pc_ble_driver_py issue with Multi notification per message
Hi All,
I have the same issue than in this thread : pc-ble-driver-py missing high-rate notifications
To explain fastly, I am using the pc_ble_driver_py v0.15.0, with a nrf52840 Dongle to try catching voice sent by a device which should send aroud 5 notification of 20 bytes per connection slots.
On my software I only gets 1 notification per connection slots though if I try on nrf Connect Desktop I can see all the notification are being received (with the same dongle).
Do you know what is missing on my software code (I tried to add the last answer of the linked thread but it did not work)
Should I update my pc_ble_driver version (is it solved on new versions?)?
Thank you,
Sylvain
    Could you post your application code? Since nRF Connect for Desktop is also based on pc-ble-driver(-js), it should be possible to get it working with the Python version as well. There could be some wrong configs, etc. Not easy to see what is missing in your code without having a look at your code.
    I can't see anything in the changelogs that indicate that such a problem should be fixed in later versions, but you could try to update the pc-ble-driver-py version if you want.
    Jørgen
  • import sys
    # Test to use local customized version of pc-ble-driver-py...
    # Don't know how to do so for now, I just:
    #   pip install pc-ble-driver-py
    #   then directly motified the files in C:\Python38\Lib\site-packages\pc_ble_driver_py ...
    #sys.path.insert(0, "./pc-ble-driver-py")
    #import pc_ble_driver_py
    #print("TEST : {}".format(pc_ble_driver_py.__file__))
    import time
    from datetime import datetime
    import logging
    import re
    import json
    import os
    import queue
    from traceback import print_tb
    from pc_ble_driver_py.observers import (BLEDriverObserver, BLEAdapterObserver, gen_conn_params_str)
    import threading
    import tkinter as tk
    from tkinter.scrolledtext import ScrolledText
    from tkinter.ttk import Treeview
    import wave, struct
    import winsound
    import numpy as np
    import scipy
    import scipy.io.wavfile
    import scipy.fftpack
    VERSION = "V0.0.7"
    logger = logging.getLogger(__name__)
    # https://docs.python.org/3/library/logging.html#logging-levels
    LOGGING_LEVEL_TEST_RESULT_SUCCESS = 25
    LOGGING_LEVEL_TEST_RESULT_FAILURE = 26
    logging.addLevelName(LOGGING_LEVEL_TEST_RESULT_SUCCESS, "TEST_RESULT_SUCCESS")
    logging.addLevelName(LOGGING_LEVEL_TEST_RESULT_FAILURE, "TEST_RESULT_FAILURE")
    # Load configuration
    CONFIG = {}
    try:
        with open(sys.argv[1] if len(sys.argv) == 2 else 'config.json') as config_file:
            CONFIG = json.load(config_file)
    except:
        pass
    # Preparing test results logging
    test_results_file = CONFIG.get("test_results_file", "")
    if test_results_file == "automatic":
        TEST_RESULTS_FOLDER = './test_results'
        if not os.path.isdir(TEST_RESULTS_FOLDER):
            os.makedirs(TEST_RESULTS_FOLDER)
        test_results_file = datetime.now().strftime(TEST_RESULTS_FOLDER + "/%Y%m%d_%H%M%S.csv")
    if len(test_results_file) > 0:
        logger.debug("Saving test results to {}".format(test_results_file))
        test_results_file = open(test_results_file, "a+")
    else:
        test_results_file = None
    TARGET_DEV_NAME = "xxxxxxx"
    TARGET_FW_VERSION = "2.0"
    CFG_TAG = 1
    TARGET_KEYS = {
        "GUIDE"        : {"page":0x0C, "code": 0x8D},
        "POWER"        : {"page":0x0C, "code": 0x30},
        "1"            : {"page":0x07, "code": 0x1E},
        "2"            : {"page":0x07, "code": 0x1F},
        "3"            : {"page":0x07, "code": 0x20},
        "4"            : {"page":0x07, "code": 0x21},
        "5"            : {"page":0x07, "code": 0x22},
        "6"            : {"page":0x07, "code": 0x23},
        "7"            : {"page":0x07, "code": 0x24},
        "8"            : {"page":0x07, "code": 0x25},
        "9"            : {"page":0x07, "code": 0x26},
        "MOVIE"        : {"page":0x07, "code": 0x3F},
        "0"            : {"page":0x07, "code": 0x27},
        "TV"           : {"page":0x0C, "code": 0x89},
        "UP"           : {"page":0x0C, "code": 0x42},
        "LEFT"         : {"page":0x0C, "code": 0x44},
        "OK"           : {"page":0x0C, "code": 0x41},
        "RIGHT"        : {"page":0x0C, "code": 0x45},
        "DOWN"         : {"page":0x0C, "code": 0x43},
