nRF52840 UART bootload issue
I developed a firmware without softdevice for a custom board with nRF52840
I recently decided to add a bootloader to my application and I based my bootloader code from the example : secure bootloader pca10056 uart
In the bootloader code I changed main to :
	gpio_setup();
	LED_GREEN();
	nrf_bootloader_init(dfu_observer);
As I intend to stay in bootloader using retention register, I set in sdk_config.h :
#ifndef NRF_BL_DFU_ENTER_METHOD_GPREGRET
#define NRF_BL_DFU_ENTER_METHOD_GPREGRET 1
Here are my steps regarding how I flash my device/prepare my files :
1 - From my app hex I generate a bootloadable app zip
nrfutil --verbose pkg generate --hw-version 52 --application-version 1 --application app.hex --key-file private.key --sd-req 0 app.zip
2 - I generate bootloader settings for my app
nrfutil --verbose settings generate --family NRF52840 --application app.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 btl_settings.hex
3 - I merge the bootloader hex and the bootloader settings to a bundle hex
mergehex --merge btl_settings.hex btl.hex --output bundle.hex
4 - I erase my whole chip to make sure to start clean
nrfjprog -f nrf52 --eraseall
5 - I flash the mbr hex I found in "nRF5_SDK_17.1.0_ddde560\examples\dfu\secure_dfu_test_images\uart\nrf52840\mbr.hex"
nrfjprog -f nrf52 --program mbr.hex --sectorerase --verify
6 - I flash the bundle generated in step 3
nrfjprog -f nrf52 --program bundle.hex --sectorerase --verify
7 - I flash the app
nrfjprog -f nrf52 --program app.hex --sectorerase --verify
8 - hard reset my device
Output :
I can clearly see that bootloader is exited shortly after power on with the green led but it doesn't look like my app is started after the bootloader exited
Why doesn't my app start and how can I fix this issue ?
I am working with :
- SDK 17.1.0
- Latest nrf command line tools
- Latest nrfutil
  • Hi Gabriel,
    Do you get any RTT log on the bootloader side ?
    Have you tried to test the bootloader (+MBR)on the nRF52840 DK ?
    Also please use the bootloader you find in \nRF5_SDK_17.1.0_ddde560\components\softdevice\mbr\hex not in \examples\dfu\secure_dfu_test_images\uart\
  • The PC outputs a baudrate of 115473 for the UART instead of 115200, that might trouble the nRF52 so we switched to 100k baudrate
    Also I need to know what is best in the sdk config for bootload UART or UARTE ? I would say UARTE but it really depends on the nRF52 bootloader code, how is the compatibility with the easyDMA feature ?
    I can clearly see with the logic analyzer that the nRF52 gets pinged by the PC but it does not respond
    PC logs :
    >nrfutil dfu serial -pkg app.zip -p COM4 -fc false -b 100000
      [------------------------------------]    0%
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\Scripts\nrfutil-script.py", line 33, in <module>
        sys.exit(load_entry_point('nrfutil==6.1.6', 'console_scripts', 'nrfutil')())
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\lib\site-packages\click\core.py", line 1130, in __call__
        return self.main(*args, **kwargs)
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\lib\site-packages\click\core.py", line 1055, in main
        rv = self.invoke(ctx)
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\lib\site-packages\click\core.py", line 1657, in invoke
        return _process_result(sub_ctx.command.invoke(sub_ctx))
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\lib\site-packages\click\core.py", line 1404, in invoke
        return ctx.invoke(self.callback, **ctx.params)
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\lib\site-packages\click\core.py", line 760, in invoke
        return __callback(*args, **kwargs)
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\lib\site-packages\nordicsemi\__main__.py", line 1073, in serial
        do_serial(package, port, connect_delay, flow_control, packet_receipt_notification, baud_rate, serial_number, True,
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\lib\site-packages\nordicsemi\__main__.py", line 988, in do_serial
        dfu.dfu_send_images()
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\lib\site-packages\nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
        self._dfu_send_image(self.manifest.application)
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\lib\site-packages\nordicsemi\dfu\dfu.py", line 88, in _dfu_send_image
        self.dfu_transport.open()
      File "C:\Users\gat\AppData\Local\Programs\Python\Python310\lib\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 214, in open
        raise NordicSemiException("No ping response after opening COM port")
    pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
  • Hi Gabriel,
    the nRF52840 doesn't support both 115200 and 100K baud. Do you mean 1M baud ?
    Regarding your question about UART/UARTE, the bootloader code by default uses UARTE.
  • I use this value to generate a 100k baudrate :
    0x01999000
  • I set the baud rate back to 115200, I can clearly see the PC pings but the bootloader just pulls the Tx low after few pings, something is missing but I can't find what
