We have installed latest NRF Mesh Android application.(3.2.4)
We were unable to find few menu's visible in the latest application.
Please can you help us to find out the menu's mentioned in the image given below.
Thanks
Sam
Thanks
Sam
Hi Sam,
I don't think the app would read the publication setting or store it on the phone. So, it's better to check it internally on the mesh node to see if it get that configured. When you open it on the app, it's the default value that it would display.
Could you try to add a log inside handle_config_model_publication_set() at line 1364, something like this:
__LOG(LOG_SRC_ACCESS, LOG_LEVEL_INFO, " Retrans = %x , interval = %x", publish_retransmit.count,publish_retransmit.interval_steps);
We may be able to check if it's actually got written by the app or not.
Also please consider to move to the latest nRF5 Mesh SDK (v5.0) or to nRF Connect SDk if possible.
I have experienced this issue in 2019, but the app supposed to fix this problem a few year back.
Hi Hung,
What is the actual meaning of Interval and Retransmission Count parameters done in Publication Settings.
As per my understanding Interval means time between messages sent from Tansmitter to Receiver,is my understanding correct?
I dint find any difference when i change the values of Inetrval parameter.
Could you please give more details regarding the parameters Interval and Retransmission count.
Hello Sam, I will be taking over this case for now.
The retransmission interval is the time between the retransmissions. You can find this description of it right after the one on Publish Retransmit Count that Hung sent you in the spec. I would recommend taking a look at the Mesh Spec for these questions, as it does a very good job of explaining the entirety of how Mesh works.
Here is an illustration of the difference between the two.
Elfving
Hello Elfving,
We are sending mesh data between two devices with some random information. Also we are using nRF52840-DK board as sniffer.
When data packets are analyzed in Wireshark, we are unable to see the random message we sent between two devices.
Could you please help us on this analysis of mesh data using sniffer ?
Are you not able to see the message, or the random information? If the issue is seeing the messages at all, then are you using a filter?
If the issue is seeing the specific information, I am not sure if it is possible to insert the application and net keys of the mesh network in wireshark. In any case, that is what you would need to do.
Elfving
