OpenThread crashes on 5340
Basic OpenThread application built for 5340 crashes in net app.
The same application works fine on 21540 (52840 + 21540)
The crash seems to happen when some thread packet is received. If I turn off all other thread transmitters, the crash doesn't happen.
Details:
I: [N] Mle-----------: Role detached -> child
I:   Local IPv6 = Origin:SLACC * fd11:22:0:0:8f99:b944:f28f:617b
E: No response within timeout 500
ASSERTION FAIL @ WEST_TOPDIR/zephyr/drivers/ieee802154/ieee802154_nrf5.c:1149
    802.15.4 serialization error
E: r0/a1:  0x00000004  r1/a2:  0x0000047d  r2/a3:  0x00000001
E: r3/a4:  0x00011cc9 r12/ip:  0xa0000000 r14/lr:  0x000180af
E:  xpsr:  0x41000000
E: Faulting instruction address (r15/pc): 0x00058b1e
E: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
E: Current thread: 0x200035b8 (openthread)
E: Resetting
  • When I flash merged_domains.hex to the 5340 is when I see the failure.  See log below for the *failing* case.  When I flash merged_domains.hex from the CLI sample, and then flash just the AP processor with my application things work OK.  There must be some difference in the network app?  How do I find that?
    -- west flash: using runner nrfjprog
    Using board 1050007064
    -- runners.nrfjprog: Recovering and erasing flash memory for both the network and application cores.
    Recovering device. This operation might take 30s.
    Writing image to disable ap protect.
    Erasing user code and UICR flash areas.
    -- runners.nrfjprog: Flashing file: /Users/bdodge/Mead/threadcpu/build_5340/zephyr/merged_domains.hex
    -- runners.nrfjprog: /Users/bdodge/Mead/threadcpu/build_5340/zephyr/merged_domains.hex targets both nRF53 coprocessors; splitting it into: /Users/bdodge/Mead/threadcpu/build_5340/zephyr/GENERATED_CP_NETWORK_merged_domains.hex and /Users/bdodge/Mead/threadcpu/build_5340/zephyr/GENERATED_CP_APPLICATION_merged_domains.hex
    Parsing image file.
    Verifying programming.
    Verified OK.
    Parsing image file.
    Verified OK.
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 1050007064 flashed successfully.
    Is it possible for you to upload your project here so I can test on my side? If you do not want to share it publicly I can make the ticket private. In that case let me know.
    If you look in your build directory you should have a directory named "802154_rpmsg". This is the build directory for the network core application. One thing you can do is to compare the 802154_rpmsg/zephyr/.config file in both projects, to check whether the same configurations are set. Another thing is if you do a pristine build, look for when the network core application is built, and see if the same files are used in the build. You should be able to find it by looking for the following line in the build output:
    === child image 802154_rpmsg - CPUNET begin ===
    Marte
  • Thanks,  It turned out there was one critical difference in the .config
    < # CONFIG_NRF_802154_ENCRYPTION is not set
    > CONFIG_NRF_802154_ENCRYPTION=y
    I haven't figured out why it is not set in my build.  In the build output for CPUNET I see
    NRF_802154_ENCRYPTION_ENABLED=1
    but that is not the same thing?
    I can force it by adding
        -D802154_rpmsg_CONFIG_NRF_802154_ENCRYPTION=y
    To my build command line and that resolves that diff in the .config, and my build now works on the 5340dk
    I will try and figure out what is in my prj.conf that is turning that off, but at first look there is nothing in there I don't need for my project.
    In the CLI sample this is set in the configuration for the child image. If you look at the sample you will see there is a directory called child_image with the file 802154_rpmsg.conf where this is set. You can add the child image directory and 802154_rpmsg.conf with CONFIG_NRF_802154_ENCRYPTION=y in your project as well.
    Marte
