Network registration status: Connected - roaming[0m
2022-07-25T05:06:17.614Z DEBUG modem << [00:00:05.691,802] [0m<dbg> modem_module: lte_evt_handler: PSM parameter update: TAU: 1152000, Active time: 20[0m
2022-07-25T05:06:17.615Z DEBUG modem << %XTIME: "8A","2270525060718A","00"
2022-07-25T05:06:17.616Z DEBUG modem << [00:00:05.705,169] [0m<dbg> date_time: date_time_core_current_check: Date time never set[0m
2022-07-25T05:06:17.619Z DEBUG modem << [00:00:05.713,439] [0m<dbg> date_time: date_time_at_xtime_handler: Time obtained from cellular network (XTIME notification)[0m
2022-07-25T05:06:17.620Z DEBUG modem << [00:00:05.724,731] [0m<dbg> date_time: date_time_core_schedule_update: New periodic date time update in: 14400 seconds[0m
2022-07-25T05:06:17.621Z DEBUG modem << [00:00:05.735,687] [0m<dbg> date_time: date_time_core_store: System time updated: 2022-07-25 05:06:17[0m
2022-07-25T05:06:17.623Z DEBUG modem << [00:00:05.745,056] [0m<dbg> date_time: date_time_core_register_handler: Previously registered handler (nil) de-registered[0m
2022-07-25T05:06:17.624Z DEBUG modem << [00:00:05.756,286] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_LTE_CONNECTED[0m
2022-07-25T05:06:17.625Z DEBUG modem << [00:00:05.764,953] [0m<dbg> ui_module: state_set: State transition STATE_LTE_CONNECTING --> STATE_RUNNING[0m
2022-07-25T05:06:17.629Z DEBUG modem << [00:00:05.775,177] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_LTE_PSM_UPDATE[0m
2022-07-25T05:06:17.630Z DEBUG modem << [00:00:05.784,332] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATE_TIME_OBTAINED[0m
2022-07-25T05:06:17.632Z DEBUG modem << [00:00:05.793,334] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:17.633Z DEBUG modem << [00:00:05.800,262] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:06:17.634Z DEBUG modem << [00:00:05.809,753] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:06:17.635Z DEBUG modem << [00:00:05.816,314] [0m<dbg> modem_module: state_set: State transition STATE_CONNECTING --> STATE_CONNECTED[0m
2022-07-25T05:06:17.646Z DEBUG modem << [00:00:05.826,293] [0m<dbg> cloud_module: state_set: Cloud State transition STATE_LTE_DISCONNECTED --> STATE_LTE_CONNECTED[0m
2022-07-25T05:06:17.647Z DEBUG modem << [00:00:05.837,463] [0m<dbg> cloud_module: connect_cloud: Connecting to cloud[0m
2022-07-25T05:06:17.648Z DEBUG modem << [00:00:05.844,848] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:06:17.650Z DEBUG modem << [00:00:05.851,898] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:06:18.048Z DEBUG modem << [00:00:06.286,865] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_CONNECTING[0m
2022-07-25T05:06:18.051Z DEBUG modem << [00:00:06.297,180] [0m<dbg> cloud_module: cloud_wrap_event_handler: CLOUD_WRAP_EVT_CONNECTING[0m
2022-07-25T05:06:18.053Z DEBUG modem << [00:00:06.305,938] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_CONNECTING[0m
2022-07-25T05:06:18.055Z DEBUG modem << [00:00:06.314,331] [0m<dbg> ui_module: state_set: State transition STATE_RUNNING --> STATE_CLOUD_CONNECTING[0m
2022-07-25T05:06:18.055Z DEBUG modem << [00:00:06.324,645] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:06:28.693Z DEBUG modem << %CESQ: 57,2,20,2
2022-07-25T05:06:28.704Z DEBUG modem << [00:00:16.965,484] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -83[0m
2022-07-25T05:06:29.194Z DEBUG modem << +CSCON: 0
2022-07-25T05:06:29.196Z DEBUG modem << [00:00:17.470,428] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:06:29.331Z DEBUG modem << +CSCON: 1
2022-07-25T05:06:29.333Z DEBUG modem << [00:00:17.605,926] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:06:30.748Z DEBUG modem << [00:00:19.013,854] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
2022-07-25T05:06:30.751Z DEBUG modem << [00:00:19.022,033] [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful[0m
2022-07-25T05:06:31.425Z DEBUG modem << [00:00:19.698,638] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_CONNECTED[0m
2022-07-25T05:06:31.998Z DEBUG modem << [00:00:20.215,698] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_READY[0m
2022-07-25T05:06:32.001Z DEBUG modem << [00:00:20.225,555] [0m<dbg> cloud_module: cloud_wrap_event_handler: CLOUD_WRAP_EVT_CONNECTED[0m
2022-07-25T05:06:32.002Z DEBUG modem << [00:00:20.234,222] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_CONNECTED[0m
2022-07-25T05:06:32.004Z DEBUG modem << [00:00:20.242,523] [0m<dbg> ui_module: state_set: State transition STATE_CLOUD_CONNECTING --> STATE_RUNNING[0m
2022-07-25T05:06:32.006Z DEBUG modem << [00:00:20.252,868] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:06:32.013Z DEBUG modem << [00:00:20.259,338] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:06:32.015Z DEBUG modem << [00:00:20.265,930] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:06:32.017Z DEBUG modem << [00:00:20.274,108] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:06:32.153Z DEBUG modem << [00:00:20.282,135] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:06:32.161Z DEBUG modem << [00:00:20.290,588] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:06:32.164Z DEBUG modem << [00:00:20.298,217] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:06:32.167Z DEBUG modem << [00:00:20.304,748] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:06:32.169Z DEBUG modem << [00:00:20.311,584] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:06:32.171Z DEBUG modem << [00:00:20.323,394] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:06:32.172Z DEBUG modem << [00:00:20.331,237] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:06:32.178Z DEBUG modem << [00:00:20.344,787] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:32.180Z DEBUG modem << [00:00:20.351,684] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:06:32.181Z DEBUG modem << [00:00:20.361,083] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:06:32.183Z DEBUG modem << [00:00:20.368,316] [0m<dbg> cloud_module: sub_state_set: Cloud Sub state transition SUB_STATE_CLOUD_DISCONNECTED --> SUB_STATE_CLOUD_CONNECTED[0m
2022-07-25T05:06:32.184Z DEBUG modem << [00:00:20.381,469] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:06:32.186Z DEBUG modem << [00:00:20.390,655] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:06:32.187Z DEBUG modem << [00:00:20.397,705] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:06:32.189Z DEBUG modem << [00:00:20.404,663] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:06:32.189Z DEBUG modem << Tx: 13
2022-07-25T05:06:32.190Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:06:32.191Z DEBUG modem << [00:00:20.417,114] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:06:32.191Z DEBUG modem << [00:00:20.426,818] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:06:32.244Z DEBUG modem << [00:00:20.501,983] [0m<dbg> cloud_codec: cloud_codec_encode_agps_request: Entered cloud_codec_encode_agps_request[0m
2022-07-25T05:06:32.250Z DEBUG modem << Encoded message:
2022-07-25T05:06:32.251Z DEBUG modem << {
2022-07-25T05:06:32.253Z DEBUG modem << "mcc":310,
2022-07-25T05:06:32.255Z DEBUG modem << "mnc":410,
2022-07-25T05:06:32.256Z DEBUG modem << "area":32771,
2022-07-25T05:06:32.256Z DEBUG modem << "cell":124434703,
2022-07-25T05:06:32.257Z DEBUG modem << "types":[1, 2, 3, 4, 6, 7, 8, 9]
2022-07-25T05:06:32.258Z DEBUG modem << }
2022-07-25T05:06:32.426Z DEBUG modem << [00:00:20.524,871] [0m<dbg> data_module: agps_request_encode: A-GPS request encoded successfully[0m
2022-07-25T05:06:32.432Z DEBUG modem << [00:00:20.533,843] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20023b10[0m
2022-07-25T05:06:32.433Z DEBUG modem << [00:00:20.542,633] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_AGPS_REQUEST_DATA_SEND[0m
2022-07-25T05:06:32.433Z DEBUG modem << [00:00:20.552,001] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:32.434Z DEBUG modem << [00:00:20.558,929] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:06:32.435Z DEBUG modem << [00:00:20.568,542] [0m<dbg> data_module: agps_request_handle: A-GPS request sent[0m
2022-07-25T05:06:32.444Z DEBUG modem << [00:00:20.576,171] [0m<dbg> data_module: state_set: State transition STATE_CLOUD_DISCONNECTED --> STATE_CLOUD_CONNECTED[0m
2022-07-25T05:06:32.447Z DEBUG modem << [00:00:20.587,188] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:06:32.449Z DEBUG modem << [00:00:20.596,282] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 1 of 9 in sensor buffer filled[0m
2022-07-25T05:06:32.451Z DEBUG modem << [00:00:20.607,757] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:32.454Z DEBUG modem << [00:00:20.617,523] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:06:32.456Z DEBUG modem << [00:00:20.629,089] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:32.459Z DEBUG modem << [00:00:20.639,709] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:06:32.459Z DEBUG modem << [00:00:20.649,871] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:06:32.461Z DEBUG modem << [00:00:20.658,203] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:32.463Z DEBUG modem << [00:00:20.665,130] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:06:32.464Z DEBUG modem << [00:00:20.674,591] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:06:32.465Z DEBUG modem << [00:00:20.681,152] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:06:32.466Z DEBUG modem << [00:00:20.689,361] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:06:32.467Z DEBUG modem << [00:00:20.697,387] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:06:32.606Z DEBUG modem << [00:00:20.705,841] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:06:32.614Z DEBUG modem << [00:00:20.713,470] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:06:32.616Z DEBUG modem << [00:00:20.720,001] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:06:32.618Z DEBUG modem << [00:00:20.726,867] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:06:32.619Z DEBUG modem << [00:00:20.738,677] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:06:32.628Z DEBUG modem << [00:00:20.746,520] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:06:32.631Z DEBUG modem << [00:00:20.760,070] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:32.633Z DEBUG modem << [00:00:20.766,998] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:06:32.635Z DEBUG modem << [00:00:20.776,367] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:06:32.637Z DEBUG modem << [00:00:20.783,630] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:32.639Z DEBUG modem << [00:00:20.793,548] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:06:32.641Z DEBUG modem << [00:00:20.802,612] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:06:32.641Z DEBUG modem << [00:00:20.812,286] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:06:32.642Z DEBUG modem << [00:00:20.822,296] [0m<dbg> cloud_module: agps_data_request_send: A-GPS request sent, data pointer: 0x20023b10[0m
2022-07-25T05:06:32.643Z DEBUG modem << [00:00:20.832,489] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:06:32.644Z DEBUG modem << [00:00:20.841,461] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 2 of 9 in sensor buffer filled[0m
2022-07-25T05:06:32.644Z DEBUG modem << [00:00:20.853,027] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:32.645Z DEBUG modem << [00:00:20.862,792] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:06:32.645Z DEBUG modem << [00:00:20.874,359] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:32.646Z DEBUG modem << [00:00:20.884,155] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20023b10[0m
2022-07-25T05:06:32.659Z DEBUG modem << [00:00:20.900,115] [1;33m<wrn> azure_fota: No job ID found[0m
2022-07-25T05:06:32.665Z DEBUG modem << [00:00:20.918,457] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RECEIVED[0m
2022-07-25T05:06:32.666Z DEBUG modem << [00:00:20.929,016] [0m<dbg> cloud_module: cloud_wrap_event_handler: CLOUD_WRAP_EVT_DATA_RECEIVED[0m
2022-07-25T05:06:32.825Z DEBUG modem << Decoded message:
2022-07-25T05:06:32.826Z DEBUG modem << {
2022-07-25T05:06:32.828Z DEBUG modem << "desired":{
2022-07-25T05:06:32.829Z DEBUG modem << "$version":1
2022-07-25T05:06:32.830Z DEBUG modem << },
2022-07-25T05:06:32.832Z DEBUG modem << "reported":{
2022-07-25T05:06:32.833Z DEBUG modem << "firmware":{
2022-07-25T05:06:32.834Z DEBUG modem << "fwUpdateStatus":"current",
2022-07-25T05:06:32.835Z DEBUG modem << "currentFwVersion":"0.0.0-development"
2022-07-25T05:06:32.835Z DEBUG modem << },
2022-07-25T05:06:32.836Z DEBUG modem << "dev":{
2022-07-25T05:06:32.837Z DEBUG modem << "v":{
2022-07-25T05:06:32.838Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:06:32.844Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:06:32.847Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:06:32.848Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:06:32.850Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:06:32.851Z DEBUG modem << },
2022-07-25T05:06:32.852Z DEBUG modem << "ts":1658320716152
2022-07-25T05:06:32.853Z DEBUG modem << },
2022-07-25T05:06:32.854Z DEBUG modem << "roam":{
2022-07-25T05:06:32.855Z DEBUG modem << "v":{
2022-07-25T05:06:32.856Z DEBUG modem << "rsrp":-80,
2022-07-25T05:06:32.857Z DEBUG modem << "band":12,
2022-07-25T05:06:32.858Z DEBUG modem << "nw":"LTE-M",
2022-07-25T05:06:32.859Z DEBUG modem << "area":32771,
2022-07-25T05:06:32.860Z DEBUG modem << "mccmnc":310410,
2022-07-25T05:06:32.861Z DEBUG modem << "cell":124434703,
2022-07-25T05:06:32.861Z DEBUG modem << "ip":"10.117.33.99"
2022-07-25T05:06:32.862Z DEBUG modem << },
2022-07-25T05:06:32.863Z DEBUG modem << "ts":1658320676088
2022-07-25T05:06:32.865Z DEBUG modem << },
2022-07-25T05:06:32.866Z DEBUG modem << "env":{
2022-07-25T05:06:32.866Z DEBUG modem << "v":{
2022-07-25T05:06:32.867Z DEBUG modem << "temp":29.465307235717773,
2022-07-25T05:06:32.868Z DEBUG modem << "hum":35.951591491699219,
2022-07-25T05:06:32.869Z DEBUG modem << "atmp":97.219999999999999,
2022-07-25T05:06:32.869Z DEBUG modem << "bsec_iaq":46
2022-07-25T05:06:32.870Z DEBUG modem << },
2022-07-25T05:06:32.871Z DEBUG modem << "ts":1658320715783
2022-07-25T05:06:32.871Z DEBUG modem << },
2022-07-25T05:06:32.873Z DEBUG modem << "acc":{
2022-07-25T05:06:32.874Z DEBUG modem << "v":{
2022-07-25T05:06:32.875Z DEBUG modem << "x":29.465307235717773,
2022-07-25T05:06:32.876Z DEBUG modem << "y":35.951591491699219,
2022-07-25T05:06:32.877Z DEBUG modem << "z":97.219999999999999
2022-07-25T05:06:32.877Z DEBUG modem << },
2022-07-25T05:06:32.878Z DEBUG modem << "ts":1658320715782
2022-07-25T05:06:32.879Z DEBUG modem << },
2022-07-25T05:06:32.880Z DEBUG modem << "bat":{
2022-07-25T05:06:32.881Z DEBUG modem << "v":4300,
2022-07-25T05:06:32.881Z DEBUG modem << "ts":1658127762682
2022-07-25T05:06:32.882Z DEBUG modem << },
2022-07-25T05:06:32.882Z DEBUG modem << "cfg":{
2022-07-25T05:06:32.884Z DEBUG modem << "act":true,
2022-07-25T05:06:32.884Z DEBUG modem << "gnsst":60,
2022-07-25T05:06:32.885Z DEBUG modem << "actwt":20,
2022-07-25T05:06:32.886Z DEBUG modem << "mvres":20,
2022-07-25T05:06:32.887Z DEBUG modem << "mvt":40,
2022-07-25T05:06:32.888Z DEBUG modem << "acct":10,
2022-07-25T05:06:32.889Z DEBUG modem << "nod":[]
2022-07-25T05:06:32.890Z DEBUG modem << },
2022-07-25T05:06:32.891Z DEBUG modem << "bms_device":{
2022-07-25T05:06:32.892Z DEBUG modem << "bms_id":3902,
2022-07-25T05:06:32.893Z DEBUG modem << "bms_pack_voltage":28,
2022-07-25T05:06:32.894Z DEBUG modem << "bms_state_of_charge":100,
2022-07-25T05:06:32.895Z DEBUG modem << "lowest_cell_voltage":4.0289999999999999,
2022-07-25T05:06:32.896Z DEBUG modem << "lowest_voltage_cell_no":3,
2022-07-25T05:06:32.897Z DEBUG modem << "highest_cell_voltage":4.1239999999999997,
2022-07-25T05:06:32.897Z DEBUG modem << "highest_voltage_cell_no":2,
2022-07-25T05:06:32.898Z DEBUG modem << "highest_battery_temp":27,
2022-07-25T05:06:32.899Z DEBUG modem << "highest_temp_cell_no":1,
2022-07-25T05:06:32.899Z DEBUG modem << "lowest_battery_temp":27,
2022-07-25T05:06:32.900Z DEBUG modem << "lowest_temp_cell_no":1,
2022-07-25T05:06:32.902Z DEBUG modem << "bms_pack_ampere":0,
2022-07-25T05:06:32.905Z DEBUG modem << "bms_life":65459,
2022-07-25T05:06:32.907Z DEBUG modem << "total_cells":7,
2022-07-25T05:06:32.908Z DEBUG modem << "total_temp_sensors":1,
2022-07-25T05:06:32.908Z DEBUG modem << "charger_status":0,
2022-07-25T05:06:32.909Z DEBUG modem << "load_status":0,
2022-07-25T05:06:32.909Z DEBUG modem << "average_voltage":0.23699999999999999,
2022-07-25T05:06:32.909Z DEBUG modem << "device_state":1,
2022-07-25T05:06:32.910Z DEBUG modem << "average_temp":0,
2022-07-25T05:06:32.925Z DEBUG modem << "cell_balance_state":0,
2022-07-25T05:06:32.926Z DEBUG modem << "fault_code":0,
2022-07-25T05:06:32.926Z DEBUG modem << "ts":1658320732973,
2022-07-25T05:06:32.927Z DEBUG modem << "failure_status":"Key software services"
2022-07-25T05:06:32.928Z DEBUG modem << },
2022-07-25T05:06:32.928Z DEBUG modem << "btn":{
2022-07-25T05:06:32.929Z DEBUG modem << "v":1,
2022-07-25T05:06:32.929Z DEBUG modem << "ts":1657878504824
2022-07-25T05:06:32.930Z DEBUG modem << },
2022-07-25T05:06:32.930Z DEBUG modem << "gnss":{
2022-07-25T05:06:32.931Z DEBUG modem << "v":{
2022-07-25T05:06:32.931Z DEBUG modem << "lng":-111.92806025420772,
2022-07-25T05:06:32.931Z DEBUG modem << "lat":33.458100320609439,
2022-07-25T05:06:32.932Z DEBUG modem << "acc":23.800798416137695,
2022-07-25T05:06:32.933Z DEBUG modem << "alt":372.61508178710938,
2022-07-25T05:06:32.933Z DEBUG modem << "spd":0.15087014436721802,
2022-07-25T05:06:32.934Z DEBUG modem << "hdg":0
2022-07-25T05:06:32.935Z DEBUG modem << },
2022-07-25T05:06:32.935Z DEBUG modem << "ts":1658320719008
2022-07-25T05:06:32.936Z DEBUG modem << "$version":10944
2022-07-25T05:06:32.936Z DEBUG modem << }
2022-07-25T05:06:32.937Z DEBUG modem << }
2022-07-25T05:06:32.947Z DEBUG modem << [00:00:21.148,162] [1;33m<wrn> cloud_module: Device configuration empty![0m
2022-07-25T05:06:32.954Z DEBUG modem << [00:00:21.155,029] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_CONFIG_EMPTY[0m
2022-07-25T05:06:32.956Z DEBUG modem << [00:00:21.164,428] [0m<dbg> cloud_codec: cloud_codec_encode_config: Entered cloud_codec_encode_config[0m
2022-07-25T05:06:32.956Z DEBUG modem << Encoded message:
2022-07-25T05:06:32.957Z DEBUG modem << {
2022-07-25T05:06:32.957Z DEBUG modem << "cfg":{
2022-07-25T05:06:32.957Z DEBUG modem << "act":true,
2022-07-25T05:06:32.958Z DEBUG modem << "gnsst":60,
2022-07-25T05:06:32.959Z DEBUG modem << "actwt":20,
2022-07-25T05:06:32.960Z DEBUG modem << "mvres":20,
2022-07-25T05:06:32.960Z DEBUG modem << "mvt":40,
2022-07-25T05:06:32.960Z DEBUG modem << "acct":10,
2022-07-25T05:06:32.961Z DEBUG modem << "nod":[]
2022-07-25T05:06:32.961Z DEBUG modem << }
2022-07-25T05:06:32.962Z DEBUG modem << }
2022-07-25T05:06:32.963Z DEBUG modem << [00:00:21.187,622] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20023a48[0m
2022-07-25T05:06:32.963Z DEBUG modem << [00:00:21.196,411] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_CONFIG_SEND[0m
2022-07-25T05:06:32.964Z DEBUG modem << [00:00:21.204,803] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:32.964Z DEBUG modem << [00:00:21.211,761] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:06:32.980Z DEBUG modem << [00:00:21.222,991] [0m<dbg> cloud_module: config_send: Configuration sent, data pointer: 0x20023a48[0m
2022-07-25T05:06:32.981Z DEBUG modem << [00:00:21.232,238] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:06:32.982Z DEBUG modem << [00:00:21.241,516] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20023a48[0m
2022-07-25T05:06:33.034Z DEBUG modem << [00:00:21.275,726] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:06:33.036Z DEBUG modem << [00:00:21.286,010] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:06:33.038Z DEBUG modem << [00:00:21.295,471] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 1 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:06:33.039Z DEBUG modem << [00:00:21.308,166] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:33.085Z DEBUG modem << [00:00:21.349,029] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:06:33.096Z DEBUG modem << [00:00:21.359,405] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:33.280Z DEBUG modem << [00:00:21.400,421] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:06:33.287Z DEBUG modem << [00:00:21.414,245] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:06:33.289Z DEBUG modem << [00:00:21.425,048] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:06:33.290Z DEBUG modem << [00:00:21.433,349] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:33.291Z DEBUG modem << [00:00:21.440,277] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:06:33.301Z DEBUG modem << [00:00:21.449,798] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:33.303Z DEBUG modem << [00:00:21.459,594] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:06:33.304Z DEBUG modem << [00:00:21.470,458] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:06:33.305Z DEBUG modem << [00:00:21.479,583] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:06:33.306Z DEBUG modem << [00:00:21.488,647] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:06:33.308Z DEBUG modem << [00:00:21.498,107] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:06:33.309Z DEBUG modem << [00:00:21.507,934] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:06:33.310Z DEBUG modem << [00:00:21.517,211] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:06:33.311Z DEBUG modem << [00:00:21.526,275] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:06:33.312Z DEBUG modem << [00:00:21.535,614] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:06:33.312Z DEBUG modem << [00:00:21.544,860] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:06:33.312Z DEBUG modem << [00:00:21.554,229] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:06:33.313Z DEBUG modem << Encoded message:
2022-07-25T05:06:33.313Z DEBUG modem << {
2022-07-25T05:06:33.314Z DEBUG modem << "dev":{
2022-07-25T05:06:33.470Z DEBUG modem << "v":{
2022-07-25T05:06:33.472Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:06:33.475Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:06:33.477Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:06:33.479Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:06:33.481Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:06:33.482Z DEBUG modem << },
2022-07-25T05:06:33.483Z DEBUG modem << "ts":1658725592612
2022-07-25T05:06:33.484Z DEBUG modem << },
2022-07-25T05:06:33.485Z DEBUG modem << "roam":{
2022-07-25T05:06:33.485Z DEBUG modem << "v":{
2022-07-25T05:06:33.486Z DEBUG modem << "band":12,
2022-07-25T05:06:33.486Z DEBUG modem << "nw":"LTE-M",
2022-07-25T05:06:33.487Z DEBUG modem << "rsrp":-83,
2022-07-25T05:06:33.488Z DEBUG modem << "area":32771,
2022-07-25T05:06:33.488Z DEBUG modem << "mccmnc":310410,
2022-07-25T05:06:33.489Z DEBUG modem << "cell":124434703,
2022-07-25T05:06:33.489Z DEBUG modem << "ip":"10.117.33.99"
2022-07-25T05:06:33.490Z DEBUG modem << },
2022-07-25T05:06:33.492Z DEBUG modem << "ts":1658725592539
2022-07-25T05:06:33.494Z DEBUG modem << },
2022-07-25T05:06:33.495Z DEBUG modem << "env":{
2022-07-25T05:06:33.495Z DEBUG modem << "v":{
2022-07-25T05:06:33.496Z DEBUG modem << "temp":25.415307998657227,
2022-07-25T05:06:33.497Z DEBUG modem << "hum":46.179561614990234,
2022-07-25T05:06:33.497Z DEBUG modem << "atmp":97.067999999999998,
2022-07-25T05:06:33.498Z DEBUG modem << "bsec_iaq":39
2022-07-25T05:06:33.498Z DEBUG modem << },
2022-07-25T05:06:33.498Z DEBUG modem << "ts":1658725592076
2022-07-25T05:06:33.499Z DEBUG modem << },
2022-07-25T05:06:33.499Z DEBUG modem << "acc":{
2022-07-25T05:06:33.500Z DEBUG modem << "v":{
2022-07-25T05:06:33.500Z DEBUG modem << "x":25.415307998657227,
2022-07-25T05:06:33.500Z DEBUG modem << "y":46.179561614990234,
2022-07-25T05:06:33.501Z DEBUG modem << "z":97.067999999999998
2022-07-25T05:06:33.501Z DEBUG modem << },
2022-07-25T05:06:33.502Z DEBUG modem << "ts":1658725592076
2022-07-25T05:06:33.502Z DEBUG modem << }
2022-07-25T05:06:33.503Z DEBUG modem << }
2022-07-25T05:06:33.504Z DEBUG modem << [00:00:21.638,214] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:06:33.514Z DEBUG modem << [00:00:21.645,690] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20023fd0[0m
2022-07-25T05:06:33.516Z DEBUG modem << [00:00:21.654,510] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:06:33.517Z DEBUG modem << [00:00:21.662,750] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:33.518Z DEBUG modem << [00:00:21.669,677] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:06:33.519Z DEBUG modem << [00:00:21.679,168] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:06:33.520Z DEBUG modem << [00:00:21.685,607] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:06:33.521Z DEBUG modem << [00:00:21.695,709] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:06:33.522Z DEBUG modem << [00:00:21.706,085] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:06:33.523Z DEBUG modem << [00:00:21.716,522] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:06:33.524Z DEBUG modem << [00:00:21.726,654] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:06:33.525Z DEBUG modem << [00:00:21.737,152] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:06:33.525Z DEBUG modem << [00:00:21.747,467] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:06:33.525Z DEBUG modem << [00:00:21.758,300] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:06:33.564Z DEBUG modem << Encoded batch message:
2022-07-25T05:06:33.566Z DEBUG modem << {
2022-07-25T05:06:33.569Z DEBUG modem << "env":[{
2022-07-25T05:06:33.570Z DEBUG modem << "v":{
2022-07-25T05:06:33.582Z DEBUG modem << "temp":25.415307998657227,
2022-07-25T05:06:33.584Z DEBUG modem << "hum":46.179561614990234,
2022-07-25T05:06:33.585Z DEBUG modem << "atmp":97.067999999999998,
2022-07-25T05:06:33.587Z DEBUG modem << "bsec_iaq":39
2022-07-25T05:06:33.588Z DEBUG modem << },
2022-07-25T05:06:33.589Z DEBUG modem << "ts":1658725591691
2022-07-25T05:06:33.590Z DEBUG modem << }],
2022-07-25T05:06:33.591Z DEBUG modem << "acc":[{
2022-07-25T05:06:33.592Z DEBUG modem << "v":{
2022-07-25T05:06:33.592Z DEBUG modem << "x":25.415307998657227,
2022-07-25T05:06:33.593Z DEBUG modem << "y":46.179561614990234,
2022-07-25T05:06:33.594Z DEBUG modem << "z":97.067999999999998
2022-07-25T05:06:33.596Z DEBUG modem << },
2022-07-25T05:06:33.597Z DEBUG modem << "ts":1658725591691
2022-07-25T05:06:33.598Z DEBUG modem << }]
2022-07-25T05:06:33.599Z DEBUG modem << }
2022-07-25T05:06:33.600Z DEBUG modem << [00:00:21.805,969] [0m<dbg> data_module: data_encode: Batch data encoded successfully[0m
2022-07-25T05:06:33.601Z DEBUG modem << [00:00:21.814,056] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20023bf8[0m
2022-07-25T05:06:33.602Z DEBUG modem << [00:00:21.822,875] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND_BATCH[0m
2022-07-25T05:06:33.603Z DEBUG modem << [00:00:21.831,634] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:33.603Z DEBUG modem << [00:00:21.838,562] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:06:33.620Z DEBUG modem << [00:00:21.850,738] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20023fd0[0m
2022-07-25T05:06:33.622Z DEBUG modem << [00:00:21.859,008] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:06:33.624Z DEBUG modem << [00:00:21.868,225] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20023fd0[0m
2022-07-25T05:06:33.626Z DEBUG modem << [00:00:21.877,105] [0m<dbg> cloud_module: batch_data_send: Batch sent, data pointer: 0x20023bf8[0m
2022-07-25T05:06:33.627Z DEBUG modem << [00:00:21.886,016] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:06:33.638Z DEBUG modem << [00:00:21.894,775] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20023bf8[0m
2022-07-25T05:06:33.779Z DEBUG modem << [00:00:22.052,642] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:06:33.802Z DEBUG modem << [00:00:22.074,645] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:06:34.154Z DEBUG modem <<  bms incoming_message: 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.164Z DEBUG modem << buffer_1: 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.166Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.168Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.169Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.170Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.171Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.173Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.181Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.182Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.183Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.184Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.185Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.186Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:34.800Z DEBUG modem << [00:00:23.072,937] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:06:36.181Z DEBUG modem << Tx: 13
2022-07-25T05:06:36.183Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:06:38.226Z DEBUG modem <<  bms incoming_message: 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.228Z DEBUG modem << buffer_1: 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.230Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.232Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.233Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.240Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.242Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.243Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.245Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.248Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.249Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.251Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.252Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.253Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.254Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.255Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:38.570Z DEBUG modem << [00:00:26.848,236] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:06:40.114Z DEBUG modem << +CSCON: 0
2022-07-25T05:06:40.116Z DEBUG modem << [00:00:28.390,686] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:06:40.230Z DEBUG modem << Tx: 13
2022-07-25T05:06:40.232Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:06:41.147Z DEBUG modem << %CESQ: 47,2,12,1
2022-07-25T05:06:41.166Z DEBUG modem << [00:00:29.420,989] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:06:41.954Z DEBUG modem << [00:00:30.231,933] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:06:42.275Z DEBUG modem <<  bms incoming_message: 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.278Z DEBUG modem << buffer_1: 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.280Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.282Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.283Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.284Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.285Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.286Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.287Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.288Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.289Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.290Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.291Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.292Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:42.293Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:43.570Z DEBUG modem << [00:00:31.848,327] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:06:44.277Z DEBUG modem << Tx: 13
2022-07-25T05:06:44.279Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:06:44.345Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:06:44.347Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:06:44.367Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:06:44.368Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:06:44.369Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:06:44.371Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:06:44.372Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:06:44.373Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:06:44.374Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:06:44.375Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:06:44.376Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:06:44.377Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:06:44.378Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:06:46.324Z DEBUG modem <<  bms incoming_message: a5,1,93,8,1,1,1,1b,0,0,7,cf,35,
2022-07-25T05:06:46.325Z DEBUG modem << buffer_1: a5,1,93,8,1,1,1,1b,0,0,7,cf,35,
2022-07-25T05:06:46.328Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.330Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.333Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.335Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.336Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.338Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.339Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.340Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.341Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.342Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.343Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.344Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:46.345Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:48.326Z DEBUG modem << Tx: 13
2022-07-25T05:06:48.328Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:06:48.411Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:06:48.413Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:06:48.415Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:06:48.417Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:06:48.418Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:06:48.426Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:06:48.428Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:06:48.429Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:06:48.431Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:06:48.432Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:06:48.433Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:06:48.434Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:06:48.435Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:06:50.372Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:06:50.375Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:06:50.376Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.378Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.380Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.381Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.382Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.391Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.393Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.395Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.397Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.398Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.399Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.400Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:50.401Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:52.391Z DEBUG modem << [00:00:40.642,150] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:06:52.407Z DEBUG modem << [00:00:40.650,543] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:52.408Z DEBUG modem << [00:00:40.657,470] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:06:52.409Z DEBUG modem << [00:00:40.666,961] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:06:52.572Z DEBUG modem << [00:00:40.673,553] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:06:52.584Z DEBUG modem << [00:00:40.681,762] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:06:52.586Z DEBUG modem << [00:00:40.689,788] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:06:52.587Z DEBUG modem << [00:00:40.698,272] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:06:52.588Z DEBUG modem << [00:00:40.705,932] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:06:52.589Z DEBUG modem << [00:00:40.712,493] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:06:52.590Z DEBUG modem << [00:00:40.719,360] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:06:52.592Z DEBUG modem << [00:00:40.731,231] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:06:52.602Z DEBUG modem << [00:00:40.739,074] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:06:52.603Z DEBUG modem << [00:00:40.752,685] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:52.604Z DEBUG modem << [00:00:40.759,643] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:06:52.606Z DEBUG modem << [00:00:40.769,042] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:06:52.607Z DEBUG modem << Tx: 13
2022-07-25T05:06:52.608Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:06:52.609Z DEBUG modem << [00:00:40.779,632] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:06:52.610Z DEBUG modem << [00:00:40.789,031] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:06:52.611Z DEBUG modem << [00:00:40.798,797] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:06:52.614Z DEBUG modem << [00:00:40.808,837] [0m<dbg> data_module: on_all_sCapture 1 data bytes:
2022-07-25T05:06:52.615Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:06:52.616Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:06:52.617Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:06:52.618Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:06:52.619Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:06:52.620Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:06:52.621Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:06:52.622Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:06:52.623Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:06:52.624Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:06:52.626Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:06:52.627Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:06:52.631Z DEBUG modem << tates:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:06:52.632Z DEBUG modem << [00:00:40.845,581] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 3 of 9 in sensor buffer filled[0m
2022-07-25T05:06:52.658Z DEBUG modem << [00:00:40.857,055] [0m<dbg> data_module: requested_dCapture 1 data bytes:
2022-07-25T05:06:52.660Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:06:52.661Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:06:52.671Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:06:52.672Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:06:52.673Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:06:52.675Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:06:52.676Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:06:52.678Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:06:52.679Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:06:52.679Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:06:52.680Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:06:52.680Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:06:52.681Z DEBUG modem << ata_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:52.682Z DEBUG modem << [00:00:40.894,378] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:06:52.683Z DEBUG modem << [00:00:40.905,944] [0m<dbg> data_module: requested_data_status_seCapture 1 data bytes:
2022-07-25T05:06:52.684Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:06:52.684Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:06:52.685Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:06:52.685Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:06:52.686Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:06:52.688Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:06:52.689Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:06:52.689Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:06:52.691Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:06:52.691Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:06:52.692Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:06:52.692Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:06:52.693Z DEBUG modem << t: processed requested_data_status_set()[0m
2022-07-25T05:06:52.737Z DEBUG modem << [00:00:41.002,014] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:06:52.749Z DEBUG modem << [00:00:41.012,268] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:52.829Z DEBUG modem << [00:00:41.080,841] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:06:52.843Z DEBUG modem << [00:00:41.091,156] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 2 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:06:52.844Z DEBUG modem << [00:00:41.103,820] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:06:53.602Z DEBUG modem << [00:00:41.845,611] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:06:53.604Z DEBUG modem << [00:00:41.853,942] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:53.606Z DEBUG modem << [00:00:41.860,900] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:06:53.608Z DEBUG modem << [00:00:41.870,483] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:06:53.688Z DEBUG modem << [00:00:41.881,408] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:06:53.702Z DEBUG modem << [00:00:41.890,563] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:06:53.704Z DEBUG modem << [00:00:41.899,658] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:06:53.706Z DEBUG modem << [00:00:41.909,149] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:06:53.706Z DEBUG modem << [00:00:41.918,670] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:06:53.708Z DEBUG modem << [00:00:41.927,978] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:06:53.718Z DEBUG modem << [00:00:41.937,072] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:06:53.719Z DEBUG modem << [00:00:41.946,441] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:06:53.720Z DEBUG modem << [00:00:41.955,718] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:06:53.721Z DEBUG modem << [00:00:41.965,118] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:06:53.791Z DEBUG modem << Encoded message:
2022-07-25T05:06:53.793Z DEBUG modem << {
2022-07-25T05:06:53.795Z DEBUG modem << "dev":{
2022-07-25T05:06:53.797Z DEBUG modem << "v":{
2022-07-25T05:06:53.807Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:06:53.808Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:06:53.810Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:06:53.811Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:06:53.813Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:06:53.814Z DEBUG modem << },
2022-07-25T05:06:53.815Z DEBUG modem << "ts":1658725612266
2022-07-25T05:06:53.816Z DEBUG modem << },
2022-07-25T05:06:53.817Z DEBUG modem << "roam":{
2022-07-25T05:06:53.817Z DEBUG modem << "v":{
2022-07-25T05:06:53.818Z DEBUG modem << "rsrp":-93
2022-07-25T05:06:53.818Z DEBUG modem << },
2022-07-25T05:06:53.819Z DEBUG modem << "ts":1658725612344
2022-07-25T05:06:53.819Z DEBUG modem << },
2022-07-25T05:06:53.820Z DEBUG modem << "env":{
2022-07-25T05:06:53.821Z DEBUG modem << "v":{
2022-07-25T05:06:53.822Z DEBUG modem << "temp":25.765340805053711,
2022-07-25T05:06:53.823Z DEBUG modem << "hum":44.140235900878906,
2022-07-25T05:06:53.823Z DEBUG modem << "atmp":97.069999999999993,
2022-07-25T05:06:53.824Z DEBUG modem << "bsec_iaq":46
2022-07-25T05:06:53.824Z DEBUG modem << },
2022-07-25T05:06:53.825Z DEBUG modem << "ts":1658725612062
2022-07-25T05:06:53.825Z DEBUG modem << },
2022-07-25T05:06:53.826Z DEBUG modem << "acc":{
2022-07-25T05:06:53.826Z DEBUG modem << "v":{
2022-07-25T05:06:53.828Z DEBUG modem << "x":25.765340805053711,
2022-07-25T05:06:53.829Z DEBUG modem << "y":44.140235900878906,
2022-07-25T05:06:53.829Z DEBUG modem << "z":97.069999999999993
2022-07-25T05:06:53.830Z DEBUG modem << },
2022-07-25T05:06:53.830Z DEBUG modem << "ts":1658725612062
2022-07-25T05:06:53.831Z DEBUG modem << }
2022-07-25T05:06:53.831Z DEBUG modem << [00:00:42.037,963] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:06:53.832Z DEBUG modem << [00:00:42.045,440] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20024140[0m
2022-07-25T05:06:53.832Z DEBUG modem << [00:00:42.054,290] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:06:53.834Z DEBUG modem << [00:00:42.062,561] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:06:53.902Z DEBUG modem << [00:00:42.069,519] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:06:53.904Z DEBUG modem << [00:00:42.079,040] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:06:53.907Z DEBUG modem << [00:00:42.085,449] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:06:53.912Z DEBUG modem << [00:00:42.095,611] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:06:53.914Z DEBUG modem << [00:00:42.105,987] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:06:53.924Z DEBUG modem << [00:00:42.116,516] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:06:53.926Z DEBUG modem << [00:00:42.126,647] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:06:53.929Z DEBUG modem << [00:00:42.136,840] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:06:53.930Z DEBUG modem << [00:00:42.147,155] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:06:53.931Z DEBUG modem << [00:00:42.157,562] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:06:53.932Z DEBUG modem << [00:00:42.167,633] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:06:53.934Z DEBUG modem << [00:00:42.177,917] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:06:53.944Z DEBUG modem << [00:00:42.189,544] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20024140[0m
2022-07-25T05:06:53.945Z DEBUG modem << [00:00:42.197,814] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:06:53.947Z DEBUG modem << [00:00:42.206,695] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20024140[0m
2022-07-25T05:06:54.061Z DEBUG modem << +CSCON: 1
2022-07-25T05:06:54.064Z DEBUG modem << [00:00:42.327,056] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:06:54.065Z DEBUG modem << %CESQ: 55,2,16,2
2022-07-25T05:06:54.072Z DEBUG modem << [00:00:42.336,242] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -85[0m
2022-07-25T05:06:54.519Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:06:54.521Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c0,e,e1,e,b9,0,c8,
2022-07-25T05:06:54.523Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:06:54.525Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:06:54.526Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.528Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.529Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.541Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.543Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.545Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.557Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.559Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.561Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.562Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.563Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:54.564Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:55.384Z DEBUG modem << [00:00:43.658,203] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:06:56.544Z DEBUG modem << Tx: 13
2022-07-25T05:06:56.546Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:06:56.599Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:06:56.601Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:06:56.612Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:06:56.616Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:06:56.618Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:06:56.619Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:06:56.621Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:06:56.622Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:06:56.623Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:06:56.624Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:06:56.624Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:06:56.624Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:06:56.625Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:06:56.648Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:06:56.650Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:06:56.660Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:06:56.661Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:06:56.662Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:06:56.664Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:06:56.666Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:06:56.668Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:06:56.668Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:06:56.669Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:06:56.670Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:06:56.670Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:06:56.671Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:06:58.592Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:06:58.611Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:06:58.612Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:06:58.613Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:06:58.614Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:58.615Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:58.616Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:58.617Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:58.618Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:58.627Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:58.628Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:58.629Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:58.630Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:06:58.800Z DEBUG modem << [00:00:47.079,162] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:00.595Z DEBUG modem << Tx: 13
2022-07-25T05:07:00.597Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:07:00.992Z DEBUG modem << +CSCON: 0
2022-07-25T05:07:00.994Z DEBUG modem << [00:00:49.271,148] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:07:01.626Z DEBUG modem << %CESQ: 46,2,14,2
2022-07-25T05:07:01.642Z DEBUG modem << [00:00:49.901,733] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -94[0m
2022-07-25T05:07:02.605Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:02.619Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:07:02.643Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:02.645Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:07:02.646Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.647Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.649Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.651Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.652Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.654Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.655Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.656Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.657Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.658Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.660Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.661Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:02.662Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:03.799Z DEBUG modem << [00:00:52.079,254] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:04.647Z DEBUG modem << Tx: 13
2022-07-25T05:07:04.649Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:07:06.778Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:06.790Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:07:06.791Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:06.793Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:07:06.795Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.797Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.798Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.800Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.801Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.802Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.803Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.804Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.805Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.814Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.816Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:06.817Z DEBUG modem << [00:00:54.980,957] [1;33m<wrn> bms_module: on line 327 0.0000,0.0000,0,0,0.2040,0,0,0 [0m
2022-07-25T05:07:06.818Z DEBUG modem << [00:00:54.989,044] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:07:06.819Z DEBUG modem << [00:00:54.997,436] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:0.0,SOC:0,Amp:0[0m
2022-07-25T05:07:06.821Z DEBUG modem << [00:00:55.008,453] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:07:06.823Z DEBUG modem << [00:00:55.015,869] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:06.823Z DEBUG modem << [00:00:55.022,857] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:07:06.824Z DEBUG modem << [00:00:55.029,876] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:07:06.825Z DEBUG modem << [00:00:55.036,834] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:07:06.825Z DEBUG modem << [00:00:55.043,914] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:07:06.826Z DEBUG modem << [00:00:55.050,872] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:07:06.826Z DEBUG modem << [00:00:55.057,983] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:07:06.959Z DEBUG modem << [00:00:55.064,941] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:07:06.961Z DEBUG modem << Tx: 13
2022-07-25T05:07:06.978Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:07:06.980Z DEBUG modem << [00:00:55.077,453] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:07:06.982Z DEBUG modem << [00:00:55.086,883] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 1 of 2 in bms buffer filled[0m
2022-07-25T05:07:06.984Z DEBUG modem << [00:00:55.097,869] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:07:06.985Z DEBUG modem << [00:Capture 1 data bytes:
2022-07-25T05:07:06.987Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:06.988Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:06.989Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:06.990Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:06.991Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:06.993Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:06.994Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:06.996Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:06.997Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:06.997Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:06.998Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:06.999Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:06.999Z DEBUG modem << 00:55.106,201] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:07:07.001Z DEBUG modem << [00:00:55.142,120] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:07.002Z DEBUG modem << [00:00:55.149,078] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:07:07.021Z DEBUG modem << [00:00:55.158,569] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:07.023Z DEBUG modem << [00:00:55.168,853] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:07:07.024Z DEBUG modem << [00:00:55.178,253] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:07:07.025Z DEBUG modem << [00:00:55.189,147] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:07:07.027Z DEBUG modem << [00:00:55.198,303] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:07:07.028Z DEBUG modem << [00:00:55.207,397] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:07:07.029Z DEBUG modem << [00:00:55.216,369] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:07:07.030Z DEBUG modem << [00:00:55.225,708] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:07:07.031Z DEBUG modem << [00:00:55.235,046] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:07:07.033Z DEBUG modem << [00:00:55.245,452] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:07:07.034Z DEBUG modem << [00:00:55.254,394] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:07:07.036Z DEBUG modem << [00:00:55.263,397] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:07:07.038Z DEBUG modem << [00:00:55.272,827] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:07:07.143Z DEBUG modem << Encoded message:
2022-07-25T05:07:07.146Z DEBUG modem << {
2022-07-25T05:07:07.149Z DEBUG modem << "bms_device":{
2022-07-25T05:07:07.150Z DEBUG modem << "bms_id":3902,
2022-07-25T05:07:07.152Z DEBUG modem << "bms_pack_voltage":0,
2022-07-25T05:07:07.154Z DEBUG modem << "bms_state_of_charge":0,
2022-07-25T05:07:07.168Z DEBUG modem << "lowest_cell_voltage":0,
2022-07-25T05:07:07.170Z DEBUG modem << "lowest_voltage_cell_no":0,
2022-07-25T05:07:07.172Z DEBUG modem << "highest_cell_voltage":0,
2022-07-25T05:07:07.173Z DEBUG modem << "highest_voltage_cell_no":0,
2022-07-25T05:07:07.176Z DEBUG modem << "highest_battery_temp":0,
2022-07-25T05:07:07.177Z DEBUG modem << "highest_temp_cell_no":0,
2022-07-25T05:07:07.178Z DEBUG modem << "lowest_battery_temp":0,
2022-07-25T05:07:07.179Z DEBUG modem << "lowest_temp_cell_no":0,
2022-07-25T05:07:07.180Z DEBUG modem << "bms_pack_ampere":0,
2022-07-25T05:07:07.180Z DEBUG modem << "bms_life":27,
2022-07-25T05:07:07.183Z DEBUG modem << "total_cells":7,
2022-07-25T05:07:07.184Z DEBUG modem << "total_temp_sensors":1,
2022-07-25T05:07:07.185Z DEBUG modem << "charger_status":0,
2022-07-25T05:07:07.186Z DEBUG modem << "load_status":0,
2022-07-25T05:07:07.188Z DEBUG modem << "average_voltage":0.20399999999999999,
2022-07-25T05:07:07.190Z DEBUG modem << "device_state":1,
2022-07-25T05:07:07.191Z DEBUG modem << "average_temp":0,
2022-07-25T05:07:07.192Z DEBUG modem << "cell_balance_state":0,
2022-07-25T05:07:07.192Z DEBUG modem << "fault_code":0,
2022-07-25T05:07:07.194Z DEBUG modem << "ts":1658725626253
2022-07-25T05:07:07.194Z DEBUG modem << }
2022-07-25T05:07:07.196Z DEBUG modem << }
2022-07-25T05:07:07.197Z DEBUG modem << [00:00:55.343,414] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:07:07.198Z DEBUG modem << [00:00:55.350,921] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20024528[0m
2022-07-25T05:07:07.199Z DEBUG modem << [00:00:55.359,741] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:07:07.200Z DEBUG modem << [00:00:55.368,011] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:07.201Z DEBUG modem << [00:00:55.374,969] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:07:07.201Z DEBUG modem << [00:00:55.384,460] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:07.202Z DEBUG modem << [00:00:55.391,387] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:07:07.203Z DEBUG modem << [00:00:55.401,550] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:07:07.204Z DEBUG modem << [00:00:55.411,926] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:07:07.236Z DEBUG modem << [00:00:55.422,363] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:07:07.238Z DEBUG modem << [00:00:55.432,495] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:07:07.239Z DEBUG modem << [00:00:55.442,626] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:07:07.240Z DEBUG modem << [00:00:55.452,941] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:07:07.241Z DEBUG modem << [00:00:55.463,439] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:07:07.242Z DEBUG modem << [00:00:55.473,449] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:07:07.243Z DEBUG modem << [00:00:55.483,764] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:07:07.260Z DEBUG modem << [00:00:55.494,415] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20024528[0m
2022-07-25T05:07:07.262Z DEBUG modem << [00:00:55.502,716] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:07:07.263Z DEBUG modem << [00:00:55.511,566] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20024528[0m
2022-07-25T05:07:07.279Z DEBUG modem << +CSCON: 1
2022-07-25T05:07:07.281Z DEBUG modem << [00:00:55.526,763] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:07:07.282Z DEBUG modem << %CESQ: 55,2,17,2
2022-07-25T05:07:07.290Z DEBUG modem << [00:00:55.535,858] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -85[0m
2022-07-25T05:07:08.601Z DEBUG modem << [00:00:56.875,366] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:07:08.839Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:08.841Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:08.844Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:08.846Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:07:08.847Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.849Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.851Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.852Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.853Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.854Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.855Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.856Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.857Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.858Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.859Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.860Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:08.869Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:10.841Z DEBUG modem << Tx: 13
2022-07-25T05:07:10.844Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:07:11.959Z DEBUG modem << [00:01:00.239,166] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:07:12.104Z DEBUG modem << [00:01:00.384,613] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:12.532Z DEBUG modem << [00:01:00.642,181] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:07:12.535Z DEBUG modem << [00:01:00.650,543] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:12.537Z DEBUG modem << [00:01:00.657,501] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:07:12.538Z DEBUG modem << [00:01:00.667,022] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:07:12.540Z DEBUG modem << [00:01:00.673,583] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:07:12.541Z DEBUG modem << [00:01:00.681,762] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:07:12.558Z DEBUG modem << [00:01:00.689,788] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:07:12.559Z DEBUG modem << [00:01:00.698,333] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:07:12.562Z DEBUG modem << [00:01:00.705,963] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:07:12.569Z DEBUG modem << [00:01:00.712,493] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:07:12.570Z DEBUG modem << [00:01:00.719,451] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:07:12.571Z DEBUG modem << [00:01:00.731,231] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:07:12.572Z DEBUG modem << [00:01:00.739,074] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:07:12.573Z DEBUG modem << [00:01:00.752,655] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:12.573Z DEBUG modem << [00:01:00.759,582] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:07:12.574Z DEBUG modem << [00:01:00.769,042] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:07:12.575Z DEBUG modem << [00:01:00.776,153] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:07:12.575Z DEBUG modem << [00:01:00.785,583] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:07:12.576Z DEBUG modem << [00:01:00.795,349] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:07:12.576Z DEBUG modem << [00:01:00.805,389] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:07:12.594Z DEBUG modem << [00:01:00.814,483] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 4 of 9 in sensor buffer filled[0m
2022-07-25T05:07:12.596Z DEBUG modem << [00:01:00.825,958] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:12.598Z DEBUG modem << [00:01:00.835,693] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:07:12.599Z DEBUG modem << [00:01:00.847,290] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:12.623Z DEBUG modem << [00:01:00.887,756] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:07:12.624Z DEBUG modem << [00:01:00.898,132] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:12.685Z DEBUG modem << [00:01:00.939,361] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:07:12.688Z DEBUG modem << [00:01:00.949,645] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 0 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:07:12.690Z DEBUG modem << [00:01:00.962,310] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:12.889Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:12.905Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:12.907Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:12.909Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:07:12.911Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.912Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.913Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.914Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.915Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.916Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.917Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.918Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.919Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.920Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.921Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:12.922Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:13.570Z DEBUG modem << [00:01:01.814,544] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:07:13.589Z DEBUG modem << [00:01:01.822,845] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:13.592Z DEBUG modem << [00:01:01.829,772] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:07:13.594Z DEBUG modem << [00:01:01.839,324] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:07:13.658Z DEBUG modem << [00:01:01.850,189] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:07:13.660Z DEBUG modem << [00:01:01.859,405] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:07:13.661Z DEBUG modem << [00:01:01.868,469] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:07:13.677Z DEBUG modem << [00:01:01.877,899] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:07:13.679Z DEBUG modem << [00:01:01.887,512] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:07:13.681Z DEBUG modem << [00:01:01.896,789] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:07:13.683Z DEBUG modem << [00:01:01.905,975] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:07:13.684Z DEBUG modem << [00:01:01.915,313] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:07:13.685Z DEBUG modem << [00:01:01.924,560] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:07:13.685Z DEBUG modem << [00:01:01.934,051] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:07:13.760Z DEBUG modem << Encoded message:
2022-07-25T05:07:13.763Z DEBUG modem << {
2022-07-25T05:07:13.765Z DEBUG modem << "dev":{
2022-07-25T05:07:13.768Z DEBUG modem << "v":{
2022-07-25T05:07:13.770Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:07:13.771Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:07:13.783Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:07:13.785Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:07:13.786Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:07:13.788Z DEBUG modem << },
2022-07-25T05:07:13.789Z DEBUG modem << "ts":1658725632151
2022-07-25T05:07:13.790Z DEBUG modem << },
2022-07-25T05:07:13.791Z DEBUG modem << "roam":{
2022-07-25T05:07:13.792Z DEBUG modem << "v":{
2022-07-25T05:07:13.794Z DEBUG modem << "rsrp":-85
2022-07-25T05:07:13.795Z DEBUG modem << },
2022-07-25T05:07:13.795Z DEBUG modem << "ts":1658725632203
2022-07-25T05:07:13.796Z DEBUG modem << },
2022-07-25T05:07:13.796Z DEBUG modem << "env":{
2022-07-25T05:07:13.797Z DEBUG modem << "v":{
2022-07-25T05:07:13.797Z DEBUG modem << "temp":25.905307769775391,
2022-07-25T05:07:13.798Z DEBUG modem << "hum":43.515293121337891,
2022-07-25T05:07:13.799Z DEBUG modem << "atmp":97.066000000000003,
2022-07-25T05:07:13.801Z DEBUG modem << "bsec_iaq":54
2022-07-25T05:07:13.803Z DEBUG modem << },
2022-07-25T05:07:13.804Z DEBUG modem << "ts":1658725632060
2022-07-25T05:07:13.804Z DEBUG modem << },
2022-07-25T05:07:13.805Z DEBUG modem << "acc":{
2022-07-25T05:07:13.805Z DEBUG modem << "v":{
2022-07-25T05:07:13.806Z DEBUG modem << "x":25.905307769775391,
2022-07-25T05:07:13.806Z DEBUG modem << "y":43.515293121337891,
2022-07-25T05:07:13.807Z DEBUG modem << "z":97.066000000000003
2022-07-25T05:07:13.808Z DEBUG modem << },
2022-07-25T05:07:13.809Z DEBUG modem << "ts":1658725632059
2022-07-25T05:07:13.809Z DEBUG modem << }
2022-07-25T05:07:13.810Z DEBUG modem << }
2022-07-25T05:07:13.810Z DEBUG modem << [00:01:02.006,744] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:07:13.811Z DEBUG modem << [00:01:02.014,221] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x200244e0[0m
2022-07-25T05:07:13.811Z DEBUG modem << [00:01:02.023,040] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:07:13.812Z DEBUG modem << [00:01:02.031,280] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:13.812Z DEBUG modem << [00:01:02.038,208] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:07:13.869Z DEBUG modem << [00:01:02.047,821] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:13.884Z DEBUG modem << [00:01:02.054,229] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:07:13.885Z DEBUG modem << [00:01:02.064,361] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:07:13.887Z DEBUG modem << [00:01:02.074,707] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:07:13.889Z DEBUG modem << [00:01:02.085,174] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:07:13.900Z DEBUG modem << [00:01:02.095,306] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:07:13.902Z DEBUG modem << [00:01:02.105,407] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:07:13.904Z DEBUG modem << [00:01:02.115,722] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:07:13.905Z DEBUG modem << [00:01:02.126,098] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:07:13.906Z DEBUG modem << [00:01:02.136,199] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:07:13.907Z DEBUG modem << [00:01:02.146,484] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:07:13.923Z DEBUG modem << [00:01:02.158,294] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x200244e0[0m
2022-07-25T05:07:13.925Z DEBUG modem << [00:01:02.166,595] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:07:13.927Z DEBUG modem << [00:01:02.175,445] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x200244e0[0m
2022-07-25T05:07:14.185Z DEBUG modem << +CSCON: 0
2022-07-25T05:07:14.187Z DEBUG modem << [00:01:02.464,416] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:07:14.768Z DEBUG modem << +CSCON: 1
2022-07-25T05:07:14.771Z DEBUG modem << [00:01:03.046,905] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:07:14.893Z DEBUG modem << Tx: 13
2022-07-25T05:07:14.895Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:07:16.101Z DEBUG modem << [00:01:04.375,549] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:07:16.908Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:16.911Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:16.913Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:16.914Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:07:16.941Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.943Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.945Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.947Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.949Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.951Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.952Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.953Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.954Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.966Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.968Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.969Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:16.970Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:18.768Z DEBUG modem << [00:01:07.047,973] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:18.944Z DEBUG modem << Tx: 13
2022-07-25T05:07:18.945Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:07:19.012Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:07:19.014Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:19.016Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:19.018Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:19.019Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:19.021Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:19.023Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:19.025Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:19.027Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:19.028Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:19.029Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:19.030Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:19.031Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:20.991Z DEBUG modem <<  bms incoming_message: a5,1,93,8,1,1,1,36,0,0,7,cf,50,
2022-07-25T05:07:20.994Z DEBUG modem << buffer_1: a5,1,93,8,1,1,1,36,0,0,7,cf,50,
2022-07-25T05:07:20.996Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:20.998Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:07:20.999Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.001Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.003Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.004Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.005Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.006Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.007Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.008Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.009Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.010Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.011Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.012Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.013Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:21.477Z DEBUG modem << +CSCON: 0
2022-07-25T05:07:21.480Z DEBUG modem << [00:01:09.754,577] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:07:22.105Z DEBUG modem << %CESQ: 47,2,13,1
2022-07-25T05:07:22.127Z DEBUG modem << [00:01:10.381,652] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:07:22.994Z DEBUG modem << Tx: 13
2022-07-25T05:07:22.996Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:07:23.053Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:07:23.055Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:23.074Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:23.077Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:23.079Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:23.080Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:23.081Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:23.082Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:23.084Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:23.086Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:23.087Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:23.088Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:23.089Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:23.768Z DEBUG modem << [00:01:12.048,065] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:24.999Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:07:25.040Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:07:25.042Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:25.057Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:07:25.059Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.061Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.062Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.063Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.065Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.066Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.067Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.068Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.069Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.070Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.071Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.072Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:25.073Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:27.045Z DEBUG modem << Tx: 13
2022-07-25T05:07:27.048Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:07:27.098Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:07:27.100Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:27.118Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:27.120Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:27.121Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:27.122Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:27.123Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:27.124Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:27.125Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:27.127Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:27.129Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:27.130Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:27.132Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:27.149Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:07:27.154Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:27.156Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:27.158Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:27.159Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:27.160Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:27.162Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:27.163Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:27.164Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:27.165Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:27.167Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:27.168Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:27.170Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:27.197Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:07:27.199Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:27.201Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:27.203Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:27.205Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:27.207Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:27.208Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:27.209Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:27.210Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:27.211Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:27.223Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:27.225Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:27.227Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:29.091Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:07:29.111Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:07:29.114Z DEBUG modem << a5,1,95,8,2,e,d7,e,cf,e,d4,0,e9,
2022-07-25T05:07:29.116Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:07:29.119Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.121Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.122Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.123Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.124Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.125Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.126Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.127Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.128Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.129Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.131Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.132Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:29.133Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:31.094Z DEBUG modem << Tx: 13
2022-07-25T05:07:31.097Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:07:31.139Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:07:31.142Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:31.144Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:31.160Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:31.161Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:31.163Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:31.164Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:31.165Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:31.166Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:31.168Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:31.169Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:31.170Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:31.171Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:31.191Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:07:31.193Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:31.195Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:31.197Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:31.199Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:31.201Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:31.203Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:31.205Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:31.207Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:31.208Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:31.210Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:31.212Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:31.214Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:32.479Z DEBUG modem << [00:01:20.642,211] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:07:32.499Z DEBUG modem << [00:01:20.650,573] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:32.501Z DEBUG modem << [00:01:20.657,531] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:07:32.504Z DEBUG modem << [00:01:20.666,992] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:07:32.505Z DEBUG modem << [00:01:20.673,583] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:07:32.506Z DEBUG modem << [00:01:20.681,793] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:07:32.508Z DEBUG modem << [00:01:20.689,819] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:07:32.531Z DEBUG modem << [00:01:20.698,333] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:07:32.533Z DEBUG modem << [00:01:20.705,963] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:07:32.534Z DEBUG modem << [00:01:20.712,524] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:07:32.536Z DEBUG modem << [00:01:20.719,390] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:07:32.539Z DEBUG modem << [00:01:20.731,231] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:07:32.541Z DEBUG modem << [00:01:20.739,105] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:07:32.543Z DEBUG modem << [00:01:20.752,716] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:32.544Z DEBUG modem << [00:01:20.759,643] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:07:32.569Z DEBUG modem << [00:01:20.769,042] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:07:32.586Z DEBUG modem << [00:01:20.776,153] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:07:32.588Z DEBUG modem << [00:01:20.785,522] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:07:32.589Z DEBUG modem << [00:01:20.795,288] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:07:32.591Z DEBUG modem << [00:01:20.805,328] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:07:32.609Z DEBUG modem << [00:01:20.814,453] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 5 of 9 in sensor buffer filled[0m
2022-07-25T05:07:32.611Z DEBUG modem << [00:01:20.825,927] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:32.613Z DEBUG modem << [00:01:20.835,723] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:07:32.614Z DEBUG modem << [00:01:20.847,320] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:32.651Z DEBUG modem << [00:01:20.915,893] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:07:32.654Z DEBUG modem << [00:01:20.926,147] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:32.740Z DEBUG modem << [00:01:20.994,689] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:07:32.743Z DEBUG modem << [00:01:21.005,004] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 1 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:07:32.745Z DEBUG modem << [00:01:21.017,669] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:33.133Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:33.151Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:07:33.153Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:33.156Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:07:33.157Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.158Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.159Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.161Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.162Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.163Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.164Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.166Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.167Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.187Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.189Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.191Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.193Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:33.656Z DEBUG modem << [00:01:21.814,514] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:07:33.658Z DEBUG modem << [00:01:21.822,845] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:33.663Z DEBUG modem << [00:01:21.829,803] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:07:33.664Z DEBUG modem << [00:01:21.839,355] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:07:33.665Z DEBUG modem << [00:01:21.850,219] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:07:33.684Z DEBUG modem << [00:01:21.859,344] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:07:33.686Z DEBUG modem << [00:01:21.868,408] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:07:33.687Z DEBUG modem << [00:01:21.877,838] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:07:33.689Z DEBUG modem << [00:01:21.887,359] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:07:33.690Z DEBUG modem << [00:01:21.896,636] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:07:33.691Z DEBUG modem << [00:01:21.905,700] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:07:33.692Z DEBUG modem << [00:01:21.915,069] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:07:33.692Z DEBUG modem << [00:01:21.924,804] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:07:33.693Z DEBUG modem << [00:01:21.934,204] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:07:33.709Z DEBUG modem << Encoded message:
2022-07-25T05:07:33.711Z DEBUG modem << {
2022-07-25T05:07:33.713Z DEBUG modem << "dev":{
2022-07-25T05:07:33.714Z DEBUG modem << "v":{
2022-07-25T05:07:33.716Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:07:33.717Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:07:33.718Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:07:33.719Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:07:33.720Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:07:33.722Z DEBUG modem << },
2022-07-25T05:07:33.723Z DEBUG modem << "ts":1658725652179
2022-07-25T05:07:33.724Z DEBUG modem << },
2022-07-25T05:07:33.725Z DEBUG modem << "roam":{
2022-07-25T05:07:33.726Z DEBUG modem << "v":{
2022-07-25T05:07:33.727Z DEBUG modem << "rsrp":-93
2022-07-25T05:07:33.728Z DEBUG modem << },
2022-07-25T05:07:33.730Z DEBUG modem << "ts":1658725652258
2022-07-25T05:07:33.731Z DEBUG modem << },
2022-07-25T05:07:33.733Z DEBUG modem << "env":{
2022-07-25T05:07:33.734Z DEBUG modem << "v":{
2022-07-25T05:07:33.735Z DEBUG modem << "temp":26.135307312011719,
2022-07-25T05:07:33.737Z DEBUG modem << "hum":42.845111846923828,
2022-07-25T05:07:33.738Z DEBUG modem << "atmp":97.069999999999993,
2022-07-25T05:07:33.739Z DEBUG modem << "bsec_iaq":64
2022-07-25T05:07:33.740Z DEBUG modem << },
2022-07-25T05:07:33.741Z DEBUG modem << "ts":1658725652060
2022-07-25T05:07:33.742Z DEBUG modem << },
2022-07-25T05:07:33.743Z DEBUG modem << "acc":{
2022-07-25T05:07:33.745Z DEBUG modem << "v":{
2022-07-25T05:07:33.868Z DEBUG modem << "x":26.135307312011719,
2022-07-25T05:07:33.870Z DEBUG modem << "y":42.845111846923828,
2022-07-25T05:07:33.894Z DEBUG modem << "z":97.069999999999993
2022-07-25T05:07:33.896Z DEBUG modem << },
2022-07-25T05:07:33.898Z DEBUG modem << "ts":1658725652059
2022-07-25T05:07:33.899Z DEBUG modem << }
2022-07-25T05:07:33.901Z DEBUG modem << }
2022-07-25T05:07:33.904Z DEBUG modem << [00:01:22.006,927] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:07:33.905Z DEBUG modem << [00:01:22.014,404] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x200244e0[0m
2022-07-25T05:07:33.907Z DEBUG modem << [00:01:22.023,223] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:07:33.908Z DEBUG modem << [00:01:22.031,494] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:33.910Z DEBUG modem << [00:01:22.038,452] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:07:33.912Z DEBUG modem << [00:01:22.047,973] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:33.913Z DEBUG modem << [00:01:22.054,412] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:07:33.913Z DEBUG modem << [00:01:22.064,544] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:07:33.937Z DEBUG modem << [00:01:22.074,951] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:07:33.940Z DEBUG modem << [00:01:22.085,479] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:07:33.941Z DEBUG modem << [00:01:22.095,611] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:07:33.942Z DEBUG modem << [00:01:22.105,804] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:07:33.943Z DEBUG modem << [00:01:22.116,149] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:07:33.945Z DEBUG modem << [00:01:22.126,525] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:07:33.947Z DEBUG modem << [00:01:22.136,688] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:07:33.948Z DEBUG modem << [00:01:22.147,033] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:07:33.949Z DEBUG modem << [00:01:22.164,916] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x200244e0[0m
2022-07-25T05:07:33.949Z DEBUG modem << [00:01:22.173,553] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:07:33.951Z DEBUG modem << [00:01:22.182,342] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x200244e0[0m
2022-07-25T05:07:34.539Z DEBUG modem << +CSCON: 1
2022-07-25T05:07:34.541Z DEBUG modem << [00:01:22.807,342] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:07:34.544Z DEBUG modem << %CESQ: 57,2,18,2
2022-07-25T05:07:34.550Z DEBUG modem << [00:01:22.816,406] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -83[0m
2022-07-25T05:07:35.145Z DEBUG modem << Tx: 13
2022-07-25T05:07:35.148Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:07:35.866Z DEBUG modem << [00:01:24.139,099] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:07:37.194Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:37.216Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:07:37.217Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:37.218Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:07:37.219Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.220Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.221Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.223Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.224Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.225Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.226Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.227Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.228Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.229Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.230Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.231Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:37.232Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:38.768Z DEBUG modem << [00:01:27.048,126] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:39.198Z DEBUG modem << Tx: 13
2022-07-25T05:07:39.200Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:07:41.278Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:41.280Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:07:41.301Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:41.303Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:07:41.305Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.307Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.308Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.310Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.312Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.314Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.315Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.317Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.318Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.321Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.322Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.323Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.325Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:41.326Z DEBUG modem << [00:01:29.533,020] [1;33m<wrn> bms_module: on line 327 0.0000,0.0000,0,0,0.2050,0,0,0 [0m
2022-07-25T05:07:41.327Z DEBUG modem << [00:01:29.541,107] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:07:41.328Z DEBUG modem << [00:01:29.549,530] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:07:41.457Z DEBUG modem << [00:01:29.560,668] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:07:41.459Z DEBUG modem << [00:01:29.568,115] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:41.461Z DEBUG modem << [00:01:29.575,195] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:07:41.463Z DEBUG modem << [00:01:29.582,214] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:07:41.464Z DEBUG modem << [00:01:29.589,172] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:07:41.465Z DEBUG modem << [00:01:29.596,252] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:07:41.466Z DEBUG modem << [00:01:29.603,210] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:07:41.468Z DEBUG modem << [00:01:29.610,290] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:07:41.492Z DEBUG modem << [00:01:29.617,248] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:07:41.495Z DEBUG modem << [00:01:29.624,298] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:07:41.498Z DEBUG modem << [00:01:29.631,256] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:07:41.500Z DEBUG modem << [00:01:29.638,336] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:07:41.501Z DEBUG modem << [00:01:29.645,294] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:07:41.503Z DEBUG modem << [00:01:29.652,374] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:07:41.504Z DEBUG modem << [00:01:29.659,332] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:07:41.505Z DEBUG modem << Tx: 13
2022-07-25T05:07:41.507Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:07:41.508Z DEBUG modem << [00:01:29.671,813] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:07:41.510Z DEBUG modem << [00:01:29.681,243] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:07:41.511Z DEBUG modem << [00:01:29.692,199] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:07:41.513Z DEBUG modem << [00:01:29.Capture 1 data bytes:
2022-07-25T05:07:41.515Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:41.516Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:41.517Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:41.518Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:41.519Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:41.521Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:41.522Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:41.523Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:41.524Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:41.525Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:41.527Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:41.530Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:41.531Z DEBUG modem << 700,500] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:07:41.532Z DEBUG modem << [00:01:29.736,358] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:41.595Z DEBUG modem << [00:01:29.743,286] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:07:41.596Z DEBUG modem << +CSCON: 0
2022-07-25T05:07:41.598Z DEBUG modem << [00:01:29.753,814] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:07:41.602Z DEBUG modem << [00:01:29.760,833] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:41.605Z DEBUG modem << [00:01:29.770,568] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:07:41.607Z DEBUG modem << [00:01:29.779,937] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:07:41.609Z DEBUG modem << [00:01:29.790,802] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:07:41.635Z DEBUG modem << [00:01:29.799,957] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:07:41.637Z DEBUG modem << [00:01:29.809,051] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:07:41.640Z DEBUG modem << [00:01:29.818,023] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:07:41.642Z DEBUG modem << [00:01:29.827,362] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:07:41.643Z DEBUG modem << [00:01:29.836,700] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:07:41.645Z DEBUG modem << [00:01:29.847,106] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:07:41.646Z DEBUG modem << [00:01:29.856,048] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:07:41.648Z DEBUG modem << [00:01:29.865,051] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:07:41.650Z DEBUG modem << [00:01:29.874,481] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:07:41.671Z DEBUG modem << Encoded message:
2022-07-25T05:07:41.674Z DEBUG modem << {
2022-07-25T05:07:41.676Z DEBUG modem << "bms_device":{
2022-07-25T05:07:41.677Z DEBUG modem << "bms_id":3902,
2022-07-25T05:07:41.679Z DEBUG modem << "bms_pack_voltage":26,
2022-07-25T05:07:41.681Z DEBUG modem << "bms_state_of_charge":99,
2022-07-25T05:07:41.683Z DEBUG modem << "lowest_cell_voltage":0,
2022-07-25T05:07:41.685Z DEBUG modem << "lowest_voltage_cell_no":0,
2022-07-25T05:07:41.686Z DEBUG modem << "highest_cell_voltage":0,
2022-07-25T05:07:41.689Z DEBUG modem << "highest_voltage_cell_no":0,
2022-07-25T05:07:41.691Z DEBUG modem << "highest_battery_temp":0,
2022-07-25T05:07:41.692Z DEBUG modem << "highest_temp_cell_no":0,
2022-07-25T05:07:41.694Z DEBUG modem << "lowest_battery_temp":0,
2022-07-25T05:07:41.696Z DEBUG modem << "lowest_temp_cell_no":0,
2022-07-25T05:07:41.698Z DEBUG modem << "bms_pack_ampere":0,
2022-07-25T05:07:41.700Z DEBUG modem << "bms_life":54,
2022-07-25T05:07:41.701Z DEBUG modem << "total_cells":7,
2022-07-25T05:07:41.703Z DEBUG modem << "total_temp_sensors":1,
2022-07-25T05:07:41.704Z DEBUG modem << "charger_status":0,
2022-07-25T05:07:41.705Z DEBUG modem << "load_status":0,
2022-07-25T05:07:41.807Z DEBUG modem << "average_voltage":0.20499999999999999,
2022-07-25T05:07:41.810Z DEBUG modem << "device_state":1,
2022-07-25T05:07:41.813Z DEBUG modem << "average_temp":0,
2022-07-25T05:07:41.815Z DEBUG modem << "cell_balance_state":0,
2022-07-25T05:07:41.816Z DEBUG modem << "fault_code":0,
2022-07-25T05:07:41.817Z DEBUG modem << "ts":1658725660806
2022-07-25T05:07:41.819Z DEBUG modem << }
2022-07-25T05:07:41.820Z DEBUG modem << }
2022-07-25T05:07:41.821Z DEBUG modem << [00:01:29.945,404] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:07:41.823Z DEBUG modem << [00:01:29.953,002] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20024e40[0m
2022-07-25T05:07:41.824Z DEBUG modem << [00:01:29.961,853] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:07:41.824Z DEBUG modem << [00:01:29.970,123] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:41.825Z DEBUG modem << [00:01:29.977,050] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:07:41.826Z DEBUG modem << [00:01:29.986,633] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:41.827Z DEBUG modem << [00:01:29.993,591] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:07:41.829Z DEBUG modem << [00:01:30.003,784] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:07:41.830Z DEBUG modem << [00:01:30.014,129] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:07:41.831Z DEBUG modem << [00:01:30.024,627] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:07:41.832Z DEBUG modem << [00:01:30.034,729] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:07:41.855Z DEBUG modem << [00:01:30.044,860] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:07:41.858Z DEBUG modem << [00:01:30.055,145] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:07:41.860Z DEBUG modem << [00:01:30.065,582] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:07:41.863Z DEBUG modem << [00:01:30.075,592] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:07:41.864Z DEBUG modem << [00:01:30.085,876] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:07:41.865Z DEBUG modem << [00:01:30.096,466] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20024e40[0m
2022-07-25T05:07:41.866Z DEBUG modem << [00:01:30.104,736] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:07:41.867Z DEBUG modem << [00:01:30.113,433] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20024e40[0m
2022-07-25T05:07:41.911Z DEBUG modem << +CSCON: 1
2022-07-25T05:07:41.915Z DEBUG modem << [00:01:30.167,510] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:07:41.964Z DEBUG modem << [00:01:30.246,368] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:07:43.243Z DEBUG modem << [00:01:31.521,392] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:07:43.431Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:43.450Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:43.453Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:43.455Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:07:43.456Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.458Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.461Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.462Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.463Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.464Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.465Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.467Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.468Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.469Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.471Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.472Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:43.473Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:45.433Z DEBUG modem << Tx: 13
2022-07-25T05:07:45.436Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:07:46.706Z DEBUG modem << [00:01:34.986,694] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:47.481Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:47.483Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:47.485Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:47.488Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:07:47.507Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.509Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.510Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.512Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.513Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.514Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.516Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.517Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.519Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.520Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.522Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.524Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:47.525Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:48.747Z DEBUG modem << +CSCON: 0
2022-07-25T05:07:48.748Z DEBUG modem << [00:01:37.026,184] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:07:48.984Z DEBUG modem << %CESQ: 48,2,15,2
2022-07-25T05:07:48.988Z DEBUG modem << [00:01:37.262,512] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -92[0m
2022-07-25T05:07:49.484Z DEBUG modem << Tx: 13
2022-07-25T05:07:49.487Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:07:51.500Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:51.525Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:07:51.526Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:51.528Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:07:51.545Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.548Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.549Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.551Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.553Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.554Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.555Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.557Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.558Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.560Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.562Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.564Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.565Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:51.704Z DEBUG modem << [00:01:39.986,785] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:52.496Z DEBUG modem << [00:01:40.642,242] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:07:52.499Z DEBUG modem << [00:01:40.650,634] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:52.502Z DEBUG modem << [00:01:40.657,562] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:07:52.504Z DEBUG modem << [00:01:40.666,992] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:07:52.506Z DEBUG modem << [00:01:40.673,614] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:07:52.509Z DEBUG modem << [00:01:40.681,823] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:07:52.511Z DEBUG modem << [00:01:40.689,849] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:07:52.512Z DEBUG modem << [00:01:40.698,333] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:07:52.532Z DEBUG modem << [00:01:40.705,993] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:07:52.534Z DEBUG modem << [00:01:40.712,554] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:07:52.536Z DEBUG modem << [00:01:40.719,421] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:07:52.538Z DEBUG modem << [00:01:40.731,292] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:07:52.540Z DEBUG modem << [00:01:40.739,135] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:07:52.541Z DEBUG modem << [00:01:40.752,746] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:52.543Z DEBUG modem << [00:01:40.759,704] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:07:52.544Z DEBUG modem << [00:01:40.769,104] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:07:52.545Z DEBUG modem << [00:01:40.776,214] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:07:52.568Z DEBUG modem << [00:01:40.785,583] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:07:52.570Z DEBUG modem << [00:01:40.795,349] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:07:52.571Z DEBUG modem << [00:01:40.805,389] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:07:52.594Z DEBUG modem << [00:01:40.814,514] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 6 of 9 in sensor buffer filled[0m
2022-07-25T05:07:52.596Z DEBUG modem << [00:01:40.826,019] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:52.598Z DEBUG modem << [00:01:40.835,784] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:07:52.599Z DEBUG modem << [00:01:40.847,412] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:52.648Z DEBUG modem << [00:01:40.915,954] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:07:52.650Z DEBUG modem << [00:01:40.926,208] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:52.739Z DEBUG modem << [00:01:40.994,781] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:07:52.742Z DEBUG modem << [00:01:41.005,065] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 2 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:07:52.744Z DEBUG modem << [00:01:41.017,761] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:07:53.581Z DEBUG modem << [00:01:41.814,544] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:07:53.607Z DEBUG modem << [00:01:41.822,906] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:53.608Z DEBUG modem << [00:01:41.829,864] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:07:53.610Z DEBUG modem << Tx: 13
2022-07-25T05:07:53.612Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:07:53.613Z DEBUG modem << [00:01:41.842,926] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:07:53.615Z DEBUG modem << [00:01:41.853,820] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:07:53.616Z DEBUG modem << [00:01:41.862,976] Capture 1 data bytes:
2022-07-25T05:07:53.617Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:53.618Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:53.685Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:53.687Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:53.690Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:53.705Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:53.707Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:53.709Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:53.711Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:53.712Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:53.713Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:53.714Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:53.715Z DEBUG modem << [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:07:53.717Z DEBUG modem << [00:01:41.899,688] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:07:53.718Z DEBUG modem << [00:01:41.909,149] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:07:53.720Z DEBUG modem << [00:01:41.918,670] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:07:53.721Z DEBUG modem << [00:01:41.927,978] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:07:53.722Z DEBUG modem << [00:01:41.937,072] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:07:53.723Z DEBUG modem << [00:01:41.946,441] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:07:53.725Z DEBUG modem << [00:01:41.955,718] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:07:53.726Z DEBUG modem << [00:01:41.965,118] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:07:53.771Z DEBUG modem << Encoded message:
2022-07-25T05:07:53.773Z DEBUG modem << {
2022-07-25T05:07:53.775Z DEBUG modem << "dev":{
2022-07-25T05:07:53.778Z DEBUG modem << "v":{
2022-07-25T05:07:53.794Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:07:53.796Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:07:53.798Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:07:53.799Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:07:53.801Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:07:53.802Z DEBUG modem << },
2022-07-25T05:07:53.803Z DEBUG modem << "ts":1658725672180
2022-07-25T05:07:53.805Z DEBUG modem << },
2022-07-25T05:07:53.807Z DEBUG modem << "roam":{
2022-07-25T05:07:53.808Z DEBUG modem << "v":{
2022-07-25T05:07:53.809Z DEBUG modem << "rsrp":-92
2022-07-25T05:07:53.810Z DEBUG modem << },
2022-07-25T05:07:53.811Z DEBUG modem << "ts":1658725672258
2022-07-25T05:07:53.813Z DEBUG modem << },
2022-07-25T05:07:53.814Z DEBUG modem << "env":{
2022-07-25T05:07:53.815Z DEBUG modem << "v":{
2022-07-25T05:07:53.816Z DEBUG modem << "temp":26.235340118408203,
2022-07-25T05:07:53.817Z DEBUG modem << "hum":42.568794250488281,
2022-07-25T05:07:53.818Z DEBUG modem << "atmp":97.069999999999993,
2022-07-25T05:07:53.819Z DEBUG modem << "bsec_iaq":74
2022-07-25T05:07:53.820Z DEBUG modem << },
2022-07-25T05:07:53.821Z DEBUG modem << "ts":1658725672059
2022-07-25T05:07:53.822Z DEBUG modem << },
2022-07-25T05:07:53.823Z DEBUG modem << "acc":{
2022-07-25T05:07:53.824Z DEBUG modem << "v":{
2022-07-25T05:07:53.825Z DEBUG modem << "x":26.235340118408203,
2022-07-25T05:07:53.826Z DEBUG modem << "y":42.568794250488281,
2022-07-25T05:07:53.827Z DEBUG modem << "z":97.069999999999993
2022-07-25T05:07:53.828Z DEBUG modem << },
2022-07-25T05:07:53.829Z DEBUG modem << "ts":1658725672059
2022-07-25T05:07:53.830Z DEBUG modem << }
2022-07-25T05:07:53.831Z DEBUG modem << }
2022-07-25T05:07:53.832Z DEBUG modem << [00:01:42.037,902] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:07:53.834Z DEBUG modem << [00:01:42.045,410] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20024df0[0m
2022-07-25T05:07:53.898Z DEBUG modem << [00:01:42.054,260] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:07:53.900Z DEBUG modem << [00:01:42.062,530] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:07:53.903Z DEBUG modem << [00:01:42.069,488] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:07:53.905Z DEBUG modem << [00:01:42.079,010] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:53.907Z DEBUG modem << [00:01:42.085,449] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:07:53.908Z DEBUG modem << [00:01:42.095,581] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:07:53.925Z DEBUG modem << [00:01:42.105,987] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:07:53.927Z DEBUG modem << [00:01:42.116,485] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:07:53.929Z DEBUG modem << [00:01:42.126,617] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:07:53.930Z DEBUG modem << [00:01:42.136,810] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:07:53.932Z DEBUG modem << [00:01:42.147,155] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:07:53.933Z DEBUG modem << [00:01:42.157,562] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:07:53.934Z DEBUG modem << [00:01:42.167,694] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:07:53.936Z DEBUG modem << [00:01:42.178,039] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:07:53.958Z DEBUG modem << [00:01:42.198,059] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20024df0[0m
2022-07-25T05:07:53.960Z DEBUG modem << [00:01:42.206,420] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:07:53.962Z DEBUG modem << [00:01:42.215,118] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20024df0[0m
2022-07-25T05:07:54.058Z DEBUG modem << +CSCON: 1
2022-07-25T05:07:54.061Z DEBUG modem << [00:01:42.327,941] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:07:54.063Z DEBUG modem << %CESQ: 56,2,17,2
2022-07-25T05:07:54.072Z DEBUG modem << [00:01:42.337,005] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -84[0m
2022-07-25T05:07:55.406Z DEBUG modem << [00:01:43.681,640] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:07:55.601Z DEBUG modem <<  bms incoming_message: a5,1,93,8,1,1,1,51,0,0,7,cf,6b,
2022-07-25T05:07:55.603Z DEBUG modem << buffer_1: a5,1,93,8,1,1,1,51,0,0,7,cf,6b,
2022-07-25T05:07:55.605Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:55.608Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:07:55.631Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.634Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.636Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.637Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.639Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.640Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.641Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.642Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.643Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.645Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.647Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.648Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:55.649Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:57.604Z DEBUG modem << Tx: 13
2022-07-25T05:07:57.607Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:07:57.645Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:07:57.648Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:07:57.665Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:07:57.668Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:07:57.669Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:07:57.671Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:07:57.673Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:07:57.674Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:07:57.675Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:07:57.676Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:07:57.677Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:07:57.679Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:07:57.681Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:07:58.795Z DEBUG modem << [00:01:47.079,162] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:07:59.650Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:07:59.652Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:07:59.655Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:07:59.657Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:07:59.660Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.662Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.664Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.665Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.666Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.668Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.669Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.671Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.672Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.673Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.675Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.677Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:07:59.701Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:00.982Z DEBUG modem << +CSCON: 0
2022-07-25T05:08:00.987Z DEBUG modem << [00:01:49.265,441] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:08:01.655Z DEBUG modem << Tx: 13
2022-07-25T05:08:01.659Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:08:01.741Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:01.743Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:01.764Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:01.766Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:01.768Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:01.769Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:01.771Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:01.772Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:01.773Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:01.774Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:01.776Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:01.777Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:01.778Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:01.795Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:01.797Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:01.798Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:01.814Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:01.816Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:01.818Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:01.833Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:01.835Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:01.836Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:01.838Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:01.839Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:01.841Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:01.843Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:01.844Z DEBUG modem << %CESQ: 47,2,13,1
2022-07-25T05:08:01.848Z DEBUG modem << [00:01:50.080,871] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:08:01.865Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:01.867Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:01.869Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:01.870Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:01.871Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:01.872Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:01.873Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:01.875Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:01.876Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:01.877Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:01.878Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:01.879Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:01.880Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:03.701Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:08:03.729Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:08:03.732Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:08:03.733Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:08:03.735Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.737Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.739Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.740Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.741Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.743Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.745Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.746Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.748Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.749Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.750Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.751Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.753Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:03.795Z DEBUG modem << [00:01:52.079,254] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:08:05.704Z DEBUG modem << Tx: 13
2022-07-25T05:08:05.706Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:08:05.783Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:05.786Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:05.803Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:05.804Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:05.806Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:05.807Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:05.809Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:05.810Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:05.812Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:05.814Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:05.815Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:05.816Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:05.817Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:05.836Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:05.837Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:05.839Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:05.841Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:05.842Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:05.843Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:05.845Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:05.846Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:05.847Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:05.849Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:05.850Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:05.851Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:05.853Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:07.710Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:07.752Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:08:07.755Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:07.757Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:08:07.759Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.776Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.778Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.781Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.782Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.784Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.786Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.787Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.788Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.790Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.792Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.794Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:07.795Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:09.755Z DEBUG modem << Tx: 13
2022-07-25T05:08:09.758Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:08:11.803Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:11.828Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:08:11.829Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:11.831Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:08:11.832Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.834Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.835Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.836Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.838Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.839Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.841Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.843Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.845Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.846Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.847Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.848Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.849Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:11.970Z DEBUG modem << [00:02:00.253,570] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:08:12.431Z DEBUG modem << [00:02:00.642,272] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:08:12.433Z DEBUG modem << [00:02:00.650,634] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:12.436Z DEBUG modem << [00:02:00.657,592] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:08:12.439Z DEBUG modem << [00:02:00.667,053] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:08:12.441Z DEBUG modem << [00:02:00.673,645] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:08:12.443Z DEBUG modem << [00:02:00.681,854] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:08:12.445Z DEBUG modem << [00:02:00.689,880] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:08:12.446Z DEBUG modem << [00:02:00.698,364] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:08:12.447Z DEBUG modem << [00:02:00.706,024] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:08:12.448Z DEBUG modem << [00:02:00.712,585] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:08:12.567Z DEBUG modem << [00:02:00.719,451] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:08:12.594Z DEBUG modem << [00:02:00.731,292] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:08:12.596Z DEBUG modem << [00:02:00.739,166] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:08:12.598Z DEBUG modem << [00:02:00.752,777] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:12.600Z DEBUG modem << [00:02:00.759,735] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:08:12.602Z DEBUG modem << [00:02:00.769,134] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:08:12.635Z DEBUG modem << [00:02:00.776,245] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:08:12.639Z DEBUG modem << [00:02:00.785,614] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:08:12.642Z DEBUG modem << [00:02:00.795,349] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:08:12.644Z DEBUG modem << [00:02:00.805,389] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:08:12.646Z DEBUG modem << [00:02:00.814,483] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 7 of 9 in sensor buffer filled[0m
2022-07-25T05:08:12.648Z DEBUG modem << [00:02:00.825,988] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:12.651Z DEBUG modem << [00:02:00.835,784] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:08:12.653Z DEBUG modem << [00:02:00.847,381] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:12.682Z DEBUG modem << [00:02:00.915,985] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:08:12.685Z DEBUG modem << [00:02:00.926,239] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:12.725Z DEBUG modem << [00:02:00.983,886] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:08:12.729Z DEBUG modem << [00:02:00.994,171] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 0 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:08:12.753Z DEBUG modem << [00:02:01.006,866] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:13.696Z DEBUG modem << [00:02:01.814,575] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:08:13.698Z DEBUG modem << [00:02:01.822,906] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:13.701Z DEBUG modem << [00:02:01.829,864] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:08:13.725Z DEBUG modem << [00:02:01.839,050] [1;33m<wrn> modules_common: bms_DALY: Message could not be enqueued, error code: -35[0m
2022-07-25T05:08:13.727Z DEBUG modem << [00:02:01.848,632] [1;31m<err> bms_module: Message could not be enqueued in bms_event_handler[0m
2022-07-25T05:08:13.730Z DEBUG modem << [00:02:01.857,727] [0m<inf> app_event_manager: e:bms_module_event BMS_EVT_ERROR - Error code -35[0m
2022-07-25T05:08:13.731Z DEBUG modem << [00:02:01.866,882] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:08:13.733Z DEBUG modem << [00:02:01.874,328] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:13.734Z DEBUG modem << [00:02:01.881,439] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:08:13.735Z DEBUG modem << [00:02:01.892,303] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:08:13.737Z DEBUG modem << [00:02:01.901,458] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:08:13.738Z DEBUG modem << [00:02:01.910,552] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:08:13.739Z DEBUG modem << [00:02:01.920,013] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:08:13.740Z DEBUG modem << [00:02:01.929,534] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:08:13.742Z DEBUG modem << [00:02:01.938,842] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:08:13.744Z DEBUG modem << [00:02:01.947,937] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:08:13.746Z DEBUG modem << [00:02:01.957,275] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:08:13.769Z DEBUG modem << [00:02:01.966,552] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:08:13.772Z DEBUG modem << [00:02:01.975,921] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:08:13.774Z DEBUG modem << Encoded message:
2022-07-25T05:08:13.775Z DEBUG modem << {
2022-07-25T05:08:13.777Z DEBUG modem << "dev":{
2022-07-25T05:08:13.778Z DEBUG modem << "v":{
2022-07-25T05:08:13.887Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:08:13.890Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:08:13.915Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:08:13.918Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:08:13.919Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:08:13.921Z DEBUG modem << },
2022-07-25T05:08:13.922Z DEBUG modem << "ts":1658725692179
2022-07-25T05:08:13.924Z DEBUG modem << },
2022-07-25T05:08:13.925Z DEBUG modem << "roam":{
2022-07-25T05:08:13.927Z DEBUG modem << "v":{
2022-07-25T05:08:13.928Z DEBUG modem << "rsrp":-93
2022-07-25T05:08:13.930Z DEBUG modem << },
2022-07-25T05:08:13.932Z DEBUG modem << "ts":1658725692247
2022-07-25T05:08:13.933Z DEBUG modem << },
2022-07-25T05:08:13.935Z DEBUG modem << "env":{
2022-07-25T05:08:13.937Z DEBUG modem << "v":{
2022-07-25T05:08:13.938Z DEBUG modem << "temp":26.365306854248047,
2022-07-25T05:08:13.940Z DEBUG modem << "hum":42.284622192382812,
2022-07-25T05:08:13.941Z DEBUG modem << "atmp":97.061999999999998,
2022-07-25T05:08:13.943Z DEBUG modem << "bsec_iaq":83
2022-07-25T05:08:13.946Z DEBUG modem << },
2022-07-25T05:08:13.947Z DEBUG modem << "ts":1658725692060
2022-07-25T05:08:13.948Z DEBUG modem << },
2022-07-25T05:08:13.949Z DEBUG modem << "acc":{
2022-07-25T05:08:13.951Z DEBUG modem << "v":{
2022-07-25T05:08:13.953Z DEBUG modem << "x":26.365306854248047,
2022-07-25T05:08:13.954Z DEBUG modem << "y":42.284622192382812,
2022-07-25T05:08:13.955Z DEBUG modem << "z":97.061999999999998
2022-07-25T05:08:13.958Z DEBUG modem << },
2022-07-25T05:08:13.961Z DEBUG modem << "ts":1658725692059
2022-07-25T05:08:13.962Z DEBUG modem << }
2022-07-25T05:08:13.963Z DEBUG modem << }
2022-07-25T05:08:13.966Z DEBUG modem << [00:02:02.048,675] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:08:13.967Z DEBUG modem << [00:02:02.056,152] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20024df0[0m
2022-07-25T05:08:13.968Z DEBUG modem << [00:02:02.064,971] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:08:13.970Z DEBUG modem << [00:02:02.073,242] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:14.003Z DEBUG modem << [00:02:02.080,200] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:08:14.006Z DEBUG modem << [00:02:02.089,691] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:08:14.008Z DEBUG modem << [00:02:02.096,160] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:08:14.010Z DEBUG modem << [00:02:02.106,292] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:08:14.011Z DEBUG modem << [00:02:02.116,668] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:08:14.013Z DEBUG modem << [00:02:02.127,227] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:08:14.015Z DEBUG modem << [00:02:02.137,329] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:08:14.017Z DEBUG modem << [00:02:02.147,552] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:08:14.018Z DEBUG modem << [00:02:02.157,897] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:08:14.020Z DEBUG modem << [00:02:02.168,273] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:08:14.067Z DEBUG modem << [00:02:02.178,344] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:08:14.096Z DEBUG modem << [00:02:02.188,690] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:08:14.100Z DEBUG modem << [00:02:02.198,211] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:08:14.101Z DEBUG modem << [00:02:02.206,542] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:14.104Z DEBUG modem << [00:02:02.213,500] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:08:14.105Z DEBUG modem << Tx: 13
2022-07-25T05:08:14.107Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:08:14.108Z DEBUG modem << [00:02:02.226,989] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:14.134Z DEBUG modem << [00:02:02.236,846] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:08:14.136Z DEBUG modem << [00:02:02.247,833] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:08:14.138Z DEBUG modem << [00:02:02.256,958] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:08:14.140Z DEBUG modem << [00:02:02.266,052] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:08:14.141Z DEBUG modem << [00:02:02.275,115] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:08:14.142Z DEBUG modem << [00:02:02.284,423] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:08:14.144Z DEBUG modem << [00:02:02.293,762] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:08:14.145Z DEBUG modem << [00:02:02.302,917] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:08:14.146Z DEBUG modem << [00:02:02.311,859] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:08:14.148Z DEBUG modem << [00:02:02.320,953] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:08:14.149Z DEBUG modem << [00:02:02.+CSCON: 1
2022-07-25T05:08:14.150Z DEBUG modem << [00:02:02.332,366] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:08:14.151Z DEBUG modem << %CESQ: 55,2,18,2