        "BACK"         : {"page":0x0C, "code":0x224},
        "MIC"          : {"page":0x0C, "code":0x221},
        "HOME"         : {"page":0x0C, "code":0x223},
        "NETFLIX"      : {"page":0x07, "code": 0x43},
        "VOL_P"        : {"page":0x0C, "code": 0xE9},
        "PLAY_PAUSE"   : {"page":0x0C, "code": 0xCD},
        "CH_P"         : {"page":0x0C, "code": 0x9C},
        "VOL_M"        : {"page":0x0C, "code": 0xEA},
        "MUTE"         : {"page":0x0C, "code": 0xE2},
        "CH_M"         : {"page":0x0C, "code": 0x9D},
    TARGET_KEYS_COORDINATES = {
        "GUIDE"        : {"x": 22, "y": 72, "w":40, "h":40},
        "POWER"        : {"x":125, "y": 72, "w":40, "h":40},
        "1"            : {"x": 22, "y":116, "w":40, "h":40},
        "2"            : {"x": 72, "y":116, "w":40, "h":40},
        "3"            : {"x":125, "y":116, "w":40, "h":40},
        "4"            : {"x": 22, "y":161, "w":40, "h":40},
        "5"            : {"x": 72, "y":161, "w":40, "h":40},
        "6"            : {"x":125, "y":161, "w":40, "h":40},
        "7"            : {"x": 22, "y":207, "w":40, "h":40},
        "8"            : {"x": 72, "y":207, "w":40, "h":40},
        "9"            : {"x":125, "y":207, "w":40, "h":40},
        "MOVIE"        : {"x": 22, "y":252, "w":40, "h":40},
        "0"            : {"x": 72, "y":252, "w":40, "h":40},
        "TV"           : {"x":125, "y":252, "w":40, "h":40},
        "UP"           : {"x": 72, "y":295, "w":40, "h":40},
        "LEFT"         : {"x": 22, "y":347, "w":40, "h":40},
        "OK"           : {"x": 72, "y":347, "w":40, "h":40},
        "RIGHT"        : {"x":125, "y":347, "w":40, "h":40},
        "DOWN"         : {"x": 72, "y":390, "w":40, "h":40},
        "BACK"         : {"x": 22, "y":441, "w":40, "h":40},
        "MIC"          : {"x": 72, "y":441, "w":40, "h":40},
        "HOME"         : {"x":125, "y":441, "w":40, "h":40},
        "NETFLIX"      : {"x": 53, "y":492, "w":77, "h":24},
        "VOL_P"        : {"x": 22, "y":527, "w":40, "h":40},
        "PLAY_PAUSE"   : {"x": 72, "y":527, "w":40, "h":40},
        "CH_P"         : {"x":125, "y":527, "w":40, "h":40},
        "VOL_M"        : {"x": 22, "y":572, "w":40, "h":40},
        "MUTE"         : {"x": 72, "y":572, "w":40, "h":40},
        "CH_M"         : {"x":125, "y":572, "w":40, "h":40},
        "AUDIO"        : {"x": 72, "y": 72, "w":40, "h":40},
    TARGET_TEST_LIST = [*TARGET_KEYS.keys(), "AUDIO"]
    # noinspection PyGlobalUndefined
    global config, BLEDriver, BLEAdvData, BLEEvtID, BLEAdapter, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID, BLEConfigCommon, BLEConfig, BLEConfigConnGatt, BLEGapScanParams
    from pc_ble_driver_py import (config, exceptions as BLEException)
    config.__conn_ic_id__ = "NRF52"
    # noinspection PyUnresolvedReferences
    from pc_ble_driver_py.ble_driver import (
        BLEDriver,
        BLEAdvData,
        BLEEvtID,
        BLEEnableParams,
        BLEGapTimeoutSrc,
        BLEUUIDBase,
        BLEUUID,
        BLEGapScanParams,
        BLEConfigCommon,
        BLEConfig,
        BLEConfigConnGatt,
        BLEGattStatusCode,
        BLEGapRoles,
        BLEGapConnParams,
        BLEConfigConnGap,
    from pc_ble_driver_py.ble_adapter import BLEAdapter
    global nrf_sd_ble_api_ver
    nrf_sd_ble_api_ver = config.sd_api_ver_get()
    HID_BASE_UUID = BLEUUID(0x2A4D)
    BATTERY_UUID = BLEUUID(0x2A19)
    ATVV_BASE_UUID = BLEUUIDBase([0xAB, 0x5E, 0x00, 0x01, 0x5A, 0x21, 0x4F, 0x05, 0xBC, 0x7D, 0xAF, 0x01, 0xF6, 0x17, 0xB6, 0x64])
    ATVV_TX_CHAR = BLEUUID(0x0002, ATVV_BASE_UUID)
    ATVV_RX_CHAR = BLEUUID(0x0003, ATVV_BASE_UUID)
    ATVV_CTL_CHAR = BLEUUID(0x0004, ATVV_BASE_UUID)
    ATVV_FREQUENCY = 8000
    def wav_frequency_peak(filename):
        # Get signal data
        Fs, signal = scipy.io.wavfile.read(filename)
        N = signal.shape[0]
        Ts = 1.0 / Fs
        # Compute signal FFT
        FFT = abs(scipy.fft.fft(signal))
        FFT_side = FFT[range(N // 2)]
        # Compute corresponding FFT frequency scale
        freqs = scipy.fftpack.fftfreq(signal.size, Ts)
        freqs_side = freqs[range(N // 2)]
        # Keep only frequency > 50Hz
        freqs_side = freqs_side[freqs_side > 50]
        FFT_side = FFT_side[-len(freqs_side):]
        # Find peak
        peak_idx = np.where(FFT_side == max(FFT_side))
        peak_frequency = max(freqs_side[peak_idx])
        return peak_frequency
    from serial.tools.list_ports import comports
