nrf_modem_at_cmd_async callback passes bad pointer
In my application (built with NCS v1.7.0) I use a nonblocking TCP socket for communication. The main modem thread handles sending data and a separate thread handles receiving. The pseudocode for the receive thread looks like this:
loop while socket is open
    num_bytes = recv(...)
    if num_bytes > 0
        put received bytes in ring buffer
        notify application
    sleep 10 msec
The main modem thread sends the AT%CONEVAL command every 500 msec to monitor the connection and collect data. The command is sent asynchronously using nrf_modem_at_cmd_async, and sometimes the pointer argument in the callback is invalid, which causes an exception (specifically it's a precise data bus error) if I attempt to use it. Here is an example of the callback function:
static void coneval_cb(const char *p_response)
    LOG_INF("p_response: %p", p_response);
    if (!_coneval_rxed)
        LOG_INF("CONEVAL: %s", p_response);
        strncpy(_coneval_string, p_response, sizeof(_coneval_string));
        _coneval_rxed = true;
        k_wakeup(modem_tid);
Most of the time it results in a log like this:
[00:14:01.144,927] <inf> modem: p_response: 0x200126b8
[00:14:01.144,958] <inf> modem: CONEVAL: %CONEVAL: 0,1,6,21,7,22,"005E8202","311480",109,5230,13,0,0,21,4,4,142
OK
But every once in a while it results in a log like this:
[00:14:01.481,170] <inf> modem: p_response: 0x7bd82863
[00:14:01.481,201] <err> os: ***** HARD FAULT *****
[00:14:01.481,201] <err> os:   Fault escalation (see below)
[00:14:01.481,201] <err> os: ***** BUS FAULT *****
[00:14:01.481,231] <err> os:   Precise data bus error
[00:14:01.481,231] <err> os:   BFAR Address: 0x7bd82863
[00:14:01.481,231] <err> os: r0/a1:  0x7bd82863  r1/a2:  0x00000004  r2/a3:  0x00051a5d
[00:14:01.481,262] <err> os: r3/a4:  0x7bd82863 r12/ip:  0x00035440 r14/lr:  0x000356c5
[00:14:01.481,262] <err> os:  xpsr:  0x2100002c
[00:14:01.481,262] <err> os: Faulting instruction address (r15/pc): 0x00021376
[00:14:01.481,292] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
[00:14:01.481,323] <err> os: Fault during interrupt handling
[00:14:01.481,323] <err> os: Current thread: 0x20018f00 (unknown)
So the callback function is being called with an invalid pointer. As a workaround I changed the callback function to look like this:
    if (((uint32_t)p_response >> 28) != 0x2)
        LOG_WRN("Bad coneval callback pointer: %p", p_response);
        return;
    if (!_coneval_rxed)
This merely ensures the pointer address falls within the SRAM block of the nRF9160 memory map (0x20000000). It is not a proper solution because there's no guarantee a pointer with a correct most significant nibble is a valid pointer. But this workaround at least prevents most of the exceptions. I did notice however that when an invalid pointer is passed to the callback function it happens within a few milliseconds of the socket receiving data:
[02:27:11.729,309] <wrn> modem: Bad coneval callback pointer: 0x3d772a63
[02:27:11.732,482] <inf> modem: Modem received 46 bytes
Why would my call to nrf_modem_at_cmd_async be causing a callback with an invalid pointer when data is received on my nonblocking socket? Is there an actual solution to ensure the validity of the pointer using NCS v1.7.0?