2022-07-25T05:08:14.158Z DEBUG modem << [00:02:02.341,522] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -85[0m
2022-07-25T05:08:14.187Z DEBUG modem << 330,352] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:08:14.189Z DEBUG modem << [00:02:02.359,741] [0m<dbg> cloud_codec: cloud_codec_encode_data: No data to encode, JSON string empty...[0m
2022-07-25T05:08:14.191Z DEBUG modem << [00:02:02.369,506] [0m<dbg> data_module: data_encode: No new data to encode[0m
2022-07-25T05:08:14.193Z DEBUG modem << [00:02:02.376,770] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:08:14.196Z DEBUG modem << [00:02:02.386,901] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:08:14.198Z DEBUG modem << [00:02:02.397,247] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:08:14.217Z DEBUG modem << [00:02:02.407,714] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:08:14.220Z DEBUG modem << [00:02:02.417,846] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:08:14.222Z DEBUG modem << [00:02:02.427,947] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:08:14.223Z DEBUG modem << [00:02:02.438,262] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:08:14.225Z DEBUG modem << [00:02:02.448,760] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:08:14.226Z DEBUG modem << [00:02:02.458,740] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:08:14.228Z DEBUG modem << [00:02:02.469,024] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:08:14.247Z DEBUG modem << [00:02:02.479,705] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20024df0[0m
2022-07-25T05:08:14.250Z DEBUG modem << [00:02:02.487,976] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:08:14.252Z DEBUG modem << [00:02:02.496,704] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20024df0[0m
2022-07-25T05:08:15.399Z DEBUG modem << [00:02:03.678,100] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:08:15.961Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:15.964Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:08:15.966Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:15.969Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:08:15.971Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:15.973Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:15.974Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.140Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.142Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.144Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.171Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.173Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.175Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.177Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.178Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.180Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.181Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:16.182Z DEBUG modem << [00:02:04.275,024] [1;33m<wrn> bms_module: on line 327 0.0000,0.0000,0,0,0.2040,0,0,0 [0m
2022-07-25T05:08:16.183Z DEBUG modem << [00:02:04.283,142] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:08:16.185Z DEBUG modem << [00:02:04.291,564] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:08:16.186Z DEBUG modem << [00:02:04.302,734] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:08:16.187Z DEBUG modem << [00:02:04.310,119] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:16.188Z DEBUG modem << [00:02:04.317,199] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:08:16.189Z DEBUG modem << [00:02:04.324,218] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:08:16.191Z DEBUG modem << [00:02:04.331,176] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:08:16.192Z DEBUG modem << [00:02:04.338,256] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:08:16.193Z DEBUG modem << [00:02:04.345,367] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:08:16.195Z DEBUG modem << [00:02:04.354,736] [1;33m<wrn> cloud_codec_ringbuffer: On line 33 in ringbuffer[0m
2022-07-25T05:08:16.196Z DEBUG modem << [00:02:04.362,274] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 0 of 2 in bms buffer filled[0m
2022-07-25T05:08:16.217Z DEBUG modem << [00:02:04.373,352] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:08:16.220Z DEBUG modem << [00:02:04.381,652] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:08:16.222Z DEBUG modem << [00:02:04.390,014] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:16.223Z DEBUG modem << [00:02:04.396,942] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:08:16.224Z DEBUG modem << [00:02:04.406,524] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:16.226Z DEBUG modem << [00:02:04.416,259] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:08:16.253Z DEBUG modem << [00:02:04.425,628] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:08:16.255Z DEBUG modem << [00:02:04.436,584] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:08:16.257Z DEBUG modem << [00:02:04.445,739] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:08:16.259Z DEBUG modem << [00:02:04.454,925] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:08:16.260Z DEBUG modem << [00:02:04.463,867] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:08:16.262Z DEBUG modem << [00:02:04.473,175] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:08:16.263Z DEBUG modem << [00:02:04.482,604] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:08:16.265Z DEBUG modem << [00:02:04.492,950] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:08:16.266Z DEBUG modem << [00:02:04.501,861] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:08:16.268Z DEBUG modem << [00:02:04.510,925] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:08:16.269Z DEBUG modem << [00:02:04.520,324] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:08:16.324Z DEBUG modem << Encoded message:
2022-07-25T05:08:16.327Z DEBUG modem << {
2022-07-25T05:08:16.328Z DEBUG modem << "bms_device":{
2022-07-25T05:08:16.331Z DEBUG modem << "bms_id":3902,
2022-07-25T05:08:16.362Z DEBUG modem << "bms_pack_voltage":26,
2022-07-25T05:08:16.365Z DEBUG modem << "bms_state_of_charge":99,
2022-07-25T05:08:16.368Z DEBUG modem << "lowest_cell_voltage":0,
2022-07-25T05:08:16.370Z DEBUG modem << "lowest_voltage_cell_no":0,
2022-07-25T05:08:16.372Z DEBUG modem << "highest_cell_voltage":0,
2022-07-25T05:08:16.376Z DEBUG modem << "highest_voltage_cell_no":0,
2022-07-25T05:08:16.377Z DEBUG modem << "highest_battery_temp":0,
2022-07-25T05:08:16.378Z DEBUG modem << "highest_temp_cell_no":0,
2022-07-25T05:08:16.379Z DEBUG modem << "lowest_battery_temp":0,
2022-07-25T05:08:16.381Z DEBUG modem << "lowest_temp_cell_no":0,
2022-07-25T05:08:16.383Z DEBUG modem << "bms_pack_ampere":0,
2022-07-25T05:08:16.384Z DEBUG modem << "bms_life":81,
2022-07-25T05:08:16.386Z DEBUG modem << "total_cells":7,
2022-07-25T05:08:16.388Z DEBUG modem << "total_temp_sensors":1,
2022-07-25T05:08:16.390Z DEBUG modem << "charger_status":0,
2022-07-25T05:08:16.391Z DEBUG modem << "load_status":0,
2022-07-25T05:08:16.392Z DEBUG modem << "average_voltage":0.20399999999999999,
2022-07-25T05:08:16.394Z DEBUG modem << "device_state":1,
2022-07-25T05:08:16.397Z DEBUG modem << "average_temp":0,
2022-07-25T05:08:16.398Z DEBUG modem << "cell_balance_state":0,
2022-07-25T05:08:16.399Z DEBUG modem << "fault_code":0,
2022-07-25T05:08:16.401Z DEBUG modem << "ts":1658725695548
2022-07-25T05:08:16.404Z DEBUG modem << }
2022-07-25T05:08:16.405Z DEBUG modem << }
2022-07-25T05:08:16.406Z DEBUG modem << [00:02:04.591,247] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:08:16.408Z DEBUG modem << [00:02:04.598,724] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20025010[0m
2022-07-25T05:08:16.411Z DEBUG modem << [00:02:04.607,666] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:08:16.471Z DEBUG modem << [00:02:04.615,905] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:16.505Z DEBUG modem << [00:02:04.622,863] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:08:16.508Z DEBUG modem << [00:02:04.632,446] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:08:16.510Z DEBUG modem << [00:02:04.639,465] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:08:16.512Z DEBUG modem << [00:02:04.646,423] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:08:16.514Z DEBUG modem << [00:02:04.653,503] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:08:16.516Z DEBUG modem << [00:02:04.661,132] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:08:16.534Z DEBUG modem << [00:02:04.671,325] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:08:16.537Z DEBUG modem << [00:02:04.681,701] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:08:16.539Z DEBUG modem << [00:02:04.692,047] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:08:16.541Z DEBUG modem << [00:02:04.702,148] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:08:16.543Z DEBUG modem << [00:02:04.712,158] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:08:16.544Z DEBUG modem << [00:02:04.722,473] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:08:16.545Z DEBUG modem << [00:02:04.732,818] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:08:16.546Z DEBUG modem << [00:02:04.742,797] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:08:16.548Z DEBUG modem << [00:02:04.753,082] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:08:16.550Z DEBUG modem << [00:02:04.763,671] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20025010[0m
2022-07-25T05:08:16.551Z DEBUG modem << [00:02:04.772,003] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:08:16.552Z DEBUG modem << [00:02:04.780,700] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20025010[0m
2022-07-25T05:08:17.651Z DEBUG modem << [00:02:05.930,999] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:08:21.348Z DEBUG modem << [00:02:09.632,476] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:08:23.566Z DEBUG modem << +CSCON: 0
2022-07-25T05:08:23.602Z DEBUG modem << [00:02:11.850,494] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:08:24.822Z DEBUG modem << %CESQ: 47,2,13,1
2022-07-25T05:08:24.853Z DEBUG modem << [00:02:13.103,302] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:08:26.349Z DEBUG modem << [00:02:14.632,568] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:08:32.495Z DEBUG modem << [00:02:20.642,303] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:08:32.499Z DEBUG modem << [00:02:20.650,665] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:32.536Z DEBUG modem << [00:02:20.657,623] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:08:32.539Z DEBUG modem << [00:02:20.667,083] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:08:32.542Z DEBUG modem << [00:02:20.673,675] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:08:32.546Z DEBUG modem << [00:02:20.681,884] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:08:32.549Z DEBUG modem << [00:02:20.689,910] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:08:32.550Z DEBUG modem << [00:02:20.698,394] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:08:32.552Z DEBUG modem << [00:02:20.706,054] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:08:32.553Z DEBUG modem << [00:02:20.712,585] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:08:32.555Z DEBUG modem << [00:02:20.719,482] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:08:32.557Z DEBUG modem << [00:02:20.731,292] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:08:32.558Z DEBUG modem << [00:02:20.739,105] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:08:32.560Z DEBUG modem << [00:02:20.752,655] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:32.591Z DEBUG modem << [00:02:20.759,582] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:08:32.593Z DEBUG modem << [00:02:20.768,951] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:08:32.596Z DEBUG modem << [00:02:20.775,939] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:08:32.633Z DEBUG modem << [00:02:20.782,958] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:08:32.635Z DEBUG modem << [00:02:20.789,916] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:08:32.638Z DEBUG modem << [00:02:20.796,997] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:08:32.640Z DEBUG modem << [00:02:20.803,955] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:08:32.643Z DEBUG modem << Tx: 13
2022-07-25T05:08:32.645Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:08:32.646Z DEBUG modem << [00:02:20.816,558] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:08:32.648Z DEBUG modem << [00:02:20.825,927] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:08:32.649Z DEBUG modem << [00:02:20.835,693] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:08:32.650Z DEBUG modem << [00:02:20.845,733] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATACapture 1 data bytes:
2022-07-25T05:08:32.652Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:32.653Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:32.654Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:32.655Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:32.657Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:32.658Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:32.660Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:32.661Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:32.662Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:32.663Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:32.665Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:32.687Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:32.690Z DEBUG modem << _GET processing[0m
2022-07-25T05:08:32.692Z DEBUG modem << [00:02:20.882,415] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 8 of 9 in sensor buffer filled[0m
2022-07-25T05:08:32.694Z DEBUG modem << [00:02:20.893,920] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:32.695Z DEBUG modem << [00:02:20.903,686] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:08:32.697Z DEBUG modem << [00:02:20.915,313] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:32.720Z DEBUG modem << [00:02:20.983,886] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:08:32.723Z DEBUG modem << [00:02:20.994,140] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:32.794Z DEBUG modem << [00:02:21.062,683] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:08:32.828Z DEBUG modem << [00:02:21.076,507] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:08:32.831Z DEBUG modem << [00:02:21.087,127] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:33.719Z DEBUG modem << [00:02:21.882,476] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:08:33.750Z DEBUG modem << [00:02:21.890,808] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:33.754Z DEBUG modem << [00:02:21.897,766] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:08:33.757Z DEBUG modem << [00:02:21.907,348] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:08:33.760Z DEBUG modem << [00:02:21.918,243] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:08:33.762Z DEBUG modem << [00:02:21.927,398] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:08:33.797Z DEBUG modem << [00:02:21.936,920] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:08:33.800Z DEBUG modem << [00:02:21.946,716] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:08:33.802Z DEBUG modem << [00:02:21.956,024] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:08:33.804Z DEBUG modem << [00:02:21.965,362] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:08:33.806Z DEBUG modem << [00:02:21.974,456] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:08:33.809Z DEBUG modem << [00:02:21.983,825] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:08:33.811Z DEBUG modem << [00:02:21.993,072] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:08:33.813Z DEBUG modem << [00:02:22.002,471] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:08:33.851Z DEBUG modem << Encoded message:
2022-07-25T05:08:33.853Z DEBUG modem << {
2022-07-25T05:08:33.854Z DEBUG modem << "dev":{
2022-07-25T05:08:33.857Z DEBUG modem << "v":{
2022-07-25T05:08:33.859Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:08:33.862Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:08:33.864Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:08:33.866Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:08:33.867Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:08:33.868Z DEBUG modem << },
2022-07-25T05:08:33.870Z DEBUG modem << "ts":1658725712247
2022-07-25T05:08:33.871Z DEBUG modem << },
2022-07-25T05:08:33.872Z DEBUG modem << "env":{
2022-07-25T05:08:33.874Z DEBUG modem << "v":{
2022-07-25T05:08:33.875Z DEBUG modem << "temp":26.405307769775391,
2022-07-25T05:08:33.876Z DEBUG modem << "hum":42.204044342041016,
2022-07-25T05:08:33.878Z DEBUG modem << "atmp":97.061999999999998,
2022-07-25T05:08:33.879Z DEBUG modem << "bsec_iaq":94
2022-07-25T05:08:33.880Z DEBUG modem << },
2022-07-25T05:08:33.881Z DEBUG modem << "ts":1658725712099
2022-07-25T05:08:33.883Z DEBUG modem << },
2022-07-25T05:08:33.885Z DEBUG modem << "acc":{
2022-07-25T05:08:33.886Z DEBUG modem << "v":{
2022-07-25T05:08:33.887Z DEBUG modem << "x":26.405307769775391,
2022-07-25T05:08:33.925Z DEBUG modem << "y":42.204044342041016,
2022-07-25T05:08:33.928Z DEBUG modem << "z":97.061999999999998
2022-07-25T05:08:33.931Z DEBUG modem << },
2022-07-25T05:08:33.935Z DEBUG modem << "ts":1658725712100
2022-07-25T05:08:33.957Z DEBUG modem << }
2022-07-25T05:08:33.959Z DEBUG modem << }
2022-07-25T05:08:33.962Z DEBUG modem << [00:02:22.067,260] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:08:33.964Z DEBUG modem << [00:02:22.074,737] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20025600[0m
2022-07-25T05:08:33.966Z DEBUG modem << [00:02:22.083,557] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:08:33.968Z DEBUG modem << [00:02:22.091,827] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:33.970Z DEBUG modem << [00:02:22.098,785] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:08:33.972Z DEBUG modem << [00:02:22.108,306] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:08:33.974Z DEBUG modem << [00:02:22.114,715] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:08:33.976Z DEBUG modem << [00:02:22.124,847] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:08:33.977Z DEBUG modem << [00:02:22.135,253] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:08:33.979Z DEBUG modem << [00:02:22.145,782] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:08:33.980Z DEBUG modem << [00:02:22.155,914] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:08:33.983Z DEBUG modem << [00:02:22.166,076] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:08:33.985Z DEBUG modem << [00:02:22.176,422] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:08:33.987Z DEBUG modem << [00:02:22.187,377] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:08:33.989Z DEBUG modem << [00:02:22.197,387] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:08:33.991Z DEBUG modem << [00:02:22.207,702] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:08:34.028Z DEBUG modem << [00:02:22.225,494] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20025600[0m
2022-07-25T05:08:34.032Z DEBUG modem << [00:02:22.233,764] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:08:34.034Z DEBUG modem << [00:02:22.242,584] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20025600[0m
2022-07-25T05:08:34.069Z DEBUG modem << +CSCON: 1
2022-07-25T05:08:34.071Z DEBUG modem << [00:02:22.329,223] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:08:34.074Z DEBUG modem << %CESQ: 54,2,16,2
2022-07-25T05:08:34.080Z DEBUG modem << [00:02:22.338,317] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -86[0m
2022-07-25T05:08:34.571Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:08:34.603Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:08:34.605Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:34.607Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:08:34.610Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.611Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.613Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.615Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.616Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.618Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.619Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.621Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.623Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.625Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.626Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.628Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:34.630Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:35.373Z DEBUG modem << [00:02:23.654,266] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:08:36.574Z DEBUG modem << Tx: 13
2022-07-25T05:08:36.577Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:08:36.610Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:36.613Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:36.615Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:36.917Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:36.920Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:36.922Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:36.925Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:36.927Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:36.929Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:36.930Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:36.932Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:36.950Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:36.953Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:38.621Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:08:38.658Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:08:38.660Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:38.662Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:08:38.664Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.666Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.669Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.671Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.673Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.674Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.676Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.677Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.678Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.680Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.682Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.683Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.684Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:38.822Z DEBUG modem << [00:02:27.108,459] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:08:40.625Z DEBUG modem << Tx: 13
2022-07-25T05:08:40.628Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:08:41.057Z DEBUG modem << +CSCON: 0
2022-07-25T05:08:41.061Z DEBUG modem << [00:02:29.342,987] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:08:41.453Z DEBUG modem << %CESQ: 47,2,13,1
2022-07-25T05:08:41.478Z DEBUG modem << [00:02:29.743,896] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:08:41.975Z DEBUG modem << [00:02:30.260,772] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:08:42.673Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:08:42.676Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:08:42.679Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:42.681Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:08:42.683Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.685Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.705Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.708Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.711Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.713Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.715Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.717Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.718Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.720Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.721Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.723Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:42.724Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:43.821Z DEBUG modem << [00:02:32.108,551] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:08:44.676Z DEBUG modem << Tx: 13
2022-07-25T05:08:44.679Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:08:46.723Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:08:46.727Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:08:46.730Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:46.732Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:08:46.735Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.737Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.739Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.741Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.743Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.745Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.748Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.750Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.752Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.754Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.757Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.759Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:46.761Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:48.726Z DEBUG modem << Tx: 13
2022-07-25T05:08:48.729Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:08:48.794Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:48.797Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:48.817Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:48.819Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:48.821Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:48.823Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:48.824Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:48.826Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:48.828Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:48.829Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:48.830Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:48.832Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:48.833Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:50.754Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:08:50.776Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:08:50.778Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:50.781Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:08:50.783Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.786Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.788Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.790Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.791Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.793Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.812Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.815Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.817Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.819Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.820Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.822Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:50.823Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:52.511Z DEBUG modem << [00:02:40.642,333] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:08:52.536Z DEBUG modem << [00:02:40.650,695] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:52.539Z DEBUG modem << [00:02:40.657,653] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:08:52.542Z DEBUG modem << [00:02:40.667,114] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:08:52.545Z DEBUG modem << [00:02:40.673,706] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:08:52.547Z DEBUG modem << [00:02:40.681,915] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:08:52.550Z DEBUG modem << [00:02:40.689,941] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:08:52.552Z DEBUG modem << [00:02:40.698,425] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:08:52.553Z DEBUG modem << [00:02:40.706,085] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:08:52.575Z DEBUG modem << [00:02:40.712,646] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:08:52.577Z DEBUG modem << [00:02:40.719,512] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:08:52.580Z DEBUG modem << [00:02:40.731,353] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:08:52.581Z DEBUG modem << [00:02:40.739,196] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:08:52.583Z DEBUG modem << [00:02:40.752,807] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:52.585Z DEBUG modem << [00:02:40.759,735] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:08:52.587Z DEBUG modem << [00:02:40.769,134] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:08:52.588Z DEBUG modem << [00:02:40.776,245] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:08:52.590Z DEBUG modem << [00:02:40.785,614] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:08:52.591Z DEBUG modem << [00:02:40.795,318] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:08:52.613Z DEBUG modem << [00:02:40.805,358] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:08:52.616Z DEBUG modem << [00:02:40.814,483] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 9 of 9 in sensor buffer filled[0m
2022-07-25T05:08:52.618Z DEBUG modem << [00:02:40.825,958] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:52.620Z DEBUG modem << [00:02:40.835,754] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:08:52.622Z DEBUG modem << [00:02:40.847,351] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:52.650Z DEBUG modem << [00:02:40.915,924] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:08:52.652Z DEBUG modem << [00:02:40.926,177] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:52.736Z DEBUG modem << [00:02:40.994,964] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:08:52.739Z DEBUG modem << [00:02:41.008,789] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:08:52.743Z DEBUG modem << [00:02:41.019,439] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:08:52.778Z DEBUG modem << Tx: 13
2022-07-25T05:08:52.781Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:08:52.838Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:52.841Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:52.866Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:52.868Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:52.871Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:52.873Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:52.875Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:52.876Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:52.879Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:52.880Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:52.882Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:52.885Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:52.886Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:52.906Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:52.910Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:52.912Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:52.914Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:52.915Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:52.917Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:52.918Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:52.920Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:52.921Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:52.923Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:52.924Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:52.926Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:52.928Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:52.948Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:52.952Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:52.954Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:52.955Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:52.957Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:52.959Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:52.960Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:52.980Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:52.983Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:52.985Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:52.987Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:52.988Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:52.990Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:53.649Z DEBUG modem << [00:02:41.814,544] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:08:53.685Z DEBUG modem << [00:02:41.822,875] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:53.687Z DEBUG modem << [00:02:41.829,833] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:08:53.690Z DEBUG modem << [00:02:41.839,416] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:08:53.692Z DEBUG modem << [00:02:41.850,311] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:08:53.694Z DEBUG modem << [00:02:41.859,466] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:08:53.696Z DEBUG modem << [00:02:41.868,560] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:08:53.729Z DEBUG modem << [00:02:41.878,021] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:08:53.731Z DEBUG modem << [00:02:41.887,329] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:08:53.732Z DEBUG modem << [00:02:41.896,667] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:08:53.734Z DEBUG modem << [00:02:41.905,761] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:08:53.736Z DEBUG modem << [00:02:41.915,130] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:08:53.737Z DEBUG modem << [00:02:41.924,407] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:08:53.739Z DEBUG modem << [00:02:41.933,776] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:08:53.740Z DEBUG modem << Encoded message:
2022-07-25T05:08:53.742Z DEBUG modem << {
2022-07-25T05:08:53.744Z DEBUG modem << "dev":{
2022-07-25T05:08:53.745Z DEBUG modem << "v":{
2022-07-25T05:08:53.748Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:08:53.749Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:08:53.751Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:08:53.752Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:08:53.754Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:08:53.755Z DEBUG modem << },
2022-07-25T05:08:53.756Z DEBUG modem << "ts":1658725732179
2022-07-25T05:08:53.758Z DEBUG modem << },
2022-07-25T05:08:53.759Z DEBUG modem << "env":{
2022-07-25T05:08:53.761Z DEBUG modem << "v":{
2022-07-25T05:08:53.763Z DEBUG modem << "temp":26.425308227539062,
2022-07-25T05:08:53.765Z DEBUG modem << "hum":42.189197540283203,
2022-07-25T05:08:53.766Z DEBUG modem << "atmp":97.061999999999998,
2022-07-25T05:08:53.768Z DEBUG modem << "bsec_iaq":105
2022-07-25T05:08:53.770Z DEBUG modem << },
2022-07-25T05:08:53.771Z DEBUG modem << "ts":1658725732060
2022-07-25T05:08:53.773Z DEBUG modem << },
2022-07-25T05:08:53.774Z DEBUG modem << "acc":{
2022-07-25T05:08:53.776Z DEBUG modem << "v":{
2022-07-25T05:08:53.777Z DEBUG modem << "x":26.425308227539062,
2022-07-25T05:08:53.855Z DEBUG modem << "y":42.189197540283203,
2022-07-25T05:08:53.858Z DEBUG modem << "z":97.061999999999998
2022-07-25T05:08:53.861Z DEBUG modem << },
2022-07-25T05:08:53.891Z DEBUG modem << "ts":1658725732059
2022-07-25T05:08:53.893Z DEBUG modem << }
2022-07-25T05:08:53.894Z DEBUG modem << }
2022-07-25T05:08:53.896Z DEBUG modem << [00:02:41.998,992] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:08:53.898Z DEBUG modem << [00:02:42.006,469] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20025600[0m
2022-07-25T05:08:53.899Z DEBUG modem << [00:02:42.015,319] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:08:53.901Z DEBUG modem << [00:02:42.023,590] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:08:53.902Z DEBUG modem << [00:02:42.030,548] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:08:53.904Z DEBUG modem << [00:02:42.040,069] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:08:53.906Z DEBUG modem << [00:02:42.046,508] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:08:53.908Z DEBUG modem << [00:02:42.056,671] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:08:53.909Z DEBUG modem << [00:02:42.067,077] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:08:53.910Z DEBUG modem << [00:02:42.077,575] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:08:53.912Z DEBUG modem << [00:02:42.087,738] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:08:53.913Z DEBUG modem << [00:02:42.097,900] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:08:53.915Z DEBUG modem << [00:02:42.108,245] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:08:53.917Z DEBUG modem << [00:02:42.118,652] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:08:53.919Z DEBUG modem << [00:02:42.128,814] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:08:53.955Z DEBUG modem << [00:02:42.139,129] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:08:53.957Z DEBUG modem << [00:02:42.159,118] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20025600[0m
2022-07-25T05:08:53.958Z DEBUG modem << [00:02:42.167,510] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:08:53.960Z DEBUG modem << [00:02:42.176,208] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20025600[0m
2022-07-25T05:08:53.995Z DEBUG modem << +CSCON: 1
2022-07-25T05:08:53.998Z DEBUG modem << [00:02:42.256,805] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:08:53.999Z DEBUG modem << %CESQ: 56,2,17,2
2022-07-25T05:08:54.004Z DEBUG modem << [00:02:42.265,899] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -84[0m
2022-07-25T05:08:54.823Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:08:54.858Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c0,e,e1,e,b9,0,c8,
2022-07-25T05:08:54.860Z DEBUG modem << a5,1,95,8,2,e,d7,e,cf,e,d4,0,e9,
2022-07-25T05:08:54.862Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:08:54.864Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.865Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.867Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.869Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.870Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.872Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.874Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.875Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.877Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.879Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.881Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.882Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:54.884Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:55.278Z DEBUG modem << [00:02:43.558,959] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:08:56.827Z DEBUG modem << Tx: 13
2022-07-25T05:08:56.830Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:08:56.882Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:56.885Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:56.887Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:56.889Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:56.890Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:56.892Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:56.894Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:56.895Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:56.917Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:56.919Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:56.921Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:56.923Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:56.925Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:56.948Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:08:56.950Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:08:56.953Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:08:56.954Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:08:56.957Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:08:56.959Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:08:56.962Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:08:56.964Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:08:56.965Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:08:56.967Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:08:56.968Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:08:56.970Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:08:56.972Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:08:58.752Z DEBUG modem << [00:02:47.040,222] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:08:58.863Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:58.866Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:08:58.869Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:08:58.872Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:08:58.873Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.875Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.877Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.879Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.881Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.883Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.884Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.918Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.922Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.924Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.925Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.927Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:08:58.929Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:00.877Z DEBUG modem << Tx: 13
2022-07-25T05:09:00.879Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:09:00.925Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:00.927Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:00.929Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:00.932Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:00.934Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:00.935Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:00.937Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:00.939Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:00.941Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:00.944Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:00.978Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:09:00.981Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:09:00.983Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:09:01.017Z DEBUG modem << +CSCON: 0
2022-07-25T05:09:01.020Z DEBUG modem << [00:02:49.273,773] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:09:01.940Z DEBUG modem << %CESQ: 46,2,10,1
2022-07-25T05:09:01.981Z DEBUG modem << [00:02:50.224,090] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -94[0m
2022-07-25T05:09:02.925Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:02.950Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:02.953Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:02.956Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:02.959Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.961Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.962Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.964Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.966Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.967Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.969Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.971Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.972Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.974Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.975Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.977Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:02.978Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:03.752Z DEBUG modem << [00:02:52.040,313] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:04.928Z DEBUG modem << Tx: 13
2022-07-25T05:09:04.930Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:09:06.985Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:06.988Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:07.012Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:07.019Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:07.023Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.025Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.028Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.030Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.034Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.038Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.041Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.042Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.045Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.048Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.050Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.052Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.055Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:07.058Z DEBUG modem << [00:02:55.269,470] [1;33m<wrn> bms_module: on line 327 0.0000,0.0000,0,0,0.2050,0,0,0 [0m
2022-07-25T05:09:07.165Z DEBUG modem << [00:02:55.277,587] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:09:07.170Z DEBUG modem << [00:02:55.286,010] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:09:07.174Z DEBUG modem << [00:02:55.297,180] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:09:07.178Z DEBUG modem << [00:02:55.304,595] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:07.180Z DEBUG modem << [00:02:55.311,584] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:09:07.182Z DEBUG modem << [00:02:55.318,603] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:09:07.183Z DEBUG modem << [00:02:55.325,561] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:09:07.185Z DEBUG modem << [00:02:55.332,641] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:09:07.186Z DEBUG modem << [00:02:55.339,599] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:09:07.188Z DEBUG modem << [00:02:55.346,649] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:09:07.190Z DEBUG modem << [00:02:55.353,637] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:09:07.191Z DEBUG modem << [00:02:55.360,717] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:09:07.193Z DEBUG modem << [00:02:55.367,675] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:09:07.195Z DEBUG modem << Tx: 13
2022-07-25T05:09:07.196Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:09:07.223Z DEBUG modem << [00:02:55.380,218] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:09:07.226Z DEBUG modem << [00:02:55.389,648] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 1 of 2 in bms buffer filled[0m
2022-07-25T05:09:07.228Z DEBUG modem << [00:02:55.400,604] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:09:07.229Z DEBUG modem << [00:02:55.408,966] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:09:07.231Z DEBUG modem << [00:02:55.417,297] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:07.233Z DEBUG modem << [00:02:55.424,224] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:09:07.235Z DEBUG modem << [00:02:55.433,746] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:07.236Z DEBUG modem << [00:02:55.443,481] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:09:07.262Z DEBUG modem << [00:02:55.452,911] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:09:07.264Z DEBUG modem << [00:02:55.463,806] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:09:07.266Z DEBUG modem << [00:02:55.472,961] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:09:07.268Z DEBUG modem << [00:02:55.482,055] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:09:07.270Z DEBUG modem << [00:02:55.491,027] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:09:07.272Z DEBUG modem << [00:02:55.500,396] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:09:07.274Z DEBUG modem << [00:02:55.509,735] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:09:07.298Z DEBUG modem << [00:02:55.520,111] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:09:07.301Z DEBUG modem << [00:02:55.529,052] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:09:07.303Z DEBUG modem << [00:02:55.538,055] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:09:07.305Z DEBUG modem << [00:02:55.547,485] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:09:07.348Z DEBUG modem << Encoded message:
2022-07-25T05:09:07.352Z DEBUG modem << {
2022-07-25T05:09:07.355Z DEBUG modem << "bms_device":{
2022-07-25T05:09:07.357Z DEBUG modem << "bms_id":3902,
2022-07-25T05:09:07.380Z DEBUG modem << "bms_pack_voltage":26,
2022-07-25T05:09:07.383Z DEBUG modem << "bms_state_of_charge":99,
2022-07-25T05:09:07.385Z DEBUG modem << "lowest_cell_voltage":0,
2022-07-25T05:09:07.387Z DEBUG modem << "lowest_voltage_cell_no":0,
2022-07-25T05:09:07.390Z DEBUG modem << "highest_cell_voltage":0,
2022-07-25T05:09:07.392Z DEBUG modem << "highest_voltage_cell_no":0,
2022-07-25T05:09:07.395Z DEBUG modem << "highest_battery_temp":0,
2022-07-25T05:09:07.398Z DEBUG modem << "highest_temp_cell_no":0,
2022-07-25T05:09:07.404Z DEBUG modem << "lowest_battery_temp":0,
2022-07-25T05:09:07.405Z DEBUG modem << "lowest_temp_cell_no":0,
2022-07-25T05:09:07.407Z DEBUG modem << "bms_pack_ampere":0,
2022-07-25T05:09:07.409Z DEBUG modem << "bms_life":81,
2022-07-25T05:09:07.410Z DEBUG modem << "total_cells":7,
2022-07-25T05:09:07.412Z DEBUG modem << "total_temp_sensors":1,
2022-07-25T05:09:07.413Z DEBUG modem << "charger_status":0,
2022-07-25T05:09:07.415Z DEBUG modem << "load_status":0,
2022-07-25T05:09:07.417Z DEBUG modem << "average_voltage":0.20499999999999999,
2022-07-25T05:09:07.418Z DEBUG modem << "device_state":1,
2022-07-25T05:09:07.420Z DEBUG modem << "average_temp":0,
2022-07-25T05:09:07.421Z DEBUG modem << "cell_balance_state":0,
2022-07-25T05:09:07.423Z DEBUG modem << "fault_code":0,
2022-07-25T05:09:07.424Z DEBUG modem << "ts":1658725746542
2022-07-25T05:09:07.426Z DEBUG modem << }
2022-07-25T05:09:07.428Z DEBUG modem << }
2022-07-25T05:09:07.429Z DEBUG modem << [00:02:55.618,286] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:09:07.431Z DEBUG modem << [00:02:55.625,793] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20025cc0[0m
2022-07-25T05:09:07.432Z DEBUG modem << [00:02:55.634,613] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:09:07.520Z DEBUG modem << [00:02:55.642,883] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:07.524Z DEBUG modem << [00:02:55.649,841] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:09:07.527Z DEBUG modem << [00:02:55.659,362] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:07.529Z DEBUG modem << [00:02:55.666,290] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:09:07.531Z DEBUG modem << [00:02:55.676,452] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:09:07.533Z DEBUG modem << [00:02:55.686,828] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:09:07.535Z DEBUG modem << [00:02:55.697,326] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:09:07.537Z DEBUG modem << [00:02:55.707,458] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:09:07.561Z DEBUG modem << [00:02:55.717,590] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:09:07.564Z DEBUG modem << [00:02:55.727,905] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:09:07.566Z DEBUG modem << [00:02:55.738,403] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:09:07.567Z DEBUG modem << [00:02:55.748,382] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:09:07.569Z DEBUG modem << [00:02:55.758,666] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:09:07.571Z DEBUG modem << +CSCON: 1
2022-07-25T05:09:07.573Z DEBUG modem << [00:02:55.769,378] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:09:07.575Z DEBUG modem << %CESQ: 55,2,16,2
2022-07-25T05:09:07.580Z DEBUG modem << [00:02:55.778,442] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -85[0m
2022-07-25T05:09:07.582Z DEBUG modem << [00:02:55.789,764] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20025cc0[0m
2022-07-25T05:09:07.583Z DEBUG modem << [00:02:55.798,034] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:09:07.585Z DEBUG modem << [00:02:55.806,793] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20025cc0[0m
2022-07-25T05:09:08.834Z DEBUG modem << [00:02:57.117,980] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:09:09.132Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:09.135Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:09.138Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:09.141Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:09.144Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.145Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.147Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.149Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.150Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.152Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.154Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.155Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.157Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.158Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.160Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.162Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:09.163Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:11.135Z DEBUG modem << Tx: 13
2022-07-25T05:09:11.139Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:09:11.203Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:11.206Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:11.209Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:11.509Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:11.513Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:11.516Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:11.519Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:11.521Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:11.544Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:11.547Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:11.550Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:11.552Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:11.554Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:11.979Z DEBUG modem << [00:03:00.267,974] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:09:12.443Z DEBUG modem << [00:03:00.642,364] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:09:12.447Z DEBUG modem << [00:03:00.650,726] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:12.473Z DEBUG modem << [00:03:00.657,684] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:09:12.475Z DEBUG modem << [00:03:00.667,297] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:12.477Z DEBUG modem << [00:03:00.673,675] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:09:12.479Z DEBUG modem << [00:03:00.680,267] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:09:12.481Z DEBUG modem << [00:03:00.688,476] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:09:12.483Z DEBUG modem << [00:03:00.696,502] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:09:12.485Z DEBUG modem << [00:03:00.705,078] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:09:12.487Z DEBUG modem << [00:03:00.712,707] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:09:12.489Z DEBUG modem << [00:03:00.719,238] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:09:12.491Z DEBUG modem << [00:03:00.726,226] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:09:12.569Z DEBUG modem << [00:03:00.738,037] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:09:12.574Z DEBUG modem << [00:03:00.745,880] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:09:12.577Z DEBUG modem << [00:03:00.759,429] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:12.579Z DEBUG modem << [00:03:00.766,387] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:09:12.582Z DEBUG modem << [00:03:00.775,817] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:09:12.585Z DEBUG modem << [00:03:00.782,928] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:09:12.587Z DEBUG modem << [00:03:00.792,358] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:09:12.589Z DEBUG modem << [00:03:00.802,215] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:09:12.616Z DEBUG modem << [00:03:00.812,255] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:09:12.619Z DEBUG modem << [00:03:00.821,350] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 0 of 9 in sensor buffer filled[0m
2022-07-25T05:09:12.621Z DEBUG modem << [00:03:00.832,916] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:12.623Z DEBUG modem << [00:03:00.842,681] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:09:12.625Z DEBUG modem << [00:03:00.854,370] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:12.650Z DEBUG modem << [00:03:00.894,805] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:09:12.654Z DEBUG modem << [00:03:00.905,151] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:12.684Z DEBUG modem << [00:03:00.946,105] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:09:12.709Z DEBUG modem << [00:03:00.956,512] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 1 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:09:12.712Z DEBUG modem << [00:03:00.969,177] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:13.182Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:13.185Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:13.215Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:13.217Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:13.220Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.222Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.224Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.226Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.228Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.230Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.232Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.234Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.235Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.237Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.239Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.240Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.242Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:13.654Z DEBUG modem << [00:03:01.821,411] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:09:13.682Z DEBUG modem << [00:03:01.829,711] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:13.685Z DEBUG modem << [00:03:01.836,669] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:09:13.689Z DEBUG modem << [00:03:01.846,191] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:09:13.691Z DEBUG modem << [00:03:01.857,086] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:09:13.693Z DEBUG modem << [00:03:01.866,210] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:09:13.695Z DEBUG modem << [00:03:01.875,274] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:09:13.719Z DEBUG modem << [00:03:01.884,704] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:09:13.721Z DEBUG modem << [00:03:01.894,226] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:09:13.723Z DEBUG modem << [00:03:01.903,533] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:09:13.725Z DEBUG modem << [00:03:01.912,567] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:09:13.728Z DEBUG modem << [00:03:01.921,905] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:09:13.730Z DEBUG modem << [00:03:01.931,152] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:09:13.732Z DEBUG modem << [00:03:01.940,521] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:09:13.733Z DEBUG modem << Encoded message:
2022-07-25T05:09:13.735Z DEBUG modem << {
2022-07-25T05:09:13.737Z DEBUG modem << "dev":{
2022-07-25T05:09:13.738Z DEBUG modem << "v":{
2022-07-25T05:09:13.740Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:09:13.741Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:09:13.851Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:09:13.854Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:09:13.882Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:09:13.884Z DEBUG modem << },
2022-07-25T05:09:13.886Z DEBUG modem << "ts":1658725752158
2022-07-25T05:09:13.888Z DEBUG modem << },
2022-07-25T05:09:13.890Z DEBUG modem << "roam":{
2022-07-25T05:09:13.892Z DEBUG modem << "v":{
2022-07-25T05:09:13.894Z DEBUG modem << "rsrp":-85
2022-07-25T05:09:13.896Z DEBUG modem << },
2022-07-25T05:09:13.898Z DEBUG modem << "ts":1658725752211
2022-07-25T05:09:13.900Z DEBUG modem << },
2022-07-25T05:09:13.902Z DEBUG modem << "env":{
2022-07-25T05:09:13.903Z DEBUG modem << "v":{
2022-07-25T05:09:13.906Z DEBUG modem << "temp":26.455307006835938,
2022-07-25T05:09:13.908Z DEBUG modem << "hum":42.134708404541016,
2022-07-25T05:09:13.910Z DEBUG modem << "atmp":97.063999999999993,
2022-07-25T05:09:13.912Z DEBUG modem << "bsec_iaq":115
2022-07-25T05:09:13.914Z DEBUG modem << },
2022-07-25T05:09:13.916Z DEBUG modem << "ts":1658725752066
2022-07-25T05:09:13.918Z DEBUG modem << },
2022-07-25T05:09:13.919Z DEBUG modem << "acc":{
2022-07-25T05:09:13.921Z DEBUG modem << "v":{
2022-07-25T05:09:13.924Z DEBUG modem << "x":26.455307006835938,
2022-07-25T05:09:13.927Z DEBUG modem << "y":42.134708404541016,
2022-07-25T05:09:13.929Z DEBUG modem << "z":97.063999999999993
2022-07-25T05:09:13.931Z DEBUG modem << },
2022-07-25T05:09:13.934Z DEBUG modem << "ts":1658725752067
2022-07-25T05:09:13.936Z DEBUG modem << }
2022-07-25T05:09:13.938Z DEBUG modem << }
2022-07-25T05:09:13.940Z DEBUG modem << [00:03:02.013,244] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:09:13.942Z DEBUG modem << [00:03:02.020,690] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20025c70[0m
2022-07-25T05:09:13.944Z DEBUG modem << [00:03:02.029,510] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:09:13.946Z DEBUG modem << [00:03:02.037,750] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:13.947Z DEBUG modem << [00:03:02.044,677] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:09:13.950Z DEBUG modem << [00:03:02.054,168] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:13.952Z DEBUG modem << [00:03:02.060,577] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:09:13.954Z DEBUG modem << [00:03:02.070,678] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:09:14.001Z DEBUG modem << [00:03:02.081,054] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:09:14.005Z DEBUG modem << [00:03:02.091,552] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:09:14.008Z DEBUG modem << [00:03:02.101,623] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:09:14.011Z DEBUG modem << [00:03:02.111,785] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:09:14.013Z DEBUG modem << [00:03:02.122,070] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:09:14.014Z DEBUG modem << [00:03:02.132,415] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:09:14.016Z DEBUG modem << [00:03:02.142,486] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:09:14.018Z DEBUG modem << [00:03:02.152,740] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:09:14.020Z DEBUG modem << [00:03:02.164,520] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20025c70[0m
2022-07-25T05:09:14.022Z DEBUG modem << [00:03:02.172,790] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:09:14.024Z DEBUG modem << [00:03:02.181,610] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20025c70[0m
2022-07-25T05:09:14.500Z DEBUG modem << +CSCON: 0
2022-07-25T05:09:14.502Z DEBUG modem << [00:03:02.787,017] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:09:14.601Z DEBUG modem << +CSCON: 1
2022-07-25T05:09:14.641Z DEBUG modem << [00:03:02.889,495] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:09:15.186Z DEBUG modem << Tx: 13
2022-07-25T05:09:15.189Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:09:15.927Z DEBUG modem << [00:03:04.211,151] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:09:17.232Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:17.266Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:17.269Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:17.271Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:17.273Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.275Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.277Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.279Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.281Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.282Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.284Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.286Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.287Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.289Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.291Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.293Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:17.294Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:18.765Z DEBUG modem << [00:03:07.054,321] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:19.235Z DEBUG modem << Tx: 13
2022-07-25T05:09:19.238Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:09:21.283Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:21.287Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:21.290Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:21.293Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:21.296Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.298Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.299Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.333Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.336Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.339Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.341Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.344Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.345Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.347Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.349Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.351Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:21.353Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:22.015Z DEBUG modem << +CSCON: 0
2022-07-25T05:09:22.056Z DEBUG modem << [00:03:10.307,189] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:09:22.418Z DEBUG modem << %CESQ: 49,2,18,2
2022-07-25T05:09:22.460Z DEBUG modem << [00:03:10.704,803] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -91[0m
2022-07-25T05:09:23.285Z DEBUG modem << Tx: 13
2022-07-25T05:09:23.289Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:09:23.335Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:23.339Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:23.341Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:23.343Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:23.346Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:23.348Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:23.350Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:23.352Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:23.392Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:23.395Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:23.398Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:09:23.400Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:09:23.402Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:09:23.765Z DEBUG modem << [00:03:12.054,412] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:25.334Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:09:25.338Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:09:25.343Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:25.345Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:25.348Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.350Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.352Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.354Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.357Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.359Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.361Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.363Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.366Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.368Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.370Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.372Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:25.375Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:27.335Z DEBUG modem << Tx: 13
2022-07-25T05:09:27.339Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:09:27.386Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:27.390Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:27.395Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:27.398Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:27.400Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:27.402Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:27.404Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:27.406Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:27.408Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:27.410Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:27.412Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:09:27.414Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:09:27.416Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:09:27.447Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:27.449Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:27.452Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:27.453Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:27.455Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:27.457Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:27.459Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:27.461Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:27.464Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:27.465Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:27.467Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:09:27.469Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:09:27.471Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:09:27.495Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:27.497Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:27.500Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:27.502Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:27.504Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:27.506Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:27.508Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:27.509Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:27.511Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:27.513Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:27.537Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:09:27.542Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:09:27.544Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:09:27.567Z DEBUG modem << %CESQ: 47,2,13,1
2022-07-25T05:09:27.573Z DEBUG modem << [00:03:15.824,768] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:09:29.382Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:29.386Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:09:29.412Z DEBUG modem << a5,1,95,8,2,e,d6,e,cf,e,d4,0,e8,
2022-07-25T05:09:29.415Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:29.418Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.421Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.423Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.425Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.427Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.429Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.431Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.433Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.435Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.436Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.439Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.441Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:29.443Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:31.390Z DEBUG modem << Tx: 13
2022-07-25T05:09:31.393Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:09:31.473Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:31.477Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:31.519Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:31.521Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:31.523Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:31.526Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:31.529Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:31.533Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:31.535Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:31.537Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:31.539Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:09:31.540Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:09:31.542Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:09:31.567Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:31.570Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:31.573Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:31.575Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:31.577Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:31.579Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:31.581Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:31.584Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:31.587Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:31.590Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:31.592Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:09:31.594Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:09:31.596Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:09:32.401Z DEBUG modem << [00:03:20.642,395] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:09:32.405Z DEBUG modem << [00:03:20.650,756] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:32.411Z DEBUG modem << [00:03:20.657,714] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:09:32.413Z DEBUG modem << [00:03:20.667,175] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:09:32.414Z DEBUG modem << [00:03:20.673,767] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:09:32.416Z DEBUG modem << [00:03:20.681,976] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:09:32.418Z DEBUG modem << [00:03:20.690,002] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:09:32.561Z DEBUG modem << [00:03:20.698,486] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:09:32.565Z DEBUG modem << [00:03:20.706,146] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:09:32.568Z DEBUG modem << [00:03:20.712,707] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:09:32.596Z DEBUG modem << [00:03:20.719,573] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:09:32.598Z DEBUG modem << [00:03:20.731,384] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:09:32.601Z DEBUG modem << [00:03:20.739,257] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:09:32.605Z DEBUG modem << [00:03:20.752,838] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:32.607Z DEBUG modem << [00:03:20.759,796] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:09:32.610Z DEBUG modem << [00:03:20.769,195] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:09:32.612Z DEBUG modem << [00:03:20.776,306] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:09:32.614Z DEBUG modem << [00:03:20.785,675] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:09:32.615Z DEBUG modem << [00:03:20.795,440] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:09:32.617Z DEBUG modem << [00:03:20.805,480] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:09:32.619Z DEBUG modem << [00:03:20.814,605] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 1 of 9 in sensor buffer filled[0m
2022-07-25T05:09:32.621Z DEBUG modem << [00:03:20.826,080] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:32.623Z DEBUG modem << [00:03:20.835,876] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:09:32.625Z DEBUG modem << [00:03:20.847,473] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:32.658Z DEBUG modem << [00:03:20.904,052] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:09:32.662Z DEBUG modem << [00:03:20.914,306] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:32.697Z DEBUG modem << [00:03:20.960,906] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:09:32.730Z DEBUG modem << [00:03:20.971,191] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 2 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:09:32.733Z DEBUG modem << [00:03:20.983,917] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:33.433Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:33.476Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:09:33.478Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:33.480Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:33.483Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.486Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.488Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.490Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.492Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.493Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.495Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.497Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.499Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.501Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.502Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.504Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.506Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:33.620Z DEBUG modem << [00:03:21.814,666] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:09:33.663Z DEBUG modem << [00:03:21.822,998] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:33.666Z DEBUG modem << [00:03:21.829,956] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:09:33.668Z DEBUG modem << [00:03:21.839,508] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:09:33.670Z DEBUG modem << [00:03:21.850,402] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:09:33.672Z DEBUG modem << [00:03:21.859,558] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:09:33.675Z DEBUG modem << [00:03:21.868,652] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:09:33.676Z DEBUG modem << [00:03:21.878,112] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:09:33.679Z DEBUG modem << [00:03:21.887,634] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:09:33.706Z DEBUG modem << [00:03:21.896,942] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:09:33.709Z DEBUG modem << [00:03:21.906,005] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:09:33.711Z DEBUG modem << [00:03:21.915,374] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:09:33.712Z DEBUG modem << [00:03:21.924,621] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:09:33.714Z DEBUG modem << [00:03:21.933,990] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:09:33.815Z DEBUG modem << Encoded message:
2022-07-25T05:09:33.818Z DEBUG modem << {
2022-07-25T05:09:33.820Z DEBUG modem << "dev":{
2022-07-25T05:09:33.822Z DEBUG modem << "v":{
2022-07-25T05:09:33.856Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:09:33.859Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:09:33.862Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:09:33.864Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:09:33.866Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:09:33.868Z DEBUG modem << },
2022-07-25T05:09:33.870Z DEBUG modem << "ts":1658725772167
2022-07-25T05:09:33.872Z DEBUG modem << },
2022-07-25T05:09:33.874Z DEBUG modem << "roam":{
2022-07-25T05:09:33.875Z DEBUG modem << "v":{
2022-07-25T05:09:33.878Z DEBUG modem << "rsrp":-93
2022-07-25T05:09:33.880Z DEBUG modem << },
2022-07-25T05:09:33.882Z DEBUG modem << "ts":1658725772224
2022-07-25T05:09:33.884Z DEBUG modem << },
2022-07-25T05:09:33.886Z DEBUG modem << "env":{
2022-07-25T05:09:33.889Z DEBUG modem << "v":{
2022-07-25T05:09:33.893Z DEBUG modem << "temp":26.535306930541992,
2022-07-25T05:09:33.897Z DEBUG modem << "hum":41.997638702392578,
2022-07-25T05:09:33.900Z DEBUG modem << "atmp":97.063999999999993,
2022-07-25T05:09:33.901Z DEBUG modem << "bsec_iaq":126
2022-07-25T05:09:33.903Z DEBUG modem << },
2022-07-25T05:09:33.905Z DEBUG modem << "ts":1658725772060
2022-07-25T05:09:33.907Z DEBUG modem << },
2022-07-25T05:09:33.909Z DEBUG modem << "acc":{
2022-07-25T05:09:33.911Z DEBUG modem << "v":{
2022-07-25T05:09:33.913Z DEBUG modem << "x":26.535306930541992,
2022-07-25T05:09:33.915Z DEBUG modem << "y":41.997638702392578,
2022-07-25T05:09:33.916Z DEBUG modem << "z":97.063999999999993
2022-07-25T05:09:33.918Z DEBUG modem << },
2022-07-25T05:09:33.920Z DEBUG modem << "ts":1658725772059
2022-07-25T05:09:33.922Z DEBUG modem << }
2022-07-25T05:09:33.924Z DEBUG modem << }
2022-07-25T05:09:33.926Z DEBUG modem << [00:03:22.007,232] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:09:33.928Z DEBUG modem << [00:03:22.014,709] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20025c70[0m
2022-07-25T05:09:33.929Z DEBUG modem << [00:03:22.023,529] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:09:33.931Z DEBUG modem << [00:03:22.031,799] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:33.932Z DEBUG modem << [00:03:22.038,757] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:09:33.934Z DEBUG modem << [00:03:22.048,248] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:33.936Z DEBUG modem << [00:03:22.054,687] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:09:33.937Z DEBUG modem << [00:03:22.064,819] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:09:33.939Z DEBUG modem << [00:03:22.075,195] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:09:33.940Z DEBUG modem << [00:03:22.085,754] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:09:33.942Z DEBUG modem << [00:03:22.095,855] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:09:33.973Z DEBUG modem << [00:03:22.105,987] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:09:33.975Z DEBUG modem << [00:03:22.116,333] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:09:33.977Z DEBUG modem << [00:03:22.126,708] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:09:33.979Z DEBUG modem << [00:03:22.136,779] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:09:33.981Z DEBUG modem << [00:03:22.147,094] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:09:33.983Z DEBUG modem << [00:03:22.164,947] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20025c70[0m
2022-07-25T05:09:33.985Z DEBUG modem << [00:03:22.173,217] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:09:33.987Z DEBUG modem << [00:03:22.181,976] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20025c70[0m
2022-07-25T05:09:34.532Z DEBUG modem << +CSCON: 1
2022-07-25T05:09:34.535Z DEBUG modem << [00:03:22.809,967] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:09:34.539Z DEBUG modem << %CESQ: 57,2,17,2
2022-07-25T05:09:34.545Z DEBUG modem << [00:03:22.819,000] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -83[0m
2022-07-25T05:09:35.436Z DEBUG modem << Tx: 13
2022-07-25T05:09:35.440Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:09:35.517Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:35.521Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:35.524Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:35.527Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:35.529Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:35.552Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:35.555Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:35.557Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:35.560Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:35.562Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:35.564Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:09:35.566Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:09:35.568Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:09:35.866Z DEBUG modem << [00:03:24.151,519] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:09:37.479Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:37.507Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:37.510Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:37.513Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:37.515Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.519Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.521Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.523Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.525Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.526Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.528Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.530Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.532Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.534Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.536Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.561Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:37.564Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:38.758Z DEBUG modem << [00:03:27.048,400] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:39.486Z DEBUG modem << Tx: 13
2022-07-25T05:09:39.490Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:09:41.455Z DEBUG modem << +CSCON: 0
2022-07-25T05:09:41.459Z DEBUG modem << [00:03:29.744,293] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:09:41.643Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:41.647Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:41.650Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:41.653Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:41.657Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.659Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.661Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.663Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.665Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.667Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.669Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.670Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.672Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.674Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.675Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.677Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.679Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:41.680Z DEBUG modem << [00:03:29.830,596] [1;33m<wrn> bms_module: on line 327 0.0000,0.0000,0,0,0.2050,0,0,0 [0m
2022-07-25T05:09:41.682Z DEBUG modem << [00:03:29.838,714] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:09:41.708Z DEBUG modem << [00:03:29.847,137] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:09:41.711Z DEBUG modem << [00:03:29.858,276] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:09:41.713Z DEBUG modem << [00:03:29.865,692] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:41.716Z DEBUG modem << [00:03:29.872,650] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:09:41.718Z DEBUG modem << [00:03:29.879,669] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:09:41.720Z DEBUG modem << [00:03:29.886,627] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:09:41.722Z DEBUG modem << [00:03:29.893,707] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:09:41.723Z DEBUG modem << [00:03:29.900,665] [0m<inf>%CESQ: 47,2,11,1
2022-07-25T05:09:41.726Z DEBUG modem << [00:03:29.904,907] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:09:41.728Z DEBUG modem <<  bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:09:41.730Z DEBUG modem << [00:03:29.919,677] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:09:41.732Z DEBUG modem << [00:03:29.926,635] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:09:41.733Z DEBUG modem << [00:03:29.933,715] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:09:41.825Z DEBUG modem << [00:03:29.940,856] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:09:41.854Z DEBUG modem << [00:03:29.947,937] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:09:41.857Z DEBUG modem << [00:03:29.954,895] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:09:41.860Z DEBUG modem << [00:03:29.961,975] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:09:41.863Z DEBUG modem << [00:03:29.969,024] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:09:41.865Z DEBUG modem << Tx: 13
2022-07-25T05:09:41.867Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:09:41.869Z DEBUG modem << [00:03:29.981,536] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:09:41.870Z DEBUG modem << [00:03:29.991,119] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:09:41.872Z DEBUG modem << [00:03:30.002,075] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:09:41.874Z DEBUG modem << [00:03:30.010,406] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:09:41.876Z DEBUG modem << [00:03:30.018,737] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:41.877Z DEBUG modem << [00:03:30.025,695] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:09:41.905Z DEBUG modem << [00:03:30.035,308] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:41.909Z DEBUG modem << [00:03:30.045,043] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:09:41.911Z DEBUG modem << [00:03:30.054,473] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:09:41.913Z DEBUG modem << [00:03:30.065,460] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:09:41.915Z DEBUG modem << [00:03:30.074,584] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:09:41.916Z DEBUG modem << [00:03:30.083,831] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:09:41.918Z DEBUG modem << [00:03:30.092,803] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:09:41.920Z DEBUG modem << [00:03:30.102,142] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:09:41.922Z DEBUG modem << [00:03:30.111,602] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:09:41.924Z DEBUG modem << [00:03:30.121,978] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:09:41.926Z DEBUG modem << [00:03:30.130,920] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:09:41.928Z DEBUG modem << [00:03:30.140,014] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:09:41.930Z DEBUG modem << [00:03:30.149,444] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:09:42.009Z DEBUG modem << Encoded message:
2022-07-25T05:09:42.013Z DEBUG modem << {
2022-07-25T05:09:42.016Z DEBUG modem << "bms_device":{
2022-07-25T05:09:42.019Z DEBUG modem << "bms_id":3902,
2022-07-25T05:09:42.043Z DEBUG modem << "bms_pack_voltage":26,
2022-07-25T05:09:42.045Z DEBUG modem << "bms_state_of_charge":99,
2022-07-25T05:09:42.048Z DEBUG modem << "lowest_cell_voltage":0,
2022-07-25T05:09:42.051Z DEBUG modem << "lowest_voltage_cell_no":0,
2022-07-25T05:09:42.054Z DEBUG modem << "highest_cell_voltage":0,
2022-07-25T05:09:42.057Z DEBUG modem << "highest_voltage_cell_no":0,
2022-07-25T05:09:42.059Z DEBUG modem << "highest_battery_temp":0,
2022-07-25T05:09:42.061Z DEBUG modem << "highest_temp_cell_no":0,
2022-07-25T05:09:42.062Z DEBUG modem << "lowest_battery_temp":0,
2022-07-25T05:09:42.064Z DEBUG modem << "lowest_temp_cell_no":0,
2022-07-25T05:09:42.067Z DEBUG modem << "bms_pack_ampere":0,
2022-07-25T05:09:42.069Z DEBUG modem << "bms_life":81,
2022-07-25T05:09:42.071Z DEBUG modem << "total_cells":7,
2022-07-25T05:09:42.073Z DEBUG modem << "total_temp_sensors":1,
2022-07-25T05:09:42.075Z DEBUG modem << "charger_status":0,
2022-07-25T05:09:42.077Z DEBUG modem << "load_status":0,
2022-07-25T05:09:42.079Z DEBUG modem << "average_voltage":0.20499999999999999,
2022-07-25T05:09:42.080Z DEBUG modem << "device_state":1,
2022-07-25T05:09:42.082Z DEBUG modem << "average_temp":0,
2022-07-25T05:09:42.084Z DEBUG modem << "cell_balance_state":0,
2022-07-25T05:09:42.085Z DEBUG modem << "fault_code":0,
2022-07-25T05:09:42.087Z DEBUG modem << "ts":1658725781103
2022-07-25T05:09:42.089Z DEBUG modem << }
2022-07-25T05:09:42.091Z DEBUG modem << }
2022-07-25T05:09:42.093Z DEBUG modem << [00:03:30.220,489] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:09:42.095Z DEBUG modem << [00:03:30.227,966] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x200265d0[0m
2022-07-25T05:09:42.096Z DEBUG modem << [00:03:30.236,877] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:09:42.098Z DEBUG modem << [00:03:30.245,147] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:42.100Z DEBUG modem << [00:03:30.252,075] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:09:42.102Z DEBUG modem << [00:03:30.261,627] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:42.103Z DEBUG modem << [00:03:30.268,524] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: En[00:03:30.275,115] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:09:42.105Z DEBUG modem << tered cloud_codec_encode_batch_data[0m
2022-07-25T05:09:42.107Z DEBUG modem << [00:03:30.285,858] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:09:42.108Z DEBUG modem << [00:03:30.296,356] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:09:42.140Z DEBUG modem << [00:03:30.306,732] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:09:42.143Z DEBUG modem << [00:03:30.316,925] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:09:42.146Z DEBUG modem << [00:03:30.326,934] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:09:42.149Z DEBUG modem << [00:03:30.337,219] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:09:42.151Z DEBUG modem << [00:03:30.347,686] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:09:42.152Z DEBUG modem << [00:03:30.357,696] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:09:42.154Z DEBUG modem << [00:03:30.368,133] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:09:42.156Z DEBUG modem << [00:03:30.378,875] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x200265d0[0m
2022-07-25T05:09:42.158Z DEBUG modem << [00:03:30.387,145] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:09:42.160Z DEBUG modem << [00:03:30.395,935] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x200265d0[0m
2022-07-25T05:09:42.190Z DEBUG modem << +CSCON: 1
2022-07-25T05:09:42.193Z DEBUG modem << [00:03:30.410,125] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:09:42.196Z DEBUG modem << %CESQ: 56,2,16,2
2022-07-25T05:09:42.201Z DEBUG modem << [00:03:30.419,189] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -84[0m
2022-07-25T05:09:43.676Z DEBUG modem << [00:03:31.961,853] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:09:43.731Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:43.770Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:43.774Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:43.777Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:43.779Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.781Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.783Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.785Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.788Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.789Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.792Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.793Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.795Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.797Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.799Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.801Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:43.803Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:44.546Z DEBUG modem << %CESQ: 57,2,21,3
2022-07-25T05:09:44.579Z DEBUG modem << [00:03:32.837,554] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -83[0m
2022-07-25T05:09:45.733Z DEBUG modem << Tx: 13
2022-07-25T05:09:45.739Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:09:45.795Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:45.799Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:45.803Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:46.101Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:46.105Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:46.134Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:46.137Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:46.140Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:46.142Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:46.144Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:46.146Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:46.148Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:46.150Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:46.970Z DEBUG modem << [00:03:35.261,718] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:47.781Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:47.785Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:47.788Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:47.792Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:47.819Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.821Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.824Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.826Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.829Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.831Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.833Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.835Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.837Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.839Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.842Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.844Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:47.846Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:49.463Z DEBUG modem << +CSCON: 0
2022-07-25T05:09:49.467Z DEBUG modem << [00:03:37.754,821] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:09:49.783Z DEBUG modem << Tx: 13
2022-07-25T05:09:49.787Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:09:50.577Z DEBUG modem << %CESQ: 47,2,10,1
2022-07-25T05:09:50.615Z DEBUG modem << [00:03:38.864,868] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:09:51.831Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:51.835Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:51.838Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:51.842Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:51.845Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.848Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.850Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.853Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.855Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.858Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.862Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.864Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.866Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.868Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.870Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.872Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.874Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:51.970Z DEBUG modem << [00:03:40.261,810] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:52.358Z DEBUG modem << [00:03:40.642,456] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:09:52.539Z DEBUG modem << [00:03:40.650,817] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:52.543Z DEBUG modem << [00:03:40.657,775] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:09:52.545Z DEBUG modem << [00:03:40.667,205] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:09:52.574Z DEBUG modem << [00:03:40.673,828] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:09:52.577Z DEBUG modem << [00:03:40.682,006] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:09:52.580Z DEBUG modem << [00:03:40.690,063] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:09:52.582Z DEBUG modem << [00:03:40.698,547] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:09:52.584Z DEBUG modem << [00:03:40.706,176] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:09:52.587Z DEBUG modem << [00:03:40.712,738] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:09:52.589Z DEBUG modem << [00:03:40.719,604] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:09:52.592Z DEBUG modem << [00:03:40.731,445] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:09:52.594Z DEBUG modem << [00:03:40.739,288] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:09:52.596Z DEBUG modem << [00:03:40.752,868] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:52.598Z DEBUG modem << [00:03:40.759,826] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:09:52.600Z DEBUG modem << [00:03:40.769,226] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:09:52.602Z DEBUG modem << [00:03:40.776,336] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:09:52.604Z DEBUG modem << [00:03:40.785,705] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:09:52.606Z DEBUG modem << [00:03:40.795,379] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:09:52.608Z DEBUG modem << [00:03:40.805,419] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:09:52.609Z DEBUG modem << [00:03:40.814,544] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 2 of 9 in sensor buffer filled[0m
2022-07-25T05:09:52.644Z DEBUG modem << [00:03:40.826,019] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:52.648Z DEBUG modem << [00:03:40.835,784] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:09:52.650Z DEBUG modem << [00:03:40.847,412] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:52.681Z DEBUG modem << [00:03:40.916,503] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:09:52.685Z DEBUG modem << [00:03:40.926,727] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:52.732Z DEBUG modem << [00:03:40.995,513] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:09:52.769Z DEBUG modem << [00:03:41.009,338] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:09:52.773Z DEBUG modem << [00:03:41.019,958] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:09:53.623Z DEBUG modem << [00:03:41.814,605] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:09:53.627Z DEBUG modem << [00:03:41.822,937] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:53.631Z DEBUG modem << [00:03:41.829,895] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:09:53.635Z DEBUG modem << [00:03:41.839,447] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:09:53.637Z DEBUG modem << [00:03:41.850,341] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:09:53.639Z DEBUG modem << [00:03:41.859,466] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:09:53.641Z DEBUG modem << [00:03:41.868,591] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:09:53.643Z DEBUG modem << [00:03:41.878,021] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:09:53.645Z DEBUG modem << [00:03:41.887,329] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:09:53.680Z DEBUG modem << [00:03:41.896,667] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:09:53.683Z DEBUG modem << [00:03:41.905,731] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:09:53.686Z DEBUG modem << [00:03:41.915,069] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:09:53.688Z DEBUG modem << [00:03:41.924,346] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:09:53.691Z DEBUG modem << [00:03:41.933,715] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:09:53.810Z DEBUG modem << Encoded message:
2022-07-25T05:09:53.814Z DEBUG modem << {
2022-07-25T05:09:53.818Z DEBUG modem << "dev":{
2022-07-25T05:09:53.821Z DEBUG modem << "v":{
2022-07-25T05:09:53.849Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:09:53.853Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:09:53.856Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:09:53.860Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:09:53.862Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:09:53.864Z DEBUG modem << },
2022-07-25T05:09:53.866Z DEBUG modem << "ts":1658725792180
2022-07-25T05:09:53.868Z DEBUG modem << },
2022-07-25T05:09:53.871Z DEBUG modem << "env":{
2022-07-25T05:09:53.874Z DEBUG modem << "v":{
2022-07-25T05:09:53.876Z DEBUG modem << "temp":26.595340728759766,
2022-07-25T05:09:53.878Z DEBUG modem << "hum":41.924732208251953,
2022-07-25T05:09:53.880Z DEBUG modem << "atmp":97.063999999999993,
2022-07-25T05:09:53.882Z DEBUG modem << "bsec_iaq":137
2022-07-25T05:09:53.884Z DEBUG modem << },
2022-07-25T05:09:53.885Z DEBUG modem << "ts":1658725792060
2022-07-25T05:09:53.889Z DEBUG modem << },
2022-07-25T05:09:53.892Z DEBUG modem << "acc":{
2022-07-25T05:09:53.895Z DEBUG modem << "v":{
2022-07-25T05:09:53.897Z DEBUG modem << "x":26.595340728759766,
2022-07-25T05:09:53.899Z DEBUG modem << "y":41.924732208251953,
2022-07-25T05:09:53.901Z DEBUG modem << "z":97.063999999999993
2022-07-25T05:09:53.903Z DEBUG modem << },
2022-07-25T05:09:53.905Z DEBUG modem << "ts":1658725792060
2022-07-25T05:09:53.908Z DEBUG modem << }
2022-07-25T05:09:53.909Z DEBUG modem << }
2022-07-25T05:09:53.911Z DEBUG modem << [00:03:41.998,718] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:09:53.913Z DEBUG modem << [00:03:42.006,195] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20026480[0m
2022-07-25T05:09:53.915Z DEBUG modem << [00:03:42.015,014] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:09:53.918Z DEBUG modem << [00:03:42.023,284] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:09:53.920Z DEBUG modem << [00:03:42.030,242] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:09:53.922Z DEBUG modem << [00:03:42.039,733] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:53.924Z DEBUG modem << [00:03:42.046,173] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:09:53.926Z DEBUG modem << [00:03:42.056,304] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:09:53.928Z DEBUG modem << [00:03:42.066,680] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:09:53.930Z DEBUG modem << [00:03:42.077,239] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:09:53.932Z DEBUG modem << [00:03:42.087,371] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:09:53.934Z DEBUG modem << [00:03:42.097,564] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:09:53.974Z DEBUG modem << [00:03:42.107,879] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:09:53.977Z DEBUG modem << [00:03:42.118,286] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:09:53.980Z DEBUG modem << [00:03:42.128,356] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:09:53.982Z DEBUG modem << [00:03:42.138,671] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:09:53.985Z DEBUG modem << Tx: 13
2022-07-25T05:09:53.987Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:09:53.989Z DEBUG modem << [00:03:42.156,433] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20026480[0m
2022-07-25T05:09:53.991Z DEBUG modem << [00:03:42.164,703] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:09:53.993Z DEBUG modem << [00:03:42.173,522] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20026480[0m
2022-07-25T05:09:54.410Z DEBUG modem << %CESQ: 56,2,22,3
2022-07-25T05:09:54.447Z DEBUG modem << [00:03:42.698,852] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -84[0m
2022-07-25T05:09:54.476Z DEBUG modem << +CSCON: 1
2022-07-25T05:09:54.480Z DEBUG modem << [00:03:42.734,558] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:09:55.786Z DEBUG modem << [00:03:44.073,120] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:09:55.900Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:55.904Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:09:55.932Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:55.936Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:55.940Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.942Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.944Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.947Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.949Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.950Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.953Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.954Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.957Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.959Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.961Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.963Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:55.965Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:57.904Z DEBUG modem << Tx: 13
2022-07-25T05:09:57.908Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:09:57.977Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:09:57.982Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:09:57.986Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:09:57.989Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:09:57.992Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:09:58.019Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:09:58.023Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:09:58.026Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:09:58.030Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:09:58.033Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:09:58.035Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:09:58.038Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:09:58.040Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:09:58.747Z DEBUG modem << [00:03:47.039,886] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:09:59.482Z DEBUG modem << %CESQ: 57,2,17,2
2022-07-25T05:09:59.491Z DEBUG modem << [00:03:47.769,927] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -83[0m
2022-07-25T05:09:59.949Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:09:59.981Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:09:59.985Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:09:59.988Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:09:59.990Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:59.992Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:59.994Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:59.996Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:09:59.997Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:00.001Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:00.004Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:00.006Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:00.008Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:00.010Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:00.013Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:00.019Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:00.022Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:01.463Z DEBUG modem << +CSCON: 0
2022-07-25T05:10:01.467Z DEBUG modem << [00:03:49.755,065] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:10:01.953Z DEBUG modem << Tx: 13
2022-07-25T05:10:01.957Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:10:02.024Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:02.028Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:02.032Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:02.035Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:02.039Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:02.068Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:02.072Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:02.074Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:02.077Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:02.079Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:02.081Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:02.083Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:02.085Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:02.112Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:02.115Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:02.118Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:02.120Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:02.122Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:02.124Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:02.126Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:02.128Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:02.130Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:02.132Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:02.134Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:02.136Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:02.138Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:02.165Z DEBUG modem << %CESQ: 46,2,13,1
2022-07-25T05:10:02.172Z DEBUG modem << [00:03:50.385,253] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status meCapture 1 data bytes:
2022-07-25T05:10:02.174Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:02.177Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:02.179Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:02.181Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:02.183Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:02.185Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:02.188Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:02.190Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:02.192Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:02.194Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:02.196Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:02.198Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:02.200Z DEBUG modem << ssage, RSRP value is -94[0m
2022-07-25T05:10:03.747Z DEBUG modem << [00:03:52.039,978] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:10:03.958Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:04.000Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:10:04.003Z DEBUG modem << a5,1,95,8,2,e,d7,e,cf,e,d4,0,e9,
2022-07-25T05:10:04.033Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:04.036Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.039Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.042Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.044Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.046Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.049Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.051Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.053Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.055Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.057Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.059Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.061Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:04.063Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:06.003Z DEBUG modem << Tx: 13
2022-07-25T05:10:06.009Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:10:06.066Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:06.069Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:06.100Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:06.102Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:06.105Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:06.107Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:06.110Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:06.112Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:06.115Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:06.117Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:06.119Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:06.121Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:06.123Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:06.152Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:06.154Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:06.157Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:06.159Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:06.162Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:06.165Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:06.167Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:06.169Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:06.171Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:06.174Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:06.176Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:06.178Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:06.180Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:08.051Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:08.055Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:10:08.059Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:08.060Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:08.062Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.065Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.067Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.069Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.070Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.072Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.074Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.076Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.078Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.080Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.082Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.084Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:08.086Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:10.054Z DEBUG modem << Tx: 13
2022-07-25T05:10:10.058Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:10:10.109Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:10.112Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:10.140Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:10.144Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:10.146Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:10.149Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:10.151Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:10.153Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:10.156Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:10.158Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:10.160Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:10.162Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:10.164Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:11.990Z DEBUG modem << [00:04:00.282,348] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:10:12.102Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:10:12.106Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:10:12.140Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:12.144Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:12.147Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.149Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.151Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.153Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.156Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.158Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.160Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.162Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.164Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.166Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.168Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.170Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.173Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:12.468Z DEBUG modem << [00:04:00.642,425] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:10:12.472Z DEBUG modem << [00:04:00.650,787] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:12.501Z DEBUG modem << [00:04:00.657,745] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:10:12.506Z DEBUG modem << [00:04:00.667,205] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:10:12.509Z DEBUG modem << [00:04:00.673,797] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:10:12.511Z DEBUG modem << [00:04:00.682,006] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:10:12.513Z DEBUG modem << [00:04:00.690,032] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:10:12.516Z DEBUG modem << [00:04:00.698,516] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:10:12.518Z DEBUG modem << [00:04:00.706,176] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:10:12.520Z DEBUG modem << [00:04:00.712,738] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:10:12.522Z DEBUG modem << [00:04:00.719,604] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:10:12.524Z DEBUG modem << [00:04:00.731,414] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:10:12.526Z DEBUG modem << [00:04:00.739,288] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:10:12.529Z DEBUG modem << [00:04:00.752,868] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:12.531Z DEBUG modem << [00:04:00.759,826] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:10:12.568Z DEBUG modem << [00:04:00.769,226] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:10:12.572Z DEBUG modem << [00:04:00.776,336] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:10:12.575Z DEBUG modem << [00:04:00.785,705] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:10:12.580Z DEBUG modem << [00:04:00.795,379] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:10:12.583Z DEBUG modem << [00:04:00.805,419] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:10:12.585Z DEBUG modem << [00:04:00.814,544] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 3 of 9 in sensor buffer filled[0m
2022-07-25T05:10:12.588Z DEBUG modem << [00:04:00.826,019] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:12.590Z DEBUG modem << [00:04:00.835,815] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:10:12.592Z DEBUG modem << [00:04:00.847,412] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:12.626Z DEBUG modem << [00:04:00.904,052] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:10:12.657Z DEBUG modem << [00:04:00.914,276] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:12.716Z DEBUG modem << [00:04:00.983,612] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:10:12.752Z DEBUG modem << [00:04:00.993,896] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 0 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:10:12.756Z DEBUG modem << [00:04:01.006,591] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:13.554Z DEBUG modem << [00:04:01.814,605] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:10:13.591Z DEBUG modem << [00:04:01.822,937] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:13.595Z DEBUG modem << [00:04:01.829,895] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:10:13.597Z DEBUG modem << [00:04:01.839,477] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:10:13.642Z DEBUG modem << [00:04:01.850,341] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:10:13.647Z DEBUG modem << [00:04:01.859,466] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:10:13.650Z DEBUG modem << [00:04:01.868,530] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:10:13.652Z DEBUG modem << [00:04:01.877,960] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:10:13.654Z DEBUG modem << [00:04:01.887,451] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:10:13.656Z DEBUG modem << [00:04:01.896,759] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:10:13.658Z DEBUG modem << [00:04:01.905,822] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:10:13.661Z DEBUG modem << [00:04:01.915,161] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:10:13.694Z DEBUG modem << [00:04:01.924,407] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:10:13.700Z DEBUG modem << [00:04:01.933,807] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:10:13.743Z DEBUG modem << Encoded message:
2022-07-25T05:10:13.747Z DEBUG modem << {
2022-07-25T05:10:13.751Z DEBUG modem << "dev":{
2022-07-25T05:10:13.755Z DEBUG modem << "v":{
2022-07-25T05:10:13.784Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:10:13.787Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:10:13.790Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:10:13.793Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:10:13.795Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:10:13.797Z DEBUG modem << },
2022-07-25T05:10:13.800Z DEBUG modem << "ts":1658725812167
2022-07-25T05:10:13.802Z DEBUG modem << },
2022-07-25T05:10:13.805Z DEBUG modem << "roam":{
2022-07-25T05:10:13.807Z DEBUG modem << "v":{
2022-07-25T05:10:13.810Z DEBUG modem << "rsrp":-94
2022-07-25T05:10:13.812Z DEBUG modem << },
2022-07-25T05:10:13.814Z DEBUG modem << "ts":1658725812247
2022-07-25T05:10:13.816Z DEBUG modem << },
2022-07-25T05:10:13.819Z DEBUG modem << "env":{
2022-07-25T05:10:13.822Z DEBUG modem << "v":{
2022-07-25T05:10:13.824Z DEBUG modem << "temp":26.675308227539062,
2022-07-25T05:10:13.826Z DEBUG modem << "hum":41.900608062744141,
2022-07-25T05:10:13.828Z DEBUG modem << "atmp":97.066000000000003,
2022-07-25T05:10:13.830Z DEBUG modem << "bsec_iaq":146
2022-07-25T05:10:13.832Z DEBUG modem << },
2022-07-25T05:10:13.834Z DEBUG modem << "ts":1658725812060
2022-07-25T05:10:13.836Z DEBUG modem << },
2022-07-25T05:10:13.838Z DEBUG modem << "acc":{
2022-07-25T05:10:13.840Z DEBUG modem << "v":{
2022-07-25T05:10:13.842Z DEBUG modem << "x":26.675308227539062,
2022-07-25T05:10:13.844Z DEBUG modem << "y":41.900608062744141,
2022-07-25T05:10:13.847Z DEBUG modem << "z":97.066000000000003
2022-07-25T05:10:13.848Z DEBUG modem << },
2022-07-25T05:10:13.852Z DEBUG modem << "ts":1658725812059
2022-07-25T05:10:13.854Z DEBUG modem << }
2022-07-25T05:10:13.856Z DEBUG modem << }
2022-07-25T05:10:13.858Z DEBUG modem << [00:04:02.006,530] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:10:13.860Z DEBUG modem << [00:04:02.014,038] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20026580[0m
2022-07-25T05:10:13.864Z DEBUG modem << [00:04:02.022,857] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:10:13.868Z DEBUG modem << [00:04:02.031,127] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:13.904Z DEBUG modem << [00:04:02.038,085] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:10:13.907Z DEBUG modem << [00:04:02.047,576] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:10:13.909Z DEBUG modem << [00:04:02.054,016] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:10:13.912Z DEBUG modem << [00:04:02.064,147] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:10:13.914Z DEBUG modem << [00:04:02.074,554] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:10:13.919Z DEBUG modem << [00:04:02.085,083] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:10:13.921Z DEBUG modem << [00:04:02.095,214] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:10:13.924Z DEBUG modem << [00:04:02.105,407] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:10:13.926Z DEBUG modem << [00:04:02.115,722] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:10:13.928Z DEBUG modem << [00:04:02.126,129] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:10:13.931Z DEBUG modem << [00:04:02.136,199] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:10:13.933Z DEBUG modem << [00:04:02.146,514] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:10:13.973Z DEBUG modem << [00:04:02.164,367] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20026580[0m
2022-07-25T05:10:13.975Z DEBUG modem << [00:04:02.172,637] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:10:13.978Z DEBUG modem << [00:04:02.181,427] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20026580[0m
2022-07-25T05:10:14.051Z DEBUG modem << +CSCON: 1
2022-07-25T05:10:14.055Z DEBUG modem << [00:04:02.330,810] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:10:14.058Z DEBUG modem << %CESQ: 55,2,17,2
2022-07-25T05:10:14.094Z DEBUG modem << [00:04:02.339,843] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -85[0m
2022-07-25T05:10:14.126Z DEBUG modem << Tx: 13
2022-07-25T05:10:14.129Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:10:15.367Z DEBUG modem << [00:04:03.656,433] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:10:16.113Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:10:16.116Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:10:16.292Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:16.296Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:16.329Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.331Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.334Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.337Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.339Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.341Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.343Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.346Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.348Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.350Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.352Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.354Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.356Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:16.358Z DEBUG modem << [00:04:04.451,538] [1;33m<wrn> bms_module: on line 327 0.0000,0.0000,0,0,0.2050,0,0,0 [0m
2022-07-25T05:10:16.360Z DEBUG modem << [00:04:04.459,655] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:10:16.363Z DEBUG modem << [00:04:04.468,139] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:10:16.366Z DEBUG modem << [00:04:04.479,278] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:10:16.368Z DEBUG modem << [00:04:04.486,694] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:16.370Z DEBUG modem << [00:04:04.493,774] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:10:16.372Z DEBUG modem << [00:04:04.500,793] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:10:16.374Z DEBUG modem << [00:04:04.507,751] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:10:16.376Z DEBUG modem << [00:04:04.514,801] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:10:16.378Z DEBUG modem << [00:04:04.521,820] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:10:16.380Z DEBUG modem << [00:04:04.528,900] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:10:16.382Z DEBUG modem << [00:04:04.535,858] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:10:16.416Z DEBUG modem << [00:04:04.543,029] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:10:16.419Z DEBUG modem << [00:04:04.549,957] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:10:16.422Z DEBUG modem << Tx: 13
2022-07-25T05:10:16.425Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:10:16.427Z DEBUG modem << [00:04:04.562,408] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:10:16.429Z DEBUG modem << [00:04:04.571,960] [1;33m<wrn> cloud_codec_ringbuffer: On line 33 in ringbuffer[0m
2022-07-25T05:10:16.431Z DEBUG modem << [00:04:04.579,467] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 0 of 2 in bms buffer filled[0m
2022-07-25T05:10:16.464Z DEBUG modem << [00:04:04.590,393] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:10:16.467Z DEBUG modem << [00:04:04.598,724] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:10:16.470Z DEBUG modem << [00:04:04.607,025] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:16.472Z DEBUG modem << [00:04:04.613,952] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:10:16.475Z DEBUG modem << [00:04:04.623,443] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:16.477Z DEBUG modem << [00:04:04.633,148] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:10:16.479Z DEBUG modem << [00:04:04.642,517] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:10:16.482Z DEBUG modem << [00:04:04.653,411] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:10:16.484Z DEBUG modem << [00:04:04.662,536] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:10:16.487Z DEBUG modem << [00:04:04.671,600] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:10:16.489Z DEBUG modem << [00:04:04.680,541] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:10:16.493Z DEBUG modem << [00:04:04.689,849] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:10:16.495Z DEBUG modem << [00:04:04.699,188] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:10:16.535Z DEBUG modem << [00:04:04.709,533] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:10:16.538Z DEBUG modem << [00:04:04.718,444] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:10:16.541Z DEBUG modem << [00:04:04.727,416] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:10:16.543Z DEBUG modem << [00:04:04.736,816] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:10:16.545Z DEBUG modem << Encoded message:
2022-07-25T05:10:16.548Z DEBUG modem << {
2022-07-25T05:10:16.550Z DEBUG modem << "bms_device":{
2022-07-25T05:10:16.552Z DEBUG modem << "bms_id":3902,
2022-07-25T05:10:16.555Z DEBUG modem << "bms_pack_voltage":26,
2022-07-25T05:10:16.557Z DEBUG modem << "bms_state_of_charge":99,
2022-07-25T05:10:16.559Z DEBUG modem << "lowest_cell_voltage":0,
2022-07-25T05:10:16.561Z DEBUG modem << "lowest_voltage_cell_no":0,
2022-07-25T05:10:16.564Z DEBUG modem << "highest_cell_voltage":0,
2022-07-25T05:10:16.566Z DEBUG modem << "highest_voltage_cell_no":0,
2022-07-25T05:10:16.568Z DEBUG modem << "highest_battery_temp":0,
2022-07-25T05:10:16.570Z DEBUG modem << "highest_temp_cell_no":0,
2022-07-25T05:10:16.657Z DEBUG modem << "lowest_battery_temp":0,
2022-07-25T05:10:16.661Z DEBUG modem << "lowest_temp_cell_no":0,
2022-07-25T05:10:16.665Z DEBUG modem << "bms_pack_ampere":0,
2022-07-25T05:10:16.697Z DEBUG modem << "bms_life":81,
2022-07-25T05:10:16.700Z DEBUG modem << "total_cells":7,
2022-07-25T05:10:16.702Z DEBUG modem << "total_temp_sensors":1,
2022-07-25T05:10:16.705Z DEBUG modem << "charger_status":0,
2022-07-25T05:10:16.709Z DEBUG modem << "load_status":0,
2022-07-25T05:10:16.712Z DEBUG modem << "average_voltage":0.20499999999999999,
2022-07-25T05:10:16.715Z DEBUG modem << "device_state":1,
2022-07-25T05:10:16.719Z DEBUG modem << "average_temp":0,
2022-07-25T05:10:16.721Z DEBUG modem << "cell_balance_state":0,
2022-07-25T05:10:16.723Z DEBUG modem << "fault_code":0,
2022-07-25T05:10:16.726Z DEBUG modem << "ts":1658725815723
2022-07-25T05:10:16.728Z DEBUG modem << }
2022-07-25T05:10:16.730Z DEBUG modem << }
2022-07-25T05:10:16.732Z DEBUG modem << [00:04:04.807,342] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:10:16.734Z DEBUG modem << [00:04:04.814,788] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20026b40[0m
2022-07-25T05:10:16.736Z DEBUG modem << [00:04:04.823,577] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:10:16.738Z DEBUG modem << [00:04:04.831,817] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:16.740Z DEBUG modem << [00:04:04.838,745] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:10:16.743Z DEBUG modem << [00:04:04.848,724] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:10:16.745Z DEBUG modem << [00:04:04.858,825] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:10:16.747Z DEBUG modem << [00:04:04.869,201] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:10:16.749Z DEBUG modem << [00:04:04.879,547] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:10:16.751Z DEBUG modem << [00:04:04.889,648] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:10:16.753Z DEBUG modem << [00:04:04.899,658] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:10:16.755Z DEBUG modem << [00:04:04.909,942] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:10:16.757Z DEBUG modem << [00:04:04.920,410] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:10:16.759Z DEBUG modem << [00:04:04.930,358] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:10:16.761Z DEBUG modem << [00:04:04.940,704] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:10:16.803Z DEBUG modem << [00:04:04.951,354] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20026b40[0m
2022-07-25T05:10:16.806Z DEBUG modem << [00:04:04.959,625] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:10:16.809Z DEBUG modem << [00:04:04.968,444] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20026b40[0m