    def serial_ports(vendor_id: int = None, product_id: int = None):
        return [port.device for port in comports()
                if ((vendor_id is None or vendor_id == port.vid) and
                    (product_id is None or product_id == port.pid))]
    class ADPCMDecoder:
        STEPSIZE_LUT = [
            7,      8,      9,      10,     11,     12,     13,     14,     16,     17,     19,     21,     23,     25,     28,     31,
            34,     37,     41,     45,     50,     55,     60,     66,     73,     80,     88,     97,     107,    118,    130,    143,
            157,    173,    190,    209,    230,    253,    279,    307,    337,    371,    408,    449,    494,    544,    598,    658,
            724,    796,    876,    963,    1060,   1166,   1282,   1411,   1552,   1707,   1878,   2066,   2272,   2499,   2749,   3024,
            3327,   3660,   4026,   4428,   4871,   5358,   5894,   6484,   7132,   7845,   8630,   9493,   10442,  11487,  12635,  13899,
            15289,  16818,  18500,  20350,  22385,  24623,  27086,  29794,  32767,
        INDEX_LUT = [
            -1, -1, -1, -1, 2, 4, 6, 8,
        @staticmethod
        def clamp(sample):
            sample = sample if sample < 32767 else 32767
            sample = sample if sample > -32767 else -32767
            return sample
        def __init__(self):
            self.audio_frame = []
            self.audio_pcm_frame_num = 0
        @staticmethod
        def decode_frame(adpcm):
            siDec = adpcm[2]
            if siDec & 0x80:
                siDec = (siDec - 256)
            pvDec = ((adpcm[0] << 8) | adpcm[1])
            if pvDec & 0x8000:
                pvDec = (pvDec - 65536)
            def decode_nibble(nibble):
                nonlocal siDec
                nonlocal pvDec
                step = ADPCMDecoder.STEPSIZE_LUT[siDec]
                cumDiff = (step >> 3)
                siDec += ADPCMDecoder.INDEX_LUT[nibble]
                if siDec < 0:
                    siDec = 0
                elif siDec >= len(ADPCMDecoder.STEPSIZE_LUT):
                    siDec = (len(ADPCMDecoder.STEPSIZE_LUT) - 1)
                if (nibble & 4) != 0:
                    cumDiff += step
                if (nibble & 2) != 0:
                    cumDiff += (step >> 1)
                if (nibble & 1) != 0:
                    cumDiff += (step >> 2)
                if (nibble & 8) != 0:
                    if pvDec < (cumDiff - 32767):
                        pvDec = -32767
                    else:
                        pvDec -= cumDiff
                else:
                    if pvDec > (32767 - cumDiff):
                        pvDec = 32767
                    else:
                        pvDec += cumDiff
                return ADPCMDecoder.clamp(pvDec)
            pcm = []
            i = 3
            while i < len(adpcm):
                pcm.append(decode_nibble(adpcm[i] >> 4))
                pcm.append(decode_nibble(adpcm[i] & 0x0F))
                i = i + 1
            return pcm
        def feed(self, data):
            pcm = None
            if len(self.audio_frame) >= 128:
            self.audio_frame.extend(data)
            print("len data : {}, len audio_frame : {}".format(len(data), len(self.audio_frame)))
            if len(data) <= 20:
                if len(self.audio_frame) == 128:
                    pcm = ADPCMDecoder.decode_frame(self.audio_frame[3:])
                    self.audio_pcm_frame_num += 1
                    print(self.audio_pcm_frame_num)
            if len(data) < 20:
                if len(self.audio_frame) == 134:
                    pcm = ADPCMDecoder.decode_frame(self.audio_frame)
            if len(self.audio_frame) >= 134:
            return pcm
    class BLE(BLEDriverObserver, BLEAdapterObserver):
        def __init__(self, gui, port = None):
            super(BLE, self).__init__()
            self.gui = gui
            self.gui.set_ble(self)
            if port == None:
                ports = BLEDriver.enum_serial_ports() # This is bugged
                if len(ports) <= 0:
                    ports = serial_ports(0x1915, 0xC00A)
                    if len(ports) > 0:
                        port = ports[0]
                else:
                    port = ports[0].port
            if port == None:
                raise IOError("BLE dongle serial port not found !")
            self.gui.set_port(port)
            self.conn_q = queue.Queue(maxsize=1) # Used to sync connection event
