I'm implementing QSPI using nRF52840 and MT29F8G01ADAFD12.
- SDK version : 17.1.0
- Soft device : s140 7.2.0
I'm wondering about custom instruction.
I'm implementing reading the ID of device.
void QspiMemory_init(void){
nrf_drv_qspi_config_t config = NRF_DRV_QSPI_DEFAULT_CONFIG;
uint8_t temporary = 0x00;
uint32_t err_code;
nrf_qspi_cinstr_conf_t cinstr_cfg = {
.opcode = MT29F_RESET,
.length = NRF_QSPI_CINSTR_LEN_1B,
.io2_level = false,
.io3_level = false,
.wipwait = true,
.wren = true
err_code = nrf_drv_qspi_init(&config, qspi_handler, NULL);
// Send reset enable
//err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, NULL);
//APP_ERROR_CHECK(err_code);
cinstr_cfg.opcode = MT29F_READ_ID;
cinstr_cfg.length = NRF_QSPI_CINSTR_LEN_3B;
err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, m_buffer_rx);
I implemented the code like this, but the data was not read.
In datasheet, for reading device's id, enter opcode(READ_ID) + dummy byte.
How can i send dummy byte?
I also run this code for sending dummy byte.
err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, &dummy, m_buffer_rx);
My question is
- Is it right to use nrf_drv_qspi_cinstr_xfer(..., &dummy, ...)to transmit dummy data?
- Does NRF_QSPI_CINSTR_LEN_4B mean length of frame?
(Should I set the length to NRF_QSPI_CINSTR_LEN_4B(opcode + dummy + manufacture id + device id)?
This is my schematic.
Youngjun.