2022-07-25T05:10:17.864Z DEBUG modem << [00:04:06.152,435] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:10:18.309Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:10:18.313Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:10:18.317Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:18.320Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:18.323Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.325Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.327Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.329Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.331Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.333Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.335Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.338Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.340Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.342Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.344Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.348Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:18.352Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:20.312Z DEBUG modem << Tx: 13
2022-07-25T05:10:20.316Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:10:20.358Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:20.362Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:20.395Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:20.400Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:20.404Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:20.406Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:20.408Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:20.410Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:20.412Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:20.414Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:20.417Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:20.419Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:20.421Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:21.554Z DEBUG modem << [00:04:09.848,297] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:10:22.359Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:10:22.393Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:10:22.396Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:22.399Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:22.402Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.404Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.407Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.409Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.411Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.413Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.416Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.418Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.420Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.422Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.425Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.427Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:22.429Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:23.455Z DEBUG modem << +CSCON: 0
2022-07-25T05:10:23.459Z DEBUG modem << [00:04:11.748,535] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:10:23.498Z DEBUG modem << %CESQ: 56,2,22,3
2022-07-25T05:10:23.504Z DEBUG modem << [00:04:11.776,550] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -84[0m
2022-07-25T05:10:23.855Z DEBUG modem << %CESQ: 50,2,20,2
2022-07-25T05:10:23.892Z DEBUG modem << [00:04:12.145,843] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -90[0m
2022-07-25T05:10:24.363Z DEBUG modem << Tx: 13
2022-07-25T05:10:24.368Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:10:26.409Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:10:26.442Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:10:26.445Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:26.448Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:26.452Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.454Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.457Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.459Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.462Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.464Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.466Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.469Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.471Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.473Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.475Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.478Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.483Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:26.553Z DEBUG modem << [00:04:14.848,388] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:10:27.696Z DEBUG modem << %CESQ: 47,2,14,2
2022-07-25T05:10:27.704Z DEBUG modem << [00:04:15.986,053] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:10:28.412Z DEBUG modem << Tx: 13
2022-07-25T05:10:28.416Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:10:30.460Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:10:30.465Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:10:30.470Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:30.472Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:30.503Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.506Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.510Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.513Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.516Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.519Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.521Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.523Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.526Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.528Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.531Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.533Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:30.536Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:32.388Z DEBUG modem << [00:04:20.642,456] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:10:32.421Z DEBUG modem << [00:04:20.650,817] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:32.424Z DEBUG modem << [00:04:20.657,775] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:10:32.428Z DEBUG modem << [00:04:20.667,205] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:10:32.432Z DEBUG modem << [00:04:20.673,797] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:10:32.434Z DEBUG modem << [00:04:20.682,006] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:10:32.559Z DEBUG modem << [00:04:20.690,032] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:10:32.592Z DEBUG modem << [00:04:20.698,516] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:10:32.596Z DEBUG modem << [00:04:20.706,176] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:10:32.599Z DEBUG modem << [00:04:20.712,707] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:10:32.602Z DEBUG modem << [00:04:20.719,604] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:10:32.604Z DEBUG modem << [00:04:20.731,414] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:10:32.606Z DEBUG modem << [00:04:20.739,288] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:10:32.608Z DEBUG modem << [00:04:20.752,899] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:32.611Z DEBUG modem << [00:04:20.759,857] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:10:32.613Z DEBUG modem << [00:04:20.769,256] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:10:32.615Z DEBUG modem << [00:04:20.776,367] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:10:32.655Z DEBUG modem << [00:04:20.785,736] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:10:32.658Z DEBUG modem << [00:04:20.795,471] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:10:32.661Z DEBUG modem << [00:04:20.805,511] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:10:32.664Z DEBUG modem << [00:04:20.814,636] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 4 of 9 in sensor buffer filled[0m
2022-07-25T05:10:32.668Z DEBUG modem << [00:04:20.826,141] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:32.671Z DEBUG modem << [00:04:20.835,937] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:10:32.674Z DEBUG modem << [00:04:20.847,534] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:32.676Z DEBUG modem << Tx: 13
2022-07-25T05:10:32.678Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:10:32.680Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:32.682Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:32.684Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:32.686Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:32.719Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:32.723Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:32.725Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:32.728Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:32.730Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:32.732Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:32.735Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:32.737Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:32.739Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:32.741Z DEBUG modem << [00:04:20.935,913] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:10:32.743Z DEBUG modem << [00:04:20.946,166] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:32.775Z DEBUG modem << [00:04:21.014,709] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:10:32.778Z DEBUG modem << [00:04:21.025,024] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 1 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:10:32.781Z DEBUG modem << [00:04:21.037,689] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:33.624Z DEBUG modem << [00:04:21.814,697] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:10:33.660Z DEBUG modem << [00:04:21.823,028] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:33.664Z DEBUG modem << [00:04:21.829,986] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:10:33.666Z DEBUG modem << [00:04:21.839,569] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:10:33.669Z DEBUG modem << [00:04:21.850,463] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:10:33.671Z DEBUG modem << [00:04:21.859,619] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:10:33.673Z DEBUG modem << [00:04:21.868,743] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:10:33.676Z DEBUG modem << [00:04:21.878,234] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:10:33.678Z DEBUG modem << [00:04:21.887,756] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:10:33.680Z DEBUG modem << [00:04:21.897,064] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:10:33.715Z DEBUG modem << [00:04:21.906,158] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:10:33.718Z DEBUG modem << [00:04:21.915,527] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:10:33.721Z DEBUG modem << [00:04:21.924,804] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:10:33.724Z DEBUG modem << [00:04:21.934,173] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:10:33.814Z DEBUG modem << Encoded message:
2022-07-25T05:10:33.818Z DEBUG modem << {
2022-07-25T05:10:33.821Z DEBUG modem << "dev":{
2022-07-25T05:10:33.823Z DEBUG modem << "v":{
2022-07-25T05:10:33.825Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:10:33.827Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:10:33.862Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:10:33.865Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:10:33.868Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:10:33.871Z DEBUG modem << },
2022-07-25T05:10:33.873Z DEBUG modem << "ts":1658725832200
2022-07-25T05:10:33.876Z DEBUG modem << },
2022-07-25T05:10:33.878Z DEBUG modem << "roam":{
2022-07-25T05:10:33.880Z DEBUG modem << "v":{
2022-07-25T05:10:33.883Z DEBUG modem << "rsrp":-93
2022-07-25T05:10:33.885Z DEBUG modem << },
2022-07-25T05:10:33.887Z DEBUG modem << "ts":1658725832278
2022-07-25T05:10:33.890Z DEBUG modem << },
2022-07-25T05:10:33.892Z DEBUG modem << "env":{
2022-07-25T05:10:33.894Z DEBUG modem << "v":{
2022-07-25T05:10:33.897Z DEBUG modem << "temp":26.695306777954102,
2022-07-25T05:10:33.899Z DEBUG modem << "hum":42.198322296142578,
2022-07-25T05:10:33.902Z DEBUG modem << "atmp":97.067999999999998,
2022-07-25T05:10:33.904Z DEBUG modem << "bsec_iaq":159
2022-07-25T05:10:33.906Z DEBUG modem << },
2022-07-25T05:10:33.909Z DEBUG modem << "ts":1658725832059
2022-07-25T05:10:33.911Z DEBUG modem << },
2022-07-25T05:10:33.913Z DEBUG modem << "acc":{
2022-07-25T05:10:33.916Z DEBUG modem << "v":{
2022-07-25T05:10:33.919Z DEBUG modem << "x":26.695306777954102,
2022-07-25T05:10:33.921Z DEBUG modem << "y":42.198322296142578,
2022-07-25T05:10:33.924Z DEBUG modem << "z":97.067999999999998
2022-07-25T05:10:33.926Z DEBUG modem << },
2022-07-25T05:10:33.928Z DEBUG modem << "ts":1658725832059
2022-07-25T05:10:33.930Z DEBUG modem << }
2022-07-25T05:10:33.932Z DEBUG modem << }
2022-07-25T05:10:33.934Z DEBUG modem << [00:04:22.008,056] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:10:33.937Z DEBUG modem << [00:04:22.015,533] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20026af0[0m
2022-07-25T05:10:33.939Z DEBUG modem << [00:04:22.024,383] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:10:33.941Z DEBUG modem << [00:04:22.032,653] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:33.943Z DEBUG modem << [00:04:22.039,611] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:10:33.946Z DEBUG modem << [00:04:22.049,133] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:10:33.948Z DEBUG modem << [00:04:22.055,541] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:10:33.950Z DEBUG modem << [00:04:22.065,704] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:10:33.952Z DEBUG modem << [00:04:22.076,080] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:10:33.954Z DEBUG modem << [00:04:22.086,608] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:10:33.956Z DEBUG modem << [00:04:22.096,740] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:10:33.994Z DEBUG modem << [00:04:22.106,933] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:10:33.998Z DEBUG modem << [00:04:22.117,279] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:10:34.000Z DEBUG modem << [00:04:22.127,655] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:10:34.003Z DEBUG modem << [00:04:22.137,756] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:10:34.005Z DEBUG modem << [00:04:22.148,071] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:10:34.008Z DEBUG modem << [00:04:22.168,090] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20026af0[0m
2022-07-25T05:10:34.010Z DEBUG modem << [00:04:22.176,452] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:10:34.012Z DEBUG modem << [00:04:22.185,424] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20026af0[0m
2022-07-25T05:10:34.050Z DEBUG modem << +CSCON: 1
2022-07-25T05:10:34.054Z DEBUG modem << [00:04:22.331,237] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:10:34.057Z DEBUG modem << %CESQ: 55,2,17,2
2022-07-25T05:10:34.064Z DEBUG modem << [00:04:22.340,301] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -85[0m
2022-07-25T05:10:34.606Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:10:34.611Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:10:34.615Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:34.617Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:34.620Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.622Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.624Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.626Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.629Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.631Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.634Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.637Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.640Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.643Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.645Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.648Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:34.650Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:35.395Z DEBUG modem << [00:04:23.685,119] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:10:36.609Z DEBUG modem << Tx: 13
2022-07-25T05:10:36.613Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:10:36.664Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:36.669Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:36.707Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:36.710Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:36.713Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:36.716Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:36.718Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:36.720Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:36.723Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:36.725Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:36.728Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:36.730Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:36.733Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:36.891Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:36.923Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:36.951Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:36.979Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:37.004Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:37.027Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:37.056Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:37.084Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:37.111Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:37.136Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:37.161Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:37.186Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:37.211Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:37.237Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:37.252Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:37.259Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:37.266Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:37.273Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:37.281Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:37.288Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:37.296Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:37.303Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:37.313Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:37.320Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:37.327Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:37.334Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:38.656Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:38.846Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:10:38.856Z DEBUG modem << a5,1,95,8,2,e,d6,e,cf,e,d4,0,e8,
2022-07-25T05:10:38.862Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:38.868Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.875Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.880Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.886Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.892Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.898Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.904Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.911Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.917Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.923Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.929Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.935Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:38.941Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:39.447Z DEBUG modem << [00:04:27.049,255] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:10:40.662Z DEBUG modem << Tx: 13
2022-07-25T05:10:40.674Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:10:40.929Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:40.940Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:40.949Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:40.958Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:40.967Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:40.976Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:40.989Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:40.998Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:41.007Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:41.016Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:41.025Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:41.034Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:41.048Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:41.054Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:41.060Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:41.065Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:41.071Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:41.076Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:41.082Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:41.087Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:41.093Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:41.098Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:41.104Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:41.110Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:10:41.115Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:10:41.121Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:10:41.852Z DEBUG modem << +CSCON: 0
2022-07-25T05:10:41.859Z DEBUG modem << [00:04:29.262,939] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:10:42.144Z DEBUG modem << %CESQ: 47,2,15,2
2022-07-25T05:10:42.166Z DEBUG modem << [00:04:30.066,528] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:10:42.468Z DEBUG modem << [00:04:30.289,550] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:10:42.746Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:42.753Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:10:42.759Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:42.765Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:42.775Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.781Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.786Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.797Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.803Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.809Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.814Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.819Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.825Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.830Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.836Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.843Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:42.849Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:43.753Z DEBUG modem << [00:04:32.049,346] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:10:44.712Z DEBUG modem << Tx: 13
2022-07-25T05:10:44.722Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:10:45.069Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:45.077Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:45.083Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:45.089Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:10:45.095Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:10:45.101Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:10:45.107Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:10:45.113Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:10:45.118Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:10:45.124Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:10:45.130Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:10:45.136Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:10:45.141Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:10:46.760Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:47.113Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:10:47.122Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:47.129Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:47.136Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.142Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.149Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.156Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.162Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.168Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.178Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.185Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.191Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.197Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.203Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.209Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:47.216Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:48.762Z DEBUG modem << Tx: 13
2022-07-25T05:10:48.771Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:10:50.794Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:50.803Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:10:50.811Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:50.818Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:50.826Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:50.834Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.301Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.310Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.320Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.327Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.793Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.802Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.809Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.817Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.824Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.831Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.839Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:51.846Z DEBUG modem << [00:04:39.113,433] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2050,0,0,0 [0m
2022-07-25T05:10:51.853Z DEBUG modem << [00:04:39.121,826] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:10:51.861Z DEBUG modem << [00:04:39.130,249] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:10:51.868Z DEBUG modem << [00:04:39.141,448] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:10:51.875Z DEBUG modem << [00:04:39.148,895] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:51.883Z DEBUG modem << [00:04:39.155,914] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:10:51.893Z DEBUG modem << [00:04:39.162,963] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:10:51.901Z DEBUG modem << [00:04:39.169,952] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:10:51.908Z DEBUG modem << [00:04:39.177,032] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:10:51.915Z DEBUG modem << [00:04:39.184,020] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:10:51.922Z DEBUG modem << [00:04:39.191,101] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:10:51.929Z DEBUG modem << [00:04:39.198,059] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:10:51.936Z DEBUG modem << [00:04:39.205,169] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:10:51.943Z DEBUG modem << [00:04:39.212,127] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:10:51.950Z DEBUG modem << [00:04:39.219,207] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:10:51.957Z DEBUG modem << [00:04:39.226,196] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:10:51.964Z DEBUG modem << [00:04:39.233,306] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:10:51.971Z DEBUG modem << [00:04:39.240,264] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:10:51.981Z DEBUG modem << Tx: 13
2022-07-25T05:10:51.991Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:10:51.998Z DEBUG modem << [00:04:39.252,807] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:10:52.005Z DEBUG modem << [00:04:39.262,237] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 1 of 2 in bms buffer filled[0m
2022-07-25T05:10:52.012Z DEBUG modem << [00:04:39.273,223] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:10:52.019Z DEBUG modem << [00:04:39.281,555] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:10:52.026Z DEBUG modem << [00:04:39.289,886] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:52.033Z DEBUG modem << [00:04:39.296,844] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:10:52.044Z DEBUG modem << [00:04:39.306,365] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:52.055Z DEBUG modem << [00:04:39.316,101] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:10:52.065Z DEBUG modem << [00:04:39.325,531] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:10:52.074Z DEBUG modem << [00:04:39.336,425] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:10:52.088Z DEBUG modem << [00:04:39.345,581] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:10:52.097Z DEBUG modem << [00:04:39.354,675] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:10:52.106Z DEBUG modem << [00:04:39.363,647] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:10:52.115Z DEBUG modem << [00:04:39.372,985] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:10:52.125Z DEBUG modem << [00:04:39.382,324] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:10:52.134Z DEBUG modem << [00:04:39.392,700] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:10:52.144Z DEBUG modem << [00:04:39.401,672] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:10:52.154Z DEBUG modem << [00:04:39.410,644] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:10:52.163Z DEBUG modem << [00:04:39.420,074] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:10:52.172Z DEBUG modem << Encoded message:
2022-07-25T05:10:52.181Z DEBUG modem << {
2022-07-25T05:10:52.190Z DEBUG modem << "bms_device":{
2022-07-25T05:10:52.203Z DEBUG modem << "bms_id":3902,
2022-07-25T05:10:52.213Z DEBUG modem << "bms_pack_voltage":26,
2022-07-25T05:10:52.222Z DEBUG modem << "bms_state_of_charge":99,
2022-07-25T05:10:52.231Z DEBUG modem << "lowest_cell_voltage":3.7690000000000001,
2022-07-25T05:10:52.240Z DEBUG modem << "lowest_voltage_cell_no":3,
2022-07-25T05:10:52.249Z DEBUG modem << "highest_cell_voltage":3.8090000000000002,
2022-07-25T05:10:52.259Z DEBUG modem << "highest_voltage_cell_no":2,
2022-07-25T05:10:52.268Z DEBUG modem << "highest_battery_temp":0,
2022-07-25T05:10:53.695Z DEBUG modem << "highest_temp_cell_no":0,
2022-07-25T05:10:53.725Z DEBUG modem << "lowest_battery_temp":0,
2022-07-25T05:10:53.734Z DEBUG modem << "lowest_temp_cell_no":0,
2022-07-25T05:10:53.740Z DEBUG modem << "bms_pack_ampere":0,
2022-07-25T05:10:53.746Z DEBUG modem << "bms_life":81,
2022-07-25T05:10:53.751Z DEBUG modem << "total_cells":7,
2022-07-25T05:10:53.757Z DEBUG modem << "total_temp_sensors":1,
2022-07-25T05:10:53.762Z DEBUG modem << "charger_status":0,
2022-07-25T05:10:53.768Z DEBUG modem << "load_status":0,
2022-07-25T05:10:53.773Z DEBUG modem << "average_voltage":0.20499999999999999,
2022-07-25T05:10:53.778Z DEBUG modem << "device_state":1,
2022-07-25T05:10:53.783Z DEBUG modem << "average_temp":0,
2022-07-25T05:10:53.788Z DEBUG modem << "cell_balance_state":0,
2022-07-25T05:10:53.793Z DEBUG modem << "fault_code":0,
2022-07-25T05:10:53.798Z DEBUG modem << "ts":1658725850385
2022-07-25T05:10:53.803Z DEBUG modem << }
2022-07-25T05:10:53.808Z DEBUG modem << }
2022-07-25T05:10:53.813Z DEBUG modem << [00:04:39.494,842] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:10:53.817Z DEBUG modem << [00:04:39.502,349] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20027110[0m
2022-07-25T05:10:53.822Z DEBUG modem << [00:04:39.511,169] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:10:53.831Z DEBUG modem << [00:04:39.519,439] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:53.836Z DEBUG modem << [00:04:39.526,397] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:10:53.841Z DEBUG modem << [00:04:39.535,888] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:10:53.846Z DEBUG modem << [00:04:39.542,785] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:10:53.851Z DEBUG modem << [00:04:39.552,917] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:10:53.856Z DEBUG modem << [00:04:39.563,262] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:10:53.860Z DEBUG modem << [00:04:39.573,760] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:10:53.865Z DEBUG modem << [00:04:39.583,862] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:10:53.870Z DEBUG modem << [00:04:39.594,024] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:10:53.875Z DEBUG modem << [00:04:39.604,339] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:10:53.880Z DEBUG modem << [00:04:39.614,837] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:10:53.885Z DEBUG modem << [00:04:39.624,847] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:10:53.894Z DEBUG modem << [00:04:39.635,162] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:10:53.899Z DEBUG modem << [00:04:39.645,904] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20027110[0m
2022-07-25T05:10:53.903Z DEBUG modem << [00:04:39.654,205] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:10:53.908Z DEBUG modem << [00:04:39.663,055] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20027110[0m
2022-07-25T05:10:53.913Z DEBUG modem << +CSCON: 1
2022-07-25T05:10:53.917Z DEBUG modem << [00:04:39.692,199] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:10:53.922Z DEBUG modem << %CESQ: 55,2,16,2
2022-07-25T05:10:54.092Z DEBUG modem << [00:04:39.701,293] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -85[0m
2022-07-25T05:10:54.935Z DEBUG modem << [00:04:40.642,486] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:10:54.941Z DEBUG modem << [00:04:40.650,848] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:54.947Z DEBUG modem << [00:04:40.657,775] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:10:54.952Z DEBUG modem << [00:04:40.667,205] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:10:54.957Z DEBUG modem << [00:04:40.673,797] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:10:54.962Z DEBUG modem << [00:04:40.681,976] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:10:54.971Z DEBUG modem << [00:04:40.689,971] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:10:54.976Z DEBUG modem << [00:04:40.698,425] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:10:54.980Z DEBUG modem << [00:04:40.706,085] [0m<dbg> main: data_get: Requested Data count = 5[0m
2022-07-25T05:10:54.985Z DEBUG modem << [00:04:40.712,615] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:10:54.990Z DEBUG modem << [00:04:40.719,451] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA[0m
2022-07-25T05:10:54.994Z DEBUG modem << [00:04:40.731,262] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:10:54.999Z DEBUG modem << [00:04:40.739,105] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:10:55.004Z DEBUG modem << [00:04:40.752,655] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:55.008Z DEBUG modem << [00:04:40.759,582] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:10:55.013Z DEBUG modem << [00:04:40.768,951] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:10:55.017Z DEBUG modem << [00:04:40.776,031] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:10:55.022Z DEBUG modem << [00:04:40.785,491] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:10:55.027Z DEBUG modem << [00:04:40.795,166] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:10:55.032Z DEBUG modem << [00:04:40.805,206] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:10:55.037Z DEBUG modem << [00:04:40.814,300] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 5 of 9 in sensor buffer filled[0m
2022-07-25T05:10:55.045Z DEBUG modem << [00:04:40.825,744] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:55.049Z DEBUG modem << [00:04:40.835,510] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:10:55.054Z DEBUG modem << [00:04:40.847,076] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:55.059Z DEBUG modem << [00:04:40.887,817] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:10:55.063Z DEBUG modem << [00:04:40.898,162] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:55.068Z DEBUG modem << [00:04:40.938,934] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:10:55.072Z DEBUG modem << [00:04:40.949,218] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 2 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:10:55.077Z DEBUG modem << [00:04:40.961,914] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:10:55.081Z DEBUG modem << [00:04:41.045,501] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:10:55.086Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:55.091Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:10:55.095Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:55.100Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:55.104Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.109Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.117Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.121Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.126Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.130Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.135Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.139Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.144Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.149Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.153Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.157Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.162Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:55.166Z DEBUG modem << [00:04:41.814,361] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_READY[0m
2022-07-25T05:10:55.171Z DEBUG modem << [00:04:41.822,692] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:55.175Z DEBUG modem << [00:04:41.829,620] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:10:56.197Z DEBUG modem << [00:04:41.839,263] [0m<dbg> cloud_codec: cloud_codec_encode_neighbor_cells: Entered cloud_codec_encode_neighbour_cells[0m
2022-07-25T05:10:56.209Z DEBUG modem << [00:04:41.850,128] [0m<dbg> data_module: data_encode: No neighbor cells data to encode, error: -61[0m
2022-07-25T05:10:56.218Z DEBUG modem << [00:04:41.859,283] [0m<dbg> cloud_codec: cloud_codec_encode_data: Entered cloud_codec_encode_data[0m
2022-07-25T05:10:56.226Z DEBUG modem << [00:04:41.868,499] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added btn data to encode_data[0m
2022-07-25T05:10:56.236Z DEBUG modem << [00:04:41.877,960] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_sta data to encode_data[0m
2022-07-25T05:10:56.244Z DEBUG modem << [00:04:41.887,634] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added mdm_dyn data to encode_data[0m
2022-07-25T05:10:56.250Z DEBUG modem << [00:04:41.896,911] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added gnss data to encode_data[0m
2022-07-25T05:10:56.257Z DEBUG modem << [00:04:41.905,975] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bms data to encode_data[0m
2022-07-25T05:10:56.263Z DEBUG modem << [00:04:41.915,466] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added env data to encode_data[0m
2022-07-25T05:10:56.269Z DEBUG modem << [00:04:41.924,713] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added movement data to encode_data[0m
2022-07-25T05:10:56.276Z DEBUG modem << [00:04:41.934,112] [0m<dbg> cloud_codec: cloud_codec_encode_data:  Added bat data to encode_data[0m
2022-07-25T05:10:56.283Z DEBUG modem << Encoded message:
2022-07-25T05:10:56.290Z DEBUG modem << {
2022-07-25T05:10:56.296Z DEBUG modem << "dev":{
2022-07-25T05:10:56.303Z DEBUG modem << "v":{
2022-07-25T05:10:56.309Z DEBUG modem << "imei":"352656101074246",
2022-07-25T05:10:56.318Z DEBUG modem << "iccid":"8944501511210382488",
2022-07-25T05:10:56.324Z DEBUG modem << "modV":"mfw_nrf9160_1.3.1",
2022-07-25T05:10:56.331Z DEBUG modem << "brdV":"thingy91_nrf9160",
2022-07-25T05:10:56.337Z DEBUG modem << "appV":"0.0.0-development"
2022-07-25T05:10:56.343Z DEBUG modem << },
2022-07-25T05:10:56.349Z DEBUG modem << "ts":1658725852151
2022-07-25T05:10:56.356Z DEBUG modem << },
2022-07-25T05:10:56.362Z DEBUG modem << "roam":{
2022-07-25T05:10:56.368Z DEBUG modem << "v":{
2022-07-25T05:10:56.374Z DEBUG modem << "rsrp":-85
2022-07-25T05:10:56.381Z DEBUG modem << },
2022-07-25T05:10:56.387Z DEBUG modem << "ts":1658725852202
2022-07-25T05:10:56.393Z DEBUG modem << },
2022-07-25T05:10:56.399Z DEBUG modem << "env":{
2022-07-25T05:10:56.406Z DEBUG modem << "v":{
2022-07-25T05:10:56.412Z DEBUG modem << "temp":26.685308456420898,
2022-07-25T05:10:56.421Z DEBUG modem << "hum":42.272941589355469,
2022-07-25T05:10:56.428Z DEBUG modem << "atmp":97.066000000000003,
2022-07-25T05:10:56.434Z DEBUG modem << "bsec_iaq":170
2022-07-25T05:10:56.440Z DEBUG modem << },
2022-07-25T05:10:56.446Z DEBUG modem << "ts":1658725852059
2022-07-25T05:10:56.452Z DEBUG modem << },
2022-07-25T05:10:56.458Z DEBUG modem << "acc":{
2022-07-25T05:10:56.464Z DEBUG modem << "v":{
2022-07-25T05:10:56.471Z DEBUG modem << "x":26.685308456420898,
2022-07-25T05:10:56.477Z DEBUG modem << "y":42.272941589355469,
2022-07-25T05:10:56.483Z DEBUG modem << "z":97.066000000000003
2022-07-25T05:10:56.490Z DEBUG modem << },
2022-07-25T05:10:56.496Z DEBUG modem << "ts":1658725852059
2022-07-25T05:10:56.503Z DEBUG modem << }
2022-07-25T05:10:56.509Z DEBUG modem << }
2022-07-25T05:10:56.515Z DEBUG modem << [00:04:42.007,080] [0m<dbg> data_module: data_encode: Data encoded successfully[0m
2022-07-25T05:10:56.526Z DEBUG modem << [00:04:42.014,648] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x20027400[0m
2022-07-25T05:10:56.534Z DEBUG modem << [00:04:42.023,437] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATA_SEND[0m
2022-07-25T05:10:56.542Z DEBUG modem << [00:04:42.031,677] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:10:56.550Z DEBUG modem << [00:04:42.038,665] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:10:56.558Z DEBUG modem << [00:04:42.048,278] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: Entered cloud_codec_encode_batch_data[0m
2022-07-25T05:10:56.566Z DEBUG modem << [00:04:42.058,380] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_sta data to encode_batch_data[0m
2022-07-25T05:10:56.574Z DEBUG modem << [00:04:42.068,756] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added mdm_dyn data to encode_batch_data[0m
2022-07-25T05:10:56.581Z DEBUG modem << [00:04:42.079,223] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added gnss data to encode_batch_data[0m
2022-07-25T05:10:56.589Z DEBUG modem << [00:04:42.089,324] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added bms data to encode_batch_data[0m
2022-07-25T05:10:56.606Z DEBUG modem << [00:04:42.099,365] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added sensor data to encode_batch_data[0m
2022-07-25T05:10:56.613Z DEBUG modem << [00:04:42.109,680] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added battery data to encode_batch_data[0m
2022-07-25T05:10:56.619Z DEBUG modem << [00:04:42.120,056] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data:  Added acc data to encode_batch_data[0m
2022-07-25T05:10:56.624Z DEBUG modem << [00:04:42.130,035] [0m<dbg> cloud_codec: cloud_codec_encode_batch_data: No data to encode, JSON string empty...[0m
2022-07-25T05:10:56.628Z DEBUG modem << [00:04:42.140,350] [0m<dbg> data_module: data_encode: No batch data to encode, ringbuffers are empty[0m
2022-07-25T05:10:56.632Z DEBUG modem << [00:04:42.152,130] [0m<dbg> cloud_module: data_send: Data sent, data pointer: 0x20027400[0m
2022-07-25T05:10:56.637Z DEBUG modem << [00:04:42.160,430] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:10:56.641Z DEBUG modem << [00:04:42.169,128] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x20027400[0m
2022-07-25T05:10:56.646Z DEBUG modem << Tx: 13
2022-07-25T05:10:56.650Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:10:56.655Z DEBUG modem << [00:04:43.440,307] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS[0m
2022-07-25T05:10:57.913Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:57.918Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:10:57.924Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:10:57.929Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:10:57.934Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.942Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.948Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.954Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.959Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.964Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.969Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.974Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.981Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.985Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.989Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.993Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:57.998Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:10:58.755Z DEBUG modem << [00:04:47.048,278] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:10:59.352Z DEBUG modem << Tx: 13
2022-07-25T05:10:59.357Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:11:00.575Z DEBUG modem << +CSCON: 0
2022-07-25T05:11:00.581Z DEBUG modem << [00:04:48.865,997] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:11:01.202Z DEBUG modem << %CESQ: 47,2,13,1
2022-07-25T05:11:01.234Z DEBUG modem << [00:04:49.266,906] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -93[0m
2022-07-25T05:11:01.240Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:01.247Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:11:01.253Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:01.262Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:01.268Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.274Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.279Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.285Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.291Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.297Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.303Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.309Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.315Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.321Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.327Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.332Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:01.338Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:03.119Z DEBUG modem << Tx: 13
2022-07-25T05:11:03.127Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:11:03.799Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:03.807Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:03.814Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:03.820Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:03.826Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:03.832Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:03.839Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:03.845Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:03.852Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:03.858Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:03.864Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:03.870Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:03.876Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:03.883Z DEBUG modem << [00:04:52.048,370] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:11:05.160Z DEBUG modem <<  bms incoming_message: a5,1,93,8,1,1,1,e5,0,0,7,cf,ff,
2022-07-25T05:11:05.174Z DEBUG modem << buffer_1: a5,1,93,8,1,1,1,e5,0,0,7,cf,ff,
2022-07-25T05:11:05.183Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:05.192Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:05.202Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:05.224Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:05.232Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:05.241Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:05.269Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:05.279Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:05.287Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:05.973Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:05.985Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:05.993Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:06.004Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:06.012Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:06.020Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:07.163Z DEBUG modem << Tx: 13
2022-07-25T05:11:07.174Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:11:07.877Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:07.893Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:07.901Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:07.911Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:07.920Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:07.929Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:07.936Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:07.945Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:07.953Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:07.961Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:07.968Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:07.977Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:07.984Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:09.209Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:11:09.218Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:11:09.225Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:09.232Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:09.239Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:09.248Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:09.254Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:09.260Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:09.267Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:09.273Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:09.281Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:09.287Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:09.293Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:09.299Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:10.016Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:10.025Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:10.032Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:11.213Z DEBUG modem << Tx: 13
2022-07-25T05:11:11.221Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:11:11.870Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:11.879Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:11.888Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:11.896Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:11.904Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:11.918Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:11.925Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:11.931Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:11.937Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:11.944Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:11.950Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:11.957Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:11.963Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:11.970Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:11.976Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:11.984Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:11.990Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:11.997Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:12.003Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:12.010Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:12.016Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:12.023Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:12.030Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:12.036Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:12.044Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:12.051Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:12.057Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:12.064Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:12.070Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:12.077Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:12.083Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:12.089Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:12.098Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:12.106Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:12.114Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:12.120Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:12.127Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:12.133Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:12.140Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:13.111Z DEBUG modem << [00:05:00.296,752] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:11:13.791Z DEBUG modem << [00:05:00.642,517] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:11:13.806Z DEBUG modem << [00:05:00.650,878] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:11:13.817Z DEBUG modem << [00:05:00.657,836] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:11:13.827Z DEBUG modem << [00:05:00.667,297] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:11:13.838Z DEBUG modem << [00:05:00.673,889] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:11:13.848Z DEBUG modem << [00:05:00.682,098] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:11:13.857Z DEBUG modem << [00:05:00.690,155] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:11:13.865Z DEBUG modem << [00:05:00.698,608] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:11:13.873Z DEBUG modem << [00:05:00.706,390] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:11:13.881Z DEBUG modem << [00:05:00.714,080] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:11:13.889Z DEBUG modem << [00:05:00.720,642] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:11:13.897Z DEBUG modem << [00:05:00.727,539] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:11:13.906Z DEBUG modem << [00:05:00.739,868] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:11:13.914Z DEBUG modem << [00:05:00.747,711] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:11:13.922Z DEBUG modem << [00:05:00.761,779] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:11:13.930Z DEBUG modem << [00:05:00.768,707] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:11:13.939Z DEBUG modem << [00:05:00.778,106] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:11:13.947Z DEBUG modem << [00:05:00.785,186] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:11:13.955Z DEBUG modem << [00:05:00.794,555] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:11:13.963Z DEBUG modem << [00:05:00.804,351] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:11:13.972Z DEBUG modem << [00:05:00.814,392] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:11:13.982Z DEBUG modem << [00:05:00.823,516] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 6 of 9 in sensor buffer filled[0m
2022-07-25T05:11:13.990Z DEBUG modem << [00:05:00.835,021] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:13.998Z DEBUG modem << [00:05:00.844,787] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:11:14.007Z DEBUG modem << [00:05:00.856,414] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:14.015Z DEBUG modem << [00:05:00.924,987] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:11:14.023Z DEBUG modem << [00:05:00.935,241] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:14.031Z DEBUG modem << [00:05:01.004,730] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:11:14.040Z DEBUG modem << [00:05:01.015,045] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 0 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:11:14.048Z DEBUG modem << [00:05:01.027,709] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:14.970Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:14.997Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:11:15.024Z DEBUG modem << a5,1,95,8,2,e,d6,e,cf,e,d4,0,e8,
2022-07-25T05:11:15.049Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:15.058Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.066Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.073Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.080Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.086Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.093Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.099Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.106Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.112Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.119Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.125Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.131Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.138Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:15.986Z DEBUG modem << Tx: 13
2022-07-25T05:11:15.993Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:11:16.000Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:16.006Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:16.014Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:16.021Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:16.027Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:16.033Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:16.041Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:16.048Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:16.054Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:16.063Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:16.069Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:16.076Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:16.082Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:16.089Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:16.095Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:16.102Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:16.108Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:16.115Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:16.121Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:16.128Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:16.134Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:16.141Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:16.147Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:16.154Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:16.160Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:16.167Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:17.320Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:17.330Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:11:17.336Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:17.345Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:17.352Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.358Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.365Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.371Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.378Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.384Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.391Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.398Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.404Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.411Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.418Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.424Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:17.431Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:19.319Z DEBUG modem << Tx: 13
2022-07-25T05:11:19.329Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:11:20.036Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:20.045Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:20.055Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:20.063Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:20.070Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:20.078Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:20.085Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:20.092Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:20.100Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:20.107Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:20.114Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:20.122Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:20.129Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:20.877Z DEBUG modem << %CESQ: 255,0,255,0
2022-07-25T05:11:21.559Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:21.567Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:21.576Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:21.585Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:21.594Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.601Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.609Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.618Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.626Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.633Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.641Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.648Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.656Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.664Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.672Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.681Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:21.688Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:23.367Z DEBUG modem << Tx: 13
2022-07-25T05:11:23.379Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:11:25.525Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:25.535Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:25.546Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:25.554Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:25.565Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.575Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.582Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.590Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.597Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.606Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.613Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.621Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.628Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.636Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.645Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.652Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.660Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:25.668Z DEBUG modem << [00:05:13.707,824] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2050,0,0,0 [0m
2022-07-25T05:11:25.676Z DEBUG modem << [00:05:13.716,217] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:11:26.484Z DEBUG modem << [00:05:13.724,639] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:11:26.494Z DEBUG modem << [00:05:13.735,839] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:11:26.504Z DEBUG modem << [00:05:13.743,286] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:11:26.514Z DEBUG modem << [00:05:13.750,305] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:11:26.521Z DEBUG modem << [00:05:13.757,354] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:11:26.529Z DEBUG modem << [00:05:13.764,343] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:11:26.538Z DEBUG modem << [00:05:13.771,423] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:11:26.546Z DEBUG modem << [00:05:13.778,411] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:11:26.554Z DEBUG modem << [00:05:13.785,491] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:11:26.562Z DEBUG modem << [00:05:13.792,480] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:11:26.570Z DEBUG modem << [00:05:13.799,560] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:11:26.577Z DEBUG modem << [00:05:13.806,518] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:11:26.585Z DEBUG modem << Tx: 13
2022-07-25T05:11:26.593Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:11:26.601Z DEBUG modem << [00:05:13.819,061] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:11:26.610Z DEBUG modem << [00:05:13.828,491] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:11:26.618Z DEBUG modem << [00:05:13.839,447] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:11:26.626Z DEBUG modem << [00:05:13.847,778] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:26.635Z DEBUG modem << [00:05:13.857,543] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:11:27.570Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:27.581Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:27.590Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:27.598Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:27.607Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:27.616Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:27.624Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:27.632Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:27.641Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:27.650Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:27.659Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:28.388Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:28.399Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:28.409Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:28.419Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:28.428Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:28.436Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:29.577Z DEBUG modem << Tx: 13
2022-07-25T05:11:29.589Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:11:31.620Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:31.631Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:31.640Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:31.650Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:31.658Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:31.667Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:31.675Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:32.367Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:32.377Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:32.388Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:32.397Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:32.405Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:32.417Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:32.426Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:32.434Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:32.443Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:32.452Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:33.165Z DEBUG modem << [00:05:20.642,547] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:11:33.176Z DEBUG modem << [00:05:20.650,909] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:11:33.187Z DEBUG modem << [00:05:20.657,867] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:11:33.197Z DEBUG modem << [00:05:20.667,327] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:11:33.208Z DEBUG modem << [00:05:20.673,919] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:11:33.936Z DEBUG modem << [00:05:20.682,128] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:11:33.948Z DEBUG modem << [00:05:20.690,185] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:11:33.959Z DEBUG modem << [00:05:20.698,669] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:11:33.970Z DEBUG modem << [00:05:20.706,451] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:11:33.978Z DEBUG modem << [00:05:20.714,111] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:11:33.987Z DEBUG modem << [00:05:20.720,672] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:11:33.996Z DEBUG modem << [00:05:20.727,569] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:11:34.006Z DEBUG modem << [00:05:20.739,929] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:11:34.014Z DEBUG modem << [00:05:20.747,833] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:11:34.024Z DEBUG modem << [00:05:20.761,962] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:11:34.034Z DEBUG modem << [00:05:20.768,890] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:11:34.043Z DEBUG modem << [00:05:20.778,289] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:11:34.052Z DEBUG modem << [00:05:20.785,400] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:11:34.062Z DEBUG modem << [00:05:20.794,799] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:11:34.071Z DEBUG modem << [00:05:20.804,534] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:11:34.080Z DEBUG modem << [00:05:20.814,605] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:11:34.090Z DEBUG modem << [00:05:20.823,730] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 7 of 9 in sensor buffer filled[0m
2022-07-25T05:11:34.099Z DEBUG modem << [00:05:20.835,235] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:34.108Z DEBUG modem << [00:05:20.845,001] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:11:34.118Z DEBUG modem << [00:05:20.856,628] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:34.127Z DEBUG modem << [00:05:20.935,455] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:11:34.137Z DEBUG modem << [00:05:20.945,709] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:34.146Z DEBUG modem << [00:05:21.024,932] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:11:34.155Z DEBUG modem << [00:05:21.038,757] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:11:34.165Z DEBUG modem << [00:05:21.049,407] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:34.990Z DEBUG modem << Tx: 13
2022-07-25T05:11:35.008Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:11:35.717Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:35.753Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:35.780Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:35.802Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:35.825Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.850Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.861Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.872Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.881Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.890Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.899Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.909Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.918Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.927Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.936Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.945Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:35.954Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:37.663Z DEBUG modem << Tx: 13
2022-07-25T05:11:37.675Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:11:39.720Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:39.732Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:11:39.742Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:39.752Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:39.763Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.773Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.782Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.791Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.801Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.810Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.819Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.828Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.837Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.846Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.858Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.867Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:39.877Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:41.722Z DEBUG modem << Tx: 13
2022-07-25T05:11:41.738Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:11:42.387Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:42.398Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:42.410Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:42.419Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:42.429Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:42.440Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:42.449Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:42.458Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:42.468Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:42.477Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:43.176Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:43.188Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:43.199Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:43.208Z DEBUG modem << [00:05:30.303,955] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:11:43.895Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:11:43.907Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:11:43.918Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:43.935Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:43.950Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:43.961Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:43.972Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:43.983Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:43.994Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:44.003Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:44.014Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:44.026Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:44.038Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:44.050Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:44.060Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:44.069Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:44.079Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:45.769Z DEBUG modem << Tx: 13
2022-07-25T05:11:45.781Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:11:46.490Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:46.501Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:46.511Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:46.522Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:46.534Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:46.549Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:46.560Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:46.572Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:46.583Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:46.595Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:46.606Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:46.620Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:46.633Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:46.643Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:46.654Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:46.665Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:46.678Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:46.689Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:46.701Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:46.712Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:46.723Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:46.734Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:46.745Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:46.758Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:46.770Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:46.782Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:46.793Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:46.803Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:46.814Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:46.824Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:46.835Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:46.845Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:46.858Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:46.872Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:46.881Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:46.891Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:46.902Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:46.914Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:46.924Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:47.804Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:47.815Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:11:47.826Z DEBUG modem << a5,1,95,8,2,e,d6,e,cf,e,d4,0,e8,
2022-07-25T05:11:47.837Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:47.847Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:47.858Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:47.868Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:47.878Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:47.889Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:47.899Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:47.911Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:48.631Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:48.642Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:48.653Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:48.663Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:48.674Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:48.684Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:49.822Z DEBUG modem << Tx: 13
2022-07-25T05:11:49.835Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:11:50.532Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:50.544Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:50.556Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:50.566Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:50.578Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:50.589Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:50.599Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:50.609Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:50.620Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:50.630Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:50.641Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:50.652Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:50.662Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:50.672Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:50.683Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:50.699Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:50.710Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:50.720Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:50.731Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:50.742Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:50.752Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:50.762Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:50.772Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:50.783Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:11:50.793Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:11:50.804Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:11:51.862Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:51.874Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:11:51.885Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:51.897Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:51.908Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:51.919Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.573Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.587Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.598Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.609Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.620Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.632Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.642Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.654Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.667Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.677Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:52.688Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:53.435Z DEBUG modem << [00:05:40.642,578] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:11:53.448Z DEBUG modem << [00:05:40.650,970] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:11:53.459Z DEBUG modem << [00:05:40.657,897] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:11:53.471Z DEBUG modem << [00:05:40.667,358] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:11:53.482Z DEBUG modem << [00:05:40.673,980] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:11:53.495Z DEBUG modem << [00:05:40.682,189] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:11:53.508Z DEBUG modem << [00:05:40.690,216] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:11:53.522Z DEBUG modem << [00:05:40.698,699] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:11:53.535Z DEBUG modem << [00:05:40.706,451] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:11:53.548Z DEBUG modem << [00:05:40.714,141] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:11:53.565Z DEBUG modem << [00:05:40.720,672] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:11:53.576Z DEBUG modem << [00:05:40.727,569] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:11:53.588Z DEBUG modem << [00:05:40.739,929] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:11:53.599Z DEBUG modem << [00:05:40.747,802] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:11:53.610Z DEBUG modem << [00:05:40.761,901] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:11:53.621Z DEBUG modem << [00:05:40.768,859] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:11:53.632Z DEBUG modem << [00:05:40.778,259] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:11:53.644Z DEBUG modem << [00:05:40.785,369] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:11:53.655Z DEBUG modem << [00:05:40.794,738] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:11:53.667Z DEBUG modem << [00:05:40.804,473] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:11:53.678Z DEBUG modem << [00:05:40.814,514] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:11:53.691Z DEBUG modem << [00:05:40.823,638] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 8 of 9 in sensor buffer filled[0m
2022-07-25T05:11:53.702Z DEBUG modem << [00:05:40.835,113] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:53.716Z DEBUG modem << [00:05:40.844,909] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:11:53.729Z DEBUG modem << [00:05:40.856,506] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:53.743Z DEBUG modem << [00:05:40.935,333] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:11:53.755Z DEBUG modem << [00:05:40.945,556] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:54.525Z DEBUG modem << [00:05:41.024,383] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:11:54.539Z DEBUG modem << [00:05:41.038,177] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:11:54.551Z DEBUG modem << [00:05:41.048,828] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:11:55.201Z DEBUG modem << Tx: 13
2022-07-25T05:11:55.214Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:11:55.225Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:55.237Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:55.249Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:55.261Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:11:55.273Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:11:55.286Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:11:55.298Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:11:55.311Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:11:55.322Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:11:55.335Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:11:55.350Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:11:55.362Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:11:55.374Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:11:56.048Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:56.061Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:11:56.074Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:11:56.086Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:11:56.099Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.111Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.123Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.136Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.149Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.161Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.173Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.185Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.197Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.209Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.222Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.233Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:56.246Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:11:57.926Z DEBUG modem << Tx: 13
2022-07-25T05:11:57.939Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:11:59.974Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:00.543Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:00.556Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:00.569Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:00.583Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.595Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.607Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.620Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.632Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.646Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.660Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.674Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.687Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.699Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.712Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.724Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.737Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:00.749Z DEBUG modem << [00:05:48.272,644] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2050,0,0,0 [0m
2022-07-25T05:12:01.327Z DEBUG modem << [00:05:48.281,036] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:12:01.340Z DEBUG modem << [00:05:48.289,459] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:12:01.354Z DEBUG modem << [00:05:48.300,659] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:12:01.367Z DEBUG modem << [00:05:48.308,105] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:12:01.379Z DEBUG modem << [00:05:48.315,124] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:01.392Z DEBUG modem << [00:05:48.322,174] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:01.404Z DEBUG modem << [00:05:48.329,162] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:01.417Z DEBUG modem << [00:05:48.336,242] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:01.429Z DEBUG modem << [00:05:48.343,231] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:01.442Z DEBUG modem << [00:05:48.350,311] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:01.454Z DEBUG modem << [00:05:48.357,269] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:01.467Z DEBUG modem << [00:05:48.364,379] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:01.479Z DEBUG modem << [00:05:48.371,337] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:01.491Z DEBUG modem << [00:05:48.378,417] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:01.504Z DEBUG modem << [00:05:48.385,406] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:01.516Z DEBUG modem << [00:05:48.392,486] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:01.529Z DEBUG modem << [00:05:48.399,475] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:12:01.541Z DEBUG modem << Tx: 13
2022-07-25T05:12:01.554Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:12:01.566Z DEBUG modem << [00:05:48.411,987] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:12:01.580Z DEBUG modem << [00:05:48.421,386] [1;33m<wrn> cloud_codec_ringbuffer: On line 33 in ringbuffer[0m
2022-07-25T05:12:01.592Z DEBUG modem << [00:05:48.428,924] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 0 of 2 in bms buffer filled[0m
2022-07-25T05:12:01.605Z DEBUG modem << [00:05:48.439,910] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:12:01.619Z DEBUG modem << [00:05:48.448,211] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:01.631Z DEBUG modem << [00:05:48.458,007] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:12:02.258Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:02.272Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:02.285Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:02.297Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:02.312Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.325Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.337Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.350Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.363Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.376Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.389Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.402Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.414Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.427Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.440Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.453Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:02.465Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:04.154Z DEBUG modem << Tx: 13
2022-07-25T05:12:04.167Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:12:06.202Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:06.775Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:06.789Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:06.804Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:06.816Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.829Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.842Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.855Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.868Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.881Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.894Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.907Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.919Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.932Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.945Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.958Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:06.970Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:08.210Z DEBUG modem << Tx: 13
2022-07-25T05:12:08.223Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:12:10.258Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:10.273Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:10.287Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:10.300Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:10.315Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.331Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.343Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.356Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.370Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.383Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.396Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.410Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.423Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.436Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.450Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.463Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:10.476Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:12.008Z DEBUG modem << [00:06:00.311,187] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:12:12.590Z DEBUG modem << Tx: 13
2022-07-25T05:12:12.604Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:12:12.617Z DEBUG modem << [00:06:00.642,608] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:12:12.631Z DEBUG modem << [00:06:00.651,000] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:12:12.644Z DEBUG modem << [00:06:00.657,928] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:12:12.656Z DEBUG modem << [00:06:00.667,419] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:12:12.670Z DEBUG modem << [00:06:00.674,011] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:12:12.682Z DEBUG modem << [00:06:00.682,220] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:12:12.695Z DEBUG modem << [00:06:00.690,277] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:12:12.709Z DEBUG modem << [00:06:00.698,730] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:12:12.721Z DEBUG modem << [00:06:00.706,512] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:12:12.734Z DEBUG modem << [00:06:00.714,202] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:12:12.748Z DEBUG modem << [00:06:00.720,764] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:12:12.760Z DEBUG modem << [00:06:00.727,630] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:12:12.773Z DEBUG modem << [00:06:00.740,020] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:12:12.786Z DEBUG modem << [00:06:00.747,894] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:12:12.799Z DEBUG modem << [00:06:00.762,023] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:12:12.812Z DEBUG modem << [00:06:00.768,981] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:12:12.826Z DEBUG modem << [00:06:00.778,381] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:12:12.839Z DEBUG modem << [00:06:00.785,491] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:12:12.851Z DEBUG modem << [00:06:00.794,860] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:12:12.864Z DEBUG modem << [00:06:00.804,626] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:12:12.877Z DEBUG modem << [00:06:00.814,666] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:12:12.890Z DEBUG modem << [00:06:00.823,791] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 9 of 9 in sensor buffer filled[0m
2022-07-25T05:12:12.903Z DEBUG modem << [00:06:00.835,296] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:12.916Z DEBUG modem << [00:06:00.845,062] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:12:12.928Z DEBUG modem << [00:06:00.856,658] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:13.530Z DEBUG modem << [00:06:00.935,424] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:12:13.545Z DEBUG modem << [00:06:00.945,648] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:13.558Z DEBUG modem << [00:06:01.025,756] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:12:13.571Z DEBUG modem << [00:06:01.039,581] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:12:13.584Z DEBUG modem << [00:06:01.050,231] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:14.306Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:14.320Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:14.334Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:14.347Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:14.360Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:14.373Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:14.953Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:14.968Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:14.981Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:14.995Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:15.009Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:15.022Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:15.035Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:15.048Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:15.061Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:15.075Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:15.087Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:16.308Z DEBUG modem << Tx: 13
2022-07-25T05:12:16.321Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:12:16.904Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:16.919Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:16.932Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:16.947Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:16.960Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:16.975Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:16.988Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:17.001Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:17.013Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:17.026Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:17.039Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:17.051Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:17.065Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:18.326Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:12:18.340Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:12:18.353Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:18.366Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:18.379Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:18.940Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:18.954Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:18.968Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:18.981Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:18.994Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:19.008Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:19.021Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:19.034Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:19.047Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:19.061Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:19.074Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:19.086Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:20.361Z DEBUG modem << Tx: 13
2022-07-25T05:12:20.375Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:12:20.952Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:20.967Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:20.980Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:20.995Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:21.010Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:21.023Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:21.036Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:21.049Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:21.063Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:21.077Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:21.090Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:21.103Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:21.117Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:21.130Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:21.143Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:21.156Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:21.169Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:21.182Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:21.195Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:21.209Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:21.222Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:21.235Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:21.249Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:21.263Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:21.276Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:21.289Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:21.302Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:21.315Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:21.328Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:21.341Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:21.354Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:21.368Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:21.381Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:21.395Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:21.408Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:21.421Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:21.434Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:21.447Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:21.461Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:22.417Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:22.435Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b8,0,c8,
2022-07-25T05:12:22.450Z DEBUG modem << a5,1,95,8,2,e,d6,e,cf,e,d4,0,e8,
2022-07-25T05:12:22.465Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:22.481Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.496Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.511Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.526Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.541Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.557Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.572Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.594Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.617Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.647Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.664Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.676Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:22.689Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:24.410Z DEBUG modem << Tx: 13
2022-07-25T05:12:24.425Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:12:24.981Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:24.996Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:25.008Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:25.022Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:25.035Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:25.047Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:25.061Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:25.074Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:25.086Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:25.099Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:25.113Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:25.126Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:25.139Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:25.152Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:25.165Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:25.178Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:25.191Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:25.204Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:25.218Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:25.231Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:25.244Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:25.257Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:25.270Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:25.284Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:25.297Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:25.311Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:26.469Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:26.484Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:26.498Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:26.511Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:26.524Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.537Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.550Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.564Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.577Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.590Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.603Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.617Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.630Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.644Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.657Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.670Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:26.683Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:28.459Z DEBUG modem << Tx: 13
2022-07-25T05:12:28.473Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:12:28.991Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:29.006Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:29.019Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:29.035Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:29.048Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:29.062Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:29.075Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:29.089Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:29.102Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:29.116Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:29.129Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:29.143Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:29.157Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:30.522Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:30.536Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:30.551Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:30.564Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:31.080Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.095Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.109Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.123Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.136Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.149Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.163Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.176Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.190Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.203Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.217Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.230Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:31.244Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:32.350Z DEBUG modem << [00:06:20.642,639] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:12:32.883Z DEBUG modem << [00:06:20.651,000] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:12:32.897Z DEBUG modem << [00:06:20.657,958] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:12:32.911Z DEBUG modem << [00:06:20.667,419] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:12:32.925Z DEBUG modem << [00:06:20.674,011] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:12:32.939Z DEBUG modem << [00:06:20.682,220] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:12:32.952Z DEBUG modem << [00:06:20.690,246] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:12:32.966Z DEBUG modem << [00:06:20.698,730] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:12:32.979Z DEBUG modem << [00:06:20.706,481] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:12:32.993Z DEBUG modem << [00:06:20.714,172] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:12:33.007Z DEBUG modem << [00:06:20.720,733] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:12:33.020Z DEBUG modem << [00:06:20.727,600] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:12:33.034Z DEBUG modem << [00:06:20.739,959] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:12:33.047Z DEBUG modem << [00:06:20.747,833] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:12:33.062Z DEBUG modem << [00:06:20.761,962] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:12:33.076Z DEBUG modem << [00:06:20.768,920] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:12:33.089Z DEBUG modem << [00:06:20.778,320] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:12:33.103Z DEBUG modem << [00:06:20.785,400] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:12:33.116Z DEBUG modem << [00:06:20.794,769] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:12:33.130Z DEBUG modem << [00:06:20.804,534] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:12:33.143Z DEBUG modem << [00:06:20.814,575] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:12:33.157Z DEBUG modem << [00:06:20.823,730] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 0 of 9 in sensor buffer filled[0m
2022-07-25T05:12:33.171Z DEBUG modem << [00:06:20.835,205] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:33.185Z DEBUG modem << [00:06:20.845,001] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:12:33.198Z DEBUG modem << [00:06:20.856,597] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:33.212Z DEBUG modem << Tx: 13
2022-07-25T05:12:33.225Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:12:33.238Z DEBUG modem << [00:06:20.935,516] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:12:33.252Z DEBUG modem << [00:06:20.945,770] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:33.265Z DEBUG modem << [00:06:21.024,566] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:12:33.279Z DEBUG modem << [00:06:21.038,391] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:12:33.293Z DEBUG modem << [00:06:21.049,041] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:34.647Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:35.363Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:35.378Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:35.392Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:35.406Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.420Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.433Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.446Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.460Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.473Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.487Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.501Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.515Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.528Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.542Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.555Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.569Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:35.583Z DEBUG modem << [00:06:22.918,151] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2050,0,0,0 [0m
2022-07-25T05:12:35.597Z DEBUG modem << [00:06:22.926,544] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:12:35.611Z DEBUG modem << [00:06:22.934,967] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:12:35.624Z DEBUG modem << [00:06:22.946,166] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:12:36.355Z DEBUG modem << [00:06:22.953,613] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:12:36.370Z DEBUG modem << [00:06:22.960,632] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:36.384Z DEBUG modem << [00:06:22.967,681] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:36.397Z DEBUG modem << [00:06:22.974,670] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:36.411Z DEBUG modem << [00:06:22.981,750] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:36.425Z DEBUG modem << [00:06:22.988,739] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:36.438Z DEBUG modem << [00:06:22.995,819] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:36.452Z DEBUG modem << [00:06:23.002,807] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:36.465Z DEBUG modem << [00:06:23.009,918] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:36.479Z DEBUG modem << [00:06:23.016,876] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:36.493Z DEBUG modem << [00:06:23.023,986] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:36.506Z DEBUG modem << [00:06:23.030,944] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:12:36.521Z DEBUG modem << [00:06:23.038,024] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:12:36.534Z DEBUG modem << [00:06:23.045,013] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:12:36.548Z DEBUG modem << Tx: 13
2022-07-25T05:12:36.562Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:12:36.575Z DEBUG modem << [00:06:23.057,525] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:12:36.589Z DEBUG modem << [00:06:23.066,986] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 1 of 2 in bms buffer filled[0m
2022-07-25T05:12:36.603Z DEBUG modem << [00:06:23.077,941] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:12:36.617Z DEBUG modem << [00:06:23.086,242] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:36.631Z DEBUG modem << [00:06:23.096,038] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:12:37.400Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:37.418Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:37.432Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:37.445Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:37.459Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.473Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.487Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.500Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.514Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.527Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.541Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.555Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.569Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.583Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.596Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.610Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:37.624Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:38.799Z DEBUG modem << Tx: 13
2022-07-25T05:12:38.814Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:12:40.847Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:40.861Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:40.875Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:40.889Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:40.902Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:40.916Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:40.930Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:40.944Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:40.957Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:40.971Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:40.985Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:40.999Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:41.013Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:41.834Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:41.848Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:41.862Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:41.876Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:42.702Z DEBUG modem << [00:06:30.318,389] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:12:43.533Z DEBUG modem << Tx: 13
2022-07-25T05:12:43.561Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:12:44.908Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:44.924Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:12:44.941Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:44.958Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:44.972Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:44.988Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.002Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.017Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.034Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.048Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.062Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.076Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.091Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.110Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.124Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.140Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:45.155Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:46.908Z DEBUG modem << Tx: 13
2022-07-25T05:12:46.924Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:12:47.796Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:47.810Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:47.824Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:47.838Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:47.852Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:47.865Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:47.879Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:47.893Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:47.907Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:47.921Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:47.934Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:47.948Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:47.961Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:48.923Z DEBUG modem <<  bms incoming_message: a5,1,93,8,1,1,1,36,0,0,7,cf,50,
2022-07-25T05:12:48.938Z DEBUG modem << buffer_1: a5,1,93,8,1,1,1,36,0,0,7,cf,50,
2022-07-25T05:12:48.952Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:48.966Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:48.979Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:48.993Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.006Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.796Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.811Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.825Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.839Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.852Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.866Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.880Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.893Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.907Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:49.921Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:50.951Z DEBUG modem << Tx: 13
2022-07-25T05:12:50.965Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:12:51.827Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:51.842Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:51.856Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:51.870Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:51.884Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:51.898Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:51.911Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:51.925Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:51.939Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:51.953Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:51.968Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:51.982Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:51.996Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:52.788Z DEBUG modem << [00:06:40.642,669] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:12:52.803Z DEBUG modem << [00:06:40.651,031] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:12:52.817Z DEBUG modem << [00:06:40.657,989] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:12:52.832Z DEBUG modem << [00:06:40.667,449] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:12:52.847Z DEBUG modem << [00:06:40.674,041] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:12:52.860Z DEBUG modem << [00:06:40.682,250] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:12:52.874Z DEBUG modem << [00:06:40.690,277] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:12:52.888Z DEBUG modem << [00:06:40.698,730] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:12:52.901Z DEBUG modem << [00:06:40.706,512] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:12:52.915Z DEBUG modem << [00:06:40.714,172] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:12:52.929Z DEBUG modem << [00:06:40.720,733] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:12:52.943Z DEBUG modem << [00:06:40.727,600] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:12:52.957Z DEBUG modem << [00:06:40.739,959] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:12:52.971Z DEBUG modem << [00:06:40.747,833] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:12:52.985Z DEBUG modem << [00:06:40.761,962] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:12:52.998Z DEBUG modem << [00:06:40.768,890] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:12:53.012Z DEBUG modem << [00:06:40.778,289] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:12:53.026Z DEBUG modem << [00:06:40.785,400] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:12:53.040Z DEBUG modem << [00:06:40.794,769] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:12:53.054Z DEBUG modem << [00:06:40.804,534] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:12:53.068Z DEBUG modem << [00:06:40.814,575] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:12:53.082Z DEBUG modem << [00:06:40.823,699] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 1 of 9 in sensor buffer filled[0m
2022-07-25T05:12:53.095Z DEBUG modem << [00:06:40.835,174] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:53.109Z DEBUG modem << [00:06:40.844,940] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:12:53.123Z DEBUG modem << [00:06:40.856,567] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:53.137Z DEBUG modem << [00:06:40.935,363] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:12:53.151Z DEBUG modem << [00:06:40.945,617] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:53.165Z DEBUG modem << [00:06:41.024,841] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:12:53.179Z DEBUG modem << [00:06:41.038,665] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:12:53.193Z DEBUG modem << [00:06:41.049,285] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:12:54.049Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:12:54.066Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:12:54.080Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:12:54.095Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:12:54.110Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.125Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.141Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.155Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.169Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.184Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.198Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.213Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.231Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.245Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.259Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.273Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:54.286Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:55.131Z DEBUG modem << Tx: 13
2022-07-25T05:12:55.146Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:12:55.160Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:55.174Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:55.188Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:55.201Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:55.215Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:55.229Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:55.243Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:55.257Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:55.271Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:55.284Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:55.298Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:55.312Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:55.325Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:56.132Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:56.147Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:56.160Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:56.174Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:56.188Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:56.201Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:56.215Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:56.228Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:56.242Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:56.256Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:56.270Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:56.283Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:56.297Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:56.311Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:56.325Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:56.339Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:56.353Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:56.367Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:56.381Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:56.395Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:56.408Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:12:56.422Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:12:56.436Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:12:56.450Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:12:56.463Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:12:56.477Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:12:57.290Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:12:57.305Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:12:57.319Z DEBUG modem << a5,1,95,8,2,e,d7,e,ce,e,d4,0,e8,
2022-07-25T05:12:57.334Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:12:57.347Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.362Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.375Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.389Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.403Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.416Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.430Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.444Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.458Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.471Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.485Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.499Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:57.513Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:12:59.055Z DEBUG modem << Tx: 13
2022-07-25T05:12:59.070Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:12:59.889Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:12:59.903Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:12:59.918Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:12:59.931Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:12:59.945Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:12:59.959Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:12:59.972Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:12:59.986Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:00.000Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:00.014Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:00.028Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:13:00.041Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:13:00.055Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:13:00.069Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:00.083Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:00.096Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:00.110Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:00.124Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:00.137Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:00.151Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:00.164Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:00.178Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:00.192Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:00.205Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:13:00.219Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:13:00.232Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:13:01.111Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:01.125Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:13:01.140Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:01.153Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:13:01.167Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.181Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.194Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.208Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.222Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.235Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.249Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.262Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.276Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.290Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.303Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.317Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:01.331Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:03.102Z DEBUG modem << Tx: 13
2022-07-25T05:13:03.117Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:13:05.152Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:05.171Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:13:05.187Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:05.201Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:13:05.215Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:05.228Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:05.242Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:05.256Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:05.269Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:05.283Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:05.297Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:06.083Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:06.097Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:06.111Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:06.124Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:06.138Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:06.151Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:07.158Z DEBUG modem << Tx: 13
2022-07-25T05:13:07.172Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:13:09.213Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:09.229Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:13:09.243Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:09.257Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:13:09.271Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:09.285Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:09.299Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:09.313Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:09.327Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:09.341Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:09.355Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:09.370Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:09.384Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:09.397Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:09.412Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:10.195Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:10.209Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:10.223Z DEBUG modem << [00:06:57.515,197] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2050,0,0,0 [0m
2022-07-25T05:13:10.237Z DEBUG modem << [00:06:57.523,559] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:13:10.251Z DEBUG modem << [00:06:57.532,012] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:13:10.265Z DEBUG modem << [00:06:57.543,212] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:13:10.279Z DEBUG modem << [00:06:57.550,659] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:13:10.292Z DEBUG modem << [00:06:57.557,647] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:13:10.306Z DEBUG modem << [00:06:57.564,697] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:13:10.320Z DEBUG modem << [00:06:57.571,685] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:13:10.334Z DEBUG modem << [00:06:57.578,765] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:13:10.347Z DEBUG modem << [00:06:57.585,754] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:13:10.361Z DEBUG modem << [00:06:57.592,834] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:13:10.375Z DEBUG modem << [00:06:57.599,822] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:13:10.388Z DEBUG modem << [00:06:57.606,903] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:13:10.402Z DEBUG modem << [00:06:57.613,891] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:13:10.416Z DEBUG modem << Tx: 13
2022-07-25T05:13:10.429Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:13:10.443Z DEBUG modem << [00:06:57.626,403] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:13:10.457Z DEBUG modem << [00:06:57.635,833] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:13:10.471Z DEBUG modem << [00:06:57.646,820] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:13:10.484Z DEBUG modem << [00:06:57.655,120] [0m<dbg> data_module: requested_data_status_set: processed Capture 1 data bytes:
2022-07-25T05:13:10.498Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:10.512Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:10.525Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:10.539Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:10.553Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:10.566Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:10.580Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:10.593Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:10.607Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:10.621Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:13:10.634Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:13:10.648Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:13:10.662Z DEBUG modem << requested_data_status_set()[0m
2022-07-25T05:13:10.676Z DEBUG modem << [00:06:57.692,504] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:13:11.489Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:13:11.504Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:13:11.518Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:11.532Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:13:11.547Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.561Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.575Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.589Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.603Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.617Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.630Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.644Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.658Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.672Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.686Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.700Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:11.714Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:12.533Z DEBUG modem << [00:07:00.325,592] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:13:12.548Z DEBUG modem << [00:07:00.642,700] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:13:12.563Z DEBUG modem << [00:07:00.651,062] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:13:12.578Z DEBUG modem << [00:07:00.658,020] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:13:12.592Z DEBUG modem << [00:07:00.667,480] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:13:12.605Z DEBUG modem << [00:07:00.674,102] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:13:12.619Z DEBUG modem << [00:07:00.682,281] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:13:12.632Z DEBUG modem << [00:07:00.690,338] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:13:12.646Z DEBUG modem << [00:07:00.698,791] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:13:12.659Z DEBUG modem << [00:07:00.706,573] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:13:12.674Z DEBUG modem << [00:07:00.714,263] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:13:12.687Z DEBUG modem << [00:07:00.720,794] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:13:12.701Z DEBUG modem << [00:07:00.727,691] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:13:12.714Z DEBUG modem << [00:07:00.740,051] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:13:13.526Z DEBUG modem << [00:07:00.747,924] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:13:13.541Z DEBUG modem << [00:07:00.762,054] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:13:13.556Z DEBUG modem << [00:07:00.769,012] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:13:13.573Z DEBUG modem << [00:07:00.778,411] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:13:13.588Z DEBUG modem << [00:07:00.785,522] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:13:13.602Z DEBUG modem << [00:07:00.794,921] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:13:13.616Z DEBUG modem << [00:07:00.804,687] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:13:13.629Z DEBUG modem << [00:07:00.814,758] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:13:13.643Z DEBUG modem << [00:07:00.823,883] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 2 of 9 in sensor buffer filled[0m