            self.adpcm_decoder = None
            self.scanned_devices = {}
            self.pressed_keys = {
                "KBRD" : [],
                "CSMR" : [],
            self.adapter = BLEAdapter(BLEDriver(serial_port=port, auto_flash=False, baud_rate=1000000, log_severity_level="info"))
            self.adapter.observer_register(self)
            self.adapter.driver.observer_register(self)
            self.adapter.driver.open()
            gatt_cfg = BLEConfigConnGatt()
            gatt_cfg.att_mtu = 250
            gatt_cfg.tag = CFG_TAG
            self.adapter.driver.ble_cfg_set(BLEConfig.conn_gatt, gatt_cfg)
            conn_cfg = BLEConfigConnGap()
            conn_cfg.conn_count = 1
            conn_cfg.event_length = 320
            self.adapter.driver.ble_cfg_set(BLEConfig.conn_gap, conn_cfg)
            self.adapter.driver.ble_enable()
            self.adapter.driver.ble_vs_uuid_add(ATVV_BASE_UUID)
        def start_scan(self):
            self.adapter.driver.ble_gap_scan_start(scan_params=BLEGapScanParams(interval_ms=200, window_ms=150, timeout_s=0))
        def stop_scan(self):
            self.adapter.driver.ble_gap_scan_stop()
        def disconnect(self, conn):
            self.adapter.disconnect(conn)
        def connect(self, mac, on_connected = None):
            def connection_thread(dev, on_connected):
                conn = None
                self.adapter.connect(dev["addr"], scan_params=BLEGapScanParams(interval_ms=200, window_ms=150, timeout_s=5), conn_params=BLEGapConnParams(7.5, 7.5, 1500, 0), tag=CFG_TAG)
                try:
                    conn = self.conn_q.get(timeout=5)
                except queue.Empty:
                    pass
                if on_connected is not None:
                    on_connected(dev, conn)
            thread = threading.Thread(target=connection_thread, args=(self.scanned_devices[mac], on_connected))
            thread.isDaemon = True
            thread.start()
        def configure_device(self, conn, on_configured):
            self.pressed_keys["KBRD"] = []
            self.pressed_keys["CSMR"] = []
            def configuration_thread(conn, on_configured):
                try:
                    self.adapter.service_discovery(conn)
                    for s in self.adapter.db_conns[conn].services:
                        logger.debug(str(s))
                        for c in s.chars :
                            logger.debug(str(c))
                except BLEException.NordicSemiException as err:
                    if on_configured is not None:
                        on_configured(conn, "Couldn't discover services : {}".format(err))
                try:
                    self.adapter.authenticate(conn, _role=BLEGapRoles.central)
                        on_configured(conn, "Couldn't pair : {}".format(err))
                try:
                    self.adapter.enable_notification(conn, HID_BASE_UUID, attr_handle=0x2C)
                    self.adapter.enable_notification(conn, HID_BASE_UUID, attr_handle=0x30)
                    self.adapter.enable_notification(conn, ATVV_RX_CHAR)
                    self.adapter.enable_notification(conn, ATVV_CTL_CHAR)
                    self.adapter.write_cmd(conn, ATVV_TX_CHAR, [0x0A, 0x01, 0x00, 0x00, 0x03, 0x01])  # Request capacity
                        on_configured(conn, "Couldn't enable notifications : {}".format(err))
                    on_configured(conn)
            thread = threading.Thread(target=configuration_thread, args=(conn, on_configured))
            thread.start()
        def get_device_fw_version(self, conn):
            status_code, value = self.adapter.read_req(conn, BLEUUID(0x2A26))
            if value is None:
                logger.error("Couldn't read device firmware version : {}".format(status_code))
            else:
                value = "".join(chr(e) for e in value)
            return value
        def on_gap_evt_connected(self, ble_driver, conn_handle, peer_addr, role, conn_params):
            logger.debug("New connection: {}".format(conn_handle))
            self.conn_q.put(conn_handle)
        def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
            try:
                self.conn_q.get_nowait()
            except:
                pass
            self.gui.on_disconnected(reason)
        def on_gap_evt_adv_report(self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data):
