OpenThread crashes on 5340
Basic OpenThread application built for 5340 crashes in net app.
The same application works fine on 21540 (52840 + 21540)
The crash seems to happen when some thread packet is received. If I turn off all other thread transmitters, the crash doesn't happen.
Details:
I: [N] Mle-----------: Role detached -> child
I:   Local IPv6 = Origin:SLACC * fd11:22:0:0:8f99:b944:f28f:617b
E: No response within timeout 500
ASSERTION FAIL @ WEST_TOPDIR/zephyr/drivers/ieee802154/ieee802154_nrf5.c:1149
    802.15.4 serialization error
E: r0/a1:  0x00000004  r1/a2:  0x0000047d  r2/a3:  0x00000001
E: r3/a4:  0x00011cc9 r12/ip:  0xa0000000 r14/lr:  0x000180af
E:  xpsr:  0x41000000
E: Faulting instruction address (r15/pc): 0x00058b1e
E: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
E: Current thread: 0x200035b8 (openthread)
E: Resetting
    Is the OpenThread sample one of the samples in our SDK or based on one of them, and if so, which one?
    Does it happen when receiving specific packets, or just when receiving packets in general?
    Please try enabling logs from the serialization module (CONFIG_NRF_802154_SER_LOG=y), since that is where the assert happens.
    Marte
  • Started with an OpenThread sample but have made a lot of changes.  Doesn't seem to matter what the config is (I have taken everything out beside openthread with the same results).  Sometimes it works for a bit, but mostly it gets in to this crash loop eventually.
    Sending spinel frame
        data: 0x80 0x03 0x8d 0x78 0x43 0x98
        data_address: 0x20029af0
    Received spinel frame
        data: 0x80 0x06 0x00 0x00
        data_address: 0x20070814
    Received response for status_ok_await
        status: OK
    Calling nrf_802154_ack_data_clear
        p_addr: 0x00 0x98
        p_addr_address: 0x20029bf4
        extended: false
        data: 0x80 0x03 0xa1 0x78 0x02 0x00 0x00 0x98 0x01
        data_address: 0x20029a78
        data: 0x80 0x06 0xa1 0x78 0x00
        data_address: 0x20070a14
    Received response for net_generic_bool_response_await
        net response: false
        p_addr: 0xd4 0xb6 0x3e 0x7b 0xe4 0xa0 0xd5 0xca
        p_addr_address: 0x20029bf8
        extended: true
        data: 0x80 0x03 0xa1 0x78 0x08 0x00 0xd4 0xb6 0x3e 0x7b 0xe4 0xa0 0xd5 0xca 0x01
        data_address: 0x20070c14
        net response: false
    Calling nrf_802154_receive_at_cancel
        data: 0x80 0x03 0xa8 0x78 0x00 0x00 0x00 0x00
        data_address: 0x20029a90
        data: 0x80 0x06 0xa8 0x78 0x00
        data_address: 0x20070e14
        net response: false
        data: 0x80 0x03 0xa8 0x78 0x01 0x00 0x00 0x00
        data_address: 0x20071014
        net response: false
    Calling nrf_802154_csl_writer_period_set
        data: 0x80 0x03 0xac 0x78 0x00 0x00
    E: r3/a4:  0x00011e61 r12/ip:  0xa0000000 r14/lr:  0x0001960f
    E:  xpsr:  0x41000000
    E: Faulting instruction address (r15/pc): 0x00055d58
    Which version of nRF Connect SDK are you using? How are you building and programming the application?
    Marte
  • 2.0.1.  Using regular west build and west flash methods
    Are you running a custom application on the network core as well, or are you running the nRF IEEE 802.15.4: Serialization RPMsg sample?
    Marte