2022-07-25T05:13:13.657Z DEBUG modem << [00:07:00.835,388] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:13.671Z DEBUG modem << [00:07:00.845,184] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:13:13.689Z DEBUG modem << [00:07:00.856,781] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:13.703Z DEBUG modem << [00:07:00.935,607] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:13:13.716Z DEBUG modem << [00:07:00.945,861] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:14.509Z DEBUG modem << [00:07:01.025,085] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:13:14.525Z DEBUG modem << [00:07:01.038,909] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:13:14.540Z DEBUG modem << [00:07:01.049,560] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:14.555Z DEBUG modem << Tx: 13
2022-07-25T05:13:14.573Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:13:15.379Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:13:15.393Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:13:15.407Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:16.172Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:13:16.186Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.200Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.214Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.227Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.241Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.254Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.268Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.281Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.294Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.308Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.322Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.335Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:16.348Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:17.415Z DEBUG modem << Tx: 13
2022-07-25T05:13:17.429Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:13:19.472Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:13:19.487Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:13:19.505Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:19.518Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:13:19.532Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.546Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.559Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.573Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.587Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.600Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.614Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.627Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.641Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.654Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.669Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.682Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:19.696Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:21.463Z DEBUG modem << Tx: 13
2022-07-25T05:13:21.477Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:13:22.294Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:22.308Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:22.323Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:22.337Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:22.351Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:22.365Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:22.380Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:22.395Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:22.409Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:22.423Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:22.436Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:13:22.450Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:13:22.464Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:13:23.510Z DEBUG modem <<  bms incoming_message: a5,1,93,8,1,1,1,51,0,0,7,cf,6b,
2022-07-25T05:13:24.303Z DEBUG modem << buffer_1: a5,1,93,8,1,1,1,51,0,0,7,cf,6b,
2022-07-25T05:13:24.317Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:24.332Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:13:24.346Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.359Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.373Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.387Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.401Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.415Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.428Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.442Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.456Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.470Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.484Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.498Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:24.512Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:25.524Z DEBUG modem << Tx: 13
2022-07-25T05:13:25.539Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:13:26.357Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:26.372Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:26.386Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:26.400Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:26.414Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:26.428Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:26.441Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:26.455Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:26.468Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:26.482Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:26.496Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:13:26.510Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:13:26.524Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:13:27.562Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:13:27.577Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:13:27.591Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:27.605Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:13:27.619Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:27.633Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:27.647Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:27.663Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:27.677Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:27.691Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:27.704Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:28.491Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:28.505Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:28.520Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:28.534Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:28.547Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:28.561Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:29.574Z DEBUG modem << Tx: 13
2022-07-25T05:13:29.589Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:13:30.389Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:30.404Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:30.417Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:30.431Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:30.445Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:30.459Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:30.472Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:30.487Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:30.500Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:30.514Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:30.527Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:13:30.541Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:13:30.555Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:13:30.568Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:30.582Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:30.596Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:30.610Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:30.623Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:30.637Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:30.650Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:30.664Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:30.677Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:30.691Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:30.705Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:13:30.719Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:13:30.732Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:13:30.746Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:30.760Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:30.773Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:30.788Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:30.801Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:30.815Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:30.829Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:30.842Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:30.856Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:30.870Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:30.888Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:13:30.902Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:13:30.916Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:13:31.719Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,b9,e,cf,e,d4,0,cc,
2022-07-25T05:13:31.733Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:13:31.747Z DEBUG modem << a5,1,95,8,2,e,d7,e,cf,e,d4,0,e9,
2022-07-25T05:13:31.761Z DEBUG modem << a5,1,95,8,3,e,b9,e,cf,e,d4,0,cc,
2022-07-25T05:13:31.774Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.789Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.802Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.816Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.829Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.843Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.857Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.870Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.885Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.898Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.912Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.925Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:31.939Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:32.752Z DEBUG modem << [00:07:20.642,730] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:13:32.771Z DEBUG modem << [00:07:20.651,092] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:13:32.785Z DEBUG modem << [00:07:20.658,050] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:13:32.799Z DEBUG modem << [00:07:20.667,510] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:13:32.813Z DEBUG modem << [00:07:20.674,102] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:13:32.827Z DEBUG modem << [00:07:20.682,342] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:13:32.840Z DEBUG modem << [00:07:20.690,368] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:13:32.854Z DEBUG modem << [00:07:20.698,852] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:13:32.868Z DEBUG modem << [00:07:20.706,604] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:13:32.882Z DEBUG modem << [00:07:20.714,294] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:13:32.896Z DEBUG modem << [00:07:20.720,855] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:13:32.909Z DEBUG modem << [00:07:20.727,752] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:13:32.923Z DEBUG modem << [00:07:20.740,112] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:13:32.937Z DEBUG modem << [00:07:20.747,985] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:13:32.950Z DEBUG modem << [00:07:20.762,115] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:13:32.964Z DEBUG modem << [00:07:20.769,073] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:13:32.977Z DEBUG modem << [00:07:20.778,472] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:13:32.991Z DEBUG modem << [00:07:20.785,583] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:13:33.005Z DEBUG modem << [00:07:20.794,982] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:13:33.018Z DEBUG modem << [00:07:20.804,718] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:13:33.032Z DEBUG modem << [00:07:20.814,788] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:13:33.046Z DEBUG modem << [00:07:20.823,913] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 3 of 9 in sensor buffer filled[0m
2022-07-25T05:13:33.060Z DEBUG modem << [00:07:20.835,388] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:33.074Z DEBUG modem << [00:07:20.845,184] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:13:33.087Z DEBUG modem << [00:07:20.856,811] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:33.102Z DEBUG modem << [00:07:20.935,607] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:13:33.115Z DEBUG modem << [00:07:20.945,861] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:33.129Z DEBUG modem << [00:07:21.025,085] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:13:33.143Z DEBUG modem << [00:07:21.038,940] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:13:33.156Z DEBUG modem << [00:07:21.049,591] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:33.973Z DEBUG modem << Tx: 13
2022-07-25T05:13:33.987Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:13:34.003Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:34.017Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:34.030Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:34.044Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:34.058Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:34.071Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:34.085Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:34.099Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:34.113Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:34.127Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:34.140Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:13:34.154Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:13:34.167Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:13:34.183Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:34.197Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:34.210Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:34.224Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:34.238Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:34.251Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:34.265Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:34.278Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:34.292Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:34.307Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:34.325Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:13:34.339Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:13:34.352Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:13:35.622Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:36.430Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:13:36.445Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:36.460Z DEBUG modem << a5,1,95,8,3,e,b9,e,cf,e,d4,0,cc,
2022-07-25T05:13:36.474Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.488Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.502Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.516Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.530Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.543Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.557Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.571Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.585Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.599Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.613Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.627Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:36.640Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:37.671Z DEBUG modem << Tx: 13
2022-07-25T05:13:37.686Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:13:38.495Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:38.509Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:38.523Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:39.318Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:39.333Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:39.347Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:39.361Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:39.375Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:39.389Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:39.403Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:39.417Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:39.432Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:39.445Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:40.244Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:40.261Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:13:40.275Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:40.289Z DEBUG modem << a5,1,95,8,3,e,b9,e,cf,e,d4,0,cc,
2022-07-25T05:13:40.303Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.317Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.331Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.346Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.361Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.375Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.389Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.402Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.416Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.430Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.444Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.458Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:40.472Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:41.719Z DEBUG modem << Tx: 13
2022-07-25T05:13:41.735Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:13:42.563Z DEBUG modem << [00:07:30.332,824] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:13:43.768Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:43.783Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:13:43.799Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:43.812Z DEBUG modem << a5,1,95,8,3,e,b9,e,cf,e,d4,0,cc,
2022-07-25T05:13:43.827Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:43.841Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:43.855Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:43.869Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:43.883Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:43.897Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:43.912Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:43.926Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:43.940Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:44.733Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:44.747Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:44.762Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:44.776Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:44.790Z DEBUG modem << [00:07:32.082,183] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2050,0,0,0 [0m
2022-07-25T05:13:44.804Z DEBUG modem << [00:07:32.090,576] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:13:44.823Z DEBUG modem << [00:07:32.098,999] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:13:44.843Z DEBUG modem << [00:07:32.110,198] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:13:44.858Z DEBUG modem << [00:07:32.117,645] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:13:44.873Z DEBUG modem << [00:07:32.124,664] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:13:44.887Z DEBUG modem << [00:07:32.131,713] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:13:44.902Z DEBUG modem << [00:07:32.138,702] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:13:44.916Z DEBUG modem << [00:07:32.145,782] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:13:44.933Z DEBUG modem << [00:07:32.152,770] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:13:44.949Z DEBUG modem << Tx: 13
2022-07-25T05:13:44.962Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:13:44.976Z DEBUG modem << [00:07:32.165,283] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:13:44.990Z DEBUG modem << [00:07:32.174,682] [1;33m<wrn> cloud_codec_ringbuffer: On line 33 in ringbuffer[0m
2022-07-25T05:13:45.005Z DEBUG modem << [00:07:32.182,250] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 0 of 2 in bms buffer filled[0m
2022-07-25T05:13:45.020Z DEBUG modem << [00:07:32.193,206] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:13:45.034Z DEBUG modem << [00:07:32.201,507] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:45.049Z DEBUG modem << [00:07:32.211,303] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:13:45.917Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:45.934Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:13:45.951Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:45.966Z DEBUG modem << a5,1,95,8,3,e,b9,e,cf,e,d4,0,cc,
2022-07-25T05:13:45.980Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:45.994Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.008Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.022Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.037Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.051Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.065Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.079Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.094Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.108Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.123Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.137Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:46.152Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:47.899Z DEBUG modem << Tx: 13
2022-07-25T05:13:47.914Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:13:48.741Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:48.757Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:48.771Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:48.786Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:13:48.800Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:13:48.814Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:13:48.827Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:13:48.841Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:13:48.855Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:13:48.869Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:13:48.883Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:13:48.897Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:13:48.910Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:13:49.947Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:50.748Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:13:50.763Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:50.777Z DEBUG modem << a5,1,95,8,3,e,b9,e,cf,e,d4,0,cc,
2022-07-25T05:13:50.792Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.806Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.819Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.833Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.847Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.861Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.875Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.889Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.903Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.917Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.930Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.944Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:50.958Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:51.958Z DEBUG modem << Tx: 13
2022-07-25T05:13:51.974Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:13:52.849Z DEBUG modem << [00:07:40.642,761] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:13:52.864Z DEBUG modem << [00:07:40.651,123] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:13:52.880Z DEBUG modem << [00:07:40.658,081] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:13:52.894Z DEBUG modem << [00:07:40.667,541] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:13:52.908Z DEBUG modem << [00:07:40.674,163] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:13:52.922Z DEBUG modem << [00:07:40.682,373] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:13:52.936Z DEBUG modem << [00:07:40.690,399] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:13:52.951Z DEBUG modem << [00:07:40.698,883] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:13:52.965Z DEBUG modem << [00:07:40.706,665] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:13:52.979Z DEBUG modem << [00:07:40.714,324] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:13:52.993Z DEBUG modem << [00:07:40.720,886] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:13:53.007Z DEBUG modem << [00:07:40.727,783] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:13:53.021Z DEBUG modem << [00:07:40.740,142] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:13:53.035Z DEBUG modem << [00:07:40.748,016] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:13:53.050Z DEBUG modem << [00:07:40.762,145] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:13:53.064Z DEBUG modem << [00:07:40.769,073] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:13:53.078Z DEBUG modem << [00:07:40.778,472] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:13:53.093Z DEBUG modem << [00:07:40.785,583] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:13:53.107Z DEBUG modem << [00:07:40.794,982] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:13:53.121Z DEBUG modem << [00:07:40.804,718] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:13:53.135Z DEBUG modem << [00:07:40.814,788] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:13:53.149Z DEBUG modem << [00:07:40.823,913] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 4 of 9 in sensor buffer filled[0m
2022-07-25T05:13:53.164Z DEBUG modem << [00:07:40.835,418] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:53.181Z DEBUG modem << [00:07:40.845,214] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:13:53.195Z DEBUG modem << [00:07:40.856,842] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:53.208Z DEBUG modem << [00:07:40.935,638] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:13:53.222Z DEBUG modem << [00:07:40.945,892] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:53.235Z DEBUG modem << [00:07:41.025,115] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:13:53.248Z DEBUG modem << [00:07:41.038,940] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:13:53.262Z DEBUG modem << [00:07:41.049,591] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:13:54.126Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:54.141Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:13:54.155Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:54.171Z DEBUG modem << a5,1,95,8,3,e,b9,e,cf,e,d4,0,cc,
2022-07-25T05:13:54.187Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.207Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.222Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.236Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.252Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.269Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.286Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.306Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.323Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.344Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.361Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.377Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:54.392Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:56.015Z DEBUG modem << Tx: 13
2022-07-25T05:13:56.031Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:13:58.055Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:58.070Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:13:58.084Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:13:58.101Z DEBUG modem << a5,1,95,8,3,e,b9,e,cf,e,d4,0,cc,
2022-07-25T05:13:58.115Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:58.128Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:58.142Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:58.156Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:58.170Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:58.184Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:58.198Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:58.985Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:58.999Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:59.013Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:59.027Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:59.041Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:13:59.054Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:00.052Z DEBUG modem << Tx: 13
2022-07-25T05:14:00.068Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:14:00.862Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:00.877Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:00.891Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:00.905Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:00.919Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:00.933Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:00.948Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:00.962Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:00.976Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:00.990Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:01.004Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:01.017Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:01.032Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:02.100Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:14:02.114Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:14:02.130Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:02.144Z DEBUG modem << a5,1,95,8,3,e,b9,e,cf,e,d4,0,cc,
2022-07-25T05:14:02.935Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:02.949Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:02.965Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:02.978Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:02.992Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:03.007Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:03.021Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:03.035Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:03.048Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:03.063Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:03.076Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:03.090Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:03.104Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:04.106Z DEBUG modem << Tx: 13
2022-07-25T05:14:04.120Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:14:04.908Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:04.923Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:04.938Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:04.952Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:04.966Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:04.980Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:04.993Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:05.007Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:05.021Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:05.035Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:05.048Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:05.062Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:05.076Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:05.090Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:05.104Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:05.118Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:05.131Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:05.145Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:05.159Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:05.173Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:05.187Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:05.200Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:05.214Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:05.227Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:05.241Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:05.255Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:05.268Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:05.282Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:05.296Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:05.310Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:05.323Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:05.337Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:05.350Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:05.364Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:05.378Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:05.392Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:05.405Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:05.419Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:05.433Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:06.230Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:06.245Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:14:06.259Z DEBUG modem << a5,1,95,8,2,e,d6,e,cf,e,d4,0,e8,
2022-07-25T05:14:06.273Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:06.287Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.301Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.314Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.328Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.341Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.356Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.370Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.383Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.397Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.411Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.425Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.438Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:06.452Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:08.161Z DEBUG modem << Tx: 13
2022-07-25T05:14:08.176Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:14:08.993Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:09.008Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:09.023Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:09.036Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:09.050Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:09.065Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:09.078Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:09.092Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:09.106Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:09.120Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:09.134Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:09.148Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:09.162Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:09.176Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:09.190Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:09.204Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:09.217Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:09.231Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:09.245Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:09.260Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:09.273Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:09.287Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:09.301Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:09.315Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:09.328Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:09.342Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:10.204Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:10.218Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:14:10.232Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:10.245Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:10.259Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.274Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.288Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.301Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.315Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.329Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.343Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.356Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.370Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.384Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.397Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.411Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:10.425Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:12.031Z DEBUG modem << [00:08:00.340,057] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:14:12.854Z DEBUG modem << Tx: 13
2022-07-25T05:14:12.868Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:14:12.882Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:12.896Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:12.911Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:12.925Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:12.938Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:12.952Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:12.966Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:12.980Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:12.994Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:13.008Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:13.022Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:13.036Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:13.050Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:13.063Z DEBUG modem << [00:08:00.642,791] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:14:13.077Z DEBUG modem << [00:08:00.651,153] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:14:13.091Z DEBUG modem << [00:08:00.658,111] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:14:13.106Z DEBUG modem << [00:08:00.667,572] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:14:13.119Z DEBUG modem << [00:08:00.674,163] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:14:13.133Z DEBUG modem << [00:08:00.682,373] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:14:13.147Z DEBUG modem << [00:08:00.690,429] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:14:13.161Z DEBUG modem << [00:08:00.698,883] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:14:13.175Z DEBUG modem << [00:08:00.706,665] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:14:13.189Z DEBUG modem << [00:08:00.714,355] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:14:13.203Z DEBUG modem << [00:08:00.720,886] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:14:13.217Z DEBUG modem << [00:08:00.727,783] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:14:13.231Z DEBUG modem << [00:08:00.740,142] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:14:13.244Z DEBUG modem << [00:08:00.748,016] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:14:13.258Z DEBUG modem << [00:08:00.762,145] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:14:13.272Z DEBUG modem << [00:08:00.769,073] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:14:13.285Z DEBUG modem << [00:08:00.778,472] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:14:13.299Z DEBUG modem << [00:08:00.785,583] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:14:13.313Z DEBUG modem << [00:08:00.794,982] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:14:13.327Z DEBUG modem << [00:08:00.804,718] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:14:13.341Z DEBUG modem << [00:08:00.814,758] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:14:13.355Z DEBUG modem << [00:08:00.823,883] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 5 of 9 in sensor buffer filled[0m
2022-07-25T05:14:13.369Z DEBUG modem << [00:08:00.835,357] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:13.382Z DEBUG modem << [00:08:00.845,153] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:14:13.396Z DEBUG modem << [00:08:00.856,750] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:13.410Z DEBUG modem << [00:08:00.935,577] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:14:13.424Z DEBUG modem << [00:08:00.945,831] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:13.438Z DEBUG modem << [00:08:01.024,597] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:14:13.452Z DEBUG modem << [00:08:01.038,421] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:14:13.466Z DEBUG modem << [00:08:01.049,041] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:14.273Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:14.289Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:14.303Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:14.317Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:14.332Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.345Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.359Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.373Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.387Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.401Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.419Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.440Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.454Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.468Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.482Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.496Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:14.511Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:16.262Z DEBUG modem << Tx: 13
2022-07-25T05:14:16.276Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:14:18.367Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:19.168Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:19.182Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:19.196Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:19.210Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.223Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.237Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.251Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.265Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.279Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.293Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.307Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.320Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.334Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.349Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.363Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.376Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:19.390Z DEBUG modem << [00:08:06.620,880] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2050,0,0,0 [0m
2022-07-25T05:14:19.404Z DEBUG modem << [00:08:06.629,241] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:14:19.418Z DEBUG modem << [00:08:06.637,695] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:14:19.432Z DEBUG modem << [00:08:06.648,864] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:14:19.446Z DEBUG modem << [00:08:06.656,311] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:14:19.460Z DEBUG modem << [00:08:06.663,330] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:14:19.473Z DEBUG modem << [00:08:06.670,379] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:14:19.487Z DEBUG modem << [00:08:06.677,368] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:14:20.285Z DEBUG modem << [00:08:06.684,448] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:14:20.300Z DEBUG modem << [00:08:06.691,406] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:14:20.315Z DEBUG modem << Tx: 13
2022-07-25T05:14:20.329Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:14:20.344Z DEBUG modem << [00:08:06.703,918] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:14:20.358Z DEBUG modem << [00:08:06.713,378] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 1 of 2 in bms buffer filled[0m
2022-07-25T05:14:20.372Z DEBUG modem << [00:08:06.724,334] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:14:20.386Z DEBUG modem << [00:08:06.732,666] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:20.399Z DEBUG modem << [00:08:06.742,431] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:14:21.193Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:21.208Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:21.222Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:21.236Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:21.250Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.264Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.278Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.293Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.306Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.320Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.334Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.348Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.362Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.375Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.389Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.403Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:21.417Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:22.448Z DEBUG modem << Tx: 13
2022-07-25T05:14:22.462Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:14:23.280Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:23.295Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:23.309Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:23.323Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:23.337Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:23.350Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:23.364Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:23.378Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:23.392Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:23.406Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:23.419Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:23.433Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:23.447Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:24.485Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:14:24.504Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:14:24.518Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:24.532Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:24.546Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:24.559Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:24.573Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:24.587Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:24.601Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:24.615Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:24.629Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:25.420Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:25.434Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:25.448Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:25.462Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:25.476Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:25.491Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:26.505Z DEBUG modem << Tx: 13
2022-07-25T05:14:26.522Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:14:28.554Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:14:28.569Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:14:28.583Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:28.597Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:28.611Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.624Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.638Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.652Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.665Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.679Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.693Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.707Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.722Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.735Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.749Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.763Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:28.777Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:30.571Z DEBUG modem << Tx: 13
2022-07-25T05:14:30.586Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:14:32.449Z DEBUG modem << [00:08:20.642,852] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:14:32.464Z DEBUG modem << [00:08:20.651,214] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:14:32.478Z DEBUG modem << [00:08:20.658,172] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:14:32.494Z DEBUG modem << [00:08:20.667,633] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:14:32.508Z DEBUG modem << [00:08:20.674,224] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:14:32.522Z DEBUG modem << [00:08:20.682,434] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:14:32.535Z DEBUG modem << [00:08:20.690,490] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:14:32.549Z DEBUG modem << [00:08:20.698,944] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:14:32.564Z DEBUG modem << [00:08:20.706,726] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:14:32.578Z DEBUG modem << [00:08:20.714,416] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:14:32.592Z DEBUG modem << [00:08:20.720,977] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:14:32.607Z DEBUG modem << [00:08:20.727,844] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:14:33.381Z DEBUG modem << [00:08:20.740,234] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:14:33.397Z DEBUG modem << [00:08:20.748,107] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:14:33.412Z DEBUG modem << [00:08:20.762,237] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:14:33.426Z DEBUG modem << [00:08:20.769,165] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:14:33.440Z DEBUG modem << [00:08:20.778,594] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:14:33.455Z DEBUG modem << [00:08:20.785,705] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:14:33.468Z DEBUG modem << [00:08:20.795,074] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:14:33.482Z DEBUG modem << [00:08:20.804,840] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:14:33.497Z DEBUG modem << [00:08:20.814,880] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:14:33.511Z DEBUG modem << [00:08:20.824,005] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 6 of 9 in sensor buffer filled[0m
2022-07-25T05:14:33.525Z DEBUG modem << [00:08:20.835,510] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:33.540Z DEBUG modem << [00:08:20.845,306] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:14:33.554Z DEBUG modem << [00:08:20.856,933] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:33.568Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:14:33.582Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:14:33.596Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:33.611Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:33.625Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.639Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.653Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.667Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.681Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.695Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.709Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.723Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.737Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.752Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.766Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.780Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:33.793Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:34.592Z DEBUG modem << [00:08:20.983,520] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:14:34.606Z DEBUG modem << [00:08:20.993,743] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:34.620Z DEBUG modem << [00:08:21.072,570] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:14:34.634Z DEBUG modem << [00:08:21.086,395] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:14:34.648Z DEBUG modem << [00:08:21.097,015] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:35.441Z DEBUG modem << Tx: 13
2022-07-25T05:14:35.456Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:14:36.237Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:36.253Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:36.267Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:36.281Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:36.295Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:36.309Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:36.323Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:36.338Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:36.352Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:36.366Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:36.380Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:36.394Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:36.408Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:37.209Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:14:37.224Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:14:37.238Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:37.252Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:37.266Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.280Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.295Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.309Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.324Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.338Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.352Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.366Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.381Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.395Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.409Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.423Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:37.438Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:38.670Z DEBUG modem << Tx: 13
2022-07-25T05:14:38.686Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:14:39.509Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:39.524Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:39.539Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:39.554Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:39.568Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:39.582Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:39.596Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:39.610Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:39.624Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:39.638Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:39.652Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:39.666Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:39.680Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:39.694Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:39.708Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:39.722Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:39.735Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:39.749Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:39.764Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:39.777Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:39.791Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:39.805Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:39.819Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:39.832Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:39.846Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:39.860Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:39.874Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:39.888Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:39.902Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:39.915Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:39.929Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:39.943Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:39.956Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:39.971Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:39.984Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:39.998Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:40.012Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:40.025Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:40.039Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:40.839Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:40.853Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:14:40.867Z DEBUG modem << a5,1,95,8,2,e,d7,e,cf,e,d4,0,e9,
2022-07-25T05:14:40.881Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:40.895Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:40.908Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:40.922Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:40.935Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:40.949Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:40.963Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:40.976Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:40.990Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:41.003Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:41.017Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:41.030Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:41.044Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:41.058Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:42.048Z DEBUG modem << [00:08:30.347,259] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:14:42.837Z DEBUG modem << Tx: 13
2022-07-25T05:14:42.853Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:14:42.868Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:42.883Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:42.897Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:42.911Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:42.925Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:42.939Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:42.953Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:42.967Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:42.981Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:42.995Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:43.010Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:43.024Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:43.038Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:43.052Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:43.066Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:43.080Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:43.094Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:43.109Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:43.123Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:43.137Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:43.151Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:43.165Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:43.179Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:43.193Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:43.207Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:43.222Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:44.761Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:45.601Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:14:45.616Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:45.631Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:45.645Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.659Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.673Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.688Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.702Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.716Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.730Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.744Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.758Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.772Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.787Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.800Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:45.814Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:46.761Z DEBUG modem << Tx: 13
2022-07-25T05:14:47.549Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:14:48.369Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:48.383Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:48.398Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:48.412Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:48.426Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:48.440Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:48.455Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:48.469Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:48.483Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:48.497Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:48.511Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:48.525Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:48.539Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:49.330Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:49.344Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:49.358Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:49.374Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:49.388Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.402Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.416Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.430Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.444Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.457Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.471Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.485Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.499Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.513Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.527Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.541Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:49.554Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:50.826Z DEBUG modem << Tx: 13
2022-07-25T05:14:50.842Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:14:52.443Z DEBUG modem << [00:08:40.642,822] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:14:52.460Z DEBUG modem << [00:08:40.651,184] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:14:52.474Z DEBUG modem << [00:08:40.658,142] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:14:52.492Z DEBUG modem << [00:08:40.667,602] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:14:52.506Z DEBUG modem << [00:08:40.674,194] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:14:52.520Z DEBUG modem << [00:08:40.682,403] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:14:52.535Z DEBUG modem << [00:08:40.690,429] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:14:52.549Z DEBUG modem << [00:08:40.698,913] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:14:52.564Z DEBUG modem << [00:08:40.706,665] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:14:52.578Z DEBUG modem << [00:08:40.714,355] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:14:52.592Z DEBUG modem << [00:08:40.720,916] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:14:53.407Z DEBUG modem << [00:08:40.727,813] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:14:53.423Z DEBUG modem << [00:08:40.740,173] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:14:53.437Z DEBUG modem << [00:08:40.748,046] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:14:53.451Z DEBUG modem << [00:08:40.762,176] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:14:53.465Z DEBUG modem << [00:08:40.769,104] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:14:53.479Z DEBUG modem << [00:08:40.778,533] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:14:53.493Z DEBUG modem << [00:08:40.785,614] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:14:53.507Z DEBUG modem << [00:08:40.795,013] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:14:53.521Z DEBUG modem << [00:08:40.804,748] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:14:53.535Z DEBUG modem << [00:08:40.814,788] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:14:53.549Z DEBUG modem << [00:08:40.823,913] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 7 of 9 in sensor buffer filled[0m
2022-07-25T05:14:53.564Z DEBUG modem << [00:08:40.835,418] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:53.577Z DEBUG modem << [00:08:40.845,214] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:14:53.591Z DEBUG modem << [00:08:40.856,811] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:54.368Z DEBUG modem << [00:08:40.935,638] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:14:54.384Z DEBUG modem << [00:08:40.945,892] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:54.398Z DEBUG modem << [00:08:41.025,360] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:14:55.256Z DEBUG modem << [00:08:41.039,154] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:14:55.273Z DEBUG modem << [00:08:41.049,804] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:55.288Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:55.305Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:55.320Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:55.334Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:55.348Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.362Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.376Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.390Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.404Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.421Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.441Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.457Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.472Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.487Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.502Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.516Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.531Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:55.546Z DEBUG modem << [00:08:41.167,297] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2050,0,0,0 [0m
2022-07-25T05:14:55.560Z DEBUG modem << [00:08:41.175,659] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:14:55.575Z DEBUG modem << [00:08:41.184,112] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:14:55.589Z DEBUG modem << [00:08:41.195,312] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:14:55.603Z DEBUG modem << [00:08:41.202,728] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:14:55.617Z DEBUG modem << [00:08:41.209,747] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:14:55.631Z DEBUG modem << [00:08:41.216,796] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:14:55.645Z DEBUG modem << [00:08:41.223,785] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:14:55.659Z DEBUG modem << [00:08:41.230,865] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:14:55.673Z DEBUG modem << [00:08:41.237,854] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:14:55.687Z DEBUG modem << Tx: 13
2022-07-25T05:14:55.701Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:14:55.715Z DEBUG modem << [00:08:41.250,366] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:14:55.729Z DEBUG modem << [00:08:41.259,796] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:14:55.742Z DEBUG modem << [00:08:41.270,782] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:14:55.757Z DEBUG modem << [00:08:41.279,052] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:14:55.771Z DEBUG modem << [00:08:41.288,848] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:14:56.579Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:56.593Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:14:56.607Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:56.621Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:56.635Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.650Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.664Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.678Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.692Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.706Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.720Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.734Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.749Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.763Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.777Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.790Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:56.804Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:57.623Z DEBUG modem << Tx: 13
2022-07-25T05:14:57.638Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:14:57.652Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:14:57.667Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:14:57.681Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:14:57.695Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:14:57.709Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:14:57.722Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:14:57.736Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:14:57.750Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:14:57.765Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:14:57.778Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:14:57.792Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:14:57.806Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:14:57.820Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:14:59.062Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:14:59.077Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:14:59.091Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:14:59.105Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:14:59.119Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.133Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.147Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.161Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.175Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.189Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.203Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.217Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.231Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.245Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.259Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.272Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:14:59.286Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:01.050Z DEBUG modem << Tx: 13
2022-07-25T05:15:01.065Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:15:03.099Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:15:03.114Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:15:03.129Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:03.144Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:15:03.929Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:03.944Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:03.958Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:03.972Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:03.986Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:04.000Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:04.014Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:04.027Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:04.041Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:04.056Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:04.069Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:04.083Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:04.097Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:05.113Z DEBUG modem << Tx: 13
2022-07-25T05:15:05.128Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:15:07.157Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:15:07.173Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:15:07.187Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:07.201Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:15:07.216Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:07.230Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:07.244Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:07.258Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:08.045Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:08.060Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:08.074Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:08.089Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:08.103Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:08.117Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:08.130Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:08.145Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:08.159Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:09.156Z DEBUG modem << Tx: 13
2022-07-25T05:15:09.172Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:15:09.970Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:09.985Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:10.000Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:10.015Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:10.029Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:10.043Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:10.057Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:10.071Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:10.085Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:10.104Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:10.118Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:10.132Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:10.147Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:11.209Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:15:11.225Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:15:11.240Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:11.254Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:15:11.268Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:11.282Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:11.296Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.083Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.097Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.113Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.127Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.141Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.155Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.169Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.183Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.197Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.212Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:12.977Z DEBUG modem << [00:09:00.354,492] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:15:13.779Z DEBUG modem << [00:09:00.642,852] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:15:13.793Z DEBUG modem << [00:09:00.651,214] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:15:13.808Z DEBUG modem << [00:09:00.658,172] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:15:13.822Z DEBUG modem << [00:09:00.667,633] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:15:13.836Z DEBUG modem << [00:09:00.674,255] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:15:13.850Z DEBUG modem << [00:09:00.682,464] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:15:13.865Z DEBUG modem << [00:09:00.690,490] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:15:13.879Z DEBUG modem << [00:09:00.698,974] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:15:13.892Z DEBUG modem << [00:09:00.706,756] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:15:13.906Z DEBUG modem << [00:09:00.714,447] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:15:13.920Z DEBUG modem << [00:09:00.721,008] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:15:13.934Z DEBUG modem << [00:09:00.727,905] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:15:13.948Z DEBUG modem << [00:09:00.740,264] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:15:13.963Z DEBUG modem << [00:09:00.748,168] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:15:13.977Z DEBUG modem << [00:09:00.762,298] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:15:13.991Z DEBUG modem << [00:09:00.769,256] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:15:14.005Z DEBUG modem << [00:09:00.778,686] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:15:14.019Z DEBUG modem << [00:09:00.785,797] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:15:14.032Z DEBUG modem << [00:09:00.795,196] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:15:14.046Z DEBUG modem << [00:09:00.804,962] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:15:14.061Z DEBUG modem << [00:09:00.815,032] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:15:14.075Z DEBUG modem << [00:09:00.824,157] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 8 of 9 in sensor buffer filled[0m
2022-07-25T05:15:14.088Z DEBUG modem << [00:09:00.835,662] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:14.102Z DEBUG modem << [00:09:00.845,458] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:15:14.116Z DEBUG modem << [00:09:00.857,086] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:14.130Z DEBUG modem << [00:09:00.935,913] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:15:14.144Z DEBUG modem << [00:09:00.946,166] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:14.158Z DEBUG modem << [00:09:01.025,695] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:15:14.172Z DEBUG modem << [00:09:01.039,520] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:15:14.186Z DEBUG modem << [00:09:01.050,170] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:14.970Z DEBUG modem << Tx: 13
2022-07-25T05:15:14.986Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:15:15.001Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:15.016Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:15.030Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:15.044Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:15.058Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:15.072Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:15.086Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:15.100Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:15.114Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:15.128Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:15.142Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:15.156Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:15.170Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:15.184Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:15.197Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:15.211Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:15.225Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:15.243Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:15.257Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:15.271Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:15.285Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:15.299Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:15.313Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:15.327Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:15.341Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:15.355Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:15.369Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:15.383Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:15.397Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:15.412Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:15.426Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:15.440Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:15.454Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:15.468Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:15.482Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:15.496Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:15.510Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:15.524Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:15.538Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:16.332Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:15:16.347Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c0,e,e1,e,b8,0,c7,
2022-07-25T05:15:16.362Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:15:16.376Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:15:16.390Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.404Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.418Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.432Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.447Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.461Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.475Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.489Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.503Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.517Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.532Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.546Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:16.560Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:17.384Z DEBUG modem << Tx: 13
2022-07-25T05:15:17.400Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:15:17.414Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:17.428Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:17.442Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:17.456Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:17.470Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:17.484Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:17.498Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:17.512Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:17.526Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:17.540Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:17.555Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:17.569Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:17.583Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:17.597Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:17.611Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:17.625Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:17.639Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:17.653Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:18.463Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:18.477Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:18.492Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:18.506Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:18.520Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:18.534Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:18.548Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:18.562Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:19.352Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:19.367Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:15:19.382Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:19.396Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:15:19.410Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.424Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.438Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.452Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.466Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.480Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.494Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.508Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.522Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.537Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.551Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.565Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:19.579Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:21.315Z DEBUG modem << Tx: 13
2022-07-25T05:15:21.331Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:15:22.146Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:22.162Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:22.176Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:22.190Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:22.204Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:22.217Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:22.231Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:22.245Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:22.259Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:22.273Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:22.287Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:22.305Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:22.319Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:23.360Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:15:23.374Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:15:23.389Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:23.403Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:15:23.417Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:23.431Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:23.446Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:24.255Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:24.270Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:24.284Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:24.298Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:24.312Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:24.326Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:24.341Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:24.356Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:24.370Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:24.385Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:25.364Z DEBUG modem << Tx: 13
2022-07-25T05:15:25.379Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:15:27.544Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:15:27.560Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:15:27.574Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:27.589Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:15:27.603Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.617Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.632Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.649Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.663Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.677Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.692Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.706Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.720Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.734Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.749Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.763Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.777Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:27.792Z DEBUG modem << [00:09:15.702,209] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2040,0,0,0 [0m
2022-07-25T05:15:27.806Z DEBUG modem << [00:09:15.710,601] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:15:27.820Z DEBUG modem << [00:09:15.719,055] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:15:27.834Z DEBUG modem << [00:09:15.730,255] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:15:27.849Z DEBUG modem << [00:09:15.737,701] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:15:28.650Z DEBUG modem << [00:09:15.744,720] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:15:28.664Z DEBUG modem << [00:09:15.751,770] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:15:28.679Z DEBUG modem << [00:09:15.758,758] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:15:28.693Z DEBUG modem << [00:09:15.765,838] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:15:28.707Z DEBUG modem << [00:09:15.772,827] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:15:28.721Z DEBUG modem << Tx: 13
2022-07-25T05:15:28.736Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:15:28.750Z DEBUG modem << [00:09:15.785,339] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:15:28.764Z DEBUG modem << [00:09:15.794,738] [1;33m<wrn> cloud_codec_ringbuffer: On line 33 in ringbuffer[0m
2022-07-25T05:15:28.778Z DEBUG modem << [00:09:15.802,307] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 0 of 2 in bms buffer filled[0m
2022-07-25T05:15:28.792Z DEBUG modem << [00:09:15.813,293] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:15:28.807Z DEBUG modem << [00:09:15.821,594] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:28.821Z DEBUG modem << [00:09:15.831,390] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:15:29.621Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:15:29.636Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:15:29.650Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:29.665Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:15:29.679Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.693Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.707Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.721Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.735Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.749Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.764Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.778Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.792Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.806Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.820Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.835Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:29.849Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:31.558Z DEBUG modem << Tx: 13
2022-07-25T05:15:31.574Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:15:32.393Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:32.408Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:32.423Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:32.437Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:32.451Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:32.465Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:32.479Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:32.493Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:32.508Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:32.522Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:32.536Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:32.550Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:32.564Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:33.339Z DEBUG modem << [00:09:20.642,883] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:15:33.354Z DEBUG modem << [00:09:20.651,275] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:15:33.368Z DEBUG modem << [00:09:20.658,233] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:15:33.383Z DEBUG modem << [00:09:20.667,694] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:15:33.397Z DEBUG modem << [00:09:20.674,285] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:15:33.411Z DEBUG modem << [00:09:20.682,495] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:15:33.425Z DEBUG modem << [00:09:20.690,551] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:15:33.440Z DEBUG modem << [00:09:20.699,005] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:15:33.455Z DEBUG modem << [00:09:20.706,787] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:15:33.469Z DEBUG modem << [00:09:20.714,477] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:15:33.483Z DEBUG modem << [00:09:20.721,038] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:15:33.497Z DEBUG modem << [00:09:20.727,935] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:15:33.511Z DEBUG modem << [00:09:20.740,295] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:15:33.525Z DEBUG modem << [00:09:20.748,168] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:15:33.540Z DEBUG modem << [00:09:20.762,329] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:15:33.554Z DEBUG modem << [00:09:20.769,287] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:15:33.568Z DEBUG modem << [00:09:20.778,686] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:15:33.583Z DEBUG modem << [00:09:20.785,797] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:15:33.597Z DEBUG modem << [00:09:20.795,196] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:15:34.377Z DEBUG modem << [00:09:20.804,931] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:15:34.393Z DEBUG modem << [00:09:20.815,002] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:15:34.408Z DEBUG modem << [00:09:20.824,127] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 9 of 9 in sensor buffer filled[0m
2022-07-25T05:15:34.423Z DEBUG modem << [00:09:20.835,632] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:34.437Z DEBUG modem << [00:09:20.845,428] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:15:34.451Z DEBUG modem << [00:09:20.857,025] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:34.465Z DEBUG modem << [00:09:20.935,852] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:15:34.479Z DEBUG modem << [00:09:20.946,105] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:34.493Z DEBUG modem << [00:09:21.025,329] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:15:34.508Z DEBUG modem << [00:09:21.039,154] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:15:34.527Z DEBUG modem << [00:09:21.049,804] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:34.541Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:15:34.555Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:15:34.569Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:34.583Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:15:34.597Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.611Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.626Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.640Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.654Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.668Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.682Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.696Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.710Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.724Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.739Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.753Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:34.767Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:35.609Z DEBUG modem << Tx: 13
2022-07-25T05:15:35.624Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:15:37.656Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:15:37.671Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:15:37.686Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:37.700Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:15:37.715Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:37.729Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:37.744Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:38.528Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:38.544Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:38.559Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:38.573Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:38.587Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:38.602Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:38.616Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:38.630Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:38.644Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:38.659Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:39.658Z DEBUG modem << Tx: 13
2022-07-25T05:15:39.674Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:15:41.696Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:15:41.711Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:15:41.725Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:41.739Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:15:42.534Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.548Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.562Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.577Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.592Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.606Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.620Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.635Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.649Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.664Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.678Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.692Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:42.706Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:43.476Z DEBUG modem << [00:09:30.361,724] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:15:44.303Z DEBUG modem << Tx: 13
2022-07-25T05:15:44.318Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:15:44.333Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:44.349Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:44.363Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:44.377Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:44.391Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:44.406Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:44.420Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:44.434Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:44.448Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:44.462Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:44.476Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:44.490Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:44.504Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:45.773Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:15:45.790Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:15:45.805Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:45.820Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:15:45.835Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.850Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.864Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.879Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.893Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.908Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.922Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.937Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.953Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.969Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.984Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:45.998Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:46.014Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:47.762Z DEBUG modem << Tx: 13
2022-07-25T05:15:47.777Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:15:48.609Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:48.625Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:48.640Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:48.655Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:48.670Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:48.685Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:48.699Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:48.713Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:48.728Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:48.743Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:48.756Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:48.771Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:48.785Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:48.801Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:48.818Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:48.833Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:48.847Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:48.862Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:48.876Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:48.891Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:48.905Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:48.919Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:48.933Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:48.948Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:48.963Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:48.978Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:48.992Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:49.006Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:49.020Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:49.034Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:49.050Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:49.064Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:49.079Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:49.094Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:49.108Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:49.122Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:49.137Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:49.151Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:49.166Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:49.966Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:15:49.983Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:15:49.997Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:15:50.011Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:15:50.025Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.040Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.054Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.068Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.082Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.096Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.110Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.124Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.138Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.153Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.167Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.181Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:50.195Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:51.803Z DEBUG modem << Tx: 13
2022-07-25T05:15:51.818Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:15:52.644Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:52.659Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:52.673Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:52.687Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:52.701Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:52.715Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:52.729Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:52.743Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:52.757Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:52.771Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:52.785Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:52.799Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:52.813Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:52.827Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:52.841Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:52.856Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:52.870Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:52.884Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:52.898Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:52.912Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:52.926Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:52.945Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:52.960Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:52.976Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:52.990Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:53.004Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:53.019Z DEBUG modem << [00:09:40.642,913] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:15:53.034Z DEBUG modem << [00:09:40.651,275] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:15:53.048Z DEBUG modem << [00:09:40.658,233] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:15:53.062Z DEBUG modem << [00:09:40.667,694] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:15:53.077Z DEBUG modem << [00:09:40.674,285] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:15:53.091Z DEBUG modem << [00:09:40.682,495] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:15:53.105Z DEBUG modem << [00:09:40.690,521] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:15:53.119Z DEBUG modem << [00:09:40.699,005] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:15:53.134Z DEBUG modem << [00:09:40.706,756] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:15:53.148Z DEBUG modem << [00:09:40.714,447] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:15:53.163Z DEBUG modem << [00:09:40.720,977] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:15:53.179Z DEBUG modem << [00:09:40.727,874] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:15:53.193Z DEBUG modem << [00:09:40.740,234] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:15:53.211Z DEBUG modem << [00:09:40.748,107] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:15:53.227Z DEBUG modem << [00:09:40.762,237] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:15:53.241Z DEBUG modem << [00:09:40.769,165] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:15:53.255Z DEBUG modem << [00:09:40.778,564] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:15:53.269Z DEBUG modem << [00:09:40.785,675] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:15:53.283Z DEBUG modem << [00:09:40.795,043] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:15:53.297Z DEBUG modem << [00:09:40.804,809] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:15:53.311Z DEBUG modem << [00:09:40.814,849] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:15:53.326Z DEBUG modem << [00:09:40.823,974] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 0 of 9 in sensor buffer filled[0m
2022-07-25T05:15:53.340Z DEBUG modem << [00:09:40.835,479] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:53.354Z DEBUG modem << [00:09:40.845,245] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:15:53.368Z DEBUG modem << [00:09:40.856,842] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:54.155Z DEBUG modem << [00:09:40.935,668] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:15:54.171Z DEBUG modem << [00:09:40.945,892] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:54.186Z DEBUG modem << [00:09:41.024,810] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:15:54.200Z DEBUG modem << [00:09:41.038,635] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:15:54.215Z DEBUG modem << [00:09:41.049,255] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:15:54.990Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:55.005Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:15:55.020Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:55.034Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:15:55.049Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.063Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.076Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.090Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.104Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.118Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.134Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.149Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.163Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.177Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.191Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.210Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:55.225Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:56.118Z DEBUG modem << Tx: 13
2022-07-25T05:15:56.132Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:15:56.146Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:15:56.160Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:15:56.174Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:15:56.188Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:15:56.201Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:15:56.215Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:15:56.229Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:15:56.243Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:15:56.257Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:15:56.270Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:15:56.284Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:15:56.298Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:15:56.311Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:15:57.914Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:15:57.929Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:15:57.943Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:15:57.957Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:15:57.971Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:57.985Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:57.999Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:58.013Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:58.028Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:58.042Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:58.056Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:58.070Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:58.084Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:58.098Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:58.112Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:58.126Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:58.140Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:15:59.935Z DEBUG modem << Tx: 13
2022-07-25T05:15:59.950Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:16:00.744Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:00.760Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:00.778Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:01.570Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:01.585Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:01.602Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:01.617Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:01.631Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:01.648Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:01.662Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:01.676Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:01.690Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:01.704Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:02.490Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:16:02.505Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:16:02.519Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:02.533Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:02.547Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.561Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.576Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.591Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.605Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.619Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.633Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.647Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.662Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.676Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.690Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.704Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.718Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:02.732Z DEBUG modem << [00:09:50.237,884] [1;33m<wrn> bms_module: on line 327 3.8090,3.7680,3809,0,0.2040,0,0,0 [0m
2022-07-25T05:16:02.746Z DEBUG modem << [00:09:50.246,276] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:16:02.760Z DEBUG modem << [00:09:50.254,699] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:16:02.774Z DEBUG modem << [00:09:50.265,899] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:16:02.788Z DEBUG modem << [00:09:50.273,345] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:16:02.803Z DEBUG modem << [00:09:50.280,364] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:16:02.817Z DEBUG modem << [00:09:50.287,414] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:16:02.831Z DEBUG modem << [00:09:50.294,372] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:16:02.845Z DEBUG modem << [00:09:50.301,483] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:16:02.860Z DEBUG modem << [00:09:50.308,441] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:16:02.874Z DEBUG modem << Tx: 13
2022-07-25T05:16:02.888Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:16:02.903Z DEBUG modem << [00:09:50.320,953] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:16:02.917Z DEBUG modem << [00:09:50.330,413] [0m<dbg> cloud_codec_ringbuCapture 1 data bytes:
2022-07-25T05:16:02.931Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:02.945Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:02.960Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:02.974Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:02.988Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:03.002Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:03.017Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:03.031Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:03.045Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:03.059Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:03.073Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:03.087Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:03.101Z DEBUG modem << ffer: cloud_codec_populate_bms_buffer: Entry: 1 of 2 in bms buffer filled[0m
2022-07-25T05:16:03.115Z DEBUG modem << [00:09:50.368,988] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:16:03.129Z DEBUG modem << [00:09:50.377,288] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:03.143Z DEBUG modem << [00:09:50.387,084] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:16:04.090Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:16:04.105Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:16:04.874Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:04.889Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:04.903Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:04.916Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:04.931Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:04.944Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:04.958Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:04.972Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:04.986Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:05.000Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:05.014Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:05.028Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:05.042Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:05.056Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:05.070Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:06.090Z DEBUG modem << Tx: 13
2022-07-25T05:16:06.104Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:16:06.919Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:06.934Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:06.949Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:06.963Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:06.977Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:06.991Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:07.005Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:07.020Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:07.034Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:07.048Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:07.063Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:07.077Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:07.092Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:08.139Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:16:08.153Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:16:08.169Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:08.184Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:08.199Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:08.213Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:08.227Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:08.241Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:08.255Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:08.270Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:08.284Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:08.299Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:08.313Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:09.114Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:09.129Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:09.144Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:09.158Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:10.141Z DEBUG modem << Tx: 13
2022-07-25T05:16:10.159Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:16:10.955Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:10.969Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:10.983Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:10.998Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:11.012Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:11.027Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:11.042Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:11.056Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:11.070Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:11.084Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:11.099Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:11.113Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:11.127Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:12.100Z DEBUG modem << [00:10:00.368,927] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:16:12.878Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:16:12.892Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:16:12.907Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:12.922Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:12.936Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:12.950Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:12.965Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:12.979Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:12.993Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:13.008Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:13.022Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:13.036Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:13.050Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:13.065Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:13.079Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:13.093Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:13.107Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:13.121Z DEBUG modem << [00:10:00.642,944] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:16:13.135Z DEBUG modem << [00:10:00.651,336] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:16:13.150Z DEBUG modem << [00:10:00.658,294] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:16:13.164Z DEBUG modem << [00:10:00.667,755] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:16:13.178Z DEBUG modem << [00:10:00.674,377] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:16:13.192Z DEBUG modem << [00:10:00.682,586] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:16:13.207Z DEBUG modem << [00:10:00.690,612] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:16:13.221Z DEBUG modem << [00:10:00.699,096] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:16:13.235Z DEBUG modem << [00:10:00.706,878] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:16:13.249Z DEBUG modem << [00:10:00.714,569] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:16:13.264Z DEBUG modem << [00:10:00.721,099] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:16:13.278Z DEBUG modem << [00:10:00.727,996] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:16:13.293Z DEBUG modem << [00:10:00.740,356] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:16:13.307Z DEBUG modem << [00:10:00.748,229] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:16:13.321Z DEBUG modem << [00:10:00.762,359] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:16:13.335Z DEBUG modem << [00:10:00.769,317] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:16:13.349Z DEBUG modem << [00:10:00.778,717] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:16:13.364Z DEBUG modem << [00:10:00.785,827] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:16:13.378Z DEBUG modem << [00:10:00.795,227] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:16:13.392Z DEBUG modem << [00:10:00.804,962] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:16:13.406Z DEBUG modem << [00:10:00.815,032] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:16:13.420Z DEBUG modem << [00:10:00.824,157] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 1 of 9 in sensor buffer filled[0m
2022-07-25T05:16:13.434Z DEBUG modem << [00:10:00.835,662] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:13.448Z DEBUG modem << [00:10:00.845,458] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:16:13.462Z DEBUG modem << [00:10:00.857,055] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:13.477Z DEBUG modem << [00:10:00.935,882] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:16:13.491Z DEBUG modem << [00:10:00.946,136] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:13.505Z DEBUG modem << [00:10:01.025,360] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:16:13.519Z DEBUG modem << [00:10:01.039,184] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:16:13.533Z DEBUG modem << [00:10:01.049,835] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:14.332Z DEBUG modem << Tx: 13
2022-07-25T05:16:14.346Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:16:16.240Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:16:17.023Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:16:17.039Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:17.054Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:17.070Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.086Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.101Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.115Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.129Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.144Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.158Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.172Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.187Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.202Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.216Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.230Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:17.245Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:18.246Z DEBUG modem << Tx: 13
2022-07-25T05:16:18.261Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:16:20.303Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:16:20.319Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:16:20.333Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:20.347Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:20.361Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.376Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.390Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.404Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.418Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.432Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.446Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.460Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.474Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.488Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.502Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.517Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:20.531Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:22.297Z DEBUG modem << Tx: 13
2022-07-25T05:16:22.314Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:16:23.125Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:23.140Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:23.154Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:23.168Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:23.182Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:23.196Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:23.211Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:23.225Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:23.239Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:23.253Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:23.267Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:23.281Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:23.295Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:23.310Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:23.324Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:23.338Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:23.352Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:23.367Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:23.381Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:23.395Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:23.409Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:23.423Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:23.437Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:23.451Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:23.465Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:23.479Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:23.493Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:23.507Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:23.521Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:23.535Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:23.549Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:23.564Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:23.577Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:23.591Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:23.605Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:23.619Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:23.633Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:23.647Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:23.661Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:24.464Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:24.478Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c0,e,e1,e,b9,0,c8,
2022-07-25T05:16:24.492Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:16:24.507Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:24.520Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.534Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.547Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.562Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.576Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.589Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.603Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.617Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.630Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.644Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.658Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.672Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:24.686Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:26.356Z DEBUG modem << Tx: 13
2022-07-25T05:16:26.374Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:16:27.206Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:27.222Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:27.236Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:27.252Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:27.266Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:27.280Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:27.295Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:27.309Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:27.324Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:27.338Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:27.353Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:27.368Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:27.382Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:27.396Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:27.411Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:27.425Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:27.439Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:27.457Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:27.471Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:27.486Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:27.500Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:27.514Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:27.528Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:27.543Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:27.557Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:27.571Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:28.409Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:28.425Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:16:28.439Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:28.454Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:28.469Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.483Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.498Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.512Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.527Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.541Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.555Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.570Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.584Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.599Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.613Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.627Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:28.642Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:30.404Z DEBUG modem << Tx: 13
2022-07-25T05:16:30.420Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:16:31.258Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:31.275Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:31.290Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:31.304Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:31.319Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:31.334Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:31.350Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:31.364Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:31.378Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:31.393Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:31.408Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:31.422Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:31.436Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:32.423Z DEBUG modem << [00:10:20.643,005] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:16:32.438Z DEBUG modem << [00:10:20.651,367] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:16:32.452Z DEBUG modem << [00:10:20.658,325] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:16:32.467Z DEBUG modem << [00:10:20.667,419] [1;33m<wrn> modules_common: bms_DALY: Message could not be enqueued, error code: -35[0m
2022-07-25T05:16:33.270Z DEBUG modem << [00:10:20.677,062] [1;31m<err> bms_module: Message could not be enqueued in bms_event_handler[0m
2022-07-25T05:16:33.286Z DEBUG modem << [00:10:20.686,187] [0m<inf> app_event_manager: e:bms_module_event BMS_EVT_ERROR - Error code -35[0m
2022-07-25T05:16:33.300Z DEBUG modem << [00:10:20.695,373] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:16:33.315Z DEBUG modem << [00:10:20.702,789] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:16:33.329Z DEBUG modem << [00:10:20.709,808] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:16:33.343Z DEBUG modem << [00:10:20.716,400] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:16:33.358Z DEBUG modem << [00:10:20.724,609] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:16:33.372Z DEBUG modem << [00:10:20.732,666] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:16:33.386Z DEBUG modem << [00:10:20.741,119] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:16:33.400Z DEBUG modem << [00:10:20.748,901] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:16:33.415Z DEBUG modem << [00:10:20.756,591] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:16:33.429Z DEBUG modem << [00:10:20.763,122] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:16:33.443Z DEBUG modem << [00:10:20.770,019] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:16:33.458Z DEBUG modem << [00:10:20.782,379] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:16:33.472Z DEBUG modem << [00:10:20.790,252] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:16:33.486Z DEBUG modem << [00:10:20.804,412] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:16:33.500Z DEBUG modem << [00:10:20.811,370] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:16:33.515Z DEBUG modem << [00:10:20.820,770] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:16:33.529Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:16:33.543Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:16:33.558Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:33.572Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:33.586Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.600Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.614Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.628Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.642Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.656Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.670Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.684Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.699Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.713Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.727Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.741Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.755Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:33.770Z DEBUG modem << [00:10:20.874,664] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:16:33.788Z DEBUG modem << [00:10:20.884,033] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:16:33.803Z DEBUG modem << [00:10:20.893,798] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:16:33.817Z DEBUG modem << [00:10:20.903,869] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:33.831Z DEBUG modem << [00:10:20.913,665] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:16:33.847Z DEBUG modem << [00:10:20.922,790] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 2 of 9 in sensor buffer filled[0m