            if BLEAdvData.Types.complete_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
            elif BLEAdvData.Types.short_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
            else:
                dev_name_list = []
            name = "".join(chr(e) for e in dev_name_list)
            mac = "".join("{0:02X}:".format(b) for b in peer_addr.addr)[:-1]
            self.scanned_devices[mac] = {"name": name, "mac" : mac, "addr": peer_addr, "rssi": rssi}
            self.gui.on_scanned(self.scanned_devices)
        def start_voice(self, conn, from_gui=False):
            try:
                logger.info("Starting voice")
                self.adpcm_decoder = ADPCMDecoder()
                self.adapter.write_cmd(conn, ATVV_TX_CHAR, [0x0C, 0x01], attr_handle=0x1B)
                self.cnt = 0
            except:
                return False
            return True
        def stop_voice(self, conn):
            try:
                logger.info("Stopping voice")
                self.adapter.write_cmd(conn, ATVV_TX_CHAR, [0x0D], attr_handle=0x1B)
            except:
                return False
            return True
        def on_notification_handle(self, ble_adapter, conn_handle, uuid, attr_handle, data):
            if uuid == HID_BASE_UUID:
                keys = []
                page_name = "KBRD"
                page_code = 0x07
                if attr_handle == 0x30:
                    data = [(data[0] | ((data[1] & 0xF) << 8)), (((data[1] & 0xF0) >> 4) | (data[2] << 4))]
                    page_name = "CSMR"
                    page_code = 0x0C
                for k in data:
                    if k:
                        for label, value in TARGET_KEYS.items():
                            if value["page"] == page_code and value["code"] == k:
                                keys.append(label)
                for k in self.pressed_keys[page_name]:
                    if not k in keys:
                        self.gui.on_key_released(conn_handle, k)
                        self.pressed_keys[page_name].remove(k)
                for k in keys:
                    if not k in self.pressed_keys[page_name]:
                        self.gui.on_key_pressed(conn_handle, k)
                        self.pressed_keys[page_name].append(k)
            elif uuid == ATVV_RX_CHAR:
                self.cnt += 1
                logger.debug(str(self.cnt))
                if data is not []:
                    self.voice_received(conn_handle, data)
            elif uuid == ATVV_CTL_CHAR:
                logger.debug("CTL : {}".format(' '.join('{:02X}'.format(b) for b in data)))
                if data == [0]:
                 self.gui.on_key_released(conn_handle, "MIC", False)
            elif uuid == BATTERY_UUID:
                logger.debug("Battery level : {}".format(data[0]))
            else:
                logger.warning("Unknow notification : {} {}".format(uuid, data))
        def voice_received(self, conn, data):
            if self.adpcm_decoder:
                pcm = self.adpcm_decoder.feed(data)
                if pcm is not None:
                    self.gui.on_audio_received(conn, pcm)
        def on_indication(self, ble_adapter, conn_handle, uuid, char_handle, data):
            logger.debug("Indication: {}, {} ({}) = {}".format(conn_handle, uuid, char_handle, data))
        def on_conn_param_update_request(self, ble_adapter, conn_handle, conn_params):
            logger.debug("Conn param update request: {}\n Params({})".format(conn_handle, gen_conn_params_str(conn_params)))
        def stop(self):
            self.adapter.driver.close()
    class GUI():
        class LoggingQueueHandler(logging.Handler):
            def __init__(self, st):
                super().__init__()
                self.log_queue = queue.Queue()
                self.st = st
                self.window = st
                while self.window.master is not None:
                    self.window = self.window.master
                self.window.after(50, self.poll_log_queue)
            def emit(self, record):
                self.log_queue.put(record)
            def poll_log_queue(self):
                while True:
                    try:
                        record = self.log_queue.get(block=False)
                    except queue.Empty:
                        break
                    else:
                        self.display_log(record)
            def display_log(self, record):
                msg = self.format(record)
