We have installed latest NRF Mesh Android application.(3.2.4)
We were unable to find few menu's visible in the latest application.
Please can you help us to find out the menu's mentioned in the image given below.
Thanks
Sam
Thanks
Sam
Hi again Hung,
Finally i found that settings visible.
Are these features available in IOS Nrf mesh application also??
Yes. it's available on iOS nRF Mesh as well.
Ok.Can you please suggest where can i get details about settings we do for each menu in Nrf Mesh app for both Android/Ios.
Also when we do for Publication settings,the settings are not being saved.
Please provide any links for detailed information regarding app settings.
Hi Sam,
I think it's self explanatory.
If you want to know more about the term "Retransmit count" and so on, I would suggest to look into the Bluetooth mesh specification for example:
SAMEER said:Also when we do for Publication settings,the settings are not being saved.
Could you let me know you found this issue on Android or on iOS ? Which SDK you use on the nRF52 ? Which example you tested with and how you tested.
We faced issue in Android app(3.2.4).
We are using nRF5 Mesh SDK, v4.2.0 the mesh peripheral is a relay used for lightning and we call it as CB.
Basically we connect all the CB's to mesh network and later if the switch is pressed the command(cmd) is broadcasting via BLE and after the fist CB reached it will transfer to the other and it goes on to the all the CB's connected in the Mesh.
When we create mesh & try to apply publication settings the values not getting saved.
So if we get any document or link how to use each feature in app it would be great for us.