2022-07-25T05:16:33.862Z DEBUG modem << [00:10:20.934,295] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:33.876Z DEBUG modem << [00:10:20.944,091] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:16:33.891Z DEBUG modem << [00:10:20.955,718] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:33.905Z DEBUG modem << [00:10:21.034,515] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:16:33.919Z DEBUG modem << [00:10:21.044,769] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:33.933Z DEBUG modem << [00:10:21.123,992] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:16:33.947Z DEBUG modem << [00:10:21.137,817] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:16:33.961Z DEBUG modem << [00:10:21.148,498] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:34.785Z DEBUG modem << Tx: 13
2022-07-25T05:16:34.801Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:16:36.626Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:16:36.641Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:16:36.655Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:36.670Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:36.684Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:36.698Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.492Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.507Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.521Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.535Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.549Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.563Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.578Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.592Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.606Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.621Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.635Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:37.649Z DEBUG modem << [00:10:24.924,865] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2040,0,0,0 [0m
2022-07-25T05:16:37.663Z DEBUG modem << [00:10:24.933,258] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:16:37.677Z DEBUG modem << [00:10:24.941,680] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:16:37.691Z DEBUG modem << [00:10:24.952,911] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:16:37.705Z DEBUG modem << [00:10:24.960,357] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:16:37.719Z DEBUG modem << [00:10:24.967,376] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:16:37.733Z DEBUG modem << [00:10:24.974,426] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:16:37.747Z DEBUG modem << [00:10:24.981,414] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:16:37.761Z DEBUG modem << Tx: 13
2022-07-25T05:16:37.775Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:16:37.789Z DEBUG modem << [00:10:24.994,110] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:16:37.803Z DEBUG modem << [00:10:25.004,150] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:16:37.817Z DEBUG modem << [00:10:25.015,136] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:16:37.831Z DEBUG modem << [00:10:25.023,437] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:37.845Z DEBUG modem << [00:10:25.033,233] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:16:38.759Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:16:38.775Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:16:38.789Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:38.804Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:38.818Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:38.832Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:38.847Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:38.861Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:38.875Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:38.889Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:38.903Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:38.918Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:38.932Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:39.721Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:39.735Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:39.750Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:39.764Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:40.773Z DEBUG modem << Tx: 13
2022-07-25T05:16:40.790Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:16:41.600Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:41.615Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:41.629Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:41.644Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:41.658Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:41.672Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:41.687Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:41.701Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:41.716Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:41.731Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:41.745Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:41.759Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:41.773Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:42.574Z DEBUG modem << [00:10:30.376,129] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:16:43.369Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:16:43.384Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:16:43.398Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:43.413Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:43.427Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.442Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.456Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.471Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.485Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.500Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.514Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.529Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.544Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.559Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.573Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.588Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:43.602Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:44.823Z DEBUG modem << Tx: 13
2022-07-25T05:16:44.838Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:16:46.868Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:16:46.884Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:16:47.722Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:47.738Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:47.754Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.769Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.783Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.798Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.813Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.827Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.842Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.857Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.871Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.886Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.901Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.916Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:47.930Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:48.873Z DEBUG modem << Tx: 13
2022-07-25T05:16:48.889Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:16:50.902Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:16:50.918Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:16:51.707Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:51.722Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:51.737Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.752Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.767Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.781Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.796Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.811Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.825Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.840Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.854Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.868Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.883Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.897Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:51.912Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:52.748Z DEBUG modem << [00:10:40.642,974] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:16:52.765Z DEBUG modem << [00:10:40.651,336] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:16:52.780Z DEBUG modem << [00:10:40.658,294] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:16:52.797Z DEBUG modem << [00:10:40.667,755] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:16:52.813Z DEBUG modem << [00:10:40.674,346] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:16:52.827Z DEBUG modem << [00:10:40.682,556] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:16:52.842Z DEBUG modem << [00:10:40.690,582] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:16:52.856Z DEBUG modem << [00:10:40.699,066] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:16:52.871Z DEBUG modem << [00:10:40.706,817] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:16:52.885Z DEBUG modem << [00:10:40.714,508] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:16:52.900Z DEBUG modem << [00:10:40.721,038] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:16:52.914Z DEBUG modem << [00:10:40.727,935] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:16:52.929Z DEBUG modem << [00:10:40.740,295] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:16:52.944Z DEBUG modem << [00:10:40.748,168] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:16:52.958Z DEBUG modem << [00:10:40.762,329] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:16:52.973Z DEBUG modem << [00:10:40.769,256] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:16:52.987Z DEBUG modem << [00:10:40.778,656] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:16:53.001Z DEBUG modem << [00:10:40.785,766] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:16:53.016Z DEBUG modem << [00:10:40.795,135] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:16:53.031Z DEBUG modem << [00:10:40.804,901] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:16:53.053Z DEBUG modem << [00:10:40.814,971] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:16:53.068Z DEBUG modem << [00:10:40.824,066] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 3 of 9 in sensor buffer filled[0m
2022-07-25T05:16:53.082Z DEBUG modem << [00:10:40.835,571] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:53.097Z DEBUG modem << [00:10:40.845,336] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:16:53.111Z DEBUG modem << [00:10:40.856,964] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:53.126Z DEBUG modem << [00:10:40.935,760] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:16:53.141Z DEBUG modem << [00:10:40.946,014] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:53.992Z DEBUG modem << [00:10:41.025,238] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:16:54.010Z DEBUG modem << [00:10:41.039,062] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:16:54.025Z DEBUG modem << [00:10:41.049,682] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:16:54.040Z DEBUG modem << Tx: 13
2022-07-25T05:16:54.054Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:16:54.069Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:54.084Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:54.098Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:54.113Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:54.127Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:54.142Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:54.157Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:54.171Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:54.186Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:54.204Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:54.219Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:54.234Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:54.248Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:55.056Z DEBUG modem <<  bms incoming_message: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:16:55.071Z DEBUG modem << buffer_1: a5,1,94,8,7,1,0,0,0,0,0,0,4a,
2022-07-25T05:16:55.086Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:16:55.101Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:55.116Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.130Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.145Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.159Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.173Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.188Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.203Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.217Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.232Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.246Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.261Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.275Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:55.289Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:56.982Z DEBUG modem << Tx: 13
2022-07-25T05:16:56.997Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:16:57.824Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:57.839Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:57.854Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:57.868Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:57.882Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:57.896Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:57.911Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:57.925Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:57.940Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:57.954Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:57.968Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:57.982Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:57.996Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:58.011Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:58.026Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:58.040Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:58.054Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:58.068Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:58.082Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:58.096Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:58.111Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:58.125Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:58.139Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:58.154Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:58.168Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:58.182Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:58.196Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:16:58.210Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:16:58.225Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:16:58.240Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:16:58.254Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:16:58.268Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:16:58.282Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:16:58.297Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:16:58.311Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:16:58.326Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:16:58.340Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:16:58.354Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:16:58.368Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:16:59.168Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:59.184Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:16:59.199Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:16:59.215Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:16:59.229Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.243Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.257Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.271Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.285Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.299Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.314Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.328Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.343Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.357Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.371Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.385Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:16:59.399Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:01.030Z DEBUG modem << Tx: 13
2022-07-25T05:17:01.045Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:17:01.858Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:01.874Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:01.889Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:01.903Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:01.918Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:01.932Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:01.947Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:01.961Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:01.976Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:01.990Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:02.004Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:02.019Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:02.033Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:02.048Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:02.062Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:02.076Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:02.090Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:02.104Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:02.118Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:02.133Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:02.147Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:02.162Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:02.176Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:02.191Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:02.205Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:02.219Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:03.085Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:03.100Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:17:03.115Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:03.129Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:17:03.144Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.158Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.172Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.187Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.201Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.215Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.230Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.244Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.258Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.272Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.286Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.300Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:03.315Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:05.103Z DEBUG modem << Tx: 13
2022-07-25T05:17:05.117Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:17:05.905Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:05.922Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:05.936Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:05.951Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:05.966Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:05.980Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:05.995Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:06.010Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:06.025Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:06.039Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:06.053Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:06.068Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:06.082Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:07.126Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:17:07.141Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:17:07.159Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:07.173Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:17:07.956Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:07.970Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:07.985Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:07.999Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:08.014Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:08.028Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:08.042Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:08.056Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:08.070Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:08.085Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:08.099Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:08.113Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:08.128Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:09.146Z DEBUG modem << Tx: 13
2022-07-25T05:17:09.162Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:17:09.961Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:09.976Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:09.990Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:10.761Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:10.776Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:10.790Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:10.804Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:10.819Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:10.833Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:10.848Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:10.863Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:10.877Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:10.891Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:11.691Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:17:11.706Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:17:11.720Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:11.735Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:17:11.749Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.763Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.778Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.793Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.807Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.822Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.836Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.851Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.865Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.879Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.893Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.908Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.922Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:11.936Z DEBUG modem << [00:10:59.446,472] [1;33m<wrn> bms_module: on line 327 3.8090,3.7680,3809,0,0.2040,0,0,0 [0m
2022-07-25T05:17:11.950Z DEBUG modem << [00:10:59.454,833] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:17:11.965Z DEBUG modem << [00:10:59.463,256] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:17:11.979Z DEBUG modem << [00:10:59.474,456] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:17:11.994Z DEBUG modem << [00:10:59.481,903] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:17:12.009Z DEBUG modem << [00:10:59.488,922] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:17:12.023Z DEBUG modem << [00:10:59.495,971] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:17:12.038Z DEBUG modem << [00:10:59.502,929] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:17:12.052Z DEBUG modem << [00:10:59.510,009] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:17:12.067Z DEBUG modem << [00:10:59.516,998] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:17:12.081Z DEBUG modem << Tx: 13
2022-07-25T05:17:12.095Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:17:12.109Z DEBUG modem << [00:10:59.529,510] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:17:12.124Z DEBUG modem << [00:10:59.538,879] [1;33m<wrn> cloud_codec_ringbuffer: On line 33 in ringbuffer[0m
2022-07-25T05:17:12.138Z DEBUG modem << [00:10:59.546,447] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 0 of 2 in bms buffer filled[0m
2022-07-25T05:17:12.152Z DEBUG modem << [00:10:59.557,403] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:17:12.166Z DEBUG modem << [00:10:59.565,704] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:12.180Z DEBUG modem << [00:1Capture 1 data bytes:
2022-07-25T05:17:12.195Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:12.210Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:12.224Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:12.239Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:12.253Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:12.268Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:12.282Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:12.296Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:12.310Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:12.324Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:12.338Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:12.353Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:12.367Z DEBUG modem << 0:59.575,469] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:17:13.172Z DEBUG modem << [00:11:00.383,331] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:17:13.949Z DEBUG modem << [00:11:00.643,005] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:17:13.964Z DEBUG modem << [00:11:00.651,397] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:17:13.979Z DEBUG modem << [00:11:00.658,325] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:17:13.993Z DEBUG modem << [00:11:00.667,785] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:17:14.011Z DEBUG modem << [00:11:00.674,377] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:17:14.025Z DEBUG modem << [00:11:00.682,586] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:17:14.039Z DEBUG modem << [00:11:00.690,643] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:17:14.054Z DEBUG modem << [00:11:00.699,127] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:17:14.068Z DEBUG modem << [00:11:00.706,878] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:17:14.082Z DEBUG modem << [00:11:00.714,569] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:17:14.096Z DEBUG modem << [00:11:00.721,130] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:17:14.110Z DEBUG modem << [00:11:00.728,027] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:17:14.124Z DEBUG modem << [00:11:00.740,386] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:17:14.138Z DEBUG modem << [00:11:00.748,260] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:17:14.153Z DEBUG modem << [00:11:00.762,420] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:17:14.167Z DEBUG modem << [00:11:00.769,378] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:17:14.181Z DEBUG modem << [00:11:00.778,778] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:17:14.196Z DEBUG modem << [00:11:00.785,888] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:17:14.211Z DEBUG modem << [00:11:00.795,288] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:17:14.225Z DEBUG modem << [00:11:00.805,023] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:17:14.239Z DEBUG modem << [00:11:00.815,093] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:17:14.254Z DEBUG modem << [00:11:00.824,218] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 4 of 9 in sensor buffer filled[0m
2022-07-25T05:17:14.268Z DEBUG modem << [00:11:00.835,693] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:14.282Z DEBUG modem << [00:11:00.845,489] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:17:14.296Z DEBUG modem << [00:11:00.857,116] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:14.310Z DEBUG modem << [00:11:00.935,943] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:17:14.324Z DEBUG modem << [00:11:00.946,197] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:14.338Z DEBUG modem << [00:11:01.025,421] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:17:14.353Z DEBUG modem << [00:11:01.039,245] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:17:14.367Z DEBUG modem << [00:11:01.049,865] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:15.150Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:17:15.166Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:17:15.181Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:15.195Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:17:15.210Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.225Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.239Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.253Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.268Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.282Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.296Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.310Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.324Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.339Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.353Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.368Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:15.382Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:16.170Z DEBUG modem << Tx: 13
2022-07-25T05:17:16.185Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:17:16.199Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:16.214Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:16.228Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:16.242Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:16.256Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:16.270Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:16.285Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:16.299Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:16.313Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:16.327Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:16.342Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:16.357Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:16.372Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:17.427Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:17:17.444Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:17:17.461Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:17.476Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:17:17.490Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.504Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.519Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.533Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.547Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.561Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.576Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.590Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.604Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.619Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.634Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.649Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:17.664Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:19.374Z DEBUG modem << Tx: 13
2022-07-25T05:17:19.392Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:17:20.186Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:20.201Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:20.216Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:20.984Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:21.000Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:21.014Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:21.029Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:21.043Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:21.058Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:21.074Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:21.088Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:21.102Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:21.117Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:21.913Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:17:21.928Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:17:21.943Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:21.957Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:17:21.971Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:21.985Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.000Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.014Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.028Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.042Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.056Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.071Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.085Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.100Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.114Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.128Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:22.912Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:23.694Z DEBUG modem << Tx: 13
2022-07-25T05:17:23.709Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:17:25.440Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:17:25.457Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:17:26.245Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:26.259Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:17:26.274Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.288Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.304Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.319Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.333Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.347Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.362Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.376Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.390Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.404Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.419Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.433Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:26.448Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:27.470Z DEBUG modem << Tx: 13
2022-07-25T05:17:27.485Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:17:29.514Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:17:29.529Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:17:30.334Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:30.349Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:17:30.363Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.378Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.392Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.406Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.421Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.436Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.450Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.464Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.479Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.493Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.508Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.522Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:30.537Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:31.528Z DEBUG modem << Tx: 13
2022-07-25T05:17:31.543Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:17:32.318Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:32.333Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:32.348Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:32.364Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:32.378Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:32.392Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:32.406Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:32.421Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:32.435Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:32.449Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:32.463Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:32.478Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:32.492Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:32.506Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:32.520Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:32.535Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:32.549Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:32.563Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:32.578Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:32.592Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:32.606Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:32.620Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:32.634Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:32.648Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:32.662Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:32.677Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:32.691Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:32.705Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:32.719Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:32.733Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:32.747Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:32.761Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:32.775Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:32.793Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:32.808Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:32.822Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:32.836Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:32.850Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:32.864Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:33.650Z DEBUG modem << [00:11:20.643,035] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:17:33.664Z DEBUG modem << [00:11:20.651,428] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:17:33.679Z DEBUG modem << [00:11:20.658,355] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:17:33.693Z DEBUG modem << [00:11:20.667,816] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:17:33.708Z DEBUG modem << [00:11:20.674,438] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:17:33.722Z DEBUG modem << [00:11:20.682,647] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:17:33.736Z DEBUG modem << [00:11:20.690,673] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:17:33.750Z DEBUG modem << [00:11:20.699,157] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:17:33.765Z DEBUG modem << [00:11:20.706,909] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:17:33.779Z DEBUG modem << [00:11:20.714,599] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:17:33.793Z DEBUG modem << [00:11:20.721,160] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:17:33.808Z DEBUG modem << [00:11:20.728,027] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:17:33.822Z DEBUG modem << [00:11:20.740,386] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:17:33.836Z DEBUG modem << [00:11:20.748,291] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:17:33.850Z DEBUG modem << [00:11:20.762,420] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:17:33.865Z DEBUG modem << [00:11:20.769,348] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:17:33.879Z DEBUG modem << [00:11:20.778,747] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:17:33.893Z DEBUG modem << [00:11:20.785,858] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:17:33.907Z DEBUG modem << [00:11:20.795,257] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:17:33.922Z DEBUG modem << [00:11:20.804,992] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:17:33.936Z DEBUG modem << [00:11:20.815,032] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:17:33.950Z DEBUG modem << [00:11:20.824,157] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 5 of 9 in sensor buffer filled[0m
2022-07-25T05:17:33.964Z DEBUG modem << [00:11:20.835,662] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:33.979Z DEBUG modem << [00:11:20.845,458] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:17:33.993Z DEBUG modem << [00:11:20.857,055] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:34.007Z DEBUG modem << [00:11:20.935,882] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:17:34.021Z DEBUG modem << [00:11:20.946,136] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:34.035Z DEBUG modem << [00:11:21.025,360] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:17:34.049Z DEBUG modem << [00:11:21.039,184] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:17:34.064Z DEBUG modem << [00:11:21.049,835] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:34.841Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:17:34.857Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b8,0,c8,
2022-07-25T05:17:34.872Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:17:34.886Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:17:34.900Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:34.914Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:34.928Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:34.947Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:34.961Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:34.975Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:34.989Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:35.003Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:35.016Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:35.031Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:35.052Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:35.066Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:35.081Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:35.874Z DEBUG modem << Tx: 13
2022-07-25T05:17:35.889Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:17:35.904Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:35.918Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:35.935Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:35.950Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:35.964Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:35.978Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:35.993Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:36.007Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:36.021Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:36.036Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:36.050Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:36.065Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:36.079Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:36.093Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:36.107Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:36.121Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:36.135Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:36.150Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:36.164Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:36.178Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:36.193Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:36.207Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:36.221Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:36.235Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:36.250Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:36.265Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:37.079Z DEBUG modem << [00:11:25.027,343] [0m<inf> app_event_manager: e:ui_module_event UI_EVT_BUTTON_DATA_READY[0m
2022-07-25T05:17:37.095Z DEBUG modem << [00:11:25.036,041] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_ui_buffer: Entry: 1 of 2 in UI buffer filled[0m
2022-07-25T05:17:37.109Z DEBUG modem << [00:11:25.046,966] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_UI_DATA_READY[0m
2022-07-25T05:17:37.129Z DEBUG modem << [00:11:25.055,572] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:17:37.144Z DEBUG modem << [00:11:25.062,530] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:17:37.158Z DEBUG modem << [00:11:25.072,143] [0m<dbg> cloud_codec: cloud_codec_encode_ui_data: Entered cloud_codec_encode_ui_data[0m
2022-07-25T05:17:37.173Z DEBUG modem << Encoded message:
2022-07-25T05:17:37.188Z DEBUG modem << {
2022-07-25T05:17:37.202Z DEBUG modem << "btn":{
2022-07-25T05:17:37.217Z DEBUG modem << "v":1,
2022-07-25T05:17:37.232Z DEBUG modem << "ts":1658726256292
2022-07-25T05:17:37.246Z DEBUG modem << }
2022-07-25T05:17:37.260Z DEBUG modem << }
2022-07-25T05:17:37.275Z DEBUG modem << [00:11:25.089,782] [0m<dbg> data_module: data_list_add_pending: Pending data added: 0x200293b0[0m
2022-07-25T05:17:37.289Z DEBUG modem << [00:11:25.098,693] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_UI_DATA_SEND[0m
2022-07-25T05:17:37.303Z DEBUG modem << [00:11:25.107,208] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:17:37.317Z DEBUG modem << [00:11:25.114,166] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:17:37.332Z DEBUG modem << [00:11:25.123,748] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:17:37.346Z DEBUG modem << [00:11:25.139,892] [0m<dbg> cloud_module: ui_data_send: UI sent, data pointer: 0x200293b0[0m
2022-07-25T05:17:37.361Z DEBUG modem << [00:11:25.148,315] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_ACK[0m
2022-07-25T05:17:37.375Z DEBUG modem << [00:11:25.157,196] [0m<dbg> data_module: data_ack: Pending data ACKed: 0x200293b0[0m
2022-07-25T05:17:37.390Z DEBUG modem << %CESQ: 53,2,13,1
2022-07-25T05:17:37.433Z DEBUG modem << [00:11:25.207,000] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -87[0m
2022-07-25T05:17:37.447Z DEBUG modem << %MDMEV: SEARCH STATUS 2
2022-07-25T05:17:37.462Z DEBUG modem << [00:11:25.219,268] [0m<dbg> modem_module: lte_evt_handler: Modem domain event, type: Search done[0m
2022-07-25T05:17:37.476Z DEBUG modem << +CSCON: 1
2022-07-25T05:17:37.490Z DEBUG modem << [00:11:25.300,506] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:17:38.297Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:38.313Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:17:38.327Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:38.342Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:17:38.357Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.371Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.386Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.400Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.415Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.429Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.443Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.458Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.472Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.486Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.501Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.515Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.530Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:38.544Z DEBUG modem << %CESQ: 57,2,18,2
2022-07-25T05:17:38.579Z DEBUG modem << [00:11:26.316,986] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -83[0m
2022-07-25T05:17:39.620Z DEBUG modem << Tx: 13
2022-07-25T05:17:39.635Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:17:40.434Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:40.449Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:40.464Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:40.478Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:40.492Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:40.507Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:40.522Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:40.536Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:40.551Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:40.565Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:40.580Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:40.594Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:40.608Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:41.668Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:17:41.684Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:17:41.698Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:41.712Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:17:42.496Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.510Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.525Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.539Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.553Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.568Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.582Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.596Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.610Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.624Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.639Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.653Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:42.668Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:43.434Z DEBUG modem << [00:11:30.123,870] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:17:43.450Z DEBUG modem << [00:11:30.390,563] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:17:44.235Z DEBUG modem << +CSCON: 0
2022-07-25T05:17:44.250Z DEBUG modem << [00:11:31.245,147] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Idle[0m
2022-07-25T05:17:45.013Z DEBUG modem << Tx: 13
2022-07-25T05:17:45.028Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:17:45.043Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:45.058Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:45.072Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:45.086Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:45.100Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:45.114Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:45.128Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:45.142Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:45.157Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:45.172Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:45.186Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:45.200Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:45.214Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:45.228Z DEBUG modem << %CESQ: 49,2,16,2
2022-07-25T05:17:45.263Z DEBUG modem << [00:11:32.475,769] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -91[0m
2022-07-25T05:17:46.057Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:17:46.074Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:17:46.089Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:46.103Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:17:46.118Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.132Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.147Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.162Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.176Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.190Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.204Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.220Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.236Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.250Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.265Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.279Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.293Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:46.308Z DEBUG modem << [00:11:33.982,208] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,0,0.2040,0,0,0 [0m
2022-07-25T05:17:46.322Z DEBUG modem << [00:11:33.990,631] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:17:46.336Z DEBUG modem << [00:11:33.999,481] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:17:46.351Z DEBUG modem << [00:11:34.010,681] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:17:46.365Z DEBUG modem << [00:11:34.018,127] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:17:46.380Z DEBUG modem << [00:11:34.025,207] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:17:46.394Z DEBUG modem << [00:11:34.032,257] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:17:46.408Z DEBUG modem << [00:11:34.039,215] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:17:46.423Z DEBUG modem << [00:11:34.046,295] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:17:46.437Z DEBUG modem << [00:11:34.053,375] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:17:46.451Z DEBUG modem << Tx: 13
2022-07-25T05:17:46.466Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:17:46.480Z DEBUG modem << [00:11:34.065,887] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:17:46.495Z DEBUG modem << [00:11:34.075,439] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 1 of 2 in bms buffer filled[0m
2022-07-25T05:17:46.509Z DEBUG modem << [00:11:34.086,395] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:17:46.523Z DEBUG modem << [00:11:34.094,726] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:46.538Z DEBUG modem << [00:11:34.104,492] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:17:46.552Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:46.566Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:46.580Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:46.595Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:46.609Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:46.624Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:46.638Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:46.652Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:46.667Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:46.681Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:46.701Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:46.722Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:46.739Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:47.602Z DEBUG modem << [00:11:35.123,962] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:17:48.395Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:17:48.411Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:17:48.425Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:48.439Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:17:48.455Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.469Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.483Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.497Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.512Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.526Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.540Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.554Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.568Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.583Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.597Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.611Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:48.626Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:49.857Z DEBUG modem << Tx: 13
2022-07-25T05:17:49.874Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:17:50.683Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:50.699Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:50.714Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:50.729Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:50.744Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:50.758Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:50.773Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:50.787Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:50.801Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:50.815Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:50.830Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:50.844Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:50.858Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:51.906Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:17:51.921Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:17:51.935Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:51.950Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:17:51.964Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:51.978Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:51.992Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.006Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.020Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.034Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.048Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.062Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.076Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.090Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.104Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.118Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.133Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:52.934Z DEBUG modem << [00:11:40.643,066] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:17:52.950Z DEBUG modem << [00:11:40.651,458] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:17:52.964Z DEBUG modem << [00:11:40.658,416] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:17:52.978Z DEBUG modem << [00:11:40.667,877] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:17:52.992Z DEBUG modem << [00:11:40.674,499] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:17:53.006Z DEBUG modem << [00:11:40.682,708] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:17:53.020Z DEBUG modem << [00:11:40.690,765] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:17:53.034Z DEBUG modem << [00:11:40.699,249] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:17:53.048Z DEBUG modem << [00:11:40.707,031] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:17:53.062Z DEBUG modem << [00:11:40.714,721] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:17:53.076Z DEBUG modem << [00:11:40.721,282] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:17:53.090Z DEBUG modem << [00:11:40.728,179] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:17:53.104Z DEBUG modem << [00:11:40.740,539] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:17:53.118Z DEBUG modem << [00:11:40.748,443] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:17:53.132Z DEBUG modem << [00:11:40.762,603] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:17:53.146Z DEBUG modem << [00:11:40.769,561] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:17:53.160Z DEBUG modem << [00:11:40.778,961] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:17:53.174Z DEBUG modem << [00:11:40.786,071] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:17:53.188Z DEBUG modem << [00:11:40.795,471] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:17:53.202Z DEBUG modem << [00:11:40.805,236] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:17:53.216Z DEBUG modem << [00:11:40.815,307] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:17:53.230Z DEBUG modem << [00:11:40.824,401] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 6 of 9 in sensor buffer filled[0m
2022-07-25T05:17:53.244Z DEBUG modem << [00:11:40.835,906] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:53.258Z DEBUG modem << [00:11:40.845,703] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:17:53.272Z DEBUG modem << [00:11:40.857,299] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:53.286Z DEBUG modem << [00:11:40.925,872] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:17:53.300Z DEBUG modem << [00:11:40.936,126] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:53.314Z DEBUG modem << [00:11:41.004,730] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
2022-07-25T05:17:53.328Z DEBUG modem << [00:11:41.015,045] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_modem_dynamic_buffer: Entry: 1 of 2 in dynamic modem buffer filled[0m
2022-07-25T05:17:53.343Z DEBUG modem << [00:11:41.027,740] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:17:54.158Z DEBUG modem << Tx: 13
2022-07-25T05:17:54.173Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:17:54.189Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:17:54.205Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:17:54.221Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:17:54.236Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:17:54.252Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:17:54.267Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:17:54.282Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:17:54.297Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:17:54.311Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:17:54.326Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:17:54.340Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:17:54.354Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:17:54.369Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:17:55.954Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:17:55.969Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:17:55.984Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:17:55.998Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:17:56.013Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:56.028Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:56.043Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:56.057Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:56.071Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:56.086Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:56.100Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:56.114Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:56.129Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:57.003Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:57.017Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:57.035Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:57.049Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:17:57.956Z DEBUG modem << Tx: 13
2022-07-25T05:17:57.971Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:17:59.965Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:17:59.979Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:18:00.773Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:00.789Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:00.803Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.818Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.832Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.846Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.860Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.874Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.888Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.902Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.916Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.930Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.944Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.958Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:00.972Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:02.010Z DEBUG modem << Tx: 13
2022-07-25T05:18:02.024Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:18:02.993Z DEBUG modem << %CESQ: 255,0,255,0
2022-07-25T05:18:04.055Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:18:04.848Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:18:04.863Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:04.877Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:04.891Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:04.906Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:04.920Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:04.934Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:04.949Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:04.963Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:04.977Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:04.992Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:05.006Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:05.020Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:05.034Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:05.049Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:05.063Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:06.061Z DEBUG modem << Tx: 13
2022-07-25T05:18:06.076Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:18:06.868Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:06.884Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:06.900Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:06.914Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:06.928Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:06.942Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:06.957Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:06.972Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:06.986Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:07.001Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:07.015Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:07.029Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:07.044Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:07.058Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:07.073Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:07.087Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:07.102Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:07.116Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:07.130Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:07.145Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:07.160Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:07.174Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:07.188Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:07.203Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:07.217Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:07.231Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:07.245Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:07.260Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:07.275Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:07.289Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:07.303Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:07.317Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:07.332Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:07.346Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:07.360Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:07.375Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:07.389Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:07.405Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:07.419Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:08.214Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:08.230Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:18:08.245Z DEBUG modem << a5,1,95,8,2,e,d7,e,ce,e,d4,0,e8,
2022-07-25T05:18:08.260Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:08.274Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.288Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.303Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.317Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.331Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.345Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.360Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.375Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.389Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.403Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.417Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.431Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:08.446Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:10.119Z DEBUG modem << Tx: 13
2022-07-25T05:18:10.133Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:18:10.927Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:10.945Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:10.959Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:10.973Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:10.987Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:11.001Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:11.016Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:11.030Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:11.044Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:11.058Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:11.072Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:11.086Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:11.100Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:11.114Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:11.128Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:11.142Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:11.156Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:11.170Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:11.184Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:11.198Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:11.212Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:11.227Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:11.241Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:11.255Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:11.269Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:11.284Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:12.166Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:12.183Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:18:12.946Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:12.961Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:12.976Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:12.990Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.004Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.018Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.032Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0[00:12:00.397,735] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:18:13.046Z DEBUG modem << ,0,
2022-07-25T05:18:13.061Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.075Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.089Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.103Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.118Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.132Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.146Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.160Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:13.948Z DEBUG modem << [00:12:00.643,096] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:18:13.962Z DEBUG modem << [00:12:00.651,458] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:18:13.976Z DEBUG modem << [00:12:00.658,416] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:18:13.990Z DEBUG modem << [00:12:00.667,877] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:18:14.004Z DEBUG modem << [00:12:00.674,499] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:18:14.019Z DEBUG modem << [00:12:00.682,708] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:18:14.034Z DEBUG modem << [00:12:00.690,734] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:18:14.048Z DEBUG modem << [00:12:00.699,218] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:18:14.062Z DEBUG modem << [00:12:00.707,000] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:18:14.076Z DEBUG modem << [00:12:00.714,660] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:18:14.091Z DEBUG modem << [00:12:00.721,221] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:18:14.105Z DEBUG modem << [00:12:00.728,118] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:18:14.119Z DEBUG modem << [00:12:00.740,478] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:18:14.134Z DEBUG modem << [00:12:00.748,352] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:18:14.148Z DEBUG modem << [00:12:00.762,512] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:18:14.162Z DEBUG modem << [00:12:00.769,470] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:18:14.176Z DEBUG modem << [00:12:00.778,869] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:18:14.191Z DEBUG modem << [00:12:00.785,980] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:18:14.205Z DEBUG modem << [00:12:00.795,379] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:18:14.219Z DEBUG modem << [00:12:00.805,114] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:18:14.233Z DEBUG modem << [00:12:00.815,155] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:18:14.248Z DEBUG modem << [00:12:00.824,279] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 7 of 9 in sensor buffer filled[0m
2022-07-25T05:18:14.262Z DEBUG modem << [00:12:00.835,784] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:14.277Z DEBUG modem << [00:12:00.845,550] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:18:14.291Z DEBUG modem << [00:12:00.857,177] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:14.306Z DEBUG modem << [00:12:00.936,492] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:18:14.320Z DEBUG modem << [00:12:00.946,746] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:14.334Z DEBUG modem << [00:12:01.025,970] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:18:14.349Z DEBUG modem << [00:12:01.039,794] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:18:14.363Z DEBUG modem << [00:12:01.050,445] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:15.141Z DEBUG modem << Tx: 13
2022-07-25T05:18:15.157Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:18:15.171Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:15.186Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:15.200Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:15.215Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:15.229Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:15.244Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:15.258Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:15.272Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:15.286Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:15.300Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:15.314Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:15.329Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:15.343Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:16.217Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:18:16.238Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:18:17.003Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:17.020Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:17.035Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.051Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.067Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.082Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.098Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.113Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.129Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.145Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.160Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.177Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.192Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.208Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:17.224Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:18.245Z DEBUG modem << Tx: 13
2022-07-25T05:18:18.259Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:18:19.041Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:19.055Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:19.068Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:19.081Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:19.095Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:19.108Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:19.122Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:19.135Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:19.148Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:19.161Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:19.174Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:19.187Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:19.200Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:20.397Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:18:20.411Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:18:20.425Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:20.438Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:20.452Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.465Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.479Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.492Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.505Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.519Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.532Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.546Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.559Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.573Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.586Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.599Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.613Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:20.626Z DEBUG modem << [00:12:08.525,665] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:18:20.640Z DEBUG modem << [00:12:08.534,210] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:18:21.429Z DEBUG modem << [00:12:08.542,633] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:18:21.443Z DEBUG modem << [00:12:08.553,833] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:18:21.456Z DEBUG modem << [00:12:08.561,279] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:18:21.470Z DEBUG modem << [00:12:08.568,298] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:18:21.483Z DEBUG modem << [00:12:08.575,347] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:18:21.497Z DEBUG modem << [00:12:08.582,336] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:18:21.510Z DEBUG modem << [00:12:08.589,416] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:18:21.523Z DEBUG modem << [00:12:08.596,374] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:18:21.536Z DEBUG modem << Tx: 13
2022-07-25T05:18:21.550Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:18:21.563Z DEBUG modem << [00:12:08.608,917] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:18:21.576Z DEBUG modem << [00:12:08.618,347] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:18:21.590Z DEBUG modem << [00:12:08.629,333] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:18:21.604Z DEBUG modem << [00:12:08.637,634] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:21.617Z DEBUG modem << [00:12:08.647,430] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:18:21.631Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:21.644Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:21.658Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:21.671Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:21.684Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:21.698Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:21.711Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:21.724Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:21.737Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:21.751Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:21.764Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:21.777Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:21.791Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:22.592Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:18:22.606Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:18:22.620Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:22.633Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:22.646Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.659Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.672Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.685Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.698Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.711Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.724Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.737Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.750Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.763Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.777Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.790Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:22.803Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:24.413Z DEBUG modem << Tx: 13
2022-07-25T05:18:24.428Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:18:25.225Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:25.239Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:25.252Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:25.265Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:25.278Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:25.291Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:25.304Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:25.318Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:25.330Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:25.343Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:25.357Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:25.370Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:25.383Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:26.454Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:18:26.468Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:18:26.481Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:26.494Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:26.507Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.520Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.533Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.546Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.559Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.572Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.585Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.598Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.616Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.629Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.642Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.655Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:26.668Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:28.461Z DEBUG modem << Tx: 13
2022-07-25T05:18:28.476Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:18:29.261Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:29.274Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:29.288Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:29.301Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:29.315Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:29.328Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:29.341Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:29.354Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:29.368Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:29.381Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:29.394Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:29.407Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:29.420Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:30.503Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:18:30.517Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:18:30.530Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:30.544Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:30.557Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.571Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.584Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.597Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.611Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.624Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.637Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.654Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.667Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.680Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.693Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.706Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:30.719Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:32.537Z DEBUG modem << [00:12:20.643,157] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:18:32.552Z DEBUG modem << [00:12:20.651,519] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:18:32.566Z DEBUG modem << [00:12:20.658,477] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:18:32.580Z DEBUG modem << [00:12:20.667,938] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:18:32.594Z DEBUG modem << [00:12:20.674,530] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:18:32.608Z DEBUG modem << [00:12:20.682,739] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:18:32.621Z DEBUG modem << [00:12:20.690,765] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:18:32.635Z DEBUG modem << [00:12:20.699,249] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:18:32.649Z DEBUG modem << [00:12:20.707,000] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:18:32.663Z DEBUG modem << [00:12:20.714,691] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:18:32.677Z DEBUG modem << [00:12:20.721,252] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:18:32.690Z DEBUG modem << [00:12:20.728,118] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:18:32.704Z DEBUG modem << [00:12:20.740,509] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:18:32.717Z DEBUG modem << [00:12:20.748,382] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:18:33.492Z DEBUG modem << [00:12:20.762,512] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:18:33.508Z DEBUG modem << [00:12:20.769,470] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:18:33.522Z DEBUG modem << [00:12:20.778,869] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:18:33.536Z DEBUG modem << [00:12:20.785,980] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:18:33.549Z DEBUG modem << [00:12:20.795,349] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:18:33.563Z DEBUG modem << [00:12:20.805,114] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:18:33.576Z DEBUG modem << [00:12:20.815,185] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:18:33.589Z DEBUG modem << [00:12:20.824,310] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 8 of 9 in sensor buffer filled[0m
2022-07-25T05:18:33.603Z DEBUG modem << [00:12:20.835,784] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:33.616Z DEBUG modem << [00:12:20.845,550] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:18:33.630Z DEBUG modem << [00:12:20.857,177] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:33.644Z DEBUG modem << Tx: 13
2022-07-25T05:18:33.657Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:18:33.673Z DEBUG modem << [00:12:20.939,453] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:18:33.688Z DEBUG modem << [00:12:20.949,676] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:34.451Z DEBUG modem << [00:12:21.028,503] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:18:34.465Z DEBUG modem << [00:12:21.042,327] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:18:34.478Z DEBUG modem << [00:12:21.052,947] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:35.247Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:18:35.262Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:18:35.275Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:35.288Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:35.301Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.314Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.327Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.340Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.353Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.366Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.379Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.392Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.405Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.418Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.431Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.444Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:35.457Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:36.674Z DEBUG modem << Tx: 13
2022-07-25T05:18:36.689Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:18:38.712Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:18:38.726Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:18:39.512Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:39.526Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:18:39.539Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.552Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.566Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.579Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.593Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.606Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.619Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.632Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.646Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.659Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.672Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.685Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:39.699Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:40.724Z DEBUG modem << Tx: 13
2022-07-25T05:18:40.739Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:18:41.538Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:41.553Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:41.567Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:41.581Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:41.594Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:41.608Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:41.621Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:41.634Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:41.647Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:41.660Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:41.674Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:41.687Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:41.700Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:41.713Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:41.727Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:41.740Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:41.754Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:41.767Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:41.780Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:41.793Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:41.807Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:41.820Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:41.833Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:41.846Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:41.859Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:41.872Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:41.886Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:41.899Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:41.912Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:41.926Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:41.940Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:41.953Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:41.966Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:41.979Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:41.993Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:42.006Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:42.019Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:42.032Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:42.045Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:42.852Z DEBUG modem << [00:12:30.404,968] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:18:42.866Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:18:42.880Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:18:42.893Z DEBUG modem << a5,1,95,8,2,e,d6,e,cf,e,d4,0,e8,
2022-07-25T05:18:42.906Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:18:42.920Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:42.933Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:42.947Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:42.960Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:42.973Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:42.986Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:42.999Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:43.012Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:43.025Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:43.038Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:43.051Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:43.064Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:43.077Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:44.778Z DEBUG modem << Tx: 13
2022-07-25T05:18:44.794Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:18:45.593Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:45.607Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:45.621Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:45.635Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:45.650Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:45.663Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:45.676Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:45.690Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:45.703Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:45.716Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:45.729Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:45.743Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:45.756Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:45.769Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:45.783Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:45.797Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:45.810Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:45.823Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:45.837Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:45.850Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:45.863Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:45.877Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:45.890Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:45.903Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:45.916Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:45.930Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:46.818Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:46.833Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:18:46.847Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:46.861Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:18:46.874Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:46.887Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:46.900Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:46.914Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:46.927Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:46.940Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:46.954Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:46.967Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:46.980Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:46.994Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:47.007Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:47.020Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:47.034Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:48.819Z DEBUG modem << Tx: 13
2022-07-25T05:18:48.833Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:18:49.628Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:49.642Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:49.655Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:49.669Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:49.682Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:49.696Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:49.709Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:49.722Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:49.735Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:49.749Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:49.762Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:49.775Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:49.789Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:50.833Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:18:51.638Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:18:51.656Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:51.670Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:18:51.684Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.698Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.711Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.726Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.739Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.753Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.767Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.780Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.794Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.807Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.821Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.834Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:51.847Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:52.647Z DEBUG modem << [00:12:40.643,127] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:18:52.662Z DEBUG modem << [00:12:40.651,489] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:18:52.675Z DEBUG modem << [00:12:40.658,447] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:18:52.689Z DEBUG modem << [00:12:40.667,907] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:18:52.702Z DEBUG modem << [00:12:40.674,530] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:18:52.716Z DEBUG modem << [00:12:40.682,739] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:18:52.729Z DEBUG modem << [00:12:40.690,765] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:18:52.743Z DEBUG modem << [00:12:40.699,249] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:18:52.756Z DEBUG modem << [00:12:40.707,000] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:18:52.770Z DEBUG modem << [00:12:40.714,691] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:18:52.783Z DEBUG modem << [00:12:40.721,252] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:18:52.797Z DEBUG modem << [00:12:40.728,118] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:18:52.810Z DEBUG modem << [00:12:40.740,478] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:18:52.824Z DEBUG modem << [00:12:40.748,352] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:18:52.837Z DEBUG modem << [00:12:40.762,481] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:18:52.851Z DEBUG modem << [00:12:40.769,439] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:18:52.864Z DEBUG modem << [00:12:40.778,869] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:18:52.878Z DEBUG modem << [00:12:40.785,980] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:18:52.891Z DEBUG modem << [00:12:40.795,349] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:18:52.905Z DEBUG modem << [00:12:40.805,114] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:18:52.919Z DEBUG modem << [00:12:40.815,185] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:18:52.932Z DEBUG modem << [00:12:40.824,310] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 9 of 9 in sensor buffer filled[0m
2022-07-25T05:18:52.946Z DEBUG modem << [00:12:40.835,815] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:52.959Z DEBUG modem << [00:12:40.845,611] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:18:52.972Z DEBUG modem << [00:12:40.857,208] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:53.759Z DEBUG modem << [00:12:40.936,035] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:18:53.774Z DEBUG modem << [00:12:40.946,289] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:53.788Z DEBUG modem << [00:12:41.025,512] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:18:53.802Z DEBUG modem << [00:12:41.039,337] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:18:53.815Z DEBUG modem << [00:12:41.049,987] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:53.828Z DEBUG modem << Tx: 13
2022-07-25T05:18:53.842Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:18:53.855Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:53.868Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:53.881Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:53.894Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:53.908Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:53.921Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:53.934Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:53.947Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:53.960Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:53.973Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:53.986Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:53.999Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:54.012Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:54.890Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:18:54.904Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:18:55.698Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:55.713Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:18:55.728Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.743Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.756Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.769Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.783Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.796Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.809Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.823Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.836Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.850Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.863Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.877Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.890Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:55.903Z DEBUG modem << [00:12:43.171,539] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,25,0.2050,25,0,0 [0m
2022-07-25T05:18:55.916Z DEBUG modem << [00:12:43.180,084] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:18:55.930Z DEBUG modem << [00:12:43.188,507] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:18:55.943Z DEBUG modem << [00:12:43.199,737] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:18:55.956Z DEBUG modem << [00:12:43.207,153] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:18:55.970Z DEBUG modem << [00:12:43.214,172] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:18:55.983Z DEBUG modem << [00:12:43.221,221] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:18:55.996Z DEBUG modem << [00:12:43.228,210] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:18:56.010Z DEBUG modem << [00:12:43.235,290] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:18:56.023Z DEBUG modem << [00:12:43.242,889] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:18:56.036Z DEBUG modem << [00:12:43.250,000] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:18:56.050Z DEBUG modem << [00:12:43.256,958] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:18:56.063Z DEBUG modem << [00:12:43.264,038] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:18:56.076Z DEBUG modem << [00:12:43.271,026] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:18:56.090Z DEBUG modem << Tx: 13
2022-07-25T05:18:56.103Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:18:56.116Z DEBUG modem << [00:12:43.283,569] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:18:56.130Z DEBUG modem << [00:12:43.292,968] [1;33m<wrn> cloud_codec_ringbuffer: On line 33 in ringbuffer[0m
2022-07-25T05:18:56.143Z DEBUG modem << [00:12:43.300,506] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 0 of 2 in bms buffer Capture 1 data bytes:
2022-07-25T05:18:56.156Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:56.170Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:56.183Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:56.196Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:56.210Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:56.223Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:56.236Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:18:56.250Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:18:56.264Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:18:56.277Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:18:56.290Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:18:56.304Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:18:56.317Z DEBUG modem << filled[0m
2022-07-25T05:18:56.330Z DEBUG modem << [00:12:43.339,111] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:18:56.344Z DEBUG modem << [00:12:43.347,412] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:18:56.357Z DEBUG modem << [00:12:43.357,208] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:18:57.245Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:18:57.261Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:18:57.275Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:18:57.289Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:18:57.302Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.320Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.334Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.347Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.361Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.374Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.388Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.402Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.415Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.429Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.442Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.458Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:57.473Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:18:59.083Z DEBUG modem << Tx: 13
2022-07-25T05:18:59.098Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:18:59.895Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:18:59.909Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:18:59.923Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:18:59.937Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:18:59.950Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:18:59.963Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:18:59.976Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:18:59.990Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:00.003Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:00.017Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:00.031Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:00.044Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:00.058Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:01.133Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:19:01.149Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:19:01.165Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:01.178Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:19:01.191Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.204Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.218Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.231Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.244Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.257Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.270Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.283Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.296Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.309Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.322Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.336Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:01.349Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:03.144Z DEBUG modem << Tx: 13
2022-07-25T05:19:03.157Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:19:03.922Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:03.936Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:04.713Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:04.726Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:04.740Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:04.753Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:04.766Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:04.779Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:04.792Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:04.805Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:04.818Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:04.831Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:04.844Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:05.623Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:05.638Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:05.651Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:05.665Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:19:05.678Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.691Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.704Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.717Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.731Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.744Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.757Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.770Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.784Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.797Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.810Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.823Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:05.836Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:07.188Z DEBUG modem << Tx: 13
2022-07-25T05:19:07.202Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:19:09.239Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:09.254Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:09.267Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:09.280Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:19:09.294Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.308Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.321Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.335Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.348Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.363Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.377Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.390Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.404Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.417Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.431Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.444Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:09.458Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:11.257Z DEBUG modem << Tx: 13
2022-07-25T05:19:11.271Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:19:12.175Z DEBUG modem << [00:13:00.412,200] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:19:12.973Z DEBUG modem << [00:13:00.643,157] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:19:12.988Z DEBUG modem << [00:13:00.651,519] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:19:13.001Z DEBUG modem << [00:13:00.658,477] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:19:13.015Z DEBUG modem << [00:13:00.667,938] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:19:13.028Z DEBUG modem << [00:13:00.674,530] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:19:13.042Z DEBUG modem << [00:13:00.682,739] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:19:13.055Z DEBUG modem << [00:13:00.690,765] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:19:13.068Z DEBUG modem << [00:13:00.699,249] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:19:13.082Z DEBUG modem << [00:13:00.707,031] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:19:13.096Z DEBUG modem << [00:13:00.714,691] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:19:13.109Z DEBUG modem << [00:13:00.721,252] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:19:13.122Z DEBUG modem << [00:13:00.728,149] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:19:13.135Z DEBUG modem << [00:13:00.740,509] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:19:13.149Z DEBUG modem << [00:13:00.748,382] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:19:13.162Z DEBUG modem << [00:13:00.762,512] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:19:13.175Z DEBUG modem << [00:13:00.769,439] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:19:13.189Z DEBUG modem << [00:13:00.778,869] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:19:13.202Z DEBUG modem << [00:13:00.785,980] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:19:13.216Z DEBUG modem << [00:13:00.795,349] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:19:13.229Z DEBUG modem << [00:13:00.805,114] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:19:13.243Z DEBUG modem << [00:13:00.815,155] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:19:13.256Z DEBUG modem << [00:13:00.824,279] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 0 of 9 in sensor buffer filled[0m
2022-07-25T05:19:13.269Z DEBUG modem << [00:13:00.835,754] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:13.283Z DEBUG modem << [00:13:00.845,550] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:19:13.296Z DEBUG modem << [00:13:00.857,147] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:13.309Z DEBUG modem << [00:13:00.935,943] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:19:13.322Z DEBUG modem << [00:13:00.946,197] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:13.336Z DEBUG modem << [00:13:01.025,604] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:19:13.349Z DEBUG modem << [00:13:01.039,398] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:19:13.363Z DEBUG modem << [00:13:01.050,048] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:14.151Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:14.167Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:14.180Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:14.194Z DEBUG modem << a5,1,95,8,3,e,ba,e,cf,e,d4,0,cd,
2022-07-25T05:19:14.207Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.221Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.234Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.247Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.260Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.273Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.287Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.300Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.314Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.327Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.340Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.353Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:14.366Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:15.288Z DEBUG modem << Tx: 13
2022-07-25T05:19:15.302Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:19:16.082Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:16.095Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:16.108Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:16.121Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:16.135Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:16.148Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:16.161Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:16.174Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:16.188Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:16.201Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:16.214Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:16.227Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:16.240Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:16.253Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:16.266Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:16.279Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:16.293Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:16.306Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:16.319Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:16.332Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:16.345Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:16.358Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:16.372Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:16.385Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:16.398Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:16.412Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:16.425Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:16.438Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:16.451Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:16.464Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:16.477Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:16.490Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:16.503Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:16.516Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:16.529Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:16.543Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:16.556Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:16.569Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:16.582Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:17.377Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:17.392Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:19:17.405Z DEBUG modem << a5,1,95,8,2,e,d7,e,ce,e,d4,0,e8,
2022-07-25T05:19:17.419Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:17.432Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.445Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.459Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.473Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.486Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.499Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.512Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.525Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.539Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.552Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.566Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.579Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:17.592Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:19.336Z DEBUG modem << Tx: 13
2022-07-25T05:19:19.351Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:19:20.141Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:20.154Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:20.168Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:20.181Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:20.194Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:20.207Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:20.220Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:20.233Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:20.246Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:20.259Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:20.272Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:20.285Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:20.298Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:20.311Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:20.324Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:20.337Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:20.350Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:20.363Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:20.376Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:20.389Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:20.402Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:20.415Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:20.428Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:20.441Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:20.454Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:20.467Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:21.385Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:21.399Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:19:21.412Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:21.426Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:21.439Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:21.452Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:21.465Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:21.478Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:22.255Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:22.268Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:22.281Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:22.294Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:22.307Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:22.320Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:22.333Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:22.346Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:22.359Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:23.392Z DEBUG modem << Tx: 13
2022-07-25T05:19:23.407Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:19:24.185Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:24.198Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:24.211Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:24.225Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:24.238Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:24.251Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:24.265Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:24.278Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:24.292Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:24.304Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:24.318Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:24.331Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:24.344Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:25.437Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:19:25.451Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:19:25.465Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:25.478Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:25.491Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.505Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.518Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.531Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.544Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.557Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.571Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.584Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.597Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.610Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.624Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.637Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:25.650Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:27.445Z DEBUG modem << Tx: 13
2022-07-25T05:19:27.461Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:19:28.244Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:28.258Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:28.272Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:28.286Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:28.300Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:28.313Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:28.326Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:28.340Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:28.353Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:28.367Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:28.380Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:28.394Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:28.407Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:29.565Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:19:29.580Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:19:29.596Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:29.611Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:29.626Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.640Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.653Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.667Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.680Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.694Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.707Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.721Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.735Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.748Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.762Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.776Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.791Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:29.807Z DEBUG modem << [00:13:17.736,175] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,25,0.2050,25,0,0 [0m
2022-07-25T05:19:29.820Z DEBUG modem << [00:13:17.744,720] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:19:29.834Z DEBUG modem << [00:13:17.753,143] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:19:29.847Z DEBUG modem << [00:13:17.764,343] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:19:30.630Z DEBUG modem << [00:13:17.771,789] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:19:30.645Z DEBUG modem << [00:13:17.778,778] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:19:30.659Z DEBUG modem << [00:13:17.785,827] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:19:30.671Z DEBUG modem << [00:13:17.792,816] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:19:30.684Z DEBUG modem << [00:13:17.799,896] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:19:30.698Z DEBUG modem << [00:13:17.806,854] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:19:30.711Z DEBUG modem << Tx: 13
2022-07-25T05:19:30.724Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:19:30.738Z DEBUG modem << [00:13:17.819,366] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:19:30.750Z DEBUG modem << [00:13:17.828,826] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 1 of 2 in bms buffer filled[0m
2022-07-25T05:19:30.763Z DEBUG modem << [00:13:17.839,782] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:19:30.776Z DEBUG modem << [00:13:17.848,083] [0m<dbg> data_module: requested_data_status_set: processed requCapture 1 data bytes:
2022-07-25T05:19:30.789Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:30.802Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:30.815Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:30.828Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:30.841Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:30.854Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:30.867Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:30.880Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:30.893Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:30.906Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:30.919Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:30.932Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:30.945Z DEBUG modem << ested_data_status_set()[0m
2022-07-25T05:19:30.958Z DEBUG modem << [00:13:17.885,437] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:19:31.757Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:19:31.775Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:19:31.792Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:31.805Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:31.818Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.831Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.844Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.857Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.871Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.884Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.897Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.910Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.923Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.941Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.954Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.967Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:31.979Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:32.768Z DEBUG modem << [00:13:20.643,188] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:19:32.782Z DEBUG modem << [00:13:20.651,580] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:19:32.795Z DEBUG modem << [00:13:20.658,508] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:19:32.808Z DEBUG modem << [00:13:20.667,968] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:19:32.821Z DEBUG modem << [00:13:20.674,591] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:19:32.834Z DEBUG modem << [00:13:20.682,800] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:19:32.847Z DEBUG modem << [00:13:20.690,826] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:19:32.860Z DEBUG modem << [00:13:20.699,310] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:19:32.873Z DEBUG modem << [00:13:20.707,061] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:19:32.886Z DEBUG modem << [00:13:20.714,752] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:19:32.899Z DEBUG modem << [00:13:20.721,282] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:19:32.912Z DEBUG modem << [00:13:20.728,179] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:19:32.925Z DEBUG modem << [00:13:20.740,539] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:19:32.938Z DEBUG modem << [00:13:20.748,413] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:19:32.951Z DEBUG modem << [00:13:20.762,542] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:19:32.964Z DEBUG modem << [00:13:20.769,500] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:19:32.978Z DEBUG modem << [00:13:20.778,900] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:19:32.991Z DEBUG modem << [00:13:20.786,010] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:19:33.004Z DEBUG modem << [00:13:20.795,379] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:19:33.017Z DEBUG modem << [00:13:20.805,145] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:19:33.030Z DEBUG modem << [00:13:20.815,185] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:19:33.051Z DEBUG modem << [00:13:20.824,310] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 1 of 9 in sensor buffer filled[0m
2022-07-25T05:19:33.064Z DEBUG modem << [00:13:20.835,815] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:33.078Z DEBUG modem << [00:13:20.845,611] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:19:33.091Z DEBUG modem << [00:13:20.857,208] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:33.104Z DEBUG modem << [00:13:20.936,004] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:19:33.118Z DEBUG modem << [00:13:20.946,258] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:33.901Z DEBUG modem << [00:13:21.025,024] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:19:33.917Z DEBUG modem << [00:13:21.038,848] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:19:33.930Z DEBUG modem << [00:13:21.049,499] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:34.702Z DEBUG modem << Tx: 13
2022-07-25T05:19:34.716Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:19:34.730Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:34.743Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:34.755Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:34.768Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:34.781Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:34.793Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:34.806Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:34.819Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:34.831Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:34.844Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:34.857Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:34.869Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:34.882Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:35.672Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:19:35.686Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:19:35.699Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:35.712Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:36.471Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.486Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.499Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.513Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.526Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.539Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.552Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.565Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.578Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.592Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.605Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.618Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:36.631Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:37.674Z DEBUG modem << Tx: 13
2022-07-25T05:19:37.689Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:19:38.484Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:38.501Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:38.515Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:38.528Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:38.542Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:38.556Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:38.569Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:38.582Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:38.595Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:38.608Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:38.621Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:38.635Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:38.648Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:39.721Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:39.735Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:39.749Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:39.762Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:39.775Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.789Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.802Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.817Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.830Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.843Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.856Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.869Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.883Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.896Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.909Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.922Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:39.935Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:41.737Z DEBUG modem << Tx: 13