                scroll = self.st.bbox("end-1c") is not None
                self.st.configure(state='normal')
                self.st.insert(tk.END, msg + '\n', record.levelname)
                self.st.update_idletasks()
                self.st.configure(state='disabled')
                if scroll or CONFIG.get("force_logs_autoscroll", False):
                    self.st.yview(tk.END)
        def __init__(self):
            self.ble = None
            self.tested_devices = []
            self.current_tested_device = None
            self.audio_data = None
            self.test_list = None
            self.clicked_keys = {}
            self.window = tk.Tk()
            self.window.title("BLE Test {} ({})".format(TARGET_DEV_NAME, VERSION))
            self.window.grid_rowconfigure(0, weight=1)
            self.window.grid_columnconfigure(0, weight=1)
            self.state_panel = tk.Frame(self.window)
            self.state_panel.grid(row=0, column=0, sticky=(tk.N + tk.E + tk.W + tk.S))
            self.state_panel.grid_rowconfigure(0, weight=1)
            self.state_panel.grid_columnconfigure(0, weight=1)
            self.state_panel.rowconfigure(0, weight=1)
            self.state_panel.columnconfigure(0, weight=1)
            # Setup GUI logging
            st = ScrolledText(self.state_panel, state='disabled')
            st.configure(font='TkFixedFont')
            st.tag_config('INFO', foreground='black')
            st.tag_config('DEBUG', foreground='gray')
            st.tag_config('WARNING', foreground='orange')
            st.tag_config('ERROR', foreground='red')
            st.tag_config('CRITICAL', foreground='red', underline=1)
            st.tag_config('TEST_RESULT_SUCCESS', background='green', font=("TkFixedFont", 16))
            st.tag_config('TEST_RESULT_FAILURE', background='red', font=("TkFixedFont", 16))
            st.grid(row=0, column=0, sticky=(tk.N + tk.E + tk.W + tk.S))
            self.logging_handler = GUI.LoggingQueueHandler(st)
            self.logging_handler.setFormatter(logging.Formatter('%(asctime)s: %(message)s'))
            logger.addHandler(self.logging_handler)
            logging.getLogger("pc_ble_driver_py.observers").addHandler(self.logging_handler)
            logging.getLogger("pc_ble_driver_py.ble_adapter").addHandler(self.logging_handler)
            logger.debug(CONFIG)
            self.status_label = tk.Label(self.state_panel, text="")
            self.set_status("Initializing...")
            # DUT panel
            self.dut_panel = tk.Frame(self.window)
            self.devices_treeview = Treeview(self.window)
            self.devices_treeview["columns"] = ("name", "rssi")
            self.devices_treeview.column("#0", width=120, minwidth=120, stretch=tk.NO)
            self.devices_treeview.column("name", width=150, minwidth=150)
            self.devices_treeview.column("rssi", width=45, minwidth=45, stretch=tk.NO)
            self.devices_treeview.heading("#0", text="MAC")
            self.devices_treeview.heading("name", text="Name")
            self.devices_treeview.heading("rssi", text="RSSI")
            self.devices_treeview.bind("<<TreeviewSelect>>", self.on_device_selected)
            self.devices_treeview.grid(row=0, column=1, sticky=(tk.N + tk.S))
            self.fw_version_label = tk.Label(self.dut_panel, text="FW Version : {}".format("UNKNOW"))
            self.fw_version_label.grid(row=0, column=0)
            self.remote_img = tk.PhotoImage(file="xxxxx.png") # We must keep a reference for some reason
            self.remote_canvas = tk.Canvas(self.dut_panel, width=self.remote_img.width(), height=self.remote_img.height())
            self.remote_canvas.create_image((0, 0), image=self.remote_img, anchor=tk.NW)
            self.remote_canvas.grid(row=1, column=0)
            #self.dut_panel.grid(row=0, column=1)
        def set_status(self, status):
            logger.info(status)
            self.status_label["text"] = status
            self.status_label.grid(row=1, column=0)
        def on_device_selected(self, event):
            try:
                item = self.devices_treeview.selection()
            except IndexError as err:
                logger.error("{}".format(err))
                return
            mac = self.devices_treeview.item(item, "text")
            self.devices_treeview.delete(*self.devices_treeview.get_children())
            self.devices_treeview.grid_forget()
            self.set_status("Stopping scan...")
