USB cannot be used as an audio source for nRF5340 Audio on mac
Hi support team, I hope you're well
I cannot test nRF5340 audio sample using MacBook as a sound source due to an unknown USB issue.
When I run a sample in BIS mode and select "nRF5340 USB Audio" as the sound output device, after a short connection with a headset the board turns red and stops any transmission.
When I run a sample in CIS mode, I can hear a sound output from two connected "headset" devices, but the playback speed is extremely slow... Around 3 times slower than it should be. It actually slows down my MacBook play speed (you can see seconds in Spotify increasing slower, as well as YouTube videos barely playing).
It looks like an USB configuration issue to me. Is there anything I should change in order to make it work on MacOS? Couldn't find anything on USB configuration in the docs.
MacOS version: Monterey, 12.5.1
I didn't find UART Logs of the crash particularly useful, but here it is:
<wrn> bt_hci_core: opcode 0x2061 status 0x0c
GW [00:00:58.869,689] <wrn> audio_system: Failed to get last filled block
GW [00:00:58.869,689] <err> os: ***** BUS FAULT *****
GW [00:00:58.869,689] <err> os: Precise data bus error
GW [00:00:58.869,689] <err> os: BFAR Address: 0x713d9
GW [00:00:58.869,720] <err> os: r0/a1: 0x20000238 r1/a2: 0x2000ee34 r2/a3: 0x20003f3c
GW [00:00:58.869,720] <err> os: r3/a4: 0x000713d9 r12/ip: 0x00000000 r14/lr: 0x000445b1
GW [00:00:58.869,720] <err> os: xpsr: 0x21100000
GW [00:00:58.869,750] <err> os: s[ 0]: 0x00000000 s[ 1]: 0x00000000 s[ 2]: 0x00000000 s[ 3]: 0x00000000
GW [00:00:58.869,750] <err> os: s[ 4]: 0x00000000 s[ 5]: 0x00000000 s[ 6]: 0x00000000 s[ 7]: 0x00000000
GW [00:00:58.869,750] <err> os: s[ 8]: 0x00000000 s[ 9]: 0x00000000 s[10]: 0x00000000 s[11]: 0x00000000
GW [00:00:58.869,781] <err> os: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000000 s[15]: 0x00000000
GW [00:00:58.869,781] <err> os: fpscr: 0x2000eea8
GW [00:00:58.869,781] <err> os: Faulting instruction address (r15/pc): 0x000445b8
GW [00:00:58.869,812] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
GW [00:00:58.869,812] <err> os: Current thread: 0x20001750 (ENCODER)
GW [00:00:58.869,812] <err> error_handler: Caught system error -- reason 0. Entering infinite loop
Many thanks,
Warm Regards,
Pavel