2022-07-25T05:19:41.751Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:19:42.588Z DEBUG modem << [00:13:30.419,403] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:19:43.770Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:43.786Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:43.799Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:43.813Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:43.826Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:43.840Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:43.853Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:43.866Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:43.879Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:44.658Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:44.671Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:44.684Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:44.698Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:44.711Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:44.724Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:44.737Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:44.751Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:45.784Z DEBUG modem << Tx: 13
2022-07-25T05:19:45.798Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:19:47.820Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:47.835Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:19:47.850Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:47.864Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:48.718Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:48.732Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:48.747Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:48.761Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:48.775Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:48.788Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:48.801Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:48.816Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:48.830Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:48.844Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:49.623Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:49.637Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:49.651Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:50.472Z DEBUG modem << Tx: 13
2022-07-25T05:19:50.487Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:19:50.503Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:50.519Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:50.533Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:50.547Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:50.561Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:50.574Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:50.588Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:50.603Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:50.617Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:50.632Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:50.646Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:50.661Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:50.674Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:50.689Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:50.704Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:50.719Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:50.732Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:50.746Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:50.760Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:50.773Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:50.787Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:50.801Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:50.815Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:50.828Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:50.843Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:50.856Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:50.870Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:50.883Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:50.897Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:50.911Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:50.925Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:50.939Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:50.953Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:50.967Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:50.980Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:50.994Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:51.008Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:51.021Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:51.035Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:51.874Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:51.889Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c0,e,e1,e,b9,0,c8,
2022-07-25T05:19:51.903Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:19:51.917Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:51.930Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:51.944Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:51.958Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:51.972Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:51.985Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:51.999Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:52.012Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:52.026Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:52.039Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:52.054Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:52.067Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:52.080Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:52.094Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:52.888Z DEBUG modem << [00:13:40.643,218] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:19:52.903Z DEBUG modem << [00:13:40.651,580] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:19:52.917Z DEBUG modem << [00:13:40.658,538] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:19:52.931Z DEBUG modem << [00:13:40.667,999] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:19:52.944Z DEBUG modem << [00:13:40.674,591] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:19:52.958Z DEBUG modem << [00:13:40.682,800] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:19:52.972Z DEBUG modem << [00:13:40.690,856] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:19:52.985Z DEBUG modem << [00:13:40.699,310] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:19:52.999Z DEBUG modem << [00:13:40.707,092] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:19:53.012Z DEBUG modem << [00:13:40.714,752] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:19:53.026Z DEBUG modem << [00:13:40.721,313] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:19:53.040Z DEBUG modem << [00:13:40.728,179] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:19:53.054Z DEBUG modem << [00:13:40.740,539] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:19:53.067Z DEBUG modem << [00:13:40.748,413] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:19:53.080Z DEBUG modem << [00:13:40.762,542] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:19:53.094Z DEBUG modem << [00:13:40.769,500] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:19:53.107Z DEBUG modem << [00:13:40.778,900] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:19:53.121Z DEBUG modem << [00:13:40.786,010] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:19:53.136Z DEBUG modem << [00:13:40.795,410] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:19:53.149Z DEBUG modem << [00:13:40.805,145] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:19:53.163Z DEBUG modem << [00:13:40.815,185] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:19:53.176Z DEBUG modem << [00:13:40.824,310] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 2 of 9 in sensor buffer filled[0m
2022-07-25T05:19:53.190Z DEBUG modem << [00:13:40.835,784] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:53.203Z DEBUG modem << [00:13:40.845,581] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:19:53.216Z DEBUG modem << [00:13:40.857,177] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:53.230Z DEBUG modem << [00:13:40.935,974] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:19:53.243Z DEBUG modem << [00:13:40.946,228] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:53.257Z DEBUG modem << [00:13:41.025,451] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:19:53.270Z DEBUG modem << [00:13:41.039,276] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:19:53.284Z DEBUG modem << [00:13:41.049,896] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:19:54.082Z DEBUG modem << Tx: 13
2022-07-25T05:19:54.096Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:19:54.110Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:54.124Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:54.138Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:54.152Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:54.165Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:54.179Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:54.192Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:54.206Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:54.220Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:54.233Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:54.246Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:54.260Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:54.273Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:54.286Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:54.299Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:54.313Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:54.327Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:54.340Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:54.354Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:54.367Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:54.381Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:54.394Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:54.408Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:54.422Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:54.436Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:54.449Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:55.930Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:55.945Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:19:55.960Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:19:55.973Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:19:55.986Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.000Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.014Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.030Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.044Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.057Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.071Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.084Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.098Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.111Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.125Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.138Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:56.152Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:19:57.964Z DEBUG modem << Tx: 13
2022-07-25T05:19:57.980Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:19:58.758Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:19:58.773Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:19:58.787Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:19:58.800Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:19:58.814Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:19:58.827Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:19:58.840Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:19:58.853Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:19:58.867Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:19:58.880Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:19:58.893Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:19:58.907Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:19:58.920Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:19:59.973Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:19:59.986Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:20:00.001Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:00.780Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:00.793Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.806Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.820Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.833Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.846Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.860Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.873Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.887Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.900Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.913Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.926Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.939Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:00.953Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:01.980Z DEBUG modem << Tx: 13
2022-07-25T05:20:01.994Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:20:02.817Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:02.832Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:02.846Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:02.859Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:02.873Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:02.886Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:02.900Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:02.913Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:02.927Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:02.940Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:02.956Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:02.969Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:02.982Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:04.083Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:20:04.096Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:20:04.110Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:04.124Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:04.139Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.152Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.166Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.179Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.193Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.206Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.220Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.233Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.247Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.260Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.274Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.287Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.301Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:04.314Z DEBUG modem << [00:13:52.272,521] [1;33m<wrn> bms_module: on line 327 3.8090,3.7680,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:20:04.328Z DEBUG modem << [00:13:52.281,066] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:20:05.119Z DEBUG modem << [00:13:52.289,520] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:20:05.132Z DEBUG modem << [00:13:52.300,720] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:20:05.146Z DEBUG modem << [00:13:52.308,166] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:20:05.160Z DEBUG modem << [00:13:52.315,185] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:20:05.173Z DEBUG modem << [00:13:52.322,235] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:20:05.186Z DEBUG modem << [00:13:52.329,223] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:20:05.199Z DEBUG modem << [00:13:52.336,303] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:20:05.212Z DEBUG modem << [00:13:52.343,292] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:20:05.225Z DEBUG modem << Tx: 13
2022-07-25T05:20:05.238Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:20:05.252Z DEBUG modem << [00:13:52.355,834] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:20:05.265Z DEBUG modem << [00:13:52.365,264] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:20:05.279Z DEBUG modem << [00:13:52.376,220] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:20:05.292Z DEBUG modem << [00:13:52.384,521] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:05.305Z DEBUG modem << [00:13:52.394,317] [0m<dbg> data_module: on_all_states:  data moduCapture 1 data bytes:
2022-07-25T05:20:05.318Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:05.332Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:05.345Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:05.358Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:05.371Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:05.384Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:05.397Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:05.410Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:05.423Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:05.437Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:05.450Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:05.464Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:05.477Z DEBUG modem << le: processed BMS_DATA_READY Event[0m
2022-07-25T05:20:06.279Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:20:06.293Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:20:06.306Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:06.320Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:06.333Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.347Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.360Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.373Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.386Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.400Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.413Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.426Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.439Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.452Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.466Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.480Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:06.493Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:08.160Z DEBUG modem << Tx: 13
2022-07-25T05:20:08.174Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:20:08.979Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:08.994Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:09.008Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:09.023Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:09.037Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:09.050Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:09.064Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:09.078Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:09.091Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:09.105Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:09.119Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:09.132Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:09.146Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:10.210Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:20:10.224Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:20:10.238Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:10.251Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:10.265Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.278Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.292Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.305Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.319Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.332Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.346Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.359Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.373Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.387Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.401Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.414Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:10.428Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:12.211Z DEBUG modem << [00:14:00.426,605] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:20:12.975Z DEBUG modem << Tx: 13
2022-07-25T05:20:12.990Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:20:13.774Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:13.788Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:13.802Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:13.815Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:13.834Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:13.848Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:13.861Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:13.875Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:13.889Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:13.902Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:13.917Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:13.931Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:13.944Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:13.958Z DEBUG modem << [00:14:00.643,249] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:20:13.972Z DEBUG modem << [00:14:00.651,641] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:20:13.985Z DEBUG modem << [00:14:00.658,599] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:20:13.999Z DEBUG modem << [00:14:00.668,060] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:20:14.013Z DEBUG modem << [00:14:00.674,652] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:20:14.027Z DEBUG modem << [00:14:00.682,861] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:20:14.041Z DEBUG modem << [00:14:00.690,917] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:20:14.054Z DEBUG modem << [00:14:00.699,401] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:20:14.069Z DEBUG modem << [00:14:00.707,153] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:20:14.082Z DEBUG modem << [00:14:00.714,843] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:20:14.096Z DEBUG modem << [00:14:00.721,405] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:20:14.111Z DEBUG modem << [00:14:00.728,302] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:20:14.125Z DEBUG modem << [00:14:00.740,661] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:20:14.139Z DEBUG modem << [00:14:00.748,565] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:20:14.152Z DEBUG modem << [00:14:00.762,725] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:20:14.166Z DEBUG modem << [00:14:00.769,653] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:20:14.180Z DEBUG modem << [00:14:00.779,083] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:20:14.193Z DEBUG modem << [00:14:00.786,193] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:20:14.208Z DEBUG modem << [00:14:00.795,593] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:20:14.221Z DEBUG modem << [00:14:00.805,328] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:20:14.235Z DEBUG modem << [00:14:00.815,399] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:20:14.249Z DEBUG modem << [00:14:00.824,523] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 3 of 9 in sensor buffer filled[0m
2022-07-25T05:20:14.263Z DEBUG modem << [00:14:00.836,029] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:14.276Z DEBUG modem << [00:14:00.845,825] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:20:14.290Z DEBUG modem << [00:14:00.857,421] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:14.304Z DEBUG modem << [00:14:00.936,248] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:20:14.318Z DEBUG modem << [00:14:00.946,502] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:14.331Z DEBUG modem << [00:14:01.025,726] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:20:14.346Z DEBUG modem << [00:14:01.039,581] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:20:14.359Z DEBUG modem << [00:14:01.050,201] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:15.142Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:15.157Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:15.171Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:15.185Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:15.199Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.213Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.228Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.241Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.255Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.269Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.282Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.296Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.310Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.324Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.338Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.352Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:15.366Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:16.274Z DEBUG modem << Tx: 13
2022-07-25T05:20:16.288Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:20:18.308Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:18.322Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:18.336Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:18.350Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:18.363Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:18.378Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:18.391Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:19.172Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:19.185Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:19.199Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:19.213Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:19.226Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:19.240Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:19.253Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:19.267Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:19.281Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:19.294Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:20.315Z DEBUG modem << Tx: 13
2022-07-25T05:20:20.329Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:20:22.364Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:22.379Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:22.393Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:22.407Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:22.421Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.435Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.448Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.462Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.476Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.489Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.504Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.517Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.531Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.545Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.559Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.572Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:22.586Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:24.380Z DEBUG modem << Tx: 13
2022-07-25T05:20:24.394Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:20:25.162Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:25.176Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:25.190Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:25.204Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:25.217Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:25.230Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:25.244Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:25.257Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:25.271Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:25.284Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:25.297Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:25.310Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:25.323Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:25.337Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:25.351Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:25.364Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:25.377Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:25.391Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:25.404Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:25.417Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:25.430Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:25.447Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:25.461Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:25.474Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:25.487Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:25.501Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:25.514Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:25.527Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:25.541Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:25.555Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:25.568Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:25.581Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:25.595Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:25.608Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:25.622Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:25.636Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:25.649Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:25.663Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:25.676Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:26.465Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:26.480Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:20:26.494Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:20:26.507Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:26.522Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.535Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.548Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.562Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.575Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.589Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.602Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.620Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.633Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.647Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.660Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.673Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:26.687Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:28.414Z DEBUG modem << Tx: 13
2022-07-25T05:20:28.428Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:20:29.222Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:29.236Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:29.250Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:29.264Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:29.277Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:29.291Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:29.304Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:29.318Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:29.331Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:29.345Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:29.358Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:29.372Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:29.385Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:29.399Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:29.413Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:29.426Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:29.439Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:29.453Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:29.466Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:29.479Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:29.493Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:29.506Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:29.519Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:29.533Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:29.546Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:29.559Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:30.436Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:30.451Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:20:30.464Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:31.225Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:31.239Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.254Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.267Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.281Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.295Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.309Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.323Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.336Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.350Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.364Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.378Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.392Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:31.406Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:32.545Z DEBUG modem << [00:14:20.643,280] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:20:32.560Z DEBUG modem << [00:14:20.651,672] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:20:32.574Z DEBUG modem << [00:14:20.658,630] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:20:32.588Z DEBUG modem << [00:14:20.668,090] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:20:32.602Z DEBUG modem << [00:14:20.674,682] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:20:32.616Z DEBUG modem << [00:14:20.682,922] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:20:32.629Z DEBUG modem << [00:14:20.690,948] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:20:32.643Z DEBUG modem << [00:14:20.699,432] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:20:32.657Z DEBUG modem << [00:14:20.707,214] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:20:33.427Z DEBUG modem << [00:14:20.714,904] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:20:33.442Z DEBUG modem << [00:14:20.721,435] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:20:33.456Z DEBUG modem << [00:14:20.728,332] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:20:33.470Z DEBUG modem << [00:14:20.740,692] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:20:33.484Z DEBUG modem << [00:14:20.748,596] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:20:33.498Z DEBUG modem << [00:14:20.762,725] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:20:33.512Z DEBUG modem << [00:14:20.769,683] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:20:33.526Z DEBUG modem << [00:14:20.779,083] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:20:33.539Z DEBUG modem << [00:14:20.786,193] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:20:33.553Z DEBUG modem << [00:14:20.795,562] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:20:33.567Z DEBUG modem << [00:14:20.805,328] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:20:33.581Z DEBUG modem << [00:14:20.815,368] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:20:33.595Z DEBUG modem << [00:14:20.824,523] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 4 of 9 in sensor buffer filled[0m
2022-07-25T05:20:33.608Z DEBUG modem << [00:14:20.835,998] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:33.622Z DEBUG modem << [00:14:20.845,794] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:20:33.636Z DEBUG modem << [00:14:20.857,421] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:33.650Z DEBUG modem << Tx: 13
2022-07-25T05:20:33.664Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:20:33.677Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:33.691Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:33.706Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:33.719Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:33.733Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:33.747Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:33.761Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:33.775Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:33.788Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:33.802Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:34.593Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:34.608Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:34.622Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:34.636Z DEBUG modem << [00:14:20.973,449] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:20:34.650Z DEBUG modem << [00:14:20.983,703] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:34.664Z DEBUG modem << [00:14:21.062,927] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:20:34.678Z DEBUG modem << [00:14:21.076,751] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:20:34.692Z DEBUG modem << [00:14:21.087,402] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:35.463Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:20:35.477Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:20:35.491Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:35.505Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:35.519Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.533Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.547Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.560Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.574Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.588Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.602Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.615Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.629Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.643Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.658Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.671Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:35.685Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:36.685Z DEBUG modem << Tx: 13
2022-07-25T05:20:36.702Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:20:37.494Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:37.509Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:37.523Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:37.538Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:37.554Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:37.568Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:37.582Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:37.595Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:37.609Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:37.623Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:37.637Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:37.651Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:37.665Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:38.800Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:20:38.814Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:20:38.828Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:38.842Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:38.856Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:38.870Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:38.884Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:38.897Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:38.911Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:38.925Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:38.938Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:38.952Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:38.966Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:38.980Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:39.761Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:39.775Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:39.789Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:39.803Z DEBUG modem << [00:14:26.967,773] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:20:39.816Z DEBUG modem << [00:14:26.976,318] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:20:39.830Z DEBUG modem << [00:14:26.984,741] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:20:39.844Z DEBUG modem << [00:14:26.995,941] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:20:39.857Z DEBUG modem << [00:14:27.003,387] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:20:39.871Z DEBUG modem << [00:14:27.010,375] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:20:39.885Z DEBUG modem << [00:14:27.017,425] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:20:39.898Z DEBUG modem << [00:14:27.024,414] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:20:39.912Z DEBUG modem << [00:14:27.031,494] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:20:39.925Z DEBUG modem << [00:14:27.038,452] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:20:39.940Z DEBUG modem << Tx: 13
2022-07-25T05:20:39.953Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:20:39.967Z DEBUG modem << [00:14:27.050,964] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:20:39.981Z DEBUG modem << [00:14:27.060,363] [1;33m<wrn> cloud_codec_ringbuffer: On line 33 in ringbuffer[0m
2022-07-25T05:20:39.995Z DEBUG modem << [00:14:27.067,932] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 0 of 2 in bms buffer filled[0m
2022-07-25T05:20:40.008Z DEBUG modem << [00:14:27.078,887] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:20:40.022Z DEBUG modem << [00:14:27.087,188] [0m<dbg> data_module: requested_data_status_set: processed requested_daCapture 1 data bytes:
2022-07-25T05:20:40.035Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:40.048Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:40.062Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:40.075Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:40.089Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:40.102Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:40.116Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:40.129Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:40.143Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:40.157Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:40.170Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:40.184Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:40.197Z DEBUG modem << ta_status_set()[0m
2022-07-25T05:20:40.211Z DEBUG modem << [00:14:27.124,572] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:20:41.015Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:20:41.030Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:20:41.044Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:41.058Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:41.072Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.085Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.099Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.113Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.127Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.141Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.155Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.168Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.182Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.196Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.209Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.223Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:41.237Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:42.198Z DEBUG modem << [00:14:30.433,807] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:20:42.968Z DEBUG modem << Tx: 13
2022-07-25T05:20:42.982Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:20:42.996Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:43.010Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:43.024Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:43.038Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:43.052Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:43.066Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:43.080Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:43.094Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:43.108Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:43.122Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:43.136Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:43.149Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:43.163Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:44.911Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:20:44.926Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:20:44.942Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:44.957Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:44.970Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:44.984Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:44.999Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:45.012Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:45.026Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:45.040Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:45.054Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:45.838Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:45.852Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:45.866Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:45.879Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:45.893Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:45.907Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:46.908Z DEBUG modem << Tx: 13
2022-07-25T05:20:46.922Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:20:47.703Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:47.717Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:47.731Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:47.745Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:47.760Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:47.784Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:47.798Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:47.813Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:47.827Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:20:47.841Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:20:47.855Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:20:47.870Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:20:47.884Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:20:48.975Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:48.990Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:49.007Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:49.022Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:49.036Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.050Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.064Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.078Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.092Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.107Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.121Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.135Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.149Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.164Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.179Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.194Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:49.210Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:50.975Z DEBUG modem << Tx: 13
2022-07-25T05:20:50.991Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:20:52.450Z DEBUG modem << [00:14:40.643,310] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:20:52.464Z DEBUG modem << [00:14:40.651,672] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:20:52.477Z DEBUG modem << [00:14:40.658,630] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:20:52.491Z DEBUG modem << [00:14:40.668,090] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:20:52.504Z DEBUG modem << [00:14:40.674,682] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:20:52.518Z DEBUG modem << [00:14:40.682,891] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:20:53.302Z DEBUG modem << [00:14:40.690,948] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:20:53.318Z DEBUG modem << [00:14:40.699,401] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:20:53.333Z DEBUG modem << [00:14:40.707,183] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:20:53.348Z DEBUG modem << [00:14:40.714,874] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:20:53.362Z DEBUG modem << [00:14:40.721,435] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:20:53.375Z DEBUG modem << [00:14:40.728,302] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:20:53.390Z DEBUG modem << [00:14:40.740,692] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:20:53.404Z DEBUG modem << [00:14:40.748,565] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:20:53.418Z DEBUG modem << [00:14:40.762,695] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:20:53.432Z DEBUG modem << [00:14:40.769,653] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:20:53.446Z DEBUG modem << [00:14:40.779,052] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:20:53.460Z DEBUG modem << [00:14:40.786,163] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:20:53.474Z DEBUG modem << [00:14:40.795,532] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:20:53.489Z DEBUG modem << [00:14:40.805,297] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:20:53.504Z DEBUG modem << [00:14:40.815,338] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:20:53.518Z DEBUG modem << [00:14:40.824,462] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 5 of 9 in sensor buffer filled[0m
2022-07-25T05:20:53.533Z DEBUG modem << [00:14:40.835,968] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:53.547Z DEBUG modem << [00:14:40.845,733] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:20:53.561Z DEBUG modem << [00:14:40.857,360] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:53.574Z DEBUG modem << [00:14:40.936,187] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:20:53.588Z DEBUG modem << [00:14:40.946,441] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:53.602Z DEBUG modem << [00:14:41.025,207] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:20:53.615Z DEBUG modem << [00:14:41.039,031] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:20:53.630Z DEBUG modem << [00:14:41.049,682] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:20:53.643Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:53.657Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:53.671Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:53.684Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:53.697Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.710Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.724Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.737Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.751Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.764Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.777Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.791Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.804Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.817Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.832Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.845Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:53.858Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:55.022Z DEBUG modem << Tx: 13
2022-07-25T05:20:55.036Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:20:57.061Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:57.076Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:20:57.090Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:20:57.104Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:20:57.118Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:57.131Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:57.145Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:57.159Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:57.173Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:57.980Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:57.994Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:58.010Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:58.024Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:58.038Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:58.052Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:58.067Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:58.081Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:20:59.068Z DEBUG modem << Tx: 13
2022-07-25T05:20:59.084Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:20:59.875Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:20:59.891Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:20:59.904Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:20:59.919Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:20:59.935Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:20:59.948Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:20:59.962Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:20:59.978Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:20:59.991Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:00.005Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:00.020Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:00.034Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:00.048Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:00.062Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:00.076Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:00.090Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:00.103Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:00.117Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:00.131Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:00.145Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:00.158Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:00.172Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:00.186Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:00.200Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:00.214Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:00.228Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:00.242Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:00.256Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:00.269Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:00.283Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:00.297Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:00.311Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:00.324Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:00.338Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:00.352Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:00.366Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:00.379Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:00.394Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:00.408Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:01.198Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:01.214Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b8,0,c8,
2022-07-25T05:21:01.229Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:21:01.243Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:01.256Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.270Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.284Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.298Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.311Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.325Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.339Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.352Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.366Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.380Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.394Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.408Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:01.422Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:03.110Z DEBUG modem << Tx: 13
2022-07-25T05:21:03.125Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:21:03.927Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:03.943Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:03.957Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:03.973Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:03.989Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:04.003Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:04.017Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:04.031Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:04.045Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:04.059Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:04.073Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:04.087Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:04.101Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:04.115Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:04.128Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:04.142Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:04.156Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:04.170Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:04.184Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:04.198Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:04.212Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:04.225Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:04.239Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:04.253Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:04.267Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:04.282Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:05.131Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:05.146Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:21:05.160Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:05.174Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:05.936Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:05.951Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:05.967Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:05.981Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:05.996Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:06.010Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:06.024Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:06.038Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:06.051Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:06.065Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:06.080Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:06.094Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:06.108Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:07.175Z DEBUG modem << Tx: 13
2022-07-25T05:21:07.190Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:21:07.990Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:08.005Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:08.019Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:08.032Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:08.047Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:08.060Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:08.074Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:08.088Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:08.101Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:08.115Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:08.129Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:08.143Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:08.156Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:09.222Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:21:09.237Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:21:09.252Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:09.266Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:09.280Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.294Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.308Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.322Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.336Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.350Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.364Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.378Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.392Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.407Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.420Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.434Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:09.449Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:11.242Z DEBUG modem << Tx: 13
2022-07-25T05:21:11.258Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:21:12.029Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:12.045Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:12.059Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:12.075Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:12.089Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:12.104Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:12.118Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:12.133Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:12.147Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:12.160Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:12.174Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:12.189Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:12.203Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:12.983Z DEBUG modem << [00:15:00.441,040] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:21:13.761Z DEBUG modem << [00:15:00.643,341] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:21:13.776Z DEBUG modem << [00:15:00.651,733] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:21:13.791Z DEBUG modem << [00:15:00.658,691] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:21:13.805Z DEBUG modem << [00:15:00.668,151] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:21:13.819Z DEBUG modem << [00:15:00.674,743] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:21:13.833Z DEBUG modem << [00:15:00.682,952] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:21:13.847Z DEBUG modem << [00:15:00.691,009] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:21:13.862Z DEBUG modem << [00:15:00.699,493] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:21:13.876Z DEBUG modem << [00:15:00.707,244] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:21:13.890Z DEBUG modem << [00:15:00.714,935] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:21:13.904Z DEBUG modem << [00:15:00.721,496] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:21:13.918Z DEBUG modem << [00:15:00.728,393] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:21:13.932Z DEBUG modem << [00:15:00.740,753] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:21:13.946Z DEBUG modem << [00:15:00.748,657] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:21:13.961Z DEBUG modem << [00:15:00.762,786] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:21:13.975Z DEBUG modem << [00:15:00.769,744] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:21:13.988Z DEBUG modem << [00:15:00.779,144] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:21:14.002Z DEBUG modem << [00:15:00.786,254] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:21:14.017Z DEBUG modem << [00:15:00.795,623] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:21:14.031Z DEBUG modem << [00:15:00.805,389] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:21:14.044Z DEBUG modem << [00:15:00.815,429] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:21:14.059Z DEBUG modem << [00:15:00.824,554] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 6 of 9 in sensor buffer filled[0m
2022-07-25T05:21:14.073Z DEBUG modem << [00:15:00.836,059] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:14.086Z DEBUG modem << [00:15:00.845,825] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:21:14.100Z DEBUG modem << [00:15:00.857,452] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:14.114Z DEBUG modem << [00:15:00.936,248] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:21:14.128Z DEBUG modem << [00:15:00.946,502] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:14.142Z DEBUG modem << [00:15:01.025,970] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:21:14.156Z DEBUG modem << [00:15:01.039,794] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:21:14.170Z DEBUG modem << [00:15:01.050,415] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:14.946Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:21:14.962Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:21:14.977Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:14.991Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:15.005Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.020Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.033Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.047Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.061Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.075Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.089Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.102Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.117Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.131Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.145Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.158Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.172Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:15.186Z DEBUG modem << [00:15:01.503,570] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:21:15.200Z DEBUG modem << [00:15:01.512,084] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:21:15.214Z DEBUG modem << [00:15:01.520,538] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:21:15.229Z DEBUG modem << [00:15:01.531,738] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:21:15.242Z DEBUG modem << [00:15:01.539,184] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:21:15.256Z DEBUG modem << [00:15:01.546,203] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:21:15.270Z DEBUG modem << [00:15:01.553,253] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:21:15.284Z DEBUG modem << [00:15:01.560,241] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:21:15.298Z DEBUG modem << [00:15:01.567,321] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:21:15.312Z DEBUG modem << [00:15:01.574,310] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:21:15.326Z DEBUG modem << Tx: 13
2022-07-25T05:21:15.340Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:21:15.354Z DEBUG modem << [00:15:01.586,853] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:21:15.368Z DEBUG modem << [00:15:01.596,282] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 1 of 2 in bms buffer filled[0m
2022-07-25T05:21:15.382Z DEBUG modem << [00:15:01.607,238] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:21:15.396Z DEBUG modem << [00:15:01.615,539] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:15.410Z DEBUG modem << [00:15:01.625,335] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:21:15.423Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:15.438Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:15.452Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:15.465Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:15.479Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:15.493Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:15.507Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:15.521Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:15.535Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:15.549Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:15.563Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:15.577Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:15.591Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:16.379Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:21:16.394Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:21:16.408Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:16.422Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:16.436Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.450Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.464Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.478Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.492Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.506Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.520Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.534Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.548Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.562Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.576Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.590Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:16.604Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:17.403Z DEBUG modem << Tx: 13
2022-07-25T05:21:17.418Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:21:18.211Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:18.227Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:18.241Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:18.255Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:18.269Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:18.283Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:18.301Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:18.315Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:18.329Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:18.343Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:18.357Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:18.371Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:18.385Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:19.417Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:21:19.433Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:21:19.448Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:19.463Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:20.243Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.258Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.272Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.287Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.301Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.315Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.329Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.344Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.358Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.372Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.386Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.400Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:20.415Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:21.452Z DEBUG modem << Tx: 13
2022-07-25T05:21:21.468Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:21:22.263Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:22.278Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:22.292Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:22.307Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:22.321Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:22.335Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:22.349Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:22.363Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:22.377Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:22.391Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:22.405Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:22.419Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:22.433Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:23.507Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:21:23.523Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:21:23.538Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:23.555Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:23.569Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.584Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.598Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.612Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.626Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.640Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.654Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.668Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.682Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.696Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.710Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.724Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:23.738Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:25.528Z DEBUG modem << Tx: 13
2022-07-25T05:21:25.542Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:21:27.556Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:21:27.572Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:21:27.587Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:27.601Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:27.615Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.629Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.643Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.657Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.672Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.686Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.700Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.714Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.729Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.743Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.757Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.771Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:27.786Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:29.556Z DEBUG modem << Tx: 13
2022-07-25T05:21:29.573Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:21:31.564Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:21:31.579Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:21:31.593Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:32.370Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:32.384Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.398Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.412Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.426Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.440Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.454Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.469Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.482Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.496Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.510Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.525Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.539Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:32.552Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:33.312Z DEBUG modem << [00:15:20.643,371] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:21:33.327Z DEBUG modem << [00:15:20.651,733] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:21:33.342Z DEBUG modem << [00:15:20.658,691] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:21:33.356Z DEBUG modem << [00:15:20.668,151] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:21:33.370Z DEBUG modem << [00:15:20.674,743] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:21:33.384Z DEBUG modem << [00:15:20.682,952] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:21:33.398Z DEBUG modem << [00:15:20.690,979] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:21:33.412Z DEBUG modem << [00:15:20.699,462] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:21:33.426Z DEBUG modem << [00:15:20.707,214] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:21:33.440Z DEBUG modem << [00:15:20.714,904] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:21:33.454Z DEBUG modem << [00:15:20.721,435] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:21:33.468Z DEBUG modem << [00:15:20.728,332] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:21:33.482Z DEBUG modem << [00:15:20.740,692] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:21:33.496Z DEBUG modem << [00:15:20.748,565] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:21:33.510Z DEBUG modem << [00:15:20.762,695] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:21:33.524Z DEBUG modem << [00:15:20.769,653] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:21:33.538Z DEBUG modem << [00:15:20.779,052] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:21:34.308Z DEBUG modem << [00:15:20.786,132] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:21:34.324Z DEBUG modem << [00:15:20.795,532] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:21:34.338Z DEBUG modem << [00:15:20.805,267] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:21:34.352Z DEBUG modem << [00:15:20.815,307] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:21:34.367Z DEBUG modem << [00:15:20.824,432] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 7 of 9 in sensor buffer filled[0m
2022-07-25T05:21:34.381Z DEBUG modem << [00:15:20.835,937] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:34.395Z DEBUG modem << [00:15:20.845,733] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:21:34.409Z DEBUG modem << [00:15:20.857,330] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:34.424Z DEBUG modem << [00:15:20.936,157] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:21:34.438Z DEBUG modem << [00:15:20.946,411] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:34.452Z DEBUG modem << [00:15:21.025,207] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:21:34.466Z DEBUG modem << [00:15:21.039,031] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:21:34.480Z DEBUG modem << [00:15:21.049,682] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:35.248Z DEBUG modem << Tx: 13
2022-07-25T05:21:35.264Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:21:35.279Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:35.293Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:35.307Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:35.322Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:35.336Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:35.349Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:35.364Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:35.377Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:35.392Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:35.406Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:35.420Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:35.434Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:35.448Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:35.462Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:35.475Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:35.490Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:35.504Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:35.518Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:35.532Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:35.546Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:35.559Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:35.573Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:35.587Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:35.602Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:35.616Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:35.630Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:35.644Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:35.658Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:35.672Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:35.686Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:35.700Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:35.714Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:35.729Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:35.743Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:35.757Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:35.771Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:35.785Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:35.799Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:35.813Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:36.596Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:36.611Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:21:36.626Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:21:36.640Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:36.655Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.669Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.683Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.697Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.711Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.726Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.739Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.753Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.767Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.782Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.796Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.810Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:36.824Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:37.648Z DEBUG modem << Tx: 13
2022-07-25T05:21:37.663Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:21:38.420Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:38.435Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:38.453Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:38.467Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:38.481Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:38.495Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:38.508Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:38.522Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:38.536Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:38.554Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:38.568Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:38.582Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:38.596Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:38.610Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:38.624Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:38.638Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:38.653Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:38.667Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:38.681Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:38.695Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:38.709Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:38.723Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:38.737Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:38.751Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:38.765Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:38.779Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:39.684Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:40.443Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:21:40.458Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:40.472Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:40.485Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.500Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.513Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.527Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.540Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.554Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.568Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.581Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.596Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.609Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.623Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.637Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:40.650Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:41.703Z DEBUG modem << Tx: 13
2022-07-25T05:21:41.717Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:21:42.506Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:42.522Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:42.536Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:42.550Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:42.563Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:42.577Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:42.591Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:42.605Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:42.618Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:42.632Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:42.646Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:42.660Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:42.674Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:42.688Z DEBUG modem << [00:15:30.448,272] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:21:43.755Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:21:43.770Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:21:44.549Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:44.564Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:44.578Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.592Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.606Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.620Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.634Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.648Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.662Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.676Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.690Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.704Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.718Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.732Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:44.746Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:45.763Z DEBUG modem << Tx: 13
2022-07-25T05:21:45.781Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:21:46.573Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:46.588Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:46.603Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:46.618Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:46.632Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:46.646Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:46.659Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:46.673Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:46.686Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:46.700Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:46.714Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:46.727Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:46.741Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:47.802Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:21:47.817Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:21:47.831Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:47.846Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:48.629Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.643Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.658Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.673Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.687Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.701Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.716Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.736Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.755Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.769Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.783Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.798Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:48.812Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:49.609Z DEBUG modem << [00:15:36.039,550] [1;33m<wrn> bms_module: on line 327 3.8090,3.7680,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:21:49.625Z DEBUG modem << [00:15:36.048,065] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:21:49.642Z DEBUG modem << [00:15:36.056,518] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:21:49.657Z DEBUG modem << [00:15:36.067,718] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:21:49.673Z DEBUG modem << [00:15:36.075,164] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:21:49.690Z DEBUG modem << [00:15:36.082,153] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:21:49.706Z DEBUG modem << [00:15:36.089,202] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:21:49.721Z DEBUG modem << [00:15:36.096,191] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:21:49.735Z DEBUG modem << [00:15:36.103,271] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:21:49.750Z DEBUG modem << [00:15:36.110,260] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:21:49.764Z DEBUG modem << Tx: 13
2022-07-25T05:21:49.779Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:21:49.793Z DEBUG modem << [00:15:36.122,772] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:21:49.808Z DEBUG modem << [00:15:36.132,202] [0m<dbg> cCapture 1 data bytes:
2022-07-25T05:21:49.822Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:49.837Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:49.852Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:49.866Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:49.881Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:49.896Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:49.910Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:49.925Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:49.940Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:49.954Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:49.968Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:49.982Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:49.997Z DEBUG modem << loud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:21:50.012Z DEBUG modem << [00:15:36.170,806] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:21:50.026Z DEBUG modem << [00:15:36.179,107] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:50.042Z DEBUG modem << [00:15:36.188,873] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:21:50.853Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:21:50.867Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:21:50.882Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:50.896Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:50.910Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:50.924Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:50.939Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:50.953Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:50.967Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:50.981Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:50.996Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:51.010Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:51.024Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:51.038Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:51.052Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:51.066Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:51.080Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:51.937Z DEBUG modem << Tx: 13
2022-07-25T05:21:51.953Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:21:52.763Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:52.779Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:52.794Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:52.808Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:52.822Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:52.837Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:52.852Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:52.866Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:52.880Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:52.894Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:52.909Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:52.923Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:52.937Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:52.952Z DEBUG modem << [00:15:40.643,402] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:21:52.966Z DEBUG modem << [00:15:40.651,763] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:21:52.980Z DEBUG modem << [00:15:40.658,721] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:21:52.995Z DEBUG modem << [00:15:40.668,182] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:21:53.009Z DEBUG modem << [00:15:40.674,774] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:21:53.023Z DEBUG modem << [00:15:40.682,983] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:21:53.038Z DEBUG modem << [00:15:40.691,009] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:21:53.052Z DEBUG modem << [00:15:40.699,493] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:21:53.067Z DEBUG modem << [00:15:40.707,244] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:21:53.081Z DEBUG modem << [00:15:40.714,935] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:21:53.095Z DEBUG modem << [00:15:40.721,496] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:21:53.110Z DEBUG modem << [00:15:40.728,393] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:21:53.124Z DEBUG modem << [00:15:40.740,753] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:21:53.138Z DEBUG modem << [00:15:40.748,626] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:21:53.153Z DEBUG modem << [00:15:40.762,786] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:21:53.168Z DEBUG modem << [00:15:40.769,714] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:21:53.182Z DEBUG modem << [00:15:40.779,113] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:21:53.196Z DEBUG modem << [00:15:40.786,224] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:21:53.210Z DEBUG modem << [00:15:40.795,623] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:21:53.225Z DEBUG modem << [00:15:40.805,358] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:21:53.241Z DEBUG modem << [00:15:40.815,399] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:21:53.256Z DEBUG modem << [00:15:40.824,523] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 8 of 9 in sensor buffer filled[0m
2022-07-25T05:21:53.270Z DEBUG modem << [00:15:40.836,029] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:53.285Z DEBUG modem << [00:15:40.845,794] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:21:53.303Z DEBUG modem << [00:15:40.857,421] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:53.319Z DEBUG modem << [00:15:40.936,218] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:21:53.334Z DEBUG modem << [00:15:40.946,472] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:54.125Z DEBUG modem << [00:15:41.025,695] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:21:54.140Z DEBUG modem << [00:15:41.039,520] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:21:54.154Z DEBUG modem << [00:15:41.050,170] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:21:54.919Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:21:54.934Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:21:54.948Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:54.963Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:54.977Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:54.991Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.005Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.019Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.033Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.047Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.061Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.075Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.089Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.103Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.117Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.131Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.145Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:55.983Z DEBUG modem << Tx: 13
2022-07-25T05:21:55.998Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:21:56.807Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:21:56.822Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:21:56.837Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:21:56.852Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:21:56.866Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:21:56.880Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:21:56.894Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:21:56.909Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:21:56.923Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:21:56.939Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:21:56.953Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:21:56.968Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:21:56.982Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:21:58.030Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:21:58.862Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:21:58.877Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:21:58.898Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:21:58.913Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:58.927Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:58.941Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:58.956Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:58.969Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:58.984Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:58.998Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:59.013Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:59.027Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:59.043Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:59.057Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:59.071Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:21:59.086Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:00.038Z DEBUG modem << Tx: 13
2022-07-25T05:22:00.052Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:22:02.086Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:22:02.100Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:22:02.115Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:02.129Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:22:02.143Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:02.157Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:02.171Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:02.185Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:02.199Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:02.213Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:02.227Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:03.008Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:03.026Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:03.048Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:03.062Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:03.079Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:03.093Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:04.086Z DEBUG modem << Tx: 13
2022-07-25T05:22:04.100Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:22:06.116Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:22:06.130Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:22:06.144Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:06.158Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d4,0,cb,
2022-07-25T05:22:06.172Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:06.186Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:06.200Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:06.214Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:06.228Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:06.245Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:07.026Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:07.040Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:07.054Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:07.068Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:07.082Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:07.096Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:07.110Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:08.135Z DEBUG modem << Tx: 13
2022-07-25T05:22:08.150Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:22:08.920Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:08.935Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:08.952Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:08.966Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:08.980Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:08.993Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:09.007Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:09.021Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:09.035Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:09.049Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:09.063Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:09.077Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:09.091Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:09.105Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:09.120Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:09.133Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:09.147Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:09.161Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:09.175Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:09.189Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:09.203Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:09.217Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:09.231Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:09.245Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:09.259Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:09.273Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:09.287Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:09.301Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:09.315Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:09.329Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:09.343Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:09.358Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:09.372Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:09.386Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:09.400Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:09.414Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:09.428Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:09.442Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:09.456Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:10.247Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,b9,e,ce,e,d3,0,ca,
2022-07-25T05:22:10.262Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c0,e,e1,e,b9,0,c8,
2022-07-25T05:22:10.276Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d3,0,e6,
2022-07-25T05:22:10.291Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d3,0,ca,
2022-07-25T05:22:10.305Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.318Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.333Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.347Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.361Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.375Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.389Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.403Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.416Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.430Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.444Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.458Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:10.472Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:12.186Z DEBUG modem << Tx: 13
2022-07-25T05:22:12.201Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:22:13.002Z DEBUG modem << [00:16:00.455,505] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:22:13.017Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:13.032Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:13.046Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:13.060Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:13.074Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:13.088Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:13.102Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:13.116Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:13.130Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:13.144Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:13.158Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:13.172Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:13.186Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:13.200Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:13.214Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:13.228Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:13.243Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:13.257Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:13.271Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:13.285Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:13.299Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:13.313Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:13.327Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:13.341Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:13.355Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:13.369Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:13.383Z DEBUG modem << [00:16:00.643,432] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:22:13.397Z DEBUG modem << [00:16:00.651,794] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:22:13.411Z DEBUG modem << [00:16:00.658,752] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:22:13.425Z DEBUG modem << [00:16:00.668,212] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:22:13.439Z DEBUG modem << [00:16:00.674,835] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:22:13.454Z DEBUG modem << [00:16:00.683,044] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:22:13.468Z DEBUG modem << [00:16:00.691,070] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:22:13.482Z DEBUG modem << [00:16:00.699,554] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:22:13.495Z DEBUG modem << [00:16:00.707,305] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:22:13.510Z DEBUG modem << [00:16:00.714,996] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:22:13.523Z DEBUG modem << [00:16:00.721,557] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:22:13.537Z DEBUG modem << [00:16:00.728,454] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:22:13.551Z DEBUG modem << [00:16:00.740,814] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:22:13.565Z DEBUG modem << [00:16:00.748,687] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:22:13.579Z DEBUG modem << [00:16:00.762,817] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:22:14.350Z DEBUG modem << [00:16:00.769,775] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:22:14.366Z DEBUG modem << [00:16:00.779,174] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:22:14.380Z DEBUG modem << [00:16:00.786,285] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:22:14.394Z DEBUG modem << [00:16:00.795,684] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:22:14.408Z DEBUG modem << [00:16:00.805,419] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:22:14.423Z DEBUG modem << [00:16:00.815,490] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:22:14.437Z DEBUG modem << [00:16:00.824,615] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 9 of 9 in sensor buffer filled[0m
2022-07-25T05:22:14.451Z DEBUG modem << [00:16:00.836,090] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:14.465Z DEBUG modem << [00:16:00.845,886] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:22:14.479Z DEBUG modem << [00:16:00.857,513] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:14.493Z DEBUG modem << [00:16:00.936,309] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:22:14.507Z DEBUG modem << [00:16:00.946,563] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:14.521Z DEBUG modem << [00:16:01.025,787] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:22:14.535Z DEBUG modem << [00:16:01.039,611] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:22:14.549Z DEBUG modem << [00:16:01.050,262] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:15.328Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:15.344Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:22:15.359Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:15.373Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d3,0,ca,
2022-07-25T05:22:15.388Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.402Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.416Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.431Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.445Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.459Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.473Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.487Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.501Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.515Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.529Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.543Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:15.557Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:16.355Z DEBUG modem << Tx: 13
2022-07-25T05:22:16.370Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:22:16.385Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:16.400Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:16.414Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:16.428Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:16.442Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:16.457Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:16.471Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:16.485Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:16.499Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:16.513Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:16.527Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:16.541Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:16.555Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:18.289Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:22:19.070Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:22:19.084Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:19.099Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d3,0,ca,
2022-07-25T05:22:19.113Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.127Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.141Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.155Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.168Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.182Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.196Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.210Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.223Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.237Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.251Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.265Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:19.279Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:20.290Z DEBUG modem << Tx: 13
2022-07-25T05:22:20.306Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:22:21.113Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:21.128Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:21.143Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:21.158Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:21.172Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:21.187Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:21.201Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:21.216Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:21.230Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:21.244Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:21.258Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:21.273Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:21.291Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:22.358Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:22:22.373Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:22:22.388Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:22.402Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d3,0,ca,
2022-07-25T05:22:22.416Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.430Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.444Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.458Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.472Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.486Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.501Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.515Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.529Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.543Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.558Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.572Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.586Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:22.601Z DEBUG modem << [00:16:10.576,141] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:22:22.616Z DEBUG modem << [00:16:10.584,655] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:22:23.396Z DEBUG modem << [00:16:10.593,109] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:22:23.411Z DEBUG modem << [00:16:10.604,309] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:22:23.425Z DEBUG modem << [00:16:10.611,755] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:22:23.440Z DEBUG modem << [00:16:10.618,743] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:22:23.454Z DEBUG modem << [00:16:10.625,793] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:22:23.469Z DEBUG modem << [00:16:10.632,781] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:22:23.483Z DEBUG modem << [00:16:10.639,862] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:22:23.498Z DEBUG modem << [00:16:10.646,850] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:22:23.512Z DEBUG modem << Tx: 13
2022-07-25T05:22:23.526Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:22:23.541Z DEBUG modem << [00:16:10.659,362] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:22:23.555Z DEBUG modem << [00:16:10.668,762] [1;33m<wrn> cloud_codec_ringbuffer: On line 33 in ringbuffer[0m
2022-07-25T05:22:23.569Z DEBUG modem << [00:16:10.676,330] [0m<dbg> cloud_codCapture 1 data bytes:
2022-07-25T05:22:23.583Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:23.598Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:23.612Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:23.626Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:23.640Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:23.655Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:23.669Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:23.684Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:23.698Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:23.713Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:23.727Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:23.741Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:23.755Z DEBUG modem << ec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 0 of 2 in bms buffer filled[0m
2022-07-25T05:22:23.770Z DEBUG modem << [00:16:10.714,904] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:22:23.784Z DEBUG modem << [00:16:10.723,205] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:23.798Z DEBUG modem << [00:16:10.732,971] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:22:24.594Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:22:24.609Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:22:24.623Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:24.638Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d3,0,ca,
2022-07-25T05:22:24.652Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.666Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.680Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.694Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.709Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.723Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.736Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.751Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.765Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.779Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.793Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.807Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:24.821Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:26.471Z DEBUG modem << Tx: 13
2022-07-25T05:22:26.486Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:22:27.279Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:27.294Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:27.309Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:27.324Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:27.338Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:27.352Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:27.366Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:27.380Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:27.394Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:27.408Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:27.423Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:27.437Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:27.451Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:28.531Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:22:28.546Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:22:28.561Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:28.575Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d3,0,ca,
2022-07-25T05:22:28.589Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.604Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.618Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.632Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.645Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.659Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.673Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.687Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.702Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.716Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.730Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.744Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:28.758Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:30.544Z DEBUG modem << Tx: 13
2022-07-25T05:22:30.559Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:22:31.343Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:31.359Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:31.374Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:31.388Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:31.403Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:31.417Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:31.431Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:31.446Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:31.461Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:31.475Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:31.490Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:31.504Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:31.519Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:32.458Z DEBUG modem << [00:16:20.643,493] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:22:33.227Z DEBUG modem << [00:16:20.651,855] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:22:33.243Z DEBUG modem << [00:16:20.658,813] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:22:33.259Z DEBUG modem << [00:16:20.668,273] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:22:33.274Z DEBUG modem << [00:16:20.674,865] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:22:33.289Z DEBUG modem << [00:16:20.683,074] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:22:33.303Z DEBUG modem << [00:16:20.691,131] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:22:34.071Z DEBUG modem << [00:16:20.699,615] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:22:34.087Z DEBUG modem << [00:16:20.707,366] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:22:34.101Z DEBUG modem << [00:16:20.715,057] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:22:34.116Z DEBUG modem << [00:16:20.721,618] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:22:34.131Z DEBUG modem << [00:16:20.728,485] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:22:34.145Z DEBUG modem << [00:16:20.740,875] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:22:34.159Z DEBUG modem << [00:16:20.748,748] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:22:34.173Z DEBUG modem << [00:16:20.762,878] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:22:34.188Z DEBUG modem << [00:16:20.769,836] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:22:34.202Z DEBUG modem << [00:16:20.779,235] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:22:34.217Z DEBUG modem << [00:16:20.786,346] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:22:34.231Z DEBUG modem << [00:16:20.795,715] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:22:34.245Z DEBUG modem << [00:16:20.805,480] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:22:34.260Z DEBUG modem << [00:16:20.815,551] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:22:34.274Z DEBUG modem << [00:16:20.824,676] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 0 of 9 in sensor buffer filled[0m
2022-07-25T05:22:34.289Z DEBUG modem << [00:16:20.836,151] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:34.303Z DEBUG modem << [00:16:20.845,947] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:22:34.317Z DEBUG modem << [00:16:20.857,574] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:34.332Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:22:34.346Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:22:34.361Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:34.375Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d3,0,ca,
2022-07-25T05:22:34.389Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.403Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.418Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.433Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.447Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.462Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.476Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.490Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.505Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.519Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.534Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.548Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.562Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:34.576Z DEBUG modem << [00:16:20.983,428] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:22:34.591Z DEBUG modem << [00:16:20.993,682] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:34.605Z DEBUG modem << [00:16:21.072,906] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:22:34.619Z DEBUG modem << [00:16:21.086,730] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:22:34.634Z DEBUG modem << [00:16:21.097,351] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:35.435Z DEBUG modem << Tx: 13
2022-07-25T05:22:35.450Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:22:36.736Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:22:36.754Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:22:36.768Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:36.783Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d3,0,ca,
2022-07-25T05:22:36.797Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.812Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.826Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.840Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.854Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.868Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.882Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.896Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.910Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.924Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.938Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.953Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:36.967Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:38.751Z DEBUG modem << Tx: 13
2022-07-25T05:22:38.766Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:22:40.782Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:22:40.798Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:22:40.812Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:40.827Z DEBUG modem << a5,1,95,8,3,e,b9,e,ce,e,d3,0,ca,
2022-07-25T05:22:40.841Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.855Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.870Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.884Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.898Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.912Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.926Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.940Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.954Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.968Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.983Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:40.997Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:41.011Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:42.236Z DEBUG modem << [00:16:30.462,707] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:22:43.024Z DEBUG modem << Tx: 13
2022-07-25T05:22:43.040Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:22:43.055Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:43.070Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:43.085Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:43.099Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:43.113Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:43.127Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:43.141Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:43.155Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:43.169Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:43.184Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:43.198Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:43.212Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:43.227Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:43.241Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:43.256Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:43.270Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:43.285Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:43.299Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:43.313Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:43.328Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:43.343Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:43.357Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:43.371Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:43.386Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:43.400Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:43.414Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:43.429Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:43.443Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:43.457Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:43.471Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:43.486Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:43.500Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:43.514Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:43.528Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:43.543Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:43.557Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:43.571Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:43.586Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:43.600Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:44.830Z DEBUG modem <<  bms incoming_message: a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:22:44.846Z DEBUG modem << buffer_1: a5,1,95,8,1,e,c1,e,e1,e,b9,0,c9,
2022-07-25T05:22:44.863Z DEBUG modem << a5,1,95,8,2,e,d6,e,ce,e,d4,0,e7,
2022-07-25T05:22:44.878Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:22:44.892Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:44.907Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:44.922Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:44.939Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:44.956Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:44.971Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:44.985Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:45.000Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:45.014Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:45.029Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:45.043Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:45.057Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:45.072Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:46.856Z DEBUG modem << Tx: 13
2022-07-25T05:22:46.870Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:22:47.646Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:47.661Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:47.676Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:47.691Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:47.705Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:47.720Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:47.734Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:47.748Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:47.763Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:47.778Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:47.792Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:47.807Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:47.821Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:47.836Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:47.850Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:47.865Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:47.880Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:47.894Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:47.909Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:47.923Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:47.937Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:47.952Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:47.966Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:47.981Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:47.996Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:48.010Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:48.887Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:48.903Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:22:48.917Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:48.932Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:22:48.947Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:48.961Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:48.976Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:48.990Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:49.004Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:49.019Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:49.033Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:49.048Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:49.063Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:49.077Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:49.091Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:49.106Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:49.120Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:50.892Z DEBUG modem << Tx: 13
2022-07-25T05:22:50.908Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:22:51.703Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:51.718Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:51.733Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:51.747Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:51.763Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:51.777Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:51.791Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:51.806Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:51.821Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:51.835Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:51.849Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:51.864Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:51.878Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:52.711Z DEBUG modem << [00:16:40.643,463] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:22:52.726Z DEBUG modem << [00:16:40.651,824] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:22:52.743Z DEBUG modem << [00:16:40.658,782] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:22:52.758Z DEBUG modem << [00:16:40.668,243] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:22:52.772Z DEBUG modem << [00:16:40.674,835] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:22:52.787Z DEBUG modem << [00:16:40.683,044] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:22:52.801Z DEBUG modem << [00:16:40.691,070] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:22:52.816Z DEBUG modem << [00:16:40.699,554] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:22:52.830Z DEBUG modem << [00:16:40.707,305] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:22:52.844Z DEBUG modem << [00:16:40.714,996] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:22:52.859Z DEBUG modem << [00:16:40.721,557] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:22:52.873Z DEBUG modem << [00:16:40.728,424] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:22:52.888Z DEBUG modem << [00:16:40.740,783] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:22:52.902Z DEBUG modem << [00:16:40.748,657] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:22:52.916Z DEBUG modem << [00:16:40.762,786] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:22:52.931Z DEBUG modem << [00:16:40.769,744] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:22:52.945Z DEBUG modem << [00:16:40.779,144] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:22:52.960Z DEBUG modem << [00:16:40.786,254] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:22:52.974Z DEBUG modem << [00:16:40.795,623] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:22:52.989Z DEBUG modem << [00:16:40.805,389] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:22:53.003Z DEBUG modem << [00:16:40.815,429] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:22:53.017Z DEBUG modem << [00:16:40.824,554] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 1 of 9 in sensor buffer filled[0m