            self.ble.stop_scan()
            self.set_status("Connecting to {}...".format(mac))
            self.ble.connect(mac, self.on_connected)
        def mainloop(self):
            return self.window.mainloop()
        def set_ble(self, ble):
            self.ble = ble
        def set_port(self, port):
            logger.debug("Using port {}".format(port))
            self.window.title("{} ({})".format(self.window.title(), port))
        def on_configured(self, conn, error = None):
            if error is None:
                self.set_status("Device configured")
                version = self.ble.get_device_fw_version(conn)
                if version is None:
                    logger.error("Couldn't read device firmware version")
                    self.ble.disconnect(conn)
                else:
                    logger.info("FW Version : {}".format(version))
                    self.fw_version_label["text"] = "FW Version : {}".format(version)
                    if version != TARGET_FW_VERSION:
                        logger.error("Invalid firmware version : {}".format(version))
                self.test_list = TARGET_TEST_LIST.copy()
                for k in TARGET_KEYS_COORDINATES.keys():
                    self.clicked_keys[k] = 0
                self.set_status("Testing...")
            else:
                logger.error("Configuration failed : {}".format(error))
        def on_connected(self, dev, conn):
            if conn is not None:
                self.set_status("Connected to {}".format(dev["mac"]))
                self.current_tested_device = dev
                self.set_status("Configuring device...")
                self.ble.configure_device(conn, self.on_configured)
            else:
                logger.error("Couldn't connect to {}".format(dev["mac"]))
                self.set_status("Scanning...")
                self.ble.start_scan()
        def on_disconnected(self, reason):
            self.set_status("Disconnected ({})".format(reason))
            if len(self.test_list) > 0:
                self.on_test_end(False, self.current_tested_device, None)
            #winsound.PlaySound("1KHz.wav", winsound.SND_FILENAME | winsound.SND_PURGE)
            winsound.PlaySound(None, winsound.SND_PURGE)
            self.dut_panel.grid_forget()
            self.remote_canvas.delete(tk.ALL)
        SCAN_REFRESH_PERIOD_SEC = 0.5
        next_scan_refresh = 0
        def on_scanned(self, devices):
            if GUI.next_scan_refresh < time.time():
                GUI.next_scan_refresh = (time.time() + GUI.SCAN_REFRESH_PERIOD_SEC)
                for _, dev in sorted(devices.items(), key=lambda item: -item[1]["rssi"]):
                    if dev["name"] == TARGET_DEV_NAME:
                        if dev["rssi"] >= CONFIG.get("scan_rssi_threshold", float("-inf")):
                            if not (CONFIG.get("hide_successfully_tested", False) and (dev["mac"] in self.tested_devices)):
                                self.devices_treeview.insert("", tk.END, text=dev["mac"], values=(dev["name"], dev["rssi"]))
                if CONFIG.get("autoconnect_nearest", False):
                    children = self.devices_treeview.get_children()
                    if len(children) > 0:
                        self.devices_treeview.selection_set(children[0])
        def voice_end(self, conn):
            self.ble.stop_voice(conn)
        def on_key_pressed(self, conn, key):
            logger.debug("Key {} pressed".format(key))
            coord = TARGET_KEYS_COORDINATES[key]
            self.remote_canvas.create_rectangle(coord["x"], coord["y"], coord["x"] + coord["w"], coord["y"] + coord["h"], fill="yellow")
            if key == "MIC":
                #threading.Timer(7, self.voice_end, args=[conn]).start()
                self.audio_data = []
                #winsound.PlaySound("1KHz.wav", winsound.SND_FILENAME | winsound.SND_ASYNC | winsound.SND_NODEFAULT | winsound.SND_LOOP)
                self.ble.start_voice(conn)
        def on_key_released(self, conn, key, mic_state = True):
            if key == "MIC" and not mic_state:
                #self.ble.stop_voice(conn)
                #winsound.PlaySound(None, winsound.SND_PURGE)
                def save_voice_record(self, conn):
                    if (self.audio_data is None) or (len(self.audio_data) <= 0):