2022-07-25T05:22:53.031Z DEBUG modem << [00:16:40.836,059] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:53.046Z DEBUG modem << [00:16:40.845,825] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:22:53.061Z DEBUG modem << [00:16:40.857,452] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:53.849Z DEBUG modem << [00:16:40.936,248] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:22:53.865Z DEBUG modem << [00:16:40.946,472] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:53.880Z DEBUG modem << [00:16:41.025,268] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:22:53.895Z DEBUG modem << [00:16:41.039,093] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:22:53.909Z DEBUG modem << [00:16:41.049,713] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:53.924Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:22:53.939Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:22:53.953Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:53.967Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:22:53.981Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:53.996Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.010Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.024Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.039Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.054Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.068Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.082Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.097Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.111Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.125Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.140Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.154Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:54.952Z DEBUG modem << Tx: 13
2022-07-25T05:22:54.967Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:22:55.761Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:22:55.777Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:55.792Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:55.807Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:55.822Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:55.837Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:55.851Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:55.865Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:55.880Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:55.894Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:55.908Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:55.922Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:55.937Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:57.018Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:22:57.035Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:22:57.051Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:57.066Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:22:57.081Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.096Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.111Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.127Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.141Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.156Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.170Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.185Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.199Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.214Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.228Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.243Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.257Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:57.272Z DEBUG modem << [00:16:45.218,566] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:22:57.286Z DEBUG modem << [00:16:45.227,111] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:22:57.301Z DEBUG modem << [00:16:45.235,534] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:22:58.088Z DEBUG modem << [00:16:45.246,734] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:22:58.103Z DEBUG modem << [00:16:45.254,180] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:22:58.118Z DEBUG modem << [00:16:45.261,199] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:22:58.133Z DEBUG modem << [00:16:45.268,249] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:22:58.148Z DEBUG modem << [00:16:45.275,207] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:22:58.162Z DEBUG modem << [00:16:45.282,287] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:22:58.176Z DEBUG modem << [00:16:45.289,276] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:22:58.191Z DEBUG modem << Tx: 13
2022-07-25T05:22:58.205Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:22:58.220Z DEBUG modem << [00:16:45.301,788] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:22:58.234Z DEBUG modem << [00:16:45.311,248] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 1 of 2 in bms buffer filled[0m
2022-07-25T05:22:58.249Z DEBUG modem << [00:16:45.322,204] [0m<dbCapture 1 data bytes:
2022-07-25T05:22:58.264Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:22:58.278Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:22:58.293Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:22:58.307Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:22:58.323Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:22:58.337Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:22:58.352Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:22:58.366Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:22:58.380Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:22:58.395Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:22:58.409Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:22:58.424Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:22:58.438Z DEBUG modem << g> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:22:58.453Z DEBUG modem << [00:16:45.358,093] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:22:58.468Z DEBUG modem << [00:16:45.367,889] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:22:59.351Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:22:59.366Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:22:59.381Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:22:59.395Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:22:59.410Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.424Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.438Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.452Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.466Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.481Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.500Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.514Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.529Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.544Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.558Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.573Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:22:59.587Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:01.110Z DEBUG modem << Tx: 13
2022-07-25T05:23:01.895Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:23:02.657Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:02.673Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:02.687Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:02.702Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:02.717Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:02.731Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:02.745Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:02.760Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:02.774Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:02.788Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:02.803Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:02.817Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:02.831Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:03.634Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:23:03.650Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b8,3,0,0,f9,
2022-07-25T05:23:03.665Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:03.680Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:03.694Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.710Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.724Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.738Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.753Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.767Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.781Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.796Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.810Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.824Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.839Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.853Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:03.868Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:05.172Z DEBUG modem << Tx: 13
2022-07-25T05:23:05.187Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:23:06.010Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:06.025Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:06.040Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:06.054Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:06.068Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:06.083Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:06.097Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:06.112Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:06.126Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:06.141Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:06.155Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:06.169Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:06.184Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:07.224Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:07.239Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:07.254Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:07.269Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:07.283Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.298Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.312Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.327Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.341Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.356Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.370Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.385Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.399Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.414Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.429Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.443Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:07.457Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:09.222Z DEBUG modem << Tx: 13
2022-07-25T05:23:09.238Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:23:11.236Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:11.252Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:11.267Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:11.282Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:11.297Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:11.311Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.097Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.111Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.127Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.141Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.156Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.171Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.185Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.200Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.215Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.230Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:12.244Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:13.012Z DEBUG modem << [00:17:00.469,909] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:23:13.796Z DEBUG modem << [00:17:00.643,493] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:23:13.811Z DEBUG modem << [00:17:00.651,855] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:23:13.826Z DEBUG modem << [00:17:00.658,813] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:23:13.841Z DEBUG modem << [00:17:00.668,273] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:23:13.856Z DEBUG modem << [00:17:00.674,865] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:23:13.870Z DEBUG modem << [00:17:00.683,074] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:23:13.885Z DEBUG modem << [00:17:00.691,101] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:23:13.900Z DEBUG modem << [00:17:00.699,584] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:23:13.914Z DEBUG modem << [00:17:00.707,336] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:23:13.930Z DEBUG modem << [00:17:00.715,026] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:23:13.944Z DEBUG modem << [00:17:00.721,588] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:23:13.959Z DEBUG modem << [00:17:00.728,454] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:23:13.974Z DEBUG modem << [00:17:00.740,814] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:23:13.989Z DEBUG modem << [00:17:00.748,718] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:23:14.004Z DEBUG modem << [00:17:00.762,817] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:23:14.018Z DEBUG modem << [00:17:00.769,775] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:23:14.033Z DEBUG modem << [00:17:00.779,205] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:23:14.048Z DEBUG modem << [00:17:00.786,315] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:23:14.063Z DEBUG modem << [00:17:00.795,684] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:23:14.077Z DEBUG modem << [00:17:00.805,450] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:23:14.093Z DEBUG modem << [00:17:00.815,521] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:23:14.107Z DEBUG modem << [00:17:00.824,645] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 2 of 9 in sensor buffer filled[0m
2022-07-25T05:23:14.122Z DEBUG modem << [00:17:00.836,120] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:14.137Z DEBUG modem << [00:17:00.845,947] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:23:14.151Z DEBUG modem << [00:17:00.857,543] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:14.166Z DEBUG modem << [00:17:00.936,340] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:23:14.181Z DEBUG modem << [00:17:00.946,594] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:14.196Z DEBUG modem << [00:17:01.025,817] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:23:14.210Z DEBUG modem << [00:17:01.039,642] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:23:14.225Z DEBUG modem << [00:17:01.050,292] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:15.007Z DEBUG modem << Tx: 13
2022-07-25T05:23:15.023Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:23:15.798Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:15.816Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:15.831Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:15.845Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:15.860Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:15.875Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:15.890Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:15.904Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:15.919Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:15.934Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:15.949Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:15.964Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:15.978Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:15.993Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:16.008Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:16.022Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:16.037Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:17.321Z DEBUG modem << Tx: 13
2022-07-25T05:23:17.337Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:23:19.363Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:19.382Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:19.397Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:19.413Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:19.428Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:19.444Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:19.459Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:19.473Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:19.487Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:20.267Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:20.281Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:20.296Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:20.310Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:20.325Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:20.339Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:20.353Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:20.367Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:21.370Z DEBUG modem << Tx: 13
2022-07-25T05:23:21.386Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:23:22.170Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:22.186Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:22.200Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:22.215Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:22.231Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:22.245Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:22.260Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:22.274Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:22.289Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:22.303Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:22.318Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:22.333Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:22.347Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:22.362Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:22.376Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:22.391Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:22.405Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:22.419Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:22.434Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:22.449Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:22.463Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:22.477Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:22.492Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:22.506Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:22.521Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:22.535Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:23.422Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:23.438Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:23:23.453Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:23.468Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:23.482Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:23.497Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:23.512Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:23.529Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:23.546Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:23.560Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:23.575Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:23.589Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:23.604Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:24.390Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:24.405Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:24.419Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:24.433Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:25.419Z DEBUG modem << Tx: 13
2022-07-25T05:23:25.437Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:23:26.217Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:26.232Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:26.247Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:26.262Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:26.277Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:26.291Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:26.306Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:26.321Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:26.335Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:26.350Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:26.365Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:26.379Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:26.394Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:27.466Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:23:27.481Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:23:27.496Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:27.511Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:27.526Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.540Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.555Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.570Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.584Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.599Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.613Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.628Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.643Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.658Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.672Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:27.687Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:28.473Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:29.489Z DEBUG modem << Tx: 13
2022-07-25T05:23:29.505Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:23:30.283Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:30.299Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:30.314Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:30.329Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:30.343Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:30.358Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:30.373Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:30.388Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:30.403Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:30.417Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:30.432Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:30.447Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:30.461Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:31.568Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:23:31.584Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:23:31.600Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:31.614Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:31.629Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.644Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.658Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.673Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.688Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.703Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.718Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.732Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.747Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.761Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.776Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.791Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:31.806Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:32.592Z DEBUG modem << [00:17:19.754,547] [1;33m<wrn> bms_module: on line 327 3.8090,3.7680,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:23:32.606Z DEBUG modem << [00:17:19.763,061] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:23:32.621Z DEBUG modem << [00:17:19.771,514] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:23:32.636Z DEBUG modem << [00:17:19.782,684] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:23:32.651Z DEBUG modem << [00:17:19.790,130] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:23:32.665Z DEBUG modem << [00:17:19.797,119] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:23:32.680Z DEBUG modem << [00:17:19.804,168] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:23:32.695Z DEBUG modem << [00:17:19.811,126] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:23:32.710Z DEBUG modem << [00:17:19.818,206] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:23:32.724Z DEBUG modem << [00:17:19.825,164] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:23:32.739Z DEBUG modem << Tx: 13
2022-07-25T05:23:32.754Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:23:32.768Z DEBUG modem << [00:17:19.837,677] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:23:32.783Z DEBUG modem << [00:17:19.847,106] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:23:32.798Z DEBUG modem << [00:17:19.858,062] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:23:32.813Z DEBUG modem << [00:17:19.866,363] [0m<dbg> data_Capture 1 data bytes:
2022-07-25T05:23:32.828Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:32.842Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:32.857Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:32.871Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:32.886Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:32.901Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:32.916Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:32.931Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:32.945Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:32.960Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:32.974Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:32.989Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:33.003Z DEBUG modem << module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:33.019Z DEBUG modem << [00:17:19.903,717] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:23:33.815Z DEBUG modem << [00:17:20.643,524] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:23:33.830Z DEBUG modem << [00:17:20.651,885] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:23:33.845Z DEBUG modem << [00:17:20.658,843] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:23:33.860Z DEBUG modem << [00:17:20.668,304] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:23:33.874Z DEBUG modem << [00:17:20.674,896] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:23:33.889Z DEBUG modem << [00:17:20.683,105] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:23:33.904Z DEBUG modem << [00:17:20.691,131] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:23:33.919Z DEBUG modem << [00:17:20.699,615] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:23:33.933Z DEBUG modem << [00:17:20.707,366] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:23:33.948Z DEBUG modem << [00:17:20.715,057] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:23:33.962Z DEBUG modem << [00:17:20.721,588] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:23:33.977Z DEBUG modem << [00:17:20.728,485] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:23:33.992Z DEBUG modem << [00:17:20.740,844] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:23:34.007Z DEBUG modem << [00:17:20.748,718] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:23:34.022Z DEBUG modem << [00:17:20.762,817] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:23:34.036Z DEBUG modem << [00:17:20.769,775] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:23:34.051Z DEBUG modem << [00:17:20.779,174] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:23:34.065Z DEBUG modem << [00:17:20.786,285] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:23:34.080Z DEBUG modem << [00:17:20.795,654] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:23:34.094Z DEBUG modem << [00:17:20.805,389] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:23:34.108Z DEBUG modem << [00:17:20.815,429] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:23:34.123Z DEBUG modem << [00:17:20.824,523] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 3 of 9 in sensor buffer filled[0m
2022-07-25T05:23:34.137Z DEBUG modem << [00:17:20.836,029] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:34.152Z DEBUG modem << [00:17:20.845,794] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:23:34.166Z DEBUG modem << [00:17:20.857,391] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:34.181Z DEBUG modem << [00:17:20.936,187] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:23:34.195Z DEBUG modem << [00:17:20.946,441] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:34.209Z DEBUG modem << [00:17:21.025,817] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:23:34.224Z DEBUG modem << [00:17:21.039,642] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:23:34.239Z DEBUG modem << [00:17:21.050,262] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:35.009Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:23:35.025Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:23:35.040Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:35.055Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:35.069Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.084Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.098Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.112Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.127Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.141Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.155Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.170Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.184Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.199Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.214Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.228Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:35.243Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:36.033Z DEBUG modem << Tx: 13
2022-07-25T05:23:36.047Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:23:36.064Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:36.078Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:36.093Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:36.107Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:36.122Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:36.136Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:36.150Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:36.165Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:36.179Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:36.193Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:36.208Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:36.223Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:36.237Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:37.696Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:23:37.711Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:23:38.491Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:38.507Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:38.521Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.536Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.550Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.565Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.579Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.594Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.608Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.623Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.638Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.653Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.667Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.682Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:38.696Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:39.703Z DEBUG modem << Tx: 13
2022-07-25T05:23:39.718Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:23:40.507Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:40.521Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:40.535Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:40.550Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:40.564Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:40.579Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:40.593Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:40.607Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:40.622Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:40.636Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:40.650Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:40.665Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:40.680Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:41.746Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:42.520Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:42.535Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:42.549Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:42.563Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.578Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.592Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.606Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.620Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.635Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.649Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.663Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.678Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.692Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.706Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.720Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:42.734Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:43.491Z DEBUG modem << [00:17:30.477,111] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:23:44.276Z DEBUG modem << Tx: 13
2022-07-25T05:23:44.291Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:23:44.305Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:44.320Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:44.334Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:44.348Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:44.362Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:44.376Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:44.391Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:44.405Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:44.419Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:44.433Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:44.447Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:44.461Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:44.475Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:45.801Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:45.816Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:45.831Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:45.846Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:45.861Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:45.875Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:45.889Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:45.904Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:45.918Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:45.933Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:45.947Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:45.962Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:45.976Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:45.991Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:46.005Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:46.019Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:46.034Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:47.822Z DEBUG modem << Tx: 13
2022-07-25T05:23:47.838Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:23:49.846Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:49.862Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:49.879Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:49.895Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:49.911Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:49.926Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:49.945Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:49.960Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:49.975Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:49.991Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:50.006Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:50.021Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:50.843Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:50.859Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:50.874Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:50.889Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:50.904Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:51.859Z DEBUG modem << Tx: 13
2022-07-25T05:23:51.874Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:23:52.678Z DEBUG modem << [00:17:40.643,554] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:23:52.695Z DEBUG modem << [00:17:40.651,947] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:23:52.710Z DEBUG modem << [00:17:40.658,874] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:23:52.726Z DEBUG modem << [00:17:40.668,365] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:23:52.741Z DEBUG modem << [00:17:40.674,957] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:23:52.757Z DEBUG modem << [00:17:40.683,166] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:23:52.771Z DEBUG modem << [00:17:40.691,223] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:23:52.786Z DEBUG modem << [00:17:40.699,707] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:23:52.801Z DEBUG modem << [00:17:40.707,458] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:23:52.816Z DEBUG modem << [00:17:40.715,148] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:23:52.830Z DEBUG modem << [00:17:40.721,710] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:23:52.845Z DEBUG modem << [00:17:40.728,607] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:23:52.861Z DEBUG modem << [00:17:40.740,966] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:23:52.875Z DEBUG modem << [00:17:40.748,840] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:23:52.890Z DEBUG modem << [00:17:40.763,000] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:23:52.906Z DEBUG modem << [00:17:40.769,958] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:23:52.920Z DEBUG modem << [00:17:40.779,357] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:23:52.936Z DEBUG modem << [00:17:40.786,468] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:23:52.951Z DEBUG modem << [00:17:40.795,837] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:23:52.966Z DEBUG modem << [00:17:40.805,603] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:23:52.980Z DEBUG modem << [00:17:40.815,673] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:23:52.995Z DEBUG modem << [00:17:40.824,798] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 4 of 9 in sensor buffer filled[0m
2022-07-25T05:23:53.011Z DEBUG modem << [00:17:40.836,303] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:53.025Z DEBUG modem << [00:17:40.846,099] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:23:53.040Z DEBUG modem << [00:17:40.857,727] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:53.819Z DEBUG modem << [00:17:40.936,523] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:23:53.835Z DEBUG modem << [00:17:40.946,777] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:53.850Z DEBUG modem << [00:17:41.026,000] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:23:53.865Z DEBUG modem << [00:17:41.039,825] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:23:53.880Z DEBUG modem << [00:17:41.050,476] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:23:54.650Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:54.670Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:23:54.686Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:54.700Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:54.715Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.730Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.744Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.760Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.774Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.789Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.804Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.819Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.833Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.848Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.864Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.878Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:54.893Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:55.906Z DEBUG modem << Tx: 13
2022-07-25T05:23:55.921Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:23:56.725Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:56.741Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:56.756Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:56.772Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:56.787Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:56.801Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:56.816Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:56.831Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:56.846Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:56.861Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:56.876Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:56.891Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:56.906Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:56.921Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:23:56.936Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:23:56.951Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:23:56.966Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:23:56.984Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:23:57.001Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:23:57.017Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:23:57.031Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:23:57.046Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:23:57.062Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:23:57.077Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:23:57.092Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:23:57.108Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:23:57.963Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:57.978Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:23:57.993Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:23:58.007Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:23:58.022Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.037Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.052Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.067Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.082Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.096Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.111Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.126Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.140Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.155Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.170Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.185Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:58.200Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:23:59.955Z DEBUG modem << Tx: 13
2022-07-25T05:23:59.971Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:24:00.762Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:00.780Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:00.795Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:00.810Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:00.824Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:00.839Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:00.853Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:00.867Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:00.882Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:00.897Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:00.911Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:00.926Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:00.940Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:02.009Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:24:02.024Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:24:02.040Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:02.055Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:02.069Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.084Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.098Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.112Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.127Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.142Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.157Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.171Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.186Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.200Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.215Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.229Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:02.243Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:04.031Z DEBUG modem << Tx: 13
2022-07-25T05:24:04.046Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:24:04.928Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:04.945Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:04.960Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:04.975Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:04.990Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:05.007Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:05.027Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:05.042Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:05.057Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:05.074Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:05.089Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:05.104Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:05.118Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:06.169Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:24:06.184Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:24:06.200Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:06.216Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:06.230Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.245Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.261Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.277Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.293Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.308Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.323Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.338Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.352Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.367Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.384Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:06.398Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:07.184Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:07.199Z DEBUG modem << [00:17:54.291,168] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:24:07.214Z DEBUG modem << [00:17:54.299,682] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:24:07.229Z DEBUG modem << [00:17:54.308,135] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:24:07.246Z DEBUG modem << [00:17:54.319,305] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:24:07.261Z DEBUG modem << [00:17:54.326,751] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:24:07.276Z DEBUG modem << [00:17:54.333,770] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:24:07.291Z DEBUG modem << [00:17:54.340,820] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:24:07.305Z DEBUG modem << [00:17:54.347,778] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:24:07.320Z DEBUG modem << [00:17:54.354,888] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:24:07.334Z DEBUG modem << [00:17:54.361,846] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:24:07.349Z DEBUG modem << Tx: 13
2022-07-25T05:24:07.364Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:24:07.379Z DEBUG modem << [00:17:54.374,359] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:24:07.394Z DEBUG modem << [00:17:54.383,758] [1;33m<wrn> cloud_codec_ringbuffer: On line 33 in ringbuffer[0m
2022-07-25T05:24:07.408Z DEBUG modem << [00:17:54.391,326] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 0 of 2 in bms buffer filled[0m
2022-07-25T05:24:07.423Z DEBUG modem << [00:17:54.402,313] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:24:07.438Z DEBUG modem << [00:17:54.410,614] [0m<dbg> data_module:Capture 1 data bytes:
2022-07-25T05:24:07.452Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:07.467Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:07.482Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:07.497Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:07.512Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:07.526Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:07.541Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:07.556Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:07.570Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:07.585Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:07.600Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:07.614Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:07.629Z DEBUG modem <<  requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:07.644Z DEBUG modem << [00:17:54.447,998] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:24:08.449Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:24:08.465Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:24:08.480Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:08.494Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:08.510Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.524Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.539Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.553Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.568Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.583Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.597Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.612Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.626Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.641Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.656Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.670Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:08.685Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:10.200Z DEBUG modem << Tx: 13
2022-07-25T05:24:10.215Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:24:11.022Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:11.037Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:11.052Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:11.067Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:11.082Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:11.097Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:11.112Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:11.126Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:11.141Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:11.156Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:11.171Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:11.186Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:11.201Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:12.233Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:24:13.021Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:24:13.036Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:13.051Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:13.066Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.081Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.096Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.110Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.125Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.140Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.154Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.169Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.184Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.199Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.213Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.228Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:13.243Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:14.039Z DEBUG modem << [00:18:00.484,313] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:24:14.054Z DEBUG modem << [00:18:00.643,585] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:24:14.068Z DEBUG modem << [00:18:00.651,947] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:24:14.083Z DEBUG modem << [00:18:00.658,905] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:24:14.098Z DEBUG modem << [00:18:00.668,365] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:24:14.113Z DEBUG modem << [00:18:00.674,957] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:24:14.128Z DEBUG modem << [00:18:00.683,166] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:24:14.143Z DEBUG modem << [00:18:00.691,192] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:24:14.157Z DEBUG modem << [00:18:00.699,676] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:24:14.172Z DEBUG modem << [00:18:00.707,427] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:24:14.187Z DEBUG modem << [00:18:00.715,118] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:24:14.202Z DEBUG modem << [00:18:00.721,649] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:24:14.217Z DEBUG modem << [00:18:00.728,546] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:24:14.231Z DEBUG modem << [00:18:00.740,905] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:24:14.247Z DEBUG modem << [00:18:00.748,779] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:24:14.261Z DEBUG modem << [00:18:00.762,908] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:24:14.276Z DEBUG modem << [00:18:00.769,866] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:24:14.291Z DEBUG modem << [00:18:00.779,266] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:24:14.306Z DEBUG modem << [00:18:00.786,376] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:24:14.321Z DEBUG modem << [00:18:00.795,745] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:24:14.336Z DEBUG modem << [00:18:00.805,511] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:24:14.351Z DEBUG modem << [00:18:00.815,551] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:24:14.366Z DEBUG modem << [00:18:00.824,676] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 5 of 9 in sensor buffer filled[0m
2022-07-25T05:24:14.380Z DEBUG modem << [00:18:00.836,181] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:14.395Z DEBUG modem << [00:18:00.845,947] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:24:14.410Z DEBUG modem << [00:18:00.857,574] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:14.425Z DEBUG modem << [00:18:00.936,370] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:24:14.439Z DEBUG modem << [00:18:00.946,624] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:14.454Z DEBUG modem << [00:18:01.031,921] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:24:14.470Z DEBUG modem << [00:18:01.045,745] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:24:14.485Z DEBUG modem << [00:18:01.056,396] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:15.273Z DEBUG modem << Tx: 13
2022-07-25T05:24:15.290Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:24:15.305Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:15.320Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:15.335Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:15.350Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:15.365Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:15.380Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:15.394Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:15.409Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:15.424Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:15.438Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:15.453Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:15.468Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:15.483Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:16.305Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:24:16.320Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:24:16.335Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:16.350Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:16.364Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.379Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.394Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.408Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.423Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.438Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.452Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.467Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.481Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.497Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.512Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.526Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:16.541Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:18.288Z DEBUG modem << Tx: 13
2022-07-25T05:24:18.307Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:24:19.097Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:19.112Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:19.126Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:19.141Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:19.156Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:19.171Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:19.185Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:19.200Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:19.214Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:19.229Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:19.244Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:19.258Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:19.273Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:20.337Z DEBUG modem <<  bms incoming_message: a5,1,93,8,1,1,1,51,0,0,7,cf,6b,
2022-07-25T05:24:20.353Z DEBUG modem << buffer_1: a5,1,93,8,1,1,1,51,0,0,7,cf,6b,
2022-07-25T05:24:20.368Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:20.383Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:20.398Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.412Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.427Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.442Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.457Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.472Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.487Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.502Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.517Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.532Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.547Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.562Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:20.577Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:22.338Z DEBUG modem << Tx: 13
2022-07-25T05:24:22.354Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:24:24.386Z DEBUG modem <<  bms incoming_message: a5,1,93,8,1,1,1,51,0,0,7,cf,6b,
2022-07-25T05:24:24.403Z DEBUG modem << buffer_1: a5,1,93,8,1,1,1,51,0,0,7,cf,6b,
2022-07-25T05:24:25.195Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:25.211Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:25.226Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.241Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.257Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.272Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.287Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.302Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.317Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.332Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.347Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.363Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.378Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.393Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:25.409Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:26.400Z DEBUG modem << Tx: 13
2022-07-25T05:24:26.416Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:24:28.436Z DEBUG modem <<  bms incoming_message: a5,1,93,8,1,1,1,51,0,0,7,cf,6b,
2022-07-25T05:24:29.218Z DEBUG modem << buffer_1: a5,1,93,8,1,1,1,51,0,0,7,cf,6b,
2022-07-25T05:24:29.233Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:29.248Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:29.263Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.279Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.294Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.308Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.324Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.339Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.353Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.369Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.384Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.399Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.413Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.429Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:29.444Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:30.441Z DEBUG modem << Tx: 13
2022-07-25T05:24:31.206Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:24:31.996Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:32.011Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:32.027Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:32.042Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:32.057Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:32.072Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:32.087Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:32.102Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:32.117Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:32.132Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:32.147Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:32.162Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:32.177Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:32.192Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:32.207Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:32.222Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:32.236Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:32.252Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:32.266Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:32.281Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:32.297Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:32.311Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:32.326Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:32.341Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:32.356Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:32.371Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:33.159Z DEBUG modem << [00:18:20.643,615] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:24:33.175Z DEBUG modem << [00:18:20.651,977] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:24:33.191Z DEBUG modem << [00:18:20.658,935] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:24:33.207Z DEBUG modem << [00:18:20.668,029] [1;33m<wrn> modules_common: bms_DALY: Message could not be enqueued, error code: -35[0m
2022-07-25T05:24:33.221Z DEBUG modem << [00:18:20.677,642] [1;31m<err> bms_module: Message could not be enqueued in bms_event_handler[0m
2022-07-25T05:24:33.237Z DEBUG modem << [00:18:20.686,737] [0m<inf> app_event_manager: e:bms_module_event BMS_EVT_ERROR - Error code -35[0m
2022-07-25T05:24:33.252Z DEBUG modem << [00:18:20.695,922] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:24:33.266Z DEBUG modem << [00:18:20.703,369] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:24:33.281Z DEBUG modem << [00:18:20.710,388] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:24:33.296Z DEBUG modem << [00:18:20.716,979] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:24:33.311Z DEBUG modem << [00:18:20.725,189] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:24:33.326Z DEBUG modem << [00:18:20.733,245] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:24:33.341Z DEBUG modem << [00:18:20.741,729] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:24:33.356Z DEBUG modem << [00:18:20.749,481] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:24:33.371Z DEBUG modem << [00:18:20.757,171] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:24:33.386Z DEBUG modem << [00:18:20.763,732] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:24:33.401Z DEBUG modem << [00:18:20.770,629] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:24:33.415Z DEBUG modem << [00:18:20.782,989] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:24:33.430Z DEBUG modem << [00:18:20.790,893] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:24:33.445Z DEBUG modem << [00:18:20.805,023] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:24:33.460Z DEBUG modem << [00:18:20.811,981] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:24:33.475Z DEBUG modem << [00:18:20.821,380] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:24:33.490Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:33.504Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:24:33.519Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:33.534Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:33.548Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.564Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.579Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.593Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.608Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.623Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.638Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.652Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.668Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.682Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.697Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.712Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.727Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:33.741Z DEBUG modem << [00:18:20.876,495] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:24:33.756Z DEBUG modem << [00:18:20.885,894] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:24:33.771Z DEBUG modem << [00:18:20.895,660] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:24:33.789Z DEBUG modem << [00:18:20.905,731] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:33.804Z DEBUG modem << [00:18:20.915,527] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:24:33.819Z DEBUG modem << [00:18:20.924,652] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 6 of 9 in sensor buffer filled[0m
2022-07-25T05:24:33.834Z DEBUG modem << [00:18:20.936,157] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:33.849Z DEBUG modem << [00:18:20.945,922] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 2 of 2 in movement buffer filled[0m
2022-07-25T05:24:33.864Z DEBUG modem << [00:18:20.957,550] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:33.879Z DEBUG modem << [00:18:21.036,376] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:24:33.894Z DEBUG modem << [00:18:21.046,630] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:33.909Z DEBUG modem << [00:18:21.125,854] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:24:34.698Z DEBUG modem << [00:18:21.139,678] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:24:34.714Z DEBUG modem << [00:18:21.150,299] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:35.484Z DEBUG modem << Tx: 13
2022-07-25T05:24:35.500Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:24:35.516Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:35.532Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:35.547Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:35.562Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:35.577Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:35.592Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:35.607Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:35.622Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:35.637Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:35.652Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:35.667Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:35.682Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:35.697Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:36.697Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:24:36.713Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:24:37.518Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:37.535Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:37.550Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.565Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.581Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.596Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.611Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.625Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.641Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.656Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.671Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.686Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.701Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.716Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:37.730Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:38.701Z DEBUG modem << Tx: 13
2022-07-25T05:24:38.720Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:24:39.494Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:39.511Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:39.526Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:39.541Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:39.558Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:39.574Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:39.589Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:39.604Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:39.619Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:39.634Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:40.422Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:40.437Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:40.453Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:41.238Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:24:41.254Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:24:41.270Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:41.285Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:41.300Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.315Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.330Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.345Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.360Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.375Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.390Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.405Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.420Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.435Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.451Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.466Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.481Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:41.496Z DEBUG modem << [00:18:28.977,020] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:24:41.511Z DEBUG modem << [00:18:28.985,534] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:24:41.526Z DEBUG modem << [00:18:28.993,957] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:24:41.541Z DEBUG modem << [00:18:29.005,157] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:24:41.556Z DEBUG modem << [00:18:29.012,603] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:24:41.571Z DEBUG modem << [00:18:29.019,592] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:24:41.586Z DEBUG modem << [00:18:29.026,672] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:24:41.601Z DEBUG modem << [00:18:29.033,630] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:24:41.616Z DEBUG modem << Tx: 13
2022-07-25T05:24:41.631Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:24:41.646Z DEBUG modem << [00:18:29.046,142] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:24:41.661Z DEBUG modem << [00:18:29.055,572] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 1 ofCapture 1 data bytes:
2022-07-25T05:24:41.677Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:41.692Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:41.707Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:41.722Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:41.737Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:41.752Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:41.767Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:41.782Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:41.797Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:41.813Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:42.623Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:42.638Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:42.654Z DEBUG modem <<  2 in bms buffer filled[0m
2022-07-25T05:24:42.669Z DEBUG modem << [00:18:29.094,146] [0m<dbg> data_module: on_all_states:  data module: populated bms_buf [0m
2022-07-25T05:24:42.684Z DEBUG modem << [00:18:29.102,447] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:42.699Z DEBUG modem << [00:18:29.112,213] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:24:43.466Z DEBUG modem << [00:18:30.491,516] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:24:44.255Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:24:44.270Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:24:44.286Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:44.301Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:44.316Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.332Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.347Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.362Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.376Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.391Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.406Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.421Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.436Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.451Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.466Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.481Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:44.496Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:45.293Z DEBUG modem << Tx: 13
2022-07-25T05:24:45.310Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:24:45.325Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:45.340Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:45.355Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:45.370Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:45.385Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:45.400Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:45.414Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:45.429Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:45.444Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:45.459Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:45.474Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:45.489Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:45.504Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:46.908Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:24:46.924Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:24:46.939Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:46.954Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:46.969Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:46.983Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:46.998Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:47.013Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:47.027Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:47.042Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:47.057Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:47.071Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:47.087Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:47.101Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:47.116Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:47.131Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:47.145Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:48.939Z DEBUG modem << Tx: 13
2022-07-25T05:24:48.954Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:24:49.788Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:49.804Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:49.818Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:49.834Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:49.848Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:49.863Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:49.877Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:49.892Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:49.907Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:49.922Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:49.936Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:24:49.952Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:24:49.967Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:24:50.990Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:24:51.009Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:24:51.026Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:51.042Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:51.057Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.073Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.088Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.103Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.119Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.135Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.151Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.166Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.182Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.197Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.213Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.228Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:51.243Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:52.544Z DEBUG modem << [00:18:40.643,646] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:24:52.561Z DEBUG modem << [00:18:40.652,008] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:24:52.577Z DEBUG modem << [00:18:40.658,935] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:24:52.592Z DEBUG modem << [00:18:40.668,395] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:24:52.606Z DEBUG modem << [00:18:40.674,987] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:24:52.622Z DEBUG modem << [00:18:40.683,166] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:24:52.637Z DEBUG modem << [00:18:40.691,223] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:24:53.457Z DEBUG modem << [00:18:40.699,676] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:24:53.475Z DEBUG modem << [00:18:40.707,427] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:24:53.490Z DEBUG modem << [00:18:40.715,118] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:24:53.506Z DEBUG modem << [00:18:40.721,679] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:24:53.521Z DEBUG modem << [00:18:40.728,546] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:24:53.537Z DEBUG modem << [00:18:40.740,905] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:24:53.552Z DEBUG modem << [00:18:40.748,779] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:24:53.567Z DEBUG modem << [00:18:40.762,908] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:24:53.583Z DEBUG modem << [00:18:40.769,836] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:24:53.598Z DEBUG modem << [00:18:40.779,235] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:24:53.614Z DEBUG modem << [00:18:40.786,346] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:24:53.632Z DEBUG modem << [00:18:40.795,715] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:24:53.647Z DEBUG modem << [00:18:40.805,450] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:24:53.662Z DEBUG modem << [00:18:40.815,490] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:24:53.678Z DEBUG modem << [00:18:40.824,615] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 7 of 9 in sensor buffer filled[0m
2022-07-25T05:24:53.693Z DEBUG modem << [00:18:40.836,090] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:53.708Z DEBUG modem << [00:18:40.845,886] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 0 of 2 in movement buffer filled[0m
2022-07-25T05:24:53.723Z DEBUG modem << [00:18:40.857,482] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:54.523Z DEBUG modem << [00:18:40.936,248] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:24:54.540Z DEBUG modem << [00:18:40.946,472] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:54.555Z DEBUG modem << [00:18:41.025,299] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:24:54.570Z DEBUG modem << [00:18:41.039,123] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:24:54.586Z DEBUG modem << [00:18:41.049,743] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:24:54.601Z DEBUG modem << Tx: 13
2022-07-25T05:24:54.616Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:24:54.631Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:54.650Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:54.665Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:54.680Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:24:54.694Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:24:54.709Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:24:54.724Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:24:54.739Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:24:54.754Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:24:54.768Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:24:54.783Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:24:54.798Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:24:54.812Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:24:55.656Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:24:55.673Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:24:55.689Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:55.705Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:55.720Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.734Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.749Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.764Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.779Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.794Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.810Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.825Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.840Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.854Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.869Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.884Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:55.899Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:57.023Z DEBUG modem << Tx: 13
2022-07-25T05:24:57.048Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:24:59.066Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:24:59.082Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:24:59.097Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:24:59.113Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:24:59.128Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.142Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.158Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.173Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.188Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.202Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.217Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.232Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.247Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.263Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.277Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.292Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:24:59.307Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:01.070Z DEBUG modem << Tx: 13
2022-07-25T05:25:01.086Z DEBUG modem << a5,40,95,8,0,0,0,0,0,0,0,0,82
2022-07-25T05:25:03.120Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:25:03.136Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:25:03.152Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:25:03.167Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:25:03.182Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.197Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.212Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.228Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.243Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.258Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.273Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.288Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.303Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.318Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.333Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.348Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:03.363Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:05.110Z DEBUG modem << Tx: 13
2022-07-25T05:25:05.128Z DEBUG modem << a5,40,96,8,0,0,0,0,0,0,0,0,83
2022-07-25T05:25:06.021Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:25:06.037Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:25:06.052Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:25:06.067Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:25:06.082Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:25:06.097Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:25:06.113Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:25:06.129Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:25:06.144Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:25:06.158Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:25:06.174Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:25:06.189Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:25:06.204Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:25:06.219Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:25:06.234Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:25:06.250Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:25:06.265Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:25:06.279Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:25:06.295Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:25:06.309Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:25:06.324Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:25:06.339Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:25:06.355Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:25:06.374Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:25:06.390Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:25:06.406Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:25:07.237Z DEBUG modem <<  bms incoming_message: a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:25:07.254Z DEBUG modem << buffer_1: a5,1,96,8,1,41,28,28,28,28,28,28,76,
2022-07-25T05:25:07.271Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:25:07.286Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:25:07.301Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.316Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.331Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.347Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.362Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.377Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.395Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.410Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.426Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.441Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.457Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.472Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:07.487Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:09.165Z DEBUG modem << Tx: 13
2022-07-25T05:25:09.185Z DEBUG modem << a5,40,97,8,0,0,0,0,0,0,0,0,84
2022-07-25T05:25:10.025Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:25:10.047Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:25:10.063Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:25:10.079Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:25:10.094Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:25:10.109Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:25:10.124Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:25:10.139Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:25:10.161Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:25:10.180Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:25:10.196Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:25:10.211Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:25:10.226Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:25:11.213Z DEBUG modem <<  bms incoming_message: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:25:11.229Z DEBUG modem << buffer_1: a5,1,97,8,0,0,0,0,0,0,0,0,45,
2022-07-25T05:25:11.244Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:25:11.259Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:25:11.274Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.289Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.304Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.319Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.334Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.349Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.364Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.378Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.394Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.409Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.424Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.438Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:11.453Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:12.292Z DEBUG modem << [00:19:00.498,748] [0m<dbg> watchdog: primary_feed_worker: Feeding watchdog[0m
2022-07-25T05:25:13.105Z DEBUG modem << [00:19:00.643,676] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:25:13.121Z DEBUG modem << [00:19:00.652,038] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:25:13.136Z DEBUG modem << [00:19:00.658,996] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:25:13.151Z DEBUG modem << [00:19:00.668,457] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:25:13.166Z DEBUG modem << [00:19:00.675,048] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:25:13.180Z DEBUG modem << [00:19:00.683,258] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:25:13.195Z DEBUG modem << [00:19:00.691,284] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:25:13.209Z DEBUG modem << [00:19:00.699,737] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:25:13.225Z DEBUG modem << [00:19:00.707,519] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:25:13.239Z DEBUG modem << [00:19:00.715,179] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:25:13.254Z DEBUG modem << [00:19:00.721,740] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:25:13.268Z DEBUG modem << [00:19:00.728,607] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:25:13.283Z DEBUG modem << [00:19:00.740,966] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:25:13.297Z DEBUG modem << [00:19:00.748,840] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:25:13.312Z DEBUG modem << [00:19:00.762,969] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:25:13.326Z DEBUG modem << [00:19:00.769,897] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:25:13.342Z DEBUG modem << [00:19:00.779,296] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:25:13.356Z DEBUG modem << [00:19:00.786,407] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:25:13.371Z DEBUG modem << [00:19:00.795,776] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:25:13.385Z DEBUG modem << [00:19:00.805,541] [0m<inf> app_event_manager: e:sensor_module_event SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
2022-07-25T05:25:13.400Z DEBUG modem << [00:19:00.815,582] [0m<dbg> data_module: on_all_states:  data_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:25:13.414Z DEBUG modem << [00:19:00.824,707] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_sensor_buffer: Entry: 8 of 9 in sensor buffer filled[0m
2022-07-25T05:25:13.429Z DEBUG modem << [00:19:00.836,181] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:25:13.444Z DEBUG modem << [00:19:00.845,947] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_accel_buffer: Entry: 1 of 2 in movement buffer filled[0m
2022-07-25T05:25:13.458Z DEBUG modem << [00:19:00.857,574] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:25:13.473Z DEBUG modem << [00:19:00.936,370] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2022-07-25T05:25:13.487Z DEBUG modem << [00:19:00.946,594] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:25:13.502Z DEBUG modem << [00:19:01.025,421] [0m<dbg> modem_module: populate_event_with_dynamic_modem_data: No dynamic modem parameters have changed from the last sample request.[0m
2022-07-25T05:25:13.516Z DEBUG modem << [00:19:01.039,703] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
2022-07-25T05:25:13.531Z DEBUG modem << [00:19:01.050,323] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:25:14.339Z DEBUG modem << Tx: 13
2022-07-25T05:25:14.356Z DEBUG modem << a5,40,98,8,0,0,0,0,0,0,0,0,85
2022-07-25T05:25:14.371Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:25:14.386Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:25:14.401Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:25:14.416Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:25:14.431Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:25:14.446Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:25:14.461Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:25:14.476Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:25:14.491Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:25:14.506Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:25:14.521Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:25:14.536Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:25:14.551Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:25:15.393Z DEBUG modem <<  bms incoming_message: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:25:15.408Z DEBUG modem << buffer_1: a5,1,98,8,0,0,0,0,0,0,0,0,46,
2022-07-25T05:25:15.424Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:25:15.439Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:25:15.453Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.468Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.483Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.499Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.514Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.529Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.543Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.558Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.573Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.588Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.603Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.618Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.633Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:15.650Z DEBUG modem << [00:19:03.498,687] [1;33m<wrn> bms_module: on line 327 3.8090,3.7690,3809,25,0.2040,25,0,0 [0m
2022-07-25T05:25:15.666Z DEBUG modem << [00:19:03.507,232] [0m<inf> bms_module: BMS Thread: bms_run_event submit in Running State[0m
2022-07-25T05:25:16.479Z DEBUG modem << [00:19:03.515,655] [0m<inf> app_event_manager: e:bms_module_event BMS_DATA_READY - bms_id: 3902,PackV:26.0,SOC:99,Amp:0[0m
2022-07-25T05:25:16.495Z DEBUG modem << [00:19:03.526,824] [0m<inf> main: MAIN Thread: BMS Event detected and enqueued[0m
2022-07-25T05:25:16.510Z DEBUG modem << [00:19:03.534,271] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:25:16.525Z DEBUG modem << [00:19:03.541,259] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:25:16.540Z DEBUG modem << [00:19:03.548,309] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:25:16.555Z DEBUG modem << [00:19:03.555,297] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:25:16.570Z DEBUG modem << [00:19:03.562,377] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:25:16.585Z DEBUG modem << [00:19:03.569,335] [0m<inf> bms_module: BMS Thread: processing APP_EVT_DATA_GET in running State[0m
2022-07-25T05:25:16.600Z DEBUG modem << Tx: 13
2022-07-25T05:25:16.615Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:25:16.629Z DEBUG modem << [00:19:03.581,848] [0m<dbg> data_module: on_all_states:  data module: processing BMS_DATA_READY Event[0m
2022-07-25T05:25:16.645Z DEBUG modem << [00:19:03.591,308] [0m<dbg> cloud_codec_ringbuffer: cloud_codec_populate_bms_buffer: Entry: 2 of 2 in bms buffer filled[0m
2022-07-25T05:25:16.660Z DEBUG modem << [00:19:03.602,264] [0m<dbg> data_module: on_all_states:  data module: populCapture 1 data bytes:
2022-07-25T05:25:16.674Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:25:16.689Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:25:16.704Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:25:16.719Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:25:16.734Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:25:16.753Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:25:16.768Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:25:16.783Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:25:16.798Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:25:16.813Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:25:16.828Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:25:16.843Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:25:16.858Z DEBUG modem << ated bms_buf [0m
2022-07-25T05:25:16.873Z DEBUG modem << [00:19:03.638,153] [0m<dbg> data_module: requested_data_status_set: processed requested_data_status_set()[0m
2022-07-25T05:25:16.888Z DEBUG modem << [00:19:03.647,918] [0m<dbg> data_module: on_all_states:  data module: processed BMS_DATA_READY Event[0m
2022-07-25T05:25:17.732Z DEBUG modem <<  bms incoming_message: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:25:17.748Z DEBUG modem << buffer_1: a5,1,90,8,1,9,1,9,75,30,3,de,d8,
2022-07-25T05:25:17.763Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:25:17.778Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:25:17.794Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.809Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.824Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.840Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.855Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.870Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.885Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.900Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.915Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.930Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.945Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.960Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:17.975Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:19.395Z DEBUG modem << Tx: 13
2022-07-25T05:25:19.411Z DEBUG modem << a5,40,91,8,0,0,0,0,0,0,0,0,7e
2022-07-25T05:25:20.246Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:25:20.261Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:25:20.276Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:25:20.291Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:25:20.307Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:25:20.322Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:25:20.337Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:25:20.352Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:25:20.367Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:25:20.382Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:25:20.397Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:25:20.411Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:25:20.426Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:25:21.443Z DEBUG modem <<  bms incoming_message: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:25:21.460Z DEBUG modem << buffer_1: a5,1,91,8,e,e1,2,e,b9,3,0,0,fa,
2022-07-25T05:25:21.475Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:25:21.490Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:25:21.506Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.521Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.536Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.551Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.565Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.580Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.595Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.610Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.625Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.640Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.654Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.669Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:21.685Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:23.456Z DEBUG modem << Tx: 13
2022-07-25T05:25:23.473Z DEBUG modem << a5,40,92,8,0,0,0,0,0,0,0,0,7f
2022-07-25T05:25:24.277Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:25:24.292Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:25:24.307Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:25:24.321Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:25:24.336Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:25:24.351Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:25:24.366Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:25:24.381Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:25:24.395Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:25:24.410Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:25:24.425Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:25:24.440Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:25:24.455Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:25:25.492Z DEBUG modem <<  bms incoming_message: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:25:25.511Z DEBUG modem << buffer_1: a5,1,92,8,41,1,41,1,0,0,0,0,c4,
2022-07-25T05:25:25.526Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:25:25.542Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:25:25.556Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:25.571Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:25.586Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:26.388Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:26.404Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:26.418Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:26.433Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:26.448Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:26.463Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:26.478Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:26.493Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:26.508Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:26.523Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:27.499Z DEBUG modem << Tx: 13
2022-07-25T05:25:27.515Z DEBUG modem << a5,40,93,8,0,0,0,0,0,0,0,0,80
2022-07-25T05:25:28.337Z DEBUG modem << Capture 1 data bytes:
2022-07-25T05:25:28.353Z DEBUG modem << Capture 2 data bytes:
2022-07-25T05:25:28.368Z DEBUG modem << Capture 3 data bytes:
2022-07-25T05:25:28.383Z DEBUG modem << Capture 4 data bytes:
2022-07-25T05:25:28.398Z DEBUG modem << Capture 5 data bytes:
2022-07-25T05:25:28.413Z DEBUG modem << Capture 6 data bytes:
2022-07-25T05:25:28.428Z DEBUG modem << Capture 7 data bytes:
2022-07-25T05:25:28.442Z DEBUG modem << Capture 8 data bytes:
2022-07-25T05:25:28.457Z DEBUG modem << Capture 9 data bytes:
2022-07-25T05:25:28.472Z DEBUG modem << Capture 10 data bytes:
2022-07-25T05:25:28.488Z DEBUG modem << Capture 11 data bytes:
2022-07-25T05:25:28.503Z DEBUG modem << Capture 12 data bytes:
2022-07-25T05:25:28.518Z DEBUG modem << Capture 13 data bytes:
2022-07-25T05:25:29.543Z DEBUG modem <<  bms incoming_message: a5,1,93,8,1,1,1,87,0,0,7,cf,a1,
2022-07-25T05:25:29.560Z DEBUG modem << buffer_1: a5,1,93,8,1,1,1,87,0,0,7,cf,a1,
2022-07-25T05:25:29.576Z DEBUG modem << a5,1,96,8,2,28,28,28,28,28,28,28,5e,
2022-07-25T05:25:29.592Z DEBUG modem << a5,1,95,8,3,e,ba,e,ce,e,d4,0,cc,
2022-07-25T05:25:29.607Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:29.622Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:29.637Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:29.653Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:29.668Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:29.683Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:29.698Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:29.713Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:29.729Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:30.534Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:30.550Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:30.566Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:30.581Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:31.552Z DEBUG modem << Tx: 13
2022-07-25T05:25:31.568Z DEBUG modem << a5,40,94,8,0,0,0,0,0,0,0,0,81
2022-07-25T05:25:32.550Z DEBUG modem << [00:19:20.643,707] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET_ALL[0m
2022-07-25T05:25:32.565Z DEBUG modem << [00:19:20.652,069] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:25:32.580Z DEBUG modem << [00:19:20.659,027] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:25:32.596Z DEBUG modem << [00:19:20.668,487] [0m<dbg> main: data_get:  Main: Entered data_get()[0m
2022-07-25T05:25:32.611Z DEBUG modem << [00:19:20.675,079] [0m<dbg> main: data_get:  Modem_dyn data request through data_list[][0m
2022-07-25T05:25:32.626Z DEBUG modem << [00:19:20.683,288] [0m<dbg> main: data_get:  APP_ENV data request through data_list[][0m
2022-07-25T05:25:32.641Z DEBUG modem << [00:19:20.691,314] [0m<dbg> main: data_get:  APP_MOVEMENT data request through data_list[][0m
2022-07-25T05:25:32.656Z DEBUG modem << [00:19:20.699,798] [0m<dbg> main: data_get:  GNSS data request through data_list[][0m
2022-07-25T05:25:32.672Z DEBUG modem << [00:19:20.707,550] [0m<dbg> main: data_get:  BMS data request through data_list[][0m
2022-07-25T05:25:32.687Z DEBUG modem << [00:19:20.715,240] [0m<dbg> main: data_get: Requested Data count = 6[0m
2022-07-25T05:25:32.702Z DEBUG modem << [00:19:20.721,771] [0m<dbg> main: data_get: The APP_DATA_COUNT_SIZE = 8[0m
2022-07-25T05:25:32.717Z DEBUG modem << [00:19:20.728,668] [0m<dbg> main: data_get: Data requested through APP_EVT_DATA_GET Event: MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA[0m
2022-07-25T05:25:32.732Z DEBUG modem << [00:19:20.741,027] [0m<dbg> main: data_get: Ready to submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:25:32.747Z DEBUG modem << [00:19:20.748,901] [0m<inf> app_event_manager: e:app_module_event APP_EVT_DATA_GET - Requested data types (MOD_DYN, ENV, MOVE, GNSS, MOD_STAT, BMS_DATA)[0m
2022-07-25T05:25:33.548Z DEBUG modem << [00:19:20.763,031] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:25:33.564Z DEBUG modem << [00:19:20.769,989] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:25:33.580Z DEBUG modem << [00:19:20.779,388] [0m<dbg> main: data_get: Submit APP_EVT_DATA_GET Event[0m
2022-07-25T05:25:33.595Z DEBUG modem << [00:19:20.786,499] [0m<dbg> modem_module: on_all_states:  modem_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:25:33.611Z DEBUG modem << [00:19:20.795,867] [0m<dbg> sensor_module: on_state_running:  sensor_module: APP_EVT_DATA_GET processing[0m
2022-07-25T05:25:33.626Z DEBUG modem << [00:19:20.805,603] [1;31m<err> app_event_manager: Application Event Manager OOM error
2022-07-25T05:25:33.641Z DEBUG modem << [0m
2022-07-25T05:25:33.656Z DEBUG modem << ASSERTION FAIL [0] @ WEST_TOPDIR/nrf/subsys/app_event_manager/app_event_manager.c:123
2022-07-25T05:25:33.671Z DEBUG modem << [00:19:20.821,319] [1;31m<err> os: r0/a1:  0x00000004  r1/a2:  0x0000007b  r2/a3:  0x00000000[0m
2022-07-25T05:25:33.687Z DEBUG modem << [00:19:20.830,047] [1;31m<err> os: r3/a4:  0x2001bb4d r12/ip:  0x0000a000 r14/lr:  0x00036385[0m
2022-07-25T05:25:33.702Z DEBUG modem << [00:19:20.838,775] [1;31m<err> os:  xpsr:  0x61000000[0m
2022-07-25T05:25:33.718Z DEBUG modem << [00:19:20.844,055] [1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000002  s[ 2]:  0x00000000  s[ 3]:  0x00000000[0m
2022-07-25T05:25:33.733Z DEBUG modem << [00:19:20.854,522] [1;31m<err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000[0m
2022-07-25T05:25:33.748Z DEBUG modem << [00:19:20.865,020] [1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000[0m
2022-07-25T05:25:33.764Z DEBUG modem << [00:19:20.875,518] [1;31m<err> os: s[12]:  0x00000064  s[13]:  0x0000ffff  s[14]:  0x00000000  s[15]:  0x00000000[0m
2022-07-25T05:25:33.779Z DEBUG modem << [00:19:20.885,955] [1;31m<err> os: fpscr:  0x20000010[0m
2022-07-25T05:25:33.794Z DEBUG modem << [00:19:20.891,204] [1;31m<err> os: Faulting instruction address (r15/pc): 0x000584ce[0m
2022-07-25T05:25:33.809Z DEBUG modem << [00:19:20.899,169] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0[0m
2022-07-25T05:25:33.824Z DEBUG modem << [00:19:20.906,951] [1;31m<err> os: Current thread: 0x2000e6e8 (sensor_module_thread)[0m
2022-07-25T05:25:33.839Z DEBUG modem << [00:19:20.914,947] [0m<dbg> util_module: state_set: State transition STATE_INIT --> STATE_REBOOT_PENDING[0m
2022-07-25T05:25:33.854Z DEBUG modem << ASSERTION FAIL [reason != K_ERR_KERNEL_PANIC] @ WEST_TOPDIR/zephyr/kernel/fatal.c:143
2022-07-25T05:25:33.869Z DEBUG modem << Attempted to recover from a kernel panic condition
2022-07-25T05:25:33.884Z DEBUG modem << [00:19:20.936,828] [1;31m<err> os: ***** HARD FAULT *****[0m
2022-07-25T05:25:34.681Z DEBUG modem << [00:19:20.942,413] [UART FRAMING ERROR! CHECK BAUDRATE!]
2022-07-25T05:25:34.697Z DEBUG modem << *** Booting Zephyr OS build v2.7.99-ncs1-2223-g240c7b9a691f  ***
2022-07-25T05:25:34.713Z DEBUG modem << [00:00:00.215,545] [0m<dbg> watchdog: watchdog_timeout_install: Watchdog timeout installed. Timeout: 60[0m
2022-07-25T05:25:34.728Z DEBUG modem << [00:00:00.225,128] [0m<dbg> watchdog: watchdog_start: Watchdog started[0m
2022-07-25T05:25:34.743Z DEBUG modem << [00:00:00.231,903] [0m<dbg> watchdog: watchdog_feed_enable: Watchdog feed enabled. Timeout: 30000[0m
2022-07-25T05:25:35.536Z DEBUG modem <<  UART1 binding Successful
2022-07-25T05:25:35.552Z DEBUG modem <<  UART1 Inittialization Successful
2022-07-25T05:25:35.568Z DEBUG modem << Tx: 13
2022-07-25T05:25:35.584Z DEBUG modem << a5,40,90,8,0,0,0,0,0,0,0,0,7d
2022-07-25T05:25:35.601Z DEBUG modem << [00:00:00.259,948] [0m<inf> bms_module: BMS Thread Start successful: 0[0m
2022-07-25T05:25:35.616Z DEBUG modem << [00:00:00.266,632] [0m<inf> bms_module: State: STATE_INIT[0m
2022-07-25T05:25:35.631Z DEBUG modem << [00:00:00.272,247] [0m<dbg> cloud_module: state_set: Cloud State: STATE_LTE_INIT[0m
2022-07-25T05:25:35.646Z DEBUG modem << [00:00:00.279,815] [0m<dbg> cloud_module: sub_state_set: Cloud Sub state: SUB_STATE_CLOUD_DISCONNECTED[0m
2022-07-25T05:25:35.661Z DEBUG modem << [00:00:00.289,337] [0m<dbg> data_module: state_set: State: STATE_CLOUD_DISCONNECTED[0m
2022-07-25T05:25:35.676Z DEBUG modem << [00:00:00.323,577] [0m<dbg> date_time: date_time_core_register_handler: Registering handler 0x2ae45[0m
2022-07-25T05:25:35.692Z DEBUG modem << [00:00:00.332,824] [0m<dbg> modem_module: state_set: State transition STATE_INIT --> STATE_DISCONNECTED[0m
2022-07-25T05:25:35.707Z DEBUG modem << [00:00:00.342,956] [0m<dbg> gnss_module: lna_configure: MAGPIO command: AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586[0m
2022-07-25T05:25:35.722Z DEBUG modem << [00:00:00.357,849] [0m<dbg> gnss_module: lna_configure: COEX0 command: AT%XCOEX0=1,1,1565,1586[0m
2022-07-25T05:25:35.737Z DEBUG modem <<  bms incoming_message: 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.752Z DEBUG modem << buffer_1: 0,0,0,0,0,0,0,0[00:00:00.373,931] [0m<dbg> gnss_module: state_set: State transition STATE_INIT --> STATE_RUNNING[0m
2022-07-25T05:25:35.768Z DEBUG modem << ,0,0,0,0,0,
2022-07-25T05:25:35.783Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.798Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.813Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.828Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.843Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.858Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.873Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.888Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.903Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.919Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.939Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.954Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.968Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.984Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:35.999Z DEBUG modem << 0,0,0,0,0,0,0,0,0,0,0,0,0,
2022-07-25T05:25:36.014Z DEBUG modem << Catured BMS Values Are: 0.000000,0,0
2022-07-25T05:25:36.028Z DEBUG modem << [00:00:00.424,591] [0m<inf> app_event_manager: e:app_module_event APP_EVT_START[0m
2022-07-25T05:25:36.043Z DEBUG modem << [00:00:00.432,128] [0m<dbg> gnss_module: state_set: State transition STATE_RUNNING --> STATE_INIT[0m
2022-07-25T05:25:36.058Z DEBUG modem << [00:00:00.441,253] [0m<dbg> ui_module: state_set: State transition STATE_INIT --> STATE_RUNNING[0m
2022-07-25T05:25:36.073Z DEBUG modem << [00:00:00.450,103] [0m<dbg> ui_module: sub_state_set: Sub state: SUB_STATE_ACTIVE[0m
2022-07-25T05:25:36.088Z DEBUG modem << [00:00:00.457,763] [0m<dbg> ui_module: sub_sub_state_set: Sub state: SUB_SUB_STATE_GNSS_INACTIVE[0m
2022-07-25T05:25:36.103Z DEBUG modem << [00:00:00.466,827] [0m<dbg> util_module: state_set: State: STATE_INIT[0m
2022-07-25T05:25:36.118Z DEBUG modem << [00:00:00.473,571] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:25:36.133Z DEBUG modem << [00:00:00.480,529] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:25:36.148Z DEBUG modem << [00:00:00.490,051] [0m<dbg> sensor_module: state_set: State: STATE_INIT[0m
2022-07-25T05:25:36.164Z DEBUG modem << [00:00:00.517,852] [0m<dbg> settings: settings_call_set_handler: set-value OK. key: bsec/state[0m
2022-07-25T05:25:36.179Z DEBUG modem << [00:00:00.527,404] [0m<dbg> data_module: config_print_all: Device mode: Active[0m
2022-07-25T05:25:36.194Z DEBUG modem << [00:00:00.534,820] [0m<dbg> data_module: config_print_all: Active wait timeout: 20[0m
2022-07-25T05:25:36.209Z DEBUG modem << [00:00:00.542,572] [0m<dbg> data_module: config_print_all: Movement resolution: 20[0m
2022-07-25T05:25:36.224Z DEBUG modem << [00:00:00.550,354] [0m<dbg> data_module: config_print_all: Movement timeout: 40[0m
2022-07-25T05:25:36.239Z DEBUG modem << [00:00:00.557,830] [0m<dbg> data_module: config_print_all: GPS timeout: 60[0m
2022-07-25T05:25:36.254Z DEBUG modem << [00:00:00.564,910] [0m<dbg> data_module: config_print_all: Accelerometer threshold: 10.00[0m
2022-07-25T05:25:36.269Z DEBUG modem << [00:00:00.573,303] [0m<dbg> data_module: config_print_all: Requesting of neighbor cell data is enabled[0m
2022-07-25T05:25:36.284Z DEBUG modem << [00:00:00.582,824] [0m<dbg> data_module: config_print_all: Requesting of GNSS data is enabled[0m
2022-07-25T05:25:36.299Z DEBUG modem << [00:00:00.591,583] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_CONFIG_INIT[0m
2022-07-25T05:25:36.314Z DEBUG modem << [00:00:00.599,792] [0m<dbg> ui_module: sub_state_set: Sub state: SUB_STATE_ACTIVE[0m
2022-07-25T05:25:36.329Z DEBUG modem << [00:00:00.607,635] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:25:36.343Z DEBUG modem << [00:00:00.614,593] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:25:36.358Z DEBUG modem << [00:00:00.624,053] [0m<dbg> main: active_mode_timers_start_all: Device mode: Active[0m
2022-07-25T05:25:36.373Z DEBUG modem << [00:00:00.631,896] [0m<dbg> main: active_mode_timers_start_all: Start data sample timer: 20 seconds interval[0m
2022-07-25T05:25:36.389Z DEBUG modem << [00:00:00.641,998] [0m<inf> app_event_manager: e:app_module_event APP_EVT_ACTIVITY_DETECTION_DISABLE[0m
2022-07-25T05:25:36.404Z DEBUG modem << [00:00:00.651,580] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:25:37.203Z DEBUG modem << [00:00:00.658,538] [0m<inf> bms_module: BMS Thread enqueue is_app_module_event() in Event handler[0m
2022-07-25T05:25:37.219Z DEBUG modem << [00:00:00.667,968] [0m<dbg> main: state_set: App State transition STATE_INIT --> STATE_RUNNING[0m
2022-07-25T05:25:37.235Z DEBUG modem << [00:00:00.676,727] [0m<dbg> main: sub_state_set: App Sub state: SUB_STATE_ACTIVE_MODE[0m
2022-07-25T05:25:37.250Z DEBUG modem << [00:00:00.684,844] [0m<dbg> cloud_module: state_set: Cloud State transition STATE_LTE_INIT --> STATE_LTE_DISCONNECTED[0m
2022-07-25T05:25:37.265Z DEBUG modem << [00:00:00.695,617] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:25:37.280Z DEBUG modem << [00:00:00.702,697] [0m<inf> bms_module: BMS Thread Enter in Init State[0m
2022-07-25T05:25:37.295Z DEBUG modem <<  UART1 binding Successful
2022-07-25T05:25:37.310Z DEBUG modem <<  UART1 Inittialization Successful
2022-07-25T05:25:37.325Z DEBUG modem << [00:00:00.714,996] [0m<inf> bms_module: State transition STATE_INIT --> BMS DETECTED[0m
2022-07-25T05:25:37.340Z DEBUG modem << [00:00:00.722,961] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:25:37.355Z DEBUG modem << [00:00:00.730,010] [0m<inf> bms_module: BMS Thread Enter in Detect_BMS State[0m
2022-07-25T05:25:37.370Z DEBUG modem << [00:00:00.737,274] [0m<inf> bms_module: State transition BMS DETECTED --> STATE_RUNNING[0m
2022-07-25T05:25:37.385Z DEBUG modem << [00:00:00.745,452] [0m<inf> bms_module: BMS Thread: BMS_FOUND[0m
2022-07-25T05:25:37.400Z DEBUG modem << [00:00:00.751,403] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:25:37.416Z DEBUG modem << [00:00:00.758,483] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:25:37.431Z DEBUG modem << [00:00:00.772,277] [0m<inf> azure_iot_hub_dps: Setting DPS registration ID: 352656101074246[0m
2022-07-25T05:25:37.446Z DEBUG modem << [00:00:00.786,407] [0m<dbg> settings: settings_call_set_handler: set-value OK. key: azure_iot_hub/hostname_len[0m
2022-07-25T05:25:37.461Z DEBUG modem << [00:00:00.802,062] [0m<dbg> settings: settings_call_set_handler: set-value OK. key: azure_iot_hub/hostname[0m
2022-07-25T05:25:37.475Z DEBUG modem << [00:00:00.822,113] [0m<inf> azure_fota: Current firmware version: 0.0.0-development[0m
2022-07-25T05:25:37.491Z DEBUG modem << [00:00:00.829,956] [0m<dbg> azure_iot_hub_integration: cloud_wrap_init: ********************************************[0m
2022-07-25T05:25:37.505Z DEBUG modem << [00:00:00.840,667] [0m<dbg> azure_iot_hub_integration: cloud_wrap_init:  The Asset Tracker v2 has started[0m
2022-07-25T05:25:37.521Z DEBUG modem << [00:00:00.850,463] [0m<dbg> azure_iot_hub_integration: cloud_wrap_init:  Version:      0.0.0-development[0m
2022-07-25T05:25:37.535Z DEBUG modem << [00:00:00.860,137] [0m<dbg> azure_iot_hub_integration: cloud_wrap_init:  Client ID:    352656101074246[0m
2022-07-25T05:25:37.550Z DEBUG modem << [00:00:00.869,659] [0m<dbg> azure_iot_hub_integration: cloud_wrap_init:  Cloud:        Azure IoT Hub[0m
2022-07-25T05:25:37.565Z DEBUG modem << [00:00:00.878,997] [0m<dbg> azure_iot_hub_integration: cloud_wrap_init:  DPS endpoint: global.azure-devices-provisioning.net[0m
2022-07-25T05:25:37.580Z DEBUG modem << [00:00:00.890,441] [0m<dbg> azure_iot_hub_integration: cloud_wrap_init:  ID scope:     0ne0055ED29[0m
2022-07-25T05:25:37.595Z DEBUG modem << [00:00:00.899,597] [0m<dbg> azure_iot_hub_integration: cloud_wrap_init: ********************************************[0m
2022-07-25T05:25:37.610Z DEBUG modem << [00:00:00.916,381] [0m<dbg> sensor_module: state_set: State transition STATE_INIT --> STATE_RUNNING[0m
2022-07-25T05:25:37.625Z DEBUG modem << [00:00:00.933,166] [0m<dbg> modem_module: configure_low_power: PSM requested[0m
2022-07-25T05:25:37.641Z DEBUG modem << [00:00:00.987,213] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_LTE_CONNECTING[0m
2022-07-25T05:25:37.656Z DEBUG modem << [00:00:00.995,941] [0m<dbg> ui_module: state_set: State transition STATE_RUNNING --> STATE_LTE_CONNECTING[0m
2022-07-25T05:25:37.670Z DEBUG modem << [00:00:01.006,195] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:25:37.686Z DEBUG modem << [00:00:01.012,634] [0m<dbg> modem_module: state_set: State transition STATE_DISCONNECTED --> STATE_CONNECTING[0m
2022-07-25T05:25:37.701Z DEBUG modem << %CESQ: 53,2,13,1
2022-07-25T05:25:37.738Z DEBUG modem << [00:00:01.732,269] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -87[0m
2022-07-25T05:25:37.753Z DEBUG modem << +CEREG: 2,"8003","076AB90F",7
2022-07-25T05:25:37.789Z DEBUG modem << [00:00:01.745,941] [0m<dbg> modem_module: lte_evt_handler: LTE cell changed: Cell ID: 124434703, Tracking area: 32771[0m
2022-07-25T05:25:37.804Z DEBUG modem << [00:00:01.756,866] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_LTE_DISCONNECTED[0m
2022-07-25T05:25:37.819Z DEBUG modem << [00:00:01.766,296] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_LTE_CELL_UPDATE[0m
2022-07-25T05:25:37.834Z DEBUG modem << +CSCON: 1
2022-07-25T05:25:37.849Z DEBUG modem << [00:00:01.921,478] [0m<dbg> modem_module: lte_evt_handler: RRC mode: Connected[0m
2022-07-25T05:25:37.865Z DEBUG modem << %CESQ: 56,2,20,2
2022-07-25T05:25:37.900Z DEBUG modem << [00:00:01.930,633] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -84[0m
2022-07-25T05:25:38.700Z DEBUG modem << %CESQ: 56,2,15,2
2022-07-25T05:25:38.737Z DEBUG modem << [00:00:03.137,237] [0m<dbg> modem_module: modem_rsrp_handler: Incoming RSRP status message, RSRP value is -84[0m
2022-07-25T05:25:38.752Z DEBUG modem << %MDMEV: SEARCH STATUS 2
2022-07-25T05:25:38.767Z DEBUG modem << [00:00:03.422,119] [0m<dbg> modem_module: lte_evt_handler: Modem domain event, type: Search done[0m
2022-07-25T05:25:38.782Z DEBUG modem << +CEREG: 5,"8003","076AB90F",7,,,"00001010","11000001"
2022-07-25T05:25:38.818Z DEBUG modem << [00:00:03.436,309] [0m<dbg> modem_module: lte_evt_handler: Network registration status: Connected - roaming[0m
2022-07-25T05:25:38.833Z DEBUG modem << [00:00:03.447,021] [0m<dbg> modem_module: lte_evt_handler: PSM parameter update: TAU: 1152000, Active time: 20[0m
2022-07-25T05:25:38.848Z DEBUG modem << %XTIME: "8A","2270525052738A","00"
2022-07-25T05:25:38.862Z DEBUG modem << [00:00:03.460,388] [0m<dbg> date_time: date_time_core_current_check: Date time never set[0m
2022-07-25T05:25:38.878Z DEBUG modem << [00:00:03.468,658] [0m<dbg> date_time: date_time_at_xtime_handler: Time obtained from cellular network (XTIME notification)[0m
2022-07-25T05:25:38.893Z DEBUG modem << [00:00:03.479,949] [0m<dbg> date_time: date_time_core_schedule_update: New periodic date time update in: 14400 seconds[0m
2022-07-25T05:25:38.908Z DEBUG modem << [00:00:03.490,875] [0m<dbg> date_time: date_time_core_store: System time updated: 2022-07-25 05:25:37[0m
2022-07-25T05:25:38.922Z DEBUG modem << [00:00:03.500,274] [0m<dbg> date_time: date_time_core_register_handler: Previously registered handler (nil) de-registered[0m
2022-07-25T05:25:38.937Z DEBUG modem << [00:00:03.511,474] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_LTE_CONNECTED[0m
2022-07-25T05:25:38.952Z DEBUG modem << [00:00:03.520,141] [0m<dbg> ui_module: state_set: State transition STATE_LTE_CONNECTING --> STATE_RUNNING[0m
2022-07-25T05:25:38.967Z DEBUG modem << [00:00:03.530,334] [0m<inf> app_event_manager: e:modem_module_event MODEM_EVT_LTE_PSM_UPDATE[0m
2022-07-25T05:25:38.981Z DEBUG modem << [00:00:03.539,581] [0m<inf> app_event_manager: e:data_module_event DATA_EVT_DATE_TIME_OBTAINED[0m
2022-07-25T05:25:38.996Z DEBUG modem << [00:00:03.548,553] [0m<inf> bms_module: BMS Thread Enter in event_handler[0m
2022-07-25T05:25:39.011Z DEBUG modem << [00:00:03.555,480] [0m<inf> bms_module: BMS Thread enqueue is_data_module_event() in Event handler[0m
2022-07-25T05:25:39.026Z DEBUG modem << [00:00:03.565,093] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:25:39.041Z DEBUG modem << [00:00:03.571,655] [0m<dbg> modem_module: state_set: State transition STATE_CONNECTING --> STATE_CONNECTED[0m
2022-07-25T05:25:39.055Z DEBUG modem << [00:00:03.581,604] [0m<dbg> cloud_module: state_set: Cloud State transition STATE_LTE_DISCONNECTED --> STATE_LTE_CONNECTED[0m
2022-07-25T05:25:39.070Z DEBUG modem << [00:00:03.592,803] [0m<dbg> cloud_module: connect_cloud: Connecting to cloud[0m
2022-07-25T05:25:39.085Z DEBUG modem << [00:00:03.600,189] [0m<inf> bms_module: New Message Received in BMS Thread[0m
2022-07-25T05:25:39.101Z DEBUG modem << [00:00:03.607,238] [0m<inf> bms_module: BMS Thread Enter in Running State[0m
2022-07-25T05:25:39.115Z DEBUG modem << [00:00:04.062,072] [0m<dbg> azure_iot_hub_integration: azure_iot_hub_event_handler: AZURE_IOT_HUB_EVT_CONNECTING[0m
2022-07-25T05:25:39.130Z DEBUG modem << [00:00:04.072,418] [0m<dbg> cloud_module: cloud_wrap_event_handler: CLOUD_WRAP_EVT_CONNECTING[0m
2022-07-25T05:25:39.145Z DEBUG modem << [00:00:04.081,176] [0m<inf> app_event_manager: e:cloud_module_event CLOUD_EVT_CONNECTING[0m
2022-07-25T05:25:39.160Z DEBUG modem << [00:00:04.089,599] [0m<dbg> ui_module: state_set: State transition STATE_RUNNING --> STATE_CLOUD_CONNECTING[0m
2022-07-25T05:25:39.175Z DEBUG modem << [00:00:04.099,914] [0m<inf> app_event_manager: e: led_state_event[0m
2022-07-25T05:25:48.634Z INFO Modem port is closed
I have attached the log file.
Have a look and observe that error is on line 13413.
The Modules stop sending data after 4348 till the error line and then after the error, it rebooted again
# Asset Tracker v2
CONFIG_ASSET_TRACKER_V2_APP_VERSION="0.0.0-development"
CONFIG_ASSET_TRACKER_V2_APP_VERSION_MAX_LEN=150
# CONFIG_MODULES_COMMON_LOG_LEVEL_OFF is not set
# CONFIG_MODULES_COMMON_LOG_LEVEL_ERR is not set
# CONFIG_MODULES_COMMON_LOG_LEVEL_WRN is not set
CONFIG_MODULES_COMMON_LOG_LEVEL_INF=y
# CONFIG_MODULES_COMMON_LOG_LEVEL_DBG is not set
CONFIG_MODULES_COMMON_LOG_LEVEL=3
# Application control module
CONFIG_APP_REQUEST_GNSS_ON_INITIAL_SAMPLING=y
CONFIG_APP_REQUEST_GNSS_WAIT_FOR_AGPS=y
CONFIG_APP_REQUEST_GNSS_WAIT_FOR_AGPS_THRESHOLD_SEC=300
CONFIG_APP_REQUEST_NEIGHBOR_CELLS_DATA=y
# end of Application control module
CONFIG_CLOUD_MODULE=y
CONFIG_NRF_CLOUD_AGPS=y
CONFIG_MQTT_CLEAN_SESSION=y
CONFIG_CLOUD_THREAD_STACK_SIZE=2688
# CONFIG_CLOUD_CLIENT_ID_USE_CUSTOM is not set
CONFIG_CLOUD_CONNECT_RETRIES=10
CONFIG_AZURE_FOTA_APP_VERSION="0.0.0-development"
CONFIG_AZURE_FOTA_VERSION_MAX_LEN=150
CONFIG_AZURE_FOTA_SEC_TAG= 42
# CONFIG_CLOUD_INTEGRATION_LOG_LEVEL_OFF is not set
# CONFIG_CLOUD_INTEGRATION_LOG_LEVEL_ERR is not set
# CONFIG_CLOUD_INTEGRATION_LOG_LEVEL_WRN is not set
# CONFIG_CLOUD_INTEGRATION_LOG_LEVEL_INF is not set
CONFIG_CLOUD_INTEGRATION_LOG_LEVEL_DBG=y
CONFIG_CLOUD_INTEGRATION_LOG_LEVEL=4
# CONFIG_CLOUD_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_CLOUD_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_CLOUD_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_CLOUD_MODULE_LOG_LEVEL_INF is not set
CONFIG_CLOUD_MODULE_LOG_LEVEL_DBG=y
CONFIG_CLOUD_MODULE_LOG_LEVEL=4
CONFIG_DATA_MODULE=y
CONFIG_DATA_AGPS_REQUEST_ALL_UPON_CONNECTION=y
CONFIG_PENDING_DATA_COUNT=10
CONFIG_FAILED_DATA_COUNT=10
# CONFIG_DATA_SEND_ALL_DEVICE_CONFIGURATIONS is not set
CONFIG_DATA_THREAD_STACK_SIZE=5120
CONFIG_DATA_GNSS_BUFFER_COUNT=10
CONFIG_DATA_BMS_BUFFER_COUNT=3
CONFIG_DATA_SENSOR_BUFFER_COUNT=10
CONFIG_DATA_MODEM_DYNAMIC_BUFFER_COUNT=3
CONFIG_DATA_UI_BUFFER_COUNT=3
CONFIG_DATA_ACCELEROMETER_BUFFER_COUNT=3
CONFIG_DATA_BATTERY_BUFFER_COUNT=3
CONFIG_DATA_GNSS_BUFFER_STORE=y
CONFIG_DATA_BMS_BUFFER_STORE=y
CONFIG_DATA_SENSOR_BUFFER_STORE=y
CONFIG_DATA_ACCELEROMETER_BUFFER_STORE=y
CONFIG_DATA_DYNAMIC_MODEM_BUFFER_STORE=y
CONFIG_DATA_BATTERY_BUFFER_STORE=y
CONFIG_DATA_UI_BUFFER_STORE=y
CONFIG_DATA_DEVICE_MODE=y
CONFIG_DATA_ACTIVE_TIMEOUT_SECONDS=20
CONFIG_DATA_MOVEMENT_RESOLUTION_SECONDS=20
CONFIG_DATA_MOVEMENT_TIMEOUT_SECONDS=40
CONFIG_DATA_ACCELEROMETER_THRESHOLD=10
CONFIG_DATA_GNSS_TIMEOUT_SECONDS=60
CONFIG_DATA_SAMPLE_GNSS_DEFAULT=y
CONFIG_DATA_SAMPLE_NEIGHBOR_CELLS_DEFAULT=y
# CONFIG_DATA_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_DATA_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_DATA_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_DATA_MODULE_LOG_LEVEL_INF is not set
CONFIG_DATA_MODULE_LOG_LEVEL_DBG=y
CONFIG_DATA_MODULE_LOG_LEVEL=4
CONFIG_GNSS_MODULE=y
CONFIG_GNSS_MODULE_PVT=y
# CONFIG_GNSS_MODULE_NMEA is not set
# CONFIG_GNSS_MODULE_PGPS_STORE_LOCATION is not set
CONFIG_GNSS_MODULE_ANTENNA_ONBOARD=y
# CONFIG_GNSS_MODULE_ANTENNA_EXTERNAL is not set
CONFIG_GNSS_MODULE_AT_MAGPIO="AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586"
CONFIG_GNSS_MODULE_AT_COEX0="AT%XCOEX0=1,1,1565,1586"
# CONFIG_GNSS_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_GNSS_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_GNSS_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_GNSS_MODULE_LOG_LEVEL_INF is not set
CONFIG_GNSS_MODULE_LOG_LEVEL_DBG=y
CONFIG_GNSS_MODULE_LOG_LEVEL=4
CONFIG_MODEM_MODULE=y
# CONFIG_MODEM_SEND_ALL_SAMPLED_DATA is not set
CONFIG_MODEM_THREAD_STACK_SIZE=8192
CONFIG_MODEM_AUTO_REQUEST_POWER_SAVING_FEATURES=y
# CONFIG_MODEM_CONVERT_RSRP_AND_RSPQ_TO_DB is not set
CONFIG_MODEM_DYNAMIC_DATA_CONVERT_RSRP_TO_DBM=y
CONFIG_MODEM_NEIGHBOR_CELLS_DATA_CONVERT_RSRP_TO_DBM=y
CONFIG_MODEM_NEIGHBOR_CELLS_DATA_CONVERT_RSRQ_TO_DB=y
# CONFIG_MODEM_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_MODEM_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_MODEM_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_MODEM_MODULE_LOG_LEVEL_INF is not set
CONFIG_MODEM_MODULE_LOG_LEVEL_DBG=y
CONFIG_MODEM_MODULE_LOG_LEVEL=4
CONFIG_SENSOR_MODULE=y
CONFIG_SENSOR_THREAD_STACK_SIZE=4096
CONFIG_EXTERNAL_SENSORS=y
# CONFIG_EXTERNAL_SENSORS_ACTIVITY_DETECTION_AUTO is not set
CONFIG_EXTERNAL_SENSORS_BME680_BSEC=y
CONFIG_EXTERNAL_SENSORS_BSEC_THREAD_STACK_SIZE=4096
# CONFIG_EXTERNAL_SENSORS_BSEC_SAMPLE_MODE_ULTRA_LOW_POWER is not set
CONFIG_EXTERNAL_SENSORS_BSEC_SAMPLE_MODE_LOW_POWER=y
# CONFIG_EXTERNAL_SENSORS_BSEC_SAMPLE_MODE_CONTINUOUS is not set
CONFIG_EXTERNAL_SENSORS_BSEC_TEMPERATURE_OFFSET=120
CONFIG_EXTERNAL_SENSORS_BME680_BSEC_PATH="D:/firmware/nrf/ext/BSEC_1.4.8.0_Generic_Release_updated_v3"
# CONFIG_EXTERNAL_SENSORS_LOG_LEVEL_OFF is not set
# CONFIG_EXTERNAL_SENSORS_LOG_LEVEL_ERR is not set
# CONFIG_EXTERNAL_SENSORS_LOG_LEVEL_WRN is not set
CONFIG_EXTERNAL_SENSORS_LOG_LEVEL_INF=y
# CONFIG_EXTERNAL_SENSORS_LOG_LEVEL_DBG is not set
CONFIG_EXTERNAL_SENSORS_LOG_LEVEL=3
# CONFIG_SENSOR_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_SENSOR_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_SENSOR_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_SENSOR_MODULE_LOG_LEVEL_INF is not set
CONFIG_SENSOR_MODULE_LOG_LEVEL_DBG=y
CONFIG_SENSOR_MODULE_LOG_LEVEL=4
CONFIG_UI_MODULE=y
CONFIG_UI_THREAD_STACK_SIZE=512
# CONFIG_UI_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_UI_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_UI_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_UI_MODULE_LOG_LEVEL_INF is not set
CONFIG_UI_MODULE_LOG_LEVEL_DBG=y
CONFIG_UI_MODULE_LOG_LEVEL=4
CONFIG_UTIL_MODULE=y
CONFIG_REBOOT_TIMEOUT=30
# CONFIG_UTIL_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_UTIL_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_UTIL_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_UTIL_MODULE_LOG_LEVEL_INF is not set
CONFIG_UTIL_MODULE_LOG_LEVEL_DBG=y
CONFIG_UTIL_MODULE_LOG_LEVEL=4
CONFIG_LED_CONTROL=y
CONFIG_LED_STATE_DEF_PATH="led_state_def.h"
# CONFIG_LED_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_LED_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_LED_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_LED_CONTROL_LOG_LEVEL_INF=y
# CONFIG_LED_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_LED_CONTROL_LOG_LEVEL=3
CONFIG_DEBUG_MODULE=y
# CONFIG_DEBUG_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_DEBUG_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_DEBUG_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_DEBUG_MODULE_LOG_LEVEL_INF is not set
CONFIG_DEBUG_MODULE_LOG_LEVEL_DBG=y
CONFIG_DEBUG_MODULE_LOG_LEVEL=4
CONFIG_BMS_MODULE=y
CONFIG_BMS_THREAD_STACK_SIZE=4096
CONFIG_DECODE_BMS_DATA=y
CONFIG_DALY_TX_LENGTH=13
CONFIG_BMS_UART_TX_BUF_SIZE=13
CONFIG_BMS_UART_RX_MSG_QUEUE_SIZE=16
CONFIG_BMS_UART_BUF_SIZE=13
CONFIG_BMS_DATA_SIZE=39
# CONFIG_BMS_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_BMS_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_BMS_MODULE_LOG_LEVEL_WRN is not set
CONFIG_BMS_MODULE_LOG_LEVEL_INF=y
# CONFIG_BMS_MODULE_LOG_LEVEL_DBG is not set
CONFIG_BMS_MODULE_LOG_LEVEL=3
CONFIG_CLOUD_CODEC=y
# CONFIG_CLOUD_CODEC_NRF_CLOUD is not set
# CONFIG_CLOUD_CODEC_AWS_IOT is not set
CONFIG_CLOUD_CODEC_AZURE_IOT_HUB=y
# CONFIG_CLOUD_CODEC_LOG_LEVEL_OFF is not set
# CONFIG_CLOUD_CODEC_LOG_LEVEL_ERR is not set
# CONFIG_CLOUD_CODEC_LOG_LEVEL_WRN is not set
# CONFIG_CLOUD_CODEC_LOG_LEVEL_INF is not set
CONFIG_CLOUD_CODEC_LOG_LEVEL_DBG=y
CONFIG_CLOUD_CODEC_LOG_LEVEL=4
CONFIG_WATCHDOG_APPLICATION=y
CONFIG_WATCHDOG_APPLICATION_TIMEOUT_SEC=60
# CONFIG_WATCHDOG_LOG_LEVEL_OFF is not set
# CONFIG_WATCHDOG_LOG_LEVEL_ERR is not set
# CONFIG_WATCHDOG_LOG_LEVEL_WRN is not set
# CONFIG_WATCHDOG_LOG_LEVEL_INF is not set
CONFIG_WATCHDOG_LOG_LEVEL_DBG=y
CONFIG_WATCHDOG_LOG_LEVEL=4
CONFIG_EVENTS=y
CONFIG_BMS_EVENTS_LOG=y
CONFIG_APP_EVENTS_LOG=y
CONFIG_MODEM_EVENTS_LOG=y
CONFIG_CLOUD_EVENTS_LOG=y
CONFIG_SENSOR_EVENTS_LOG=y
CONFIG_UI_EVENTS_LOG=y
CONFIG_UTIL_EVENTS_LOG=y
CONFIG_GNSS_EVENTS_LOG=y
CONFIG_DATA_EVENTS_LOG=y
CONFIG_DEBUG_EVENTS_LOG=y
# end of Asset Tracker v2
# Zephyr Kernel
CONFIG_GPIO=y
CONFIG_SPI=y
CONFIG_I2C=y
# CONFIG_KSCAN is not set
CONFIG_LV_Z_POINTER_KSCAN_DEV_NAME="KSCAN"
# CONFIG_WIFI is not set
# CONFIG_NET_L2_ETHERNET is not set
# CONFIG_FT800 is not set
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_MODEM is not set
CONFIG_NET_IPV6=y
# CONFIG_NET_CONFIG_NEED_IPV6 is not set
CONFIG_BOARD="thingy91_nrf9160"
CONFIG_FLASH_LOAD_SIZE=0x0
CONFIG_FLASH_LOAD_OFFSET=0x0
CONFIG_HW_STACK_PROTECTION=y
CONFIG_SOC="nRF9160_SICA"
CONFIG_SOC_SERIES="nrf91"
CONFIG_NUM_IRQS=65
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_HEAP_MEM_POOL_SIZE=32384
CONFIG_ROM_START_OFFSET=0
CONFIG_WATCHDOG=y
# CONFIG_PINCTRL is not set
# CONFIG_UART_NS16550 is not set
CONFIG_PM=y
# CONFIG_PM_DEVICE is not set
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
# CONFIG_CORTEX_M_SYSTICK is not set
CONFIG_CLOCK_CONTROL=y
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_SERIAL_INIT_PRIORITY=55
CONFIG_FPU=y
# CONFIG_PWM_IMX is not set
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
# CONFIG_MBEDTLS is not set
CONFIG_TEST_EXTRA_STACK_SIZE=0
# CONFIG_GPIO_MCUX is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_NET_L2_IEEE802154 is not set
CONFIG_SERIAL=y
# CONFIG_UART_PL011 is not set
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_MP_NUM_CPUS=1
# Modules
# Available modules.
# nrf (D:/firmware/nrf)
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
CONFIG_MAIN_STACK_SIZE=8192
# CONFIG_INIT_STACKS is not set
CONFIG_NET_IPV6_NBR_CACHE=y
CONFIG_NET_IPV6_MLD=y
CONFIG_NET_PKT_RX_COUNT=4
CONFIG_NET_PKT_TX_COUNT=4
# CONFIG_NET_PKT_TXTIME is not set
# CONFIG_NET_PKT_TIMESTAMP is not set
# Nordic nRF Connect
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_BOARD_THINGY91_NRF9160_NS=y
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_ENTROPY_GENERATOR=y
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
CONFIG_LOG_DEFAULT_LEVEL=3
# CONFIG_NCS_IS_VARIANT_IMAGE is not set
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_SECURE_BOOT_CRYPTO is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# end of Bootloader
# Bluetooth Low Energy
# BLE over nRF RPC
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_MCUBOOT=y
CONFIG_DFU_TARGET_STREAM=y
# CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set
# CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS is not set
CONFIG_DFU_TARGET_MODEM_DELTA=y
CONFIG_DFU_TARGET_MODEM_TIMEOUT=60
# CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set
CONFIG_DFU_TARGET_LOG_LEVEL_INF=y
# CONFIG_DFU_TARGET_LOG_LEVEL_DBG is not set
CONFIG_DFU_TARGET_LOG_LEVEL=3
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
CONFIG_CLOUD_SERVICE_MUTUAL_EXCLUSIVE=y
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI=y
# CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME is not set
CONFIG_NRF_CLOUD_CLIENT_ID_PREFIX="nrf-"
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
# CONFIG_NRF_CLOUD_AGPS_FILTERED is not set
# CONFIG_NRF_CLOUD_PGPS is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_GATEWAY is not set
# CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_INF is not set
CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_DBG=y
CONFIG_NRF_CLOUD_GPS_LOG_LEVEL=4
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL=3
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=4096
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE=1024
# CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_2048 is not set
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
# CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_512 is not set
# CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_256 is not set
# Thread and stack buffers
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
CONFIG_DOWNLOAD_CLIENT_MAX_HOSTNAME_SIZE=255
CONFIG_DOWNLOAD_CLIENT_MAX_FILENAME_SIZE=255
CONFIG_DOWNLOAD_CLIENT_TCP_SOCK_TIMEO_MS=30000
CONFIG_DOWNLOAD_CLIENT_COAP_MAX_RETRANSMIT_REQUEST_COUNT=4
CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS=y
# CONFIG_DOWNLOAD_CLIENT_IPV6 is not set
# CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_OFF is not set
# CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_ERR is not set
# CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_WRN is not set
CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_INF=y
# CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DBG is not set
CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL=3
CONFIG_FOTA_DOWNLOAD=y
CONFIG_FOTA_SOCKET_RETRIES=2
# CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT is not set
CONFIG_FOTA_DOWNLOAD_MCUBOOT_FLASH_BUF_SZ=512
# CONFIG_FOTA_DOWNLOAD_NATIVE_TLS is not set
# CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_OFF is not set
# CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_ERR is not set
# CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_WRN is not set
CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_INF=y
# CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DBG is not set
CONFIG_FOTA_DOWNLOAD_LOG_LEVEL=3
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AWS_FOTA is not set
CONFIG_AZURE_FOTA=y
CONFIG_AZURE_FOTA_HOSTNAME_MAX_LEN=64
CONFIG_AZURE_FOTA_FILE_PATH_MAX_LEN=64
CONFIG_AZURE_FOTA_JOB_ID_MAX_LEN=40
# CONFIG_AZURE_FOTA_APP_VERSION_AUTO is not set
CONFIG_AZURE_FOTA_TLS=y
CONFIG_AZURE_FOTA_DOWNLOAD_PORT=443
# CONFIG_AZURE_FOTA_LOG_LEVEL_OFF is not set
# CONFIG_AZURE_FOTA_LOG_LEVEL_ERR is not set
# CONFIG_AZURE_FOTA_LOG_LEVEL_WRN is not set
CONFIG_AZURE_FOTA_LOG_LEVEL_INF=y
# CONFIG_AZURE_FOTA_LOG_LEVEL_DBG is not set
CONFIG_AZURE_FOTA_LOG_LEVEL=3
CONFIG_AZURE_IOT_HUB=y
CONFIG_AZURE_IOT_HUB_CHOICE=y
CONFIG_AZURE_IOT_HUB_SEND_TIMEOUT=y
CONFIG_AZURE_IOT_HUB_SEND_TIMEOUT_SEC=60
# CONFIG_AZURE_IOT_HUB_PROVISION_CERTIFICATES is not set
CONFIG_AZURE_IOT_HUB_HOSTNAME=""
CONFIG_AZURE_IOT_HUB_HOSTNAME_MAX_LEN=48
# CONFIG_AZURE_IOT_HUB_STATIC_IPV4 is not set
CONFIG_AZURE_IOT_HUB_SEC_TAG= 42
CONFIG_AZURE_IOT_HUB_PORT=8883
CONFIG_AZURE_IOT_HUB_MQTT_RX_TX_BUFFER_LEN=2048
CONFIG_AZURE_IOT_HUB_MQTT_PAYLOAD_BUFFER_LEN=2304
CONFIG_AZURE_IOT_HUB_DEVICE_ID_MAX_LEN=37
CONFIG_AZURE_IOT_HUB_DEVICE_ID="352656101074246"
CONFIG_AZURE_IOT_HUB_DEVICE_ID_APP=y
CONFIG_AZURE_IOT_HUB_STACK_SIZE=4096
CONFIG_AZURE_IOT_HUB_AUTO_DEVICE_TWIN_REQUEST=y
CONFIG_AZURE_IOT_HUB_TOPIC_MAX_LEN=100
CONFIG_AZURE_IOT_HUB_TOPIC_ELEMENT_MAX_LEN=256
CONFIG_AZURE_IOT_HUB_PROPERTY_BAG_MAX_COUNT=2
CONFIG_AZURE_IOT_HUB_TOPIC_PROPERTY_BAG_PREFIX=y
CONFIG_AZURE_IOT_HUB_DPS=y
# CONFIG_AZURE_IOT_HUB_NATIVE_TLS is not set
CONFIG_AZURE_IOT_HUB_DPS_ID_SCOPE="0ne0055ED29"
CONFIG_AZURE_IOT_HUB_DPS_HOSTNAME="global.azure-devices-provisioning.net"
# CONFIG_AZURE_IOT_HUB_LOG_LEVEL_OFF is not set
# CONFIG_AZURE_IOT_HUB_LOG_LEVEL_ERR is not set
# CONFIG_AZURE_IOT_HUB_LOG_LEVEL_WRN is not set
CONFIG_AZURE_IOT_HUB_LOG_LEVEL_INF=y
# CONFIG_AZURE_IOT_HUB_LOG_LEVEL_DBG is not set
CONFIG_AZURE_IOT_HUB_LOG_LEVEL=3
# CONFIG_CLOUD_API is not set
# Self-Registration (Zi ZHu Ce)
# CONFIG_ZZHC is not set
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_COAP_UTILS is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# end of Application protocols
# CONFIG_BUILD_WITH_TFM is not set
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
CONFIG_APP_EVENT_MANAGER=y
CONFIG_APP_EVENT_MANAGER_SHOW_EVENTS=y
# CONFIG_APP_EVENT_MANAGER_SHOW_EVENT_HANDLERS is not set
# CONFIG_APP_EVENT_MANAGER_TRACE_EVENT_DATA is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_OFF is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_ERR is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_WRN is not set
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_INF=y
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DBG is not set
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL=3
# CONFIG_APP_EVENT_MANAGER_USE_DEPRECATED_LOG_FUN is not set
CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=y
CONFIG_APP_EVENT_MANAGER_MAX_EVENT_CNT=32
# CONFIG_APP_EVENT_MANAGER_PROVIDE_EVENT_SIZE is not set
# CONFIG_APP_EVENT_MANAGER_POSTINIT_HOOK is not set
# CONFIG_APP_EVENT_MANAGER_SUBMIT_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_PREPROCESS_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_POSTPROCESS_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_PROFILER_TRACER is not set
# CONFIG_PROFILER is not set
# SPM
CONFIG_SPM=y
# CONFIG_SPM_BUILD_STRATEGY_USE_HEX_FILE is not set
# CONFIG_SPM_BUILD_STRATEGY_SKIP_BUILD is not set
CONFIG_SPM_BUILD_STRATEGY_FROM_SOURCE=y
# CONFIG_IS_SPM is not set
CONFIG_SPM_SECURE_SERVICES=y
CONFIG_SPM_SERVICE_RNG=y
CONFIG_SPM_SERVICE_READ=y
# CONFIG_SPM_SERVICE_REBOOT is not set
CONFIG_SPM_SERVICE_FIND_FIRMWARE_INFO=y
CONFIG_SPM_SERVICE_S0_ACTIVE=y
# CONFIG_SPM_SERVICE_PREVALIDATE is not set
# CONFIG_SPM_SERVICE_BUSY_WAIT is not set
# CONFIG_SPM_SERVICE_NS_HANDLER_FROM_SPM_FAULT is not set
CONFIG_ARM_ENTRY_VENEERS_LIB_NAME="spm/libspmsecureentries.a"
# end of SPM
CONFIG_FW_INFO=y
CONFIG_FW_INFO_OFFSET=0x200
CONFIG_FW_INFO_FIRMWARE_VERSION=1
CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de
CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c
CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea
CONFIG_FW_INFO_HARDWARE_ID=91
CONFIG_FW_INFO_VERSION=2
CONFIG_FW_INFO_CRYPTO_ID=0
CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0
CONFIG_FW_INFO_MAGIC_LEN=12
CONFIG_FW_INFO_VALID_VAL=0x9102FFFF
CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y
# CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set
# CONFIG_PPI_TRACE is not set
# CONFIG_CPU_LOAD is not set
# Nordic MPSL
# CONFIG_MPSL_CX is not set
# CONFIG_MPSL_CX_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_CX_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_CX_LOG_LEVEL_WRN is not set
CONFIG_MPSL_CX_LOG_LEVEL_INF=y
# CONFIG_MPSL_CX_LOG_LEVEL_DBG is not set
CONFIG_MPSL_CX_LOG_LEVEL=3
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
CONFIG_MPSL_FEM_LOG_LEVEL_INF=y
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_WORK_STACK_SIZE=1024
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
CONFIG_MPSL_LOG_LEVEL_INF=y
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL=3
# end of Nordic MPSL
# CONFIG_CHIP is not set
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_SIZE=128
CONFIG_SRAM_BASE_ADDRESS=0x20020000
# Zephyr subsystem configurations
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# Full Modem Firmware Update Management(FMFU)
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL=3
# end of Full Modem Firmware Update Management(FMFU)
CONFIG_CAF=y
# Event options
# CONFIG_CAF_PM_EVENTS is not set
# CONFIG_CAF_BLE_COMMON_EVENTS is not set
# CONFIG_CAF_BLE_SMP_TRANSFER_EVENTS is not set
# CONFIG_CAF_BUTTON_EVENTS is not set
# CONFIG_CAF_CLICK_EVENTS is not set
CONFIG_CAF_LED_EVENTS=y
# CONFIG_CAF_INIT_LOG_LED_EVENTS is not set
# CONFIG_CAF_INIT_LOG_LED_READY_EVENTS is not set
# CONFIG_CAF_SENSOR_EVENTS is not set
# CONFIG_CAF_NET_STATE_EVENTS is not set
# CONFIG_CAF_FACTORY_RESET_EVENTS is not set
# CONFIG_CAF_FORCE_POWER_DOWN_EVENTS is not set
# CONFIG_CAF_KEEP_ALIVE_EVENTS is not set
CONFIG_CAF_MODULE_STATE_EVENTS=y
# CONFIG_CAF_INIT_LOG_MODULE_STATE_EVENTS is not set
CONFIG_CAF_MODULES_FLAGS_COUNT=32
# CONFIG_CAF_POWER_MANAGER_EVENTS is not set
# end of Event options
# CONFIG_CAF_BUTTONS is not set
# Factory reset request
# CONFIG_CAF_FACTORY_RESET_REQUEST is not set
# end of Factory reset request
CONFIG_CAF_LEDS=y
CONFIG_CAF_LEDS_PWM=y
# CONFIG_CAF_LEDS_LOG_LEVEL_OFF is not set
# CONFIG_CAF_LEDS_LOG_LEVEL_ERR is not set
# CONFIG_CAF_LEDS_LOG_LEVEL_WRN is not set
CONFIG_CAF_LEDS_LOG_LEVEL_INF=y
# CONFIG_CAF_LEDS_LOG_LEVEL_DBG is not set
CONFIG_CAF_LEDS_LOG_LEVEL=3
# CONFIG_CAF_NET_STATE is not set
# Power manager
# end of Power manager
# CONFIG_CAF_SENSOR_DATA_AGGREGATOR_EVENTS is not set
# CONFIG_CAF_SENSOR_MANAGER is not set
# CONFIG_CAF_SETTINGS_LOADER is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_ZCBOR is not set
CONFIG_TFM_BOARD="D:/firmware/nrf/modules/tfm/tfm/boards/nrf9160"
# Libraries
# Binary libraries
# end of Binary libraries
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_SYS_INIT=y
# CONFIG_NRF_MODEM_LIB_TRACE_ENABLED is not set
CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE=128
# Heap and buffers
CONFIG_NRF_MODEM_LIB_HEAP_SIZE=1024
CONFIG_NRF_MODEM_LIB_SHMEM_CTRL_SIZE=0x4e8
CONFIG_NRF_MODEM_LIB_SHMEM_TX_SIZE=8192
CONFIG_NRF_MODEM_LIB_SHMEM_RX_SIZE=8192
CONFIG_NRF_MODEM_LIB_SHMEM_TRACE_SIZE=0
CONFIG_NRF_MODEM_LIB_TRACE_HEAP_SIZE=0
# Diagnostics
# CONFIG_NRF_MODEM_LIB_DEBUG_ALLOC is not set
# CONFIG_NRF_MODEM_LIB_DEBUG_SHM_TX_ALLOC is not set
# CONFIG_NRF_MODEM_LIB_HEAP_DUMP_PERIODIC is not set
# CONFIG_NRF_MODEM_LIB_SHM_TX_DUMP_PERIODIC is not set
# end of Diagnostics
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_OFF is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_ERR is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_WRN is not set
CONFIG_NRF_MODEM_LIB_LOG_LEVEL_INF=y
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DBG is not set
CONFIG_NRF_MODEM_LIB_LOG_LEVEL=3
# CONFIG_NRF_MODEM_LIB_LOG_FW_VERSION_UUID is not set
CONFIG_ADP536X=y
CONFIG_ADP536X_BUS_NAME="I2C_2"
CONFIG_AT_MONITOR=y
CONFIG_AT_MONITOR_HEAP_SIZE=2048
# CONFIG_AT_MONITOR_LOG_LEVEL_OFF is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_ERR is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_WRN is not set
CONFIG_AT_MONITOR_LOG_LEVEL_INF=y
# CONFIG_AT_MONITOR_LOG_LEVEL_DBG is not set
CONFIG_AT_MONITOR_LOG_LEVEL=3
CONFIG_LTE_LINK_CONTROL=y
# CONFIG_LTE_AUTO_INIT_AND_CONNECT is not set
# CONFIG_LTE_LOCK_BANDS is not set
# CONFIG_LTE_LOCK_PLMN is not set
# CONFIG_LTE_UNLOCK_PLMN is not set
CONFIG_LTE_PSM_REQ_RPTAU="11000001"
CONFIG_LTE_PSM_REQ_RAT="00001010"
# CONFIG_LTE_EDRX_REQ is not set
CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="1001"
CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="1001"
CONFIG_LTE_PTW_VALUE_LTE_M=""
CONFIG_LTE_PTW_VALUE_NBIOT=""
# CONFIG_LTE_NETWORK_DEFAULT is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M_GPS is not set
# CONFIG_LTE_NETWORK_MODE_NBIOT is not set
# CONFIG_LTE_NETWORK_MODE_NBIOT_GPS is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT is not set
CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS=y
CONFIG_LTE_MODE_PREFERENCE_AUTO=y
# CONFIG_LTE_MODE_PREFERENCE_LTE_M is not set
# CONFIG_LTE_MODE_PREFERENCE_NBIOT is not set
# CONFIG_LTE_MODE_PREFERENCE_LTE_M_PLMN_PRIO is not set
# CONFIG_LTE_MODE_PREFERENCE_NBIOT_PLMN_PRIO is not set
CONFIG_LTE_MODE_PREFERENCE=0
CONFIG_LTE_RAI_REQ_VALUE="0"
# CONFIG_LTE_NETWORK_USE_FALLBACK is not set
CONFIG_LTE_NETWORK_TIMEOUT=600
# CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS is not set
CONFIG_LTE_LC_TAU_PRE_WARNING_TIME_MS=5000
CONFIG_LTE_LC_TAU_PRE_WARNING_THRESHOLD_MS=1200000
CONFIG_LTE_NEIGHBOR_CELLS_MAX=10
# CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS is not set
CONFIG_LTE_LC_MODEM_SLEEP_PRE_WARNING_TIME_MS=5000
CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS_THRESHOLD_MS=1200000
# CONFIG_LTE_LC_TRACE is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_INF=y
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL=3
# CONFIG_FPROTECT is not set
CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000
CONFIG_FPROTECT_BLOCK_SIZE=0x8000
# CONFIG_AT_SMS_CERT is not set
CONFIG_AT_HOST_LIBRARY=y
CONFIG_AT_HOST_UART_0=y
# CONFIG_AT_HOST_UART_1 is not set
# CONFIG_AT_HOST_UART_2 is not set
CONFIG_AT_HOST_UART=0
CONFIG_AT_HOST_UART_INIT_TIMEOUT=500
# CONFIG_NULL_TERMINATION is not set
CONFIG_CR_TERMINATION=y
# CONFIG_LF_TERMINATION is not set
# CONFIG_CR_LF_TERMINATION is not set
CONFIG_AT_HOST_TERMINATION=1
CONFIG_AT_HOST_CMD_MAX_LEN=4096
CONFIG_AT_HOST_THREAD_PRIO=10
# CONFIG_AT_HOST_LOG_LEVEL_OFF is not set
# CONFIG_AT_HOST_LOG_LEVEL_ERR is not set
# CONFIG_AT_HOST_LOG_LEVEL_WRN is not set
CONFIG_AT_HOST_LOG_LEVEL_INF=y
# CONFIG_AT_HOST_LOG_LEVEL_DBG is not set
CONFIG_AT_HOST_LOG_LEVEL=3
CONFIG_DK_LIBRARY=y
CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL=10
CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS=y
# CONFIG_DK_LIBRARY_LOG_LEVEL_OFF is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_ERR is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_WRN is not set
CONFIG_DK_LIBRARY_LOG_LEVEL_INF=y
# CONFIG_DK_LIBRARY_LOG_LEVEL_DBG is not set
CONFIG_DK_LIBRARY_LOG_LEVEL=3
CONFIG_AT_CMD_PARSER=y
CONFIG_MODEM_INFO=y
CONFIG_MODEM_INFO_MAX_AT_PARAMS_RSP=10
CONFIG_MODEM_INFO_BUFFER_SIZE=128
CONFIG_MODEM_INFO_ADD_NETWORK=y
CONFIG_MODEM_INFO_ADD_DATE_TIME=y
CONFIG_MODEM_INFO_ADD_SIM=y
CONFIG_MODEM_INFO_ADD_SIM_ICCID=y
CONFIG_MODEM_INFO_ADD_SIM_IMSI=y
CONFIG_MODEM_INFO_ADD_DEVICE=y
CONFIG_MODEM_INFO_ADD_BOARD=y
# CONFIG_PDN is not set
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_MODEM_KEY_MGMT is not set
# CONFIG_SUPL_CLIENT_LIB is not set
CONFIG_DATE_TIME=y
CONFIG_DATE_TIME_AUTO_UPDATE=y
CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=14400
CONFIG_DATE_TIME_TOO_OLD_SECONDS=3600
CONFIG_DATE_TIME_MODEM=y
CONFIG_DATE_TIME_NTP=y
CONFIG_DATE_TIME_THREAD_STACK_SIZE=1280
CONFIG_DATE_TIME_NTP_QUERY_TIME_SECONDS=5
# CONFIG_DATE_TIME_LOG_LEVEL_OFF is not set
# CONFIG_DATE_TIME_LOG_LEVEL_ERR is not set
# CONFIG_DATE_TIME_LOG_LEVEL_WRN is not set
# CONFIG_DATE_TIME_LOG_LEVEL_INF is not set
CONFIG_DATE_TIME_LOG_LEVEL_DBG=y
CONFIG_DATE_TIME_LOG_LEVEL=4
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
# CONFIG_MODEM_JWT is not set
# CONFIG_MODEM_ATTEST_TOKEN is not set
# CONFIG_MULTICELL_LOCATION is not set
# CONFIG_LOCATION is not set
CONFIG_MODEM_ANTENNA=y
CONFIG_MODEM_ANTENNA_GNSS_ONBOARD=y
# CONFIG_MODEM_ANTENNA_GNSS_EXTERNAL is not set
CONFIG_MODEM_ANTENNA_AT_MAGPIO="AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586"
CONFIG_MODEM_ANTENNA_AT_COEX0="AT%XCOEX0=1,1,1565,1586"
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_OFF is not set
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_ERR is not set
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_WRN is not set
CONFIG_MODEM_ANTENNA_LOG_LEVEL_INF=y
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_DBG is not set
CONFIG_MODEM_ANTENNA_LOG_LEVEL=3
# CONFIG_QOS is not set
# CONFIG_QOS_LOG_LEVEL_OFF is not set
# CONFIG_QOS_LOG_LEVEL_ERR is not set
# CONFIG_QOS_LOG_LEVEL_WRN is not set
CONFIG_QOS_LOG_LEVEL_INF=y
# CONFIG_QOS_LOG_LEVEL_DBG is not set
CONFIG_QOS_LOG_LEVEL=3
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
CONFIG_ENTROPY_CC3XX=y
# CONFIG_ETH_RTT is not set
CONFIG_SENSOR=y
# CONFIG_BH1749 is not set
# CONFIG_SENSOR_SIM is not set
# CONFIG_PMW3360 is not set
# CONFIG_PAW3212 is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_FLASH=y
# CONFIG_FLASH_NOP_DEVICE is not set
# end of Device Drivers
# External libraries
# CONFIG_SBC is not set
# end of External libraries
# CONFIG_UNITY is not set
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (D:/firmware/nrf)
# mcuboot (D:/firmware/bootloader/mcuboot)
# MCUboot
CONFIG_SIGN_IMAGES=y
# CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set
# CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set
CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y
CONFIG_MCUBOOT_IMAGE_VERSION="0.0.0+0"
CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (D:/firmware/bootloader/mcuboot)
# mbedtls (D:/firmware/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
CONFIG_MBEDTLS_BUILTIN=y
# CONFIG_MBEDTLS_LIBRARY is not set
# end of mbedtls (D:/firmware/mbedtls)
# trusted-firmware-m (D:/firmware/modules/tee/tf-m/trusted-firmware-m)
# CONFIG_TFM_MINIMAL is not set
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (D:/firmware/modules/tee/tf-m/trusted-firmware-m)
# cjson (D:/firmware/modules/lib/cjson)
CONFIG_CJSON_LIB=y
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (D:/firmware/modules/lib/cjson)
# zcbor (D:/firmware/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# end of zcbor (D:/firmware/modules/lib/zcbor)
# memfault-firmware-sdk (D:/firmware/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (D:/firmware/modules/lib/memfault-firmware-sdk)
# canopennode (D:/firmware/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (D:/firmware/modules/lib/canopennode)
# hal_nordic (D:/firmware/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
CONFIG_HAS_NRFX=y
# nrfx drivers
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
CONFIG_NRFX_DPPI=y
# CONFIG_NRFX_EGU is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# CONFIG_NRFX_I2S is not set
CONFIG_NRFX_IPC=y
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_PDM is not set
# CONFIG_NRFX_POWER is not set
CONFIG_NRFX_PWM=y
CONFIG_NRFX_PWM0=y
CONFIG_NRFX_PWM1=y
CONFIG_NRFX_PWM2=y
CONFIG_NRFX_PWM3=y
# CONFIG_NRFX_RTC is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_SAADC is not set
CONFIG_NRFX_SPIM=y
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
CONFIG_NRFX_SPIM3=y
# CONFIG_NRFX_SPIS is not set
# CONFIG_NRFX_SPIS0 is not set
# CONFIG_NRFX_SPIS1 is not set
# CONFIG_NRFX_SPIS2 is not set
# CONFIG_NRFX_SPIS3 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TIMER is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
CONFIG_NRFX_TWIM=y
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_TWIM1 is not set
CONFIG_NRFX_TWIM2=y
# CONFIG_NRFX_TWIM3 is not set
# CONFIG_NRFX_TWIS is not set
# CONFIG_NRFX_TWIS0 is not set
# CONFIG_NRFX_TWIS1 is not set
# CONFIG_NRFX_TWIS2 is not set
# CONFIG_NRFX_TWIS3 is not set
# CONFIG_NRFX_UARTE is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_UARTE2 is not set
# CONFIG_NRFX_UARTE3 is not set
CONFIG_NRFX_WDT=y
CONFIG_NRFX_WDT0=y
# CONFIG_NRFX_PRS is not set
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of nrfx drivers
# end of hal_nordic (D:/firmware/modules/hal/nordic)
# littlefs (D:/firmware/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (D:/firmware/modules/fs/littlefs)
# loramac-node (D:/firmware/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (D:/firmware/modules/lib/loramac-node)
# lvgl (D:/firmware/modules/lib/gui/lvgl)
CONFIG_LV_Z_POINTER_KSCAN_MSGQ_COUNT=10
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (D:/firmware/modules/lib/gui/lvgl)
# lz4 (D:/firmware/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (D:/firmware/modules/lib/lz4)
# mbedtls (D:/firmware/modules/crypto/mbedtls)
# end of mbedtls (D:/firmware/modules/crypto/mbedtls)
# nanopb (D:/firmware/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (D:/firmware/modules/lib/nanopb)
# TraceRecorder (D:/firmware/modules/debug/TraceRecorder)
CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
# end of TraceRecorder (D:/firmware/modules/debug/TraceRecorder)
# zscilib (D:/firmware/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (D:/firmware/modules/lib/zscilib)
# nrfxlib (D:/firmware/nrfxlib)
# Nordic nrfxlib
CONFIG_NRF_MODEM=y
# nrf_modem (Modem library)
CONFIG_NRF_MODEM_LINK_BINARY=y
# CONFIG_NRF_MODEM_LOG is not set
# end of nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
# end of Crypto libraries for nRF5x SOCs.
# nrf_security module
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# end of nrf_security module
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_NRF_DM is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (D:/firmware/nrfxlib)
# connectedhomeip (D:/firmware/modules/lib/matter)
# CONFIG_CHIP_NFC_COMMISSIONING is not set
CONFIG_CHIP_DEBUG_SYMBOLS=y
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (D:/firmware/modules/lib/matter)
# Optional modules. Make sure they're installed, via the project manifest.
# CONFIG_CIVETWEB is not set
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_DSP is not set
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_SOF is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCBOR is not set
CONFIG_MCUBOOT_BOOTUTIL_LIB=y
CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF=y
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
# CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# FFF module not available.
# end of Modules
# CONFIG_NET_DRIVERS is not set
# CONFIG_BOARD_THINGY91_NRF9160 is not set
# Board Options
# CONFIG_BOARD_LOG_LEVEL_OFF is not set
# CONFIG_BOARD_LOG_LEVEL_ERR is not set
# CONFIG_BOARD_LOG_LEVEL_WRN is not set
CONFIG_BOARD_LOG_LEVEL_INF=y
# CONFIG_BOARD_LOG_LEVEL_DBG is not set
CONFIG_BOARD_LOG_LEVEL=3
# end of Board Options
# CONFIG_SOC_SERIES_BEETLE is not set
# CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
# CONFIG_SOC_SERIES_MPS2 is not set
# CONFIG_SOC_SERIES_MPS3 is not set
# CONFIG_SOC_SERIES_MUSCA_B1 is not set
# CONFIG_SOC_SERIES_MUSCA_S1 is not set
# CONFIG_SOC_SERIES_SAMD20 is not set
# CONFIG_SOC_SERIES_SAMD21 is not set
# CONFIG_SOC_SERIES_SAMD51 is not set
# CONFIG_SOC_SERIES_SAME51 is not set
# CONFIG_SOC_SERIES_SAME53 is not set
# CONFIG_SOC_SERIES_SAME54 is not set
# CONFIG_SOC_SERIES_SAMR21 is not set
# CONFIG_SOC_SERIES_SAM3X is not set
# CONFIG_SOC_SERIES_SAM4E is not set
# CONFIG_SOC_SERIES_SAM4L is not set
# CONFIG_SOC_SERIES_SAM4S is not set
# CONFIG_SOC_SERIES_SAME70 is not set
# CONFIG_SOC_SERIES_SAMV71 is not set
# CONFIG_SOC_SERIES_VALKYRIE is not set
# CONFIG_SOC_SERIES_VIPER is not set
# CONFIG_SOC_SERIES_PSOC62 is not set
# CONFIG_SOC_SERIES_PSOC63 is not set
# CONFIG_SOC_SERIES_GD32E10X is not set
# CONFIG_SOC_SERIES_GD32F3X0 is not set
# CONFIG_SOC_SERIES_GD32F403 is not set
# CONFIG_SOC_SERIES_GD32F4XX is not set
# CONFIG_SOC_SERIES_XMC_4XXX is not set
# CONFIG_SOC_SERIES_MEC1501X is not set
# CONFIG_SOC_SERIES_MEC1701X is not set
# CONFIG_SOC_SERIES_MEC172X is not set
# CONFIG_SOC_SERIES_NRF51X is not set
# CONFIG_SOC_SERIES_NRF52X is not set
# CONFIG_SOC_SERIES_NRF53X is not set
CONFIG_SOC_SERIES_NRF91X=y
# CONFIG_SOC_SERIES_NPCX7 is not set
# CONFIG_SOC_SERIES_NPCX9 is not set
# CONFIG_SOC_SERIES_M48X is not set
# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
# CONFIG_SOC_SERIES_IMX7_M4 is not set
# CONFIG_SOC_SERIES_IMX8ML_M7 is not set
# CONFIG_SOC_SERIES_IMX8MM_M4 is not set
# CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
# CONFIG_SOC_SERIES_IMX_RT5XX is not set
# CONFIG_SOC_SERIES_IMX_RT6XX is not set
# CONFIG_SOC_SERIES_IMX_RT is not set
# CONFIG_SOC_SERIES_KINETIS_K2X is not set
# CONFIG_SOC_SERIES_KINETIS_K6X is not set
# CONFIG_SOC_SERIES_KINETIS_K8X is not set
# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
# CONFIG_SOC_SERIES_KINETIS_KV5X is not set
# CONFIG_SOC_SERIES_KINETIS_KWX is not set
# CONFIG_SOC_SERIES_LPC11U6X is not set
# CONFIG_SOC_SERIES_LPC54XXX is not set
# CONFIG_SOC_SERIES_LPC55XXX is not set
# CONFIG_SOC_EOS_S3 is not set
# CONFIG_SOC_SERIES_RCAR_GEN3 is not set
# CONFIG_SOC_SERIES_RP2XXX is not set
# CONFIG_SOC_SERIES_EFM32GG11B is not set
# CONFIG_SOC_SERIES_EFM32HG is not set
# CONFIG_SOC_SERIES_EFM32JG12B is not set
# CONFIG_SOC_SERIES_EFM32PG12B is not set
# CONFIG_SOC_SERIES_EFM32PG1B is not set
# CONFIG_SOC_SERIES_EFM32WG is not set
# CONFIG_SOC_SERIES_EFR32BG13P is not set
# CONFIG_SOC_SERIES_EFR32FG13P is not set
# CONFIG_SOC_SERIES_EFR32FG1P is not set
# CONFIG_SOC_SERIES_EFR32MG12P is not set
# CONFIG_SOC_SERIES_EFR32MG21 is not set
# CONFIG_SOC_SERIES_STM32F0X is not set
# CONFIG_SOC_SERIES_STM32F1X is not set
# CONFIG_SOC_SERIES_STM32F2X is not set
# CONFIG_SOC_SERIES_STM32F3X is not set
# CONFIG_SOC_SERIES_STM32F4X is not set
# CONFIG_SOC_SERIES_STM32F7X is not set
# CONFIG_SOC_SERIES_STM32G0X is not set
# CONFIG_SOC_SERIES_STM32G4X is not set
# CONFIG_SOC_SERIES_STM32H7X is not set
# CONFIG_SOC_SERIES_STM32L0X is not set
# CONFIG_SOC_SERIES_STM32L1X is not set
# CONFIG_SOC_SERIES_STM32L4X is not set
# CONFIG_SOC_SERIES_STM32L5X is not set
# CONFIG_SOC_SERIES_STM32MP1X is not set
# CONFIG_SOC_SERIES_STM32U5X is not set
# CONFIG_SOC_SERIES_STM32WBX is not set
# CONFIG_SOC_SERIES_STM32WLX is not set
# CONFIG_SOC_TI_LM3S6965 is not set
# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
# CONFIG_SOC_SERIES_CC32XX is not set
# CONFIG_SOC_SERIES_MSP432P4XX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
# CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
# Hardware Configuration
CONFIG_CPU_HAS_ARM_MPU=y
CONFIG_CPU_HAS_NRF_IDAU=y
CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_DPPIC=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIOTE=y
CONFIG_HAS_HW_NRF_I2S=y
CONFIG_HAS_HW_NRF_IPC=y
CONFIG_HAS_HW_NRF_KMU=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_PDM=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_PWM1=y
CONFIG_HAS_HW_NRF_PWM2=y
CONFIG_HAS_HW_NRF_PWM3=y
CONFIG_HAS_HW_NRF_REGULATORS=y
CONFIG_HAS_HW_NRF_RTC0=y
CONFIG_HAS_HW_NRF_RTC1=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPIM0=y
CONFIG_HAS_HW_NRF_SPIM1=y
CONFIG_HAS_HW_NRF_SPIM2=y
CONFIG_HAS_HW_NRF_SPIM3=y
CONFIG_HAS_HW_NRF_SPIS0=y
CONFIG_HAS_HW_NRF_SPIS1=y
CONFIG_HAS_HW_NRF_SPIS2=y
CONFIG_HAS_HW_NRF_SPIS3=y
CONFIG_HAS_HW_NRF_SPU=y
CONFIG_HAS_HW_NRF_TIMER0=y
CONFIG_HAS_HW_NRF_TIMER1=y
CONFIG_HAS_HW_NRF_TIMER2=y
CONFIG_HAS_HW_NRF_TWIM0=y
CONFIG_HAS_HW_NRF_TWIM1=y
CONFIG_HAS_HW_NRF_TWIM2=y
CONFIG_HAS_HW_NRF_TWIM3=y
CONFIG_HAS_HW_NRF_TWIS0=y
CONFIG_HAS_HW_NRF_TWIS1=y
CONFIG_HAS_HW_NRF_TWIS2=y
CONFIG_HAS_HW_NRF_TWIS3=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_UARTE1=y
CONFIG_HAS_HW_NRF_UARTE2=y
CONFIG_HAS_HW_NRF_UARTE3=y
CONFIG_HAS_HW_NRF_VMC=y
CONFIG_HAS_HW_NRF_WDT=y
CONFIG_NRF_HW_RTC1_RESERVED=y
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_SOC_NRF9160=y
CONFIG_SOC_NRF9160_SICA=y
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
# CONFIG_NRF_TRACE_PORT is not set
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
CONFIG_SOC_LOG_LEVEL_INF=y
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
# ARM Options
CONFIG_ARCH="arm"
CONFIG_CPU_CORTEX=y
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_CPU_CORTEX_M=y
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_FAULT_DUMP=2
CONFIG_BUILTIN_STACK_GUARD=y
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_ARM_NONSECURE_FIRMWARE=y
# CONFIG_ARM_NONSECURE_PREEMPTIBLE_SECURE_CALLS is not set
CONFIG_ARM_STORE_EXC_RETURN=y
CONFIG_FP_HARDABI=y
# CONFIG_FP_SOFTABI is not set
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M33=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_CPU_CORTEX_M_HAS_CMSE=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_SE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
CONFIG_ARMV8_M_DSP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_GEN_ISR_TABLES=y
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
CONFIG_ARM_TRUSTZONE_M=y
# ARM TrustZone-M Options
# Non-secure firmware
CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS=y
# end of ARM TrustZone-M Options
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_STACK_GUARD is not set
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
CONFIG_ARCH_LOG_LEVEL_INF=y
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL=3
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
CONFIG_MPU_LOG_LEVEL_INF=y
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL=3
# CONFIG_TRUSTED_EXECUTION_SECURE is not set
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=0
CONFIG_GEN_IRQ_START_VECTOR=0
# CONFIG_EXTRA_EXCEPTION_INFO is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_CPU_HAS_TEE=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
CONFIG_MPU_GAP_FILLING=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# Floating Point Options
CONFIG_FPU_SHARING=y
# end of Floating Point Options
# Cache Options
# CONFIG_CACHE_MANAGEMENT is not set
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
CONFIG_KERNEL_LOG_LEVEL_INF=y
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_IDLE_STACK_SIZE=320
CONFIG_ISR_STACK_SIZE=2048
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
CONFIG_ERRNO=y
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Kernel Debugging and Metrics
CONFIG_BOOT_BANNER=y
CONFIG_BOOT_DELAY=0
CONFIG_THREAD_MONITOR=y
CONFIG_THREAD_NAME=y
CONFIG_THREAD_MAX_NAME_LEN=32
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# Work Queue Options
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of Work Queue Options
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
CONFIG_POLL=y
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
CONFIG_KERNEL_MEM_POOL=y
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
CONFIG_XIP=y
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# SMP Options
# end of SMP Options
CONFIG_TICKLESS_KERNEL=y
# end of General Kernel Options
# Virtual Memory Support
# end of Virtual Memory Support
CONFIG_HAS_DTS=y
CONFIG_HAS_DTS_GPIO=y
CONFIG_HAS_DTS_WDT=y
# Device Drivers
# CONFIG_IEEE802154 is not set
# CONFIG_LORA is not set
CONFIG_CONSOLE=y
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE=y
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
CONFIG_UART_CONSOLE_INPUT_EXPIRED=y
CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT=15000
# CONFIG_RAM_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_PIPE is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_SEMIHOST_CONSOLE is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_GSM_MUX is not set
CONFIG_HAS_SEGGER_RTT=y
# CONFIG_USE_SEGGER_RTT is not set
# CONFIG_EC_HOST_CMD_PERIPH is not set
# CONFIG_MDIO is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
CONFIG_UART_USE_RUNTIME_CONFIGURE=y
# CONFIG_UART_ASYNC_API is not set
# CONFIG_UART_LINE_CTRL is not set
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# Serial Drivers
# CONFIG_UART_ITE_IT8XXX2 is not set
CONFIG_UART_NRFX=y
CONFIG_UART_0_NRF_UARTE=y
CONFIG_UART_0_ENHANCED_POLL_OUT=y
CONFIG_UART_0_INTERRUPT_DRIVEN=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
CONFIG_UART_1_NRF_UARTE=y
CONFIG_UART_1_INTERRUPT_DRIVEN=y
CONFIG_UART_1_ENHANCED_POLL_OUT=y
# CONFIG_UART_1_NRF_PARITY_BIT is not set
CONFIG_UART_1_NRF_TX_BUFFER_SIZE=32
CONFIG_UART_ENHANCED_POLL_OUT=y
CONFIG_NRF_UARTE_PERIPHERAL=y
# CONFIG_UART_ALTERA_JTAG is not set
# CONFIG_UART_RPI_PICO is not set
# CONFIG_UART_XLNX_UARTLITE is not set
# Interrupt Controllers
# CONFIG_SWERV_PIC is not set
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_INTC_ESP32 is not set
# end of Interrupt Controllers
# Timer Drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
# CONFIG_CAVS_TIMER is not set
# CONFIG_HPET_TIMER is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
CONFIG_RISCV_MACHINE_TIMER_SYSTEM_CLOCK_DIVIDER=0
# end of Timer Drivers
# CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
# CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
# CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
CONFIG_ENTROPY_LOG_LEVEL_INF=y
# CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
CONFIG_ENTROPY_LOG_LEVEL=3
CONFIG_ENTROPY_INIT_PRIORITY=50
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
CONFIG_GPIO_LOG_LEVEL_INF=y
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL=3
# CONFIG_GPIO_DW is not set
# CONFIG_GPIO_PCA95XX is not set
# CONFIG_GPIO_MCP23S17 is not set
# CONFIG_GPIO_MCP230XX is not set
# CONFIG_GPIO_MCP23SXX is not set
CONFIG_GPIO_NRFX=y
# CONFIG_GPIO_SX1509B is not set
# CONFIG_GPIO_ITE_IT8XXX2 is not set
# CONFIG_GPIO_INTEL is not set
# CONFIG_GPIO_RPI_PICO is not set
# CONFIG_GPIO_XLNX_AXI is not set
# CONFIG_GPIO_EMUL is not set
# CONFIG_GPIO_PCAL6408A is not set
# CONFIG_GPIO_CY8C95XX is not set
# CONFIG_GPIO_SNPS_CREG is not set
# CONFIG_GPIO_STMPE1600 is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_FXL6408 is not set
# CONFIG_FXL6408_LOG_LEVEL_OFF is not set
# CONFIG_FXL6408_LOG_LEVEL_ERR is not set
# CONFIG_FXL6408_LOG_LEVEL_WRN is not set
CONFIG_FXL6408_LOG_LEVEL_INF=y
# CONFIG_FXL6408_LOG_LEVEL_DBG is not set
CONFIG_FXL6408_LOG_LEVEL=3
# CONFIG_GPIO_NCT38XX is not set
# CONFIG_SHARED_IRQ is not set
# CONFIG_SPI_ASYNC is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPI_EXTENDED_MODES is not set
CONFIG_SPI_INIT_PRIORITY=70
CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
# CONFIG_SPI_LOG_LEVEL_OFF is not set
# CONFIG_SPI_LOG_LEVEL_ERR is not set
# CONFIG_SPI_LOG_LEVEL_WRN is not set
CONFIG_SPI_LOG_LEVEL_INF=y
# CONFIG_SPI_LOG_LEVEL_DBG is not set
CONFIG_SPI_LOG_LEVEL=3
# CONFIG_SPI_EMUL is not set
CONFIG_SPI_NRFX=y
CONFIG_SPI_3_NRF_SPIM=y
CONFIG_SPI_3_NRF_ORC=0xff
CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
# CONFIG_SPI_OC_SIMPLE is not set
# CONFIG_SPI_XLNX_AXI_QUADSPI is not set
# CONFIG_SPI_BITBANG is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_GPIO is not set
CONFIG_I2C_NRFX=y
CONFIG_I2C_2_NRF_TWIM=y
# CONFIG_I2C_EMUL is not set
# CONFIG_I2C_SBCON is not set
# CONFIG_I2C_TCA954X is not set
CONFIG_I2C_INIT_PRIORITY=60
# CONFIG_I2C_LOG_LEVEL_OFF is not set
# CONFIG_I2C_LOG_LEVEL_ERR is not set
# CONFIG_I2C_LOG_LEVEL_WRN is not set
CONFIG_I2C_LOG_LEVEL_INF=y
# CONFIG_I2C_LOG_LEVEL_DBG is not set
CONFIG_I2C_LOG_LEVEL=3
# CONFIG_I2S is not set
CONFIG_PWM=y
# CONFIG_PWM_LOG_LEVEL_OFF is not set
# CONFIG_PWM_LOG_LEVEL_ERR is not set
# CONFIG_PWM_LOG_LEVEL_WRN is not set
CONFIG_PWM_LOG_LEVEL_INF=y
# CONFIG_PWM_LOG_LEVEL_DBG is not set
CONFIG_PWM_LOG_LEVEL=3
# CONFIG_PWM_CAPTURE is not set
CONFIG_PWM_NRFX=y
# CONFIG_PWM_LED_ESP32 is not set
# CONFIG_PWM_XLNX_AXI_TIMER is not set
# CONFIG_PINMUX is not set
# CONFIG_ADC is not set
# CONFIG_DAC is not set
# CONFIG_WDT_DISABLE_AT_BOOT is not set
# CONFIG_WDT_LOG_LEVEL_OFF is not set
# CONFIG_WDT_LOG_LEVEL_ERR is not set
# CONFIG_WDT_LOG_LEVEL_WRN is not set
CONFIG_WDT_LOG_LEVEL_INF=y
# CONFIG_WDT_LOG_LEVEL_DBG is not set
CONFIG_WDT_LOG_LEVEL=3
# CONFIG_WDT_COUNTER is not set
CONFIG_WDT_NRFX=y
CONFIG_WDT_ITE_WARNING_LEADING_TIME_MS=500
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_PTP_CLOCK is not set
# CONFIG_IPM is not set
CONFIG_FLASH_HAS_DRIVER_ENABLED=y
CONFIG_FLASH_HAS_PAGE_LAYOUT=y
# CONFIG_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_FLASH_LOG_LEVEL_WRN is not set
CONFIG_FLASH_LOG_LEVEL_INF=y
# CONFIG_FLASH_LOG_LEVEL_DBG is not set
CONFIG_FLASH_LOG_LEVEL=3
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_INIT_PRIORITY=50
# CONFIG_SPI_FLASH_AT45 is not set
CONFIG_SOC_FLASH_NRF=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
# CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
# CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
# CONFIG_SPI_NOR is not set
# CONFIG_FLASH_SIMULATOR is not set
# CONFIG_SENSOR_LOG_LEVEL_OFF is not set
# CONFIG_SENSOR_LOG_LEVEL_ERR is not set
# CONFIG_SENSOR_LOG_LEVEL_WRN is not set
CONFIG_SENSOR_LOG_LEVEL_INF=y
# CONFIG_SENSOR_LOG_LEVEL_DBG is not set
CONFIG_SENSOR_LOG_LEVEL=3
CONFIG_SENSOR_INIT_PRIORITY=90
# Device Drivers
# CONFIG_ADT7420 is not set
# CONFIG_ADXL345 is not set
CONFIG_ADXL362=y
# CONFIG_ADXL362_ACCEL_RANGE_RUNTIME is not set
CONFIG_ADXL362_ACCEL_RANGE_2G=y
# CONFIG_ADXL362_ACCEL_RANGE_4G is not set
# CONFIG_ADXL362_ACCEL_RANGE_8G is not set
# CONFIG_ADXL362_ACCEL_ODR_RUNTIME is not set
CONFIG_ADXL362_ACCEL_ODR_12_5=y
# CONFIG_ADXL362_ACCEL_ODR_25 is not set
# CONFIG_ADXL362_ACCEL_ODR_50 is not set
# CONFIG_ADXL362_ACCEL_ODR_100 is not set
# CONFIG_ADXL362_ACCEL_ODR_200 is not set
# CONFIG_ADXL362_ACCEL_ODR_400 is not set
# CONFIG_ADXL362_TRIGGER_NONE is not set
CONFIG_ADXL362_TRIGGER_GLOBAL_THREAD=y
# CONFIG_ADXL362_TRIGGER_OWN_THREAD is not set
CONFIG_ADXL362_TRIGGER=y
CONFIG_ADXL362_ACTIVITY_THRESHOLD=20
CONFIG_ADXL362_ACTIVITY_TIME=1
CONFIG_ADXL362_INACTIVITY_THRESHOLD=100
CONFIG_ADXL362_INACTIVITY_TIME=1
CONFIG_ADXL362_INTERRUPT_MODE=1
CONFIG_ADXL362_ABS_REF_MODE=1
# CONFIG_ADXL372 is not set
# CONFIG_AK8975 is not set
# CONFIG_AMG88XX is not set
# CONFIG_AMS_IAQ_CORE is not set
# CONFIG_APDS9960 is not set
# CONFIG_BMA280 is not set
# CONFIG_BMC150_MAGN is not set
# CONFIG_BME280 is not set
# CONFIG_BME680 is not set
# CONFIG_BMG160 is not set
# CONFIG_BMI160 is not set
# CONFIG_BMI270 is not set
# CONFIG_BMM150 is not set
# CONFIG_BMP388 is not set
# CONFIG_BQ274XX is not set
# CONFIG_CCS811 is not set
# CONFIG_DHT is not set
# CONFIG_DPS310 is not set
# CONFIG_ENS210 is not set
# CONFIG_FDC2X1X is not set
# CONFIG_FXAS21002 is not set
# CONFIG_FXOS8700 is not set
# CONFIG_GROVE_SENSORS is not set
# CONFIG_TI_HDC is not set
# CONFIG_TI_HDC20XX is not set
# CONFIG_HMC5883L is not set
# CONFIG_HP206C is not set
# CONFIG_HTS221 is not set
# CONFIG_I3G4250D is not set
# CONFIG_ICM42605 is not set
# CONFIG_IIS2DH is not set
# CONFIG_IIS2DLPC is not set
# CONFIG_IIS2ICLX is not set
# CONFIG_IIS2MDC is not set
# CONFIG_IIS3DHHC is not set
# CONFIG_INA23X is not set
# CONFIG_ISL29035 is not set
# CONFIG_INA219 is not set
# CONFIG_ISM330DHCX is not set
# CONFIG_LIS2DH is not set
# CONFIG_LIS2DS12 is not set
# CONFIG_LIS2DW12 is not set
# CONFIG_LIS2MDL is not set
# CONFIG_LIS3MDL is not set
# CONFIG_LM75 is not set
# CONFIG_LM77 is not set
# CONFIG_LPS22HB is not set
# CONFIG_LPS22HH is not set
# CONFIG_LPS25HB is not set
# CONFIG_LSM303DLHC_MAGN is not set
# CONFIG_LSM6DS0 is not set
# CONFIG_LSM6DSL is not set
# CONFIG_LSM6DSO is not set
# CONFIG_LSM9DS0_GYRO is not set
# CONFIG_LSM9DS0_MFD is not set
# CONFIG_MAX17055 is not set
# CONFIG_MAX17262 is not set
# CONFIG_MAX30101 is not set
# CONFIG_MAX31875 is not set
# CONFIG_MAX44009 is not set
# CONFIG_MAX6675 is not set
# CONFIG_MCP9808 is not set
# CONFIG_MHZ19B is not set
# CONFIG_MPR is not set
# CONFIG_MPU6050 is not set
# CONFIG_MPU9250 is not set
# CONFIG_MS5837 is not set
# CONFIG_MS5607 is not set
# CONFIG_OPT3001 is not set
# CONFIG_PMS7003 is not set
# CONFIG_SBS_GAUGE is not set
# CONFIG_SGP40 is not set
# CONFIG_SHTCX is not set
# CONFIG_SHT3XD is not set
# CONFIG_SHT4X is not set
# CONFIG_SI7006 is not set
# CONFIG_SI7055 is not set
# CONFIG_SI7060 is not set
# CONFIG_SI7210 is not set
# CONFIG_SM351LT is not set
# CONFIG_STTS751 is not set
# CONFIG_SX9500 is not set
# CONFIG_TH02 is not set
# CONFIG_TMP007 is not set
# CONFIG_TMP108 is not set
# CONFIG_TMP112 is not set
CONFIG_TMP112_FULL_SCALE_RUNTIME=y
CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y
# CONFIG_TMP116 is not set
# CONFIG_VCNL4040 is not set
# CONFIG_VL53L0X is not set
# CONFIG_ITDS is not set
# CONFIG_COUNTER is not set
# CONFIG_DMA is not set
# CONFIG_USB_DEVICE_DRIVER is not set
# CONFIG_CRYPTO is not set
# CONFIG_DISPLAY is not set
# CONFIG_LED_STRIP is not set
CONFIG_LED=y
# CONFIG_LED_LOG_LEVEL_OFF is not set
# CONFIG_LED_LOG_LEVEL_ERR is not set
# CONFIG_LED_LOG_LEVEL_WRN is not set
CONFIG_LED_LOG_LEVEL_INF=y
# CONFIG_LED_LOG_LEVEL_DBG is not set
CONFIG_LED_LOG_LEVEL=3
CONFIG_LED_INIT_PRIORITY=90
# CONFIG_LED_GPIO is not set
# CONFIG_HT16K33 is not set
# CONFIG_LP3943 is not set
# CONFIG_LP503X is not set
# CONFIG_LP5562 is not set
# CONFIG_PCA9633 is not set
CONFIG_LED_PWM=y
# CONFIG_TLC59108 is not set
# CONFIG_CAN is not set
# CONFIG_AUDIO is not set
# CONFIG_NEURAL_NET_ACCEL is not set
# CONFIG_HWINFO is not set
# CONFIG_ESPI is not set
# CONFIG_PS2 is not set
# CONFIG_VIDEO is not set
# CONFIG_EEPROM is not set
# CONFIG_PECI is not set
# CONFIG_PECI_INTERRUPT_DRIVEN is not set
# CONFIG_REGULATOR is not set
# CONFIG_MEMC is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_EDAC is not set
# CONFIG_PM_CPU_OPS is not set
# Miscellaneous Drivers
# CONFIG_GROVE_LCD_RGB_LOG_LEVEL_OFF is not set
# CONFIG_GROVE_LCD_RGB_LOG_LEVEL_ERR is not set
# CONFIG_GROVE_LCD_RGB_LOG_LEVEL_WRN is not set
CONFIG_GROVE_LCD_RGB_LOG_LEVEL_INF=y
# CONFIG_GROVE_LCD_RGB_LOG_LEVEL_DBG is not set
CONFIG_GROVE_LCD_RGB_LOG_LEVEL=3
# CONFIG_GROVE_LCD_RGB is not set
# end of Miscellaneous Drivers
# CONFIG_DISK_DRIVERS is not set
# CONFIG_CACHE is not set
# CONFIG_SYSCON is not set
# CONFIG_BBRAM is not set
# CONFIG_FPGA is not set
# CONFIG_MBOX is not set
# CONFIG_MM_DRV is not set
# CONFIG_POWER_DOMAIN is not set
# C Library
CONFIG_SUPPORT_MINIMAL_LIBC=y
# CONFIG_MINIMAL_LIBC is not set
CONFIG_NEWLIB_LIBC=y
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_NEWLIB_LIBC_NANO=y
CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
# CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
# CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
CONFIG_STDOUT_CONSOLE=y
# end of C Library
# Additional libraries
# OS Support Library
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
# CONFIG_BASE64 is not set
# CONFIG_PRINTK_SYNC is not set
CONFIG_MPSC_PBUF=y
# CONFIG_SHARED_MULTI_HEAP is not set
# CONFIG_WINSTREAM is not set
# CONFIG_MPSC_CLEAR_ALLOCATED is not set
CONFIG_REBOOT=y
# CONFIG_UTF8 is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
CONFIG_CBPRINTF_FP_SUPPORT=y
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_FP_ALWAYS_A is not set
CONFIG_CBPRINTF_N_SPECIFIER=y
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
CONFIG_SYS_HEAP_SMALL_ONLY=y
# CONFIG_SYS_HEAP_BIG_ONLY is not set
# CONFIG_SYS_HEAP_AUTO is not set
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Heap and Memory Allocation
# end of OS Support Library
# CONFIG_GETOPT is not set
CONFIG_POSIX_MAX_FDS=4
# CONFIG_POSIX_API is not set
# CONFIG_PTHREAD_IPC is not set
CONFIG_POSIX_CLOCK=y
CONFIG_MAX_TIMER_COUNT=5
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_EVENTFD is not set
# CONFIG_OPENAMP_RSC_TABLE is not set
# Util libraries
# CONFIG_FNMATCH is not set
# end of Util libraries
# CONFIG_SMF is not set
# end of Additional libraries
# Sub Systems and OS Services
# CONFIG_BT is not set
# Controller Area Network (CAN) bus subsystem
# CONFIG_ISOTP is not set
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_CPLUSPLUS is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
CONFIG_ASSERT=y
CONFIG_ASSERT_LEVEL=2
CONFIG_SPIN_VALIDATE=y
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
CONFIG_DEBUG_THREAD_INFO=y
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
# CONFIG_DISK_ACCESS is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
CONFIG_FCB=y
# CONFIG_NVS is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
CONFIG_LOG=y
# CONFIG_LOG_MODE_DEFERRED is not set
CONFIG_LOG_MODE_IMMEDIATE=y
# CONFIG_LOG_MODE_MINIMAL is not set
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG2_MODE_DEFERRED is not set
# CONFIG_LOG2_MODE_IMMEDIATE is not set
# CONFIG_LOG1 is not set
CONFIG_LOG2=y
CONFIG_LOG2_IMMEDIATE=y
# Logging levels filtering
# CONFIG_LOG_RUNTIME_FILTERING is not set
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Output Formatting
# Prepend non-hexdump log message with function name
# CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend non-hexdump log message with function name
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# CONFIG_LOG_IMMEDIATE_CLEAN_OUTPUT is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
# CONFIG_LOG_INFO_COLOR_GREEN is not set
CONFIG_LOG_TAG_MAX_LEN=0
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
# end of Output Formatting
# Processing
# CONFIG_LOG_PRINTK is not set
CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
# CONFIG_LOG_TIMESTAMP_64BIT is not set
# end of Processing
# Backends
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
# end of Backends
# Misc
CONFIG_LOG_DOMAIN_ID=0
CONFIG_LOG2_USE_VLA=y
CONFIG_LOG2_ALWAYS_RUNTIME=y
# CONFIG_LOG2_FMT_SECTION is not set
# end of Misc
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_MCUMGR is not set
# CONFIG_HAWKBIT is not set
# CONFIG_UPDATEHUB is not set
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# Networking
CONFIG_NET_BUF=y
CONFIG_NET_BUF_USER_DATA_SIZE=0
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
# CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
# CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
CONFIG_NET_BUF_LOG_LEVEL_INF=y
# CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
CONFIG_NET_BUF_LOG_LEVEL=3
# CONFIG_NET_BUF_POOL_USAGE is not set
CONFIG_NETWORKING=y
# CONFIG_NET_HOSTNAME_ENABLE is not set
# Link layer options
# CONFIG_NET_L2_DUMMY is not set
# CONFIG_NET_L2_BT_SHELL is not set
# CONFIG_NET_L2_VIRTUAL is not set
# CONFIG_NET_L2_PPP is not set
# CONFIG_NET_L2_OPENTHREAD is not set
# CONFIG_NET_L2_CUSTOM_IEEE802154 is not set
# CONFIG_NET_L2_CANBUS_RAW is not set
# CONFIG_NET_L2_WIFI_MGMT is not set
# CONFIG_NET_L2_WIFI_SHELL is not set
# CONFIG_NET_L2_PTP is not set
# end of Link layer options
# IP stack
# CONFIG_NET_NATIVE is not set
# CONFIG_NET_OFFLOAD is not set
CONFIG_NET_INIT_PRIO=90
CONFIG_NET_IF_MAX_IPV6_COUNT=1
CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=2
CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=3
CONFIG_NET_IF_IPV6_PREFIX_COUNT=2
CONFIG_NET_INITIAL_HOP_LIMIT=64
CONFIG_NET_IPV6_MAX_NEIGHBORS=8
# CONFIG_NET_IPV6_FRAGMENT is not set
CONFIG_NET_IPV6_ND=y
CONFIG_NET_IPV6_DAD=y
CONFIG_NET_IPV6_RA_RDNSS=y
# CONFIG_NET_6LO is not set
CONFIG_NET_IPV6_LOG_LEVEL=0
CONFIG_NET_ICMPV6_LOG_LEVEL=0
CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL=0
# CONFIG_NET_IPV4 is not set
# CONFIG_NET_SHELL is not set
CONFIG_NET_TC_TX_COUNT=0
CONFIG_NET_TC_RX_COUNT=1
# CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set
CONFIG_NET_TC_THREAD_COOPERATIVE=y
# CONFIG_NET_TC_THREAD_PREEMPTIVE is not set
CONFIG_NET_TC_NUM_PRIORITIES=16
CONFIG_NET_TC_MAPPING_STRICT=y
CONFIG_NET_TX_DEFAULT_PRIORITY=1
CONFIG_NET_RX_DEFAULT_PRIORITY=0
CONFIG_NET_IP_ADDR_CHECK=y
CONFIG_NET_MAX_ROUTERS=1
CONFIG_NET_ROUTE=y
CONFIG_NET_MAX_ROUTES=8
CONFIG_NET_MAX_NEXTHOPS=8
# CONFIG_NET_ROUTE_MCAST is not set
# CONFIG_NET_TCP is not set
# CONFIG_NET_TEST_PROTOCOL is not set
CONFIG_NET_UDP=y
CONFIG_NET_UDP_CHECKSUM=y
CONFIG_NET_UDP_LOG_LEVEL=0
CONFIG_NET_MAX_CONN=4
CONFIG_NET_MAX_CONTEXTS=6
# CONFIG_NET_CONTEXT_NET_PKT_POOL is not set
CONFIG_NET_CONTEXT_SYNC_RECV=y
CONFIG_NET_CONTEXT_CHECK=y
# CONFIG_NET_CONTEXT_PRIORITY is not set
# CONFIG_NET_CONTEXT_TXTIME is not set
# CONFIG_NET_CONTEXT_RCVTIMEO is not set
# CONFIG_NET_CONTEXT_SNDTIMEO is not set
# CONFIG_NET_TEST is not set
# CONFIG_NET_TRICKLE is not set
CONFIG_NET_BUF_RX_COUNT=16
CONFIG_NET_BUF_TX_COUNT=16
CONFIG_NET_BUF_FIXED_DATA_SIZE=y
# CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set
CONFIG_NET_BUF_DATA_SIZE=128
CONFIG_NET_DEFAULT_IF_FIRST=y
# CONFIG_NET_PROMISCUOUS_MODE is not set
# CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set
# Stack usage
CONFIG_NET_TX_STACK_SIZE=1200
CONFIG_NET_RX_STACK_SIZE=1500
# end of Stack usage
# CONFIG_NET_MGMT is not set
# CONFIG_NET_STATISTICS is not set
# CONFIG_NET_LOG is not set
CONFIG_NET_PKT_LOG_LEVEL=0
# CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set
CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0
# CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set
CONFIG_NET_CORE_LOG_LEVEL=0
CONFIG_NET_IF_LOG_LEVEL=0
CONFIG_NET_TC_LOG_LEVEL=0
CONFIG_NET_UTILS_LOG_LEVEL=0
CONFIG_NET_CONTEXT_LOG_LEVEL=0
CONFIG_NET_CONN_LOG_LEVEL=0
CONFIG_NET_ROUTE_LOG_LEVEL=0
# end of IP stack
# Network Packet Filtering
# CONFIG_NET_PKT_FILTER is not set
# end of Network Packet Filtering
# Network Protocols
# CONFIG_COAP is not set
# CONFIG_DNS_SD is not set
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LOG_LEVEL=0
CONFIG_MQTT_KEEPALIVE=1177
CONFIG_MQTT_LIB_TLS=y
# CONFIG_MQTT_LIB_WEBSOCKET is not set
# CONFIG_MQTT_LIB_CUSTOM_TRANSPORT is not set
# CONFIG_TFTP_LIB is not set
# CONFIG_HTTP_PARSER is not set
# CONFIG_HTTP_PARSER_URL is not set
# CONFIG_HTTP_CLIENT is not set
CONFIG_NET_HTTP_LOG_LEVEL=0
# CONFIG_WEBSOCKET_CLIENT is not set
# CONFIG_LWM2M is not set
# CONFIG_SOCKS is not set
CONFIG_SNTP=y
CONFIG_SNTP_LOG_LEVEL=0
# end of Network Protocols
# Network Libraries
CONFIG_NET_CONFIG_AUTO_INIT=y
CONFIG_NET_CONFIG_INIT_PRIO=95
CONFIG_NET_CONFIG_INIT_TIMEOUT=30
# CONFIG_NET_CONFIG_NEED_IPV6_ROUTER is not set
# CONFIG_NET_CONFIG_NEED_IPV4 is not set
CONFIG_NET_CONFIG_LOG_LEVEL=0
# CONFIG_NET_CONFIG_SETTINGS is not set
# CONFIG_NET_CONFIG_CLOCK_SNTP_INIT is not set
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_POLL_MAX=3
CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000
# CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set
CONFIG_NET_SOCKETS_TLS_PRIORITY=45
CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS_OFFLOAD_TLS=y
# CONFIG_NET_SOCKETS_PACKET is not set
# CONFIG_NET_SOCKETS_CAN is not set
# CONFIG_NET_SOCKETPAIR is not set
CONFIG_NET_SOCKETS_LOG_LEVEL=0
# CONFIG_TLS_CREDENTIALS is not set
# end of Network Libraries
# Network additional services
# CONFIG_NET_CONNECTION_MANAGER is not set
# CONFIG_NET_CAPTURE is not set
# end of Network additional services
# end of Networking
# Portability
# end of Portability
# Power Management
# CONFIG_PM_LOG_LEVEL_OFF is not set
# CONFIG_PM_LOG_LEVEL_ERR is not set
# CONFIG_PM_LOG_LEVEL_WRN is not set
CONFIG_PM_LOG_LEVEL_INF=y
# CONFIG_PM_LOG_LEVEL_DBG is not set
CONFIG_PM_LOG_LEVEL=3
CONFIG_PM_POLICY_RESIDENCY=y
# CONFIG_PM_POLICY_APP is not set
# end of Power Management
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# CONFIG_USB_DEVICE_STACK is not set
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
CONFIG_IMG_BLOCK_BUF_SIZE=512
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
CONFIG_IMG_MANAGER_LOG_LEVEL_INF=y
# CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
CONFIG_IMG_MANAGER_LOG_LEVEL=3
CONFIG_UPDATEABLE_IMAGE_NUMBER=1
# Random Number Generators
CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
# CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
# CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
CONFIG_CSPRING_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# end of Random Number Generators
# Storage
CONFIG_FLASH_MAP=y
# CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
CONFIG_STREAM_FLASH=y
CONFIG_STREAM_FLASH_ERASE=y
# CONFIG_STREAM_FLASH_PROGRESS is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
CONFIG_STREAM_FLASH_LOG_LEVEL_DBG=y
CONFIG_STREAM_FLASH_LOG_LEVEL=4
# end of Storage
CONFIG_SETTINGS=y
# CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
# CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
# CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
# CONFIG_SETTINGS_LOG_LEVEL_INF is not set
CONFIG_SETTINGS_LOG_LEVEL_DBG=y
CONFIG_SETTINGS_LOG_LEVEL=4
# CONFIG_SETTINGS_RUNTIME is not set
CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
CONFIG_SETTINGS_FCB=y
# CONFIG_SETTINGS_CUSTOM is not set
# CONFIG_SETTINGS_NONE is not set
CONFIG_SETTINGS_FCB_NUM_AREAS=8
CONFIG_SETTINGS_FCB_MAGIC=0xc0ffeeee
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
# CONFIG_TEST_USERSPACE is not set
CONFIG_TEST_LOGGING_FLUSH_AFTER_TEST=y
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# end of Sub Systems and OS Services
CONFIG_TOOLCHAIN_GNUARMEMB=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
CONFIG_USE_DT_CODE_PARTITION=y
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_KERNEL_ENTRY="__start"
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
CONFIG_SRAM_OFFSET=0
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
# end of Linker Sections
# end of Linker Options
# Compiler Options
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_NATIVE_APPLICATION is not set
# CONFIG_SIZE_OPTIMIZATIONS is not set
# CONFIG_SPEED_OPTIMIZATIONS is not set
CONFIG_DEBUG_OPTIMIZATIONS=y
# CONFIG_NO_OPTIMIZATIONS is not set
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
CONFIG_OUTPUT_DISASSEMBLY=y
# CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
CONFIG_BUILD_OUTPUT_META=y
# CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
# end of Build Options
CONFIG_EXPERIMENTAL=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_SIGNATURE_KEY_FILE=""
CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
# CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
# CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_COMPAT_INCLUDES=y
# end of Compatibility
# end of Zephyr Kernel
# CONFIG_APPLICATION_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_APPLICATION_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_APPLICATION_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_APPLICATION_MODULE_LOG_LEVEL_INF is not set
CONFIG_APPLICATION_MODULE_LOG_LEVEL_DBG=y
CONFIG_APPLICATION_MODULE_LOG_LEVEL=4
This is my .config file