                        logger.warning("No audio data to save")
                        return
                    audio_file = wave.open("test.wav", "w")
                    audio_file.setnchannels(1)
                    audio_file.setsampwidth(2)
                    audio_file.setframerate(ATVV_FREQUENCY)
                    for s in self.audio_data:
                        audio_file.writeframes(struct.pack('h', ADPCMDecoder.clamp(s)))
                    audio_file.close()
                    #winsound.PlaySound("test.wav", winsound.SND_FILENAME | winsound.SND_ASYNC | winsound.SND_NODEFAULT)
                    freq_peak = wav_frequency_peak("test.wav")
                    color = "red"
                    if (freq_peak < 950) or (freq_peak > 1050):
                        logger.warning("Wrong frequency peak : {}".format(freq_peak))
                    else:
                        logger.debug("Frequency peak : {}".format(freq_peak))
                        color = "green"
                        if "AUDIO" in self.test_list:
                            self.test_list.remove("AUDIO")
                            if len(self.test_list) <= 0:
                                self.on_test_end(True, self.current_tested_device, conn)
                    coord = TARGET_KEYS_COORDINATES["AUDIO"]
                    self.remote_canvas.create_rectangle(coord["x"], coord["y"], coord["x"] + coord["w"], coord["y"] + coord["h"], fill=color)
                if self.audio_data is not None:
                    threading.Timer(0.1, save_voice_record, [self, conn]).start()
            else:
                logger.debug("Key {} released".format(key))
                COLORS = ["green", "blue", "grey", "cyan", "brown", "purple", "#404040"]
                color = COLORS[self.clicked_keys[key] % len(COLORS)]
                self.clicked_keys[key] += 1
                if key in self.test_list:
                    self.test_list.remove(key)
        def on_audio_received(self, conn, pcm):
                self.audio_data.extend(pcm)
        def on_test_end(self, success, dev=None, conn=None):
            if success:
                self.set_status("TEST SUCCESS")
                logger.log(LOGGING_LEVEL_TEST_RESULT_SUCCESS, "TEST SUCCESS")
                if dev is not None:
                    self.tested_devices.append(dev["mac"])
            else:
                self.set_status("TEST FAILURE")
                logger.log(LOGGING_LEVEL_TEST_RESULT_FAILURE, "TEST FAILURE")
            if dev is not None:
                if test_results_file is not None:
                    test_results_file.write("{};{};{}\n".format(dev["mac"], success, datetime.now().strftime("%Y/%m/%d %H:%M:%S")))
                    test_results_file.flush()
    if __name__ == "__main__":
        logging.basicConfig(
            level="DEBUG",
            format="%(asctime)s [%(thread)d/%(threadName)s] %(message)s",
        logging.getLogger("pc_ble_driver_py.observers").setLevel("INFO")
        logging.getLogger("pc_ble_driver_py.ble_adapter").setLevel("INFO")
        log_file = CONFIG.get("log_file", "")
        if log_file == "automatic":
            LOGS_FOLDER = './logs'
            if not os.path.isdir(LOGS_FOLDER):
                os.makedirs(LOGS_FOLDER)
            log_file = datetime.now().strftime(LOGS_FOLDER + "/%Y%m%d_%H%M%S.log")
        if len(log_file) > 0:
            logger.debug("Saving logs to {}".format(log_file))
            fh = logging.FileHandler(log_file)
            fh.setFormatter(logging.Formatter('%(asctime)s: %(message)s'))
            fh.setLevel(logging.DEBUG)
            logger.addHandler(fh)
            logging.getLogger("pc_ble_driver_py.observers").addHandler(fh)
            logging.getLogger("pc_ble_driver_py.ble_adapter").addHandler(fh)
        gui = GUI()
        ble = BLE(gui, CONFIG.get("com_port", None))
        gui.set_status("Scanning...")
        ble.start_scan()
        gui.mainloop()
        ble.stop()
    Thank you for your answer,
    You will find the code attached,
    Sylvain
    Can you try to increase the GATTS hvn_tx_queue_size? It looks like this is set to 1 by default.
    Jørgen
    I just tried it does not seem to improve the issue, I still have only one data every 30ms instead of seven frames in that time on nrf Connect.
    Sylvain
  • I use Python 3.8, should I use a newer version of python?
