Notification is not working
Hi, I have created two proprietary characteristics with notification property to notify some data's using these two characteristics when some event occurs. I can able to get the notification from one characteristics properly, but other characteristics is not giving the notification but i can able to read the updated value through read option in the master control panel. Suggest me to overcome this.
Regards, Balaji.
  • Hi Balaji,
    Have you make sure you set the CCCD for both characteristics to 1 ?
    You can find in many of our example we have 2 characteristics that have notify properties, such as HRM and battery level.
    Please upload your source code if issue remains.
  • Thanks for the reply Hung Bui, Yes i can see it, but, HRM and battery status are two different services, but in my case both the characteristics are in same services. Now i can able to get the notificaion properly, but need to findout the cause of the problem.
  • @Balaji: There should be no issue to implement 2 characteristics with notification in one service. Please make sure you call sd_ble_gatts_hvx() function with proper hvx_params.handle value for each characteristic. Attached is a very rough example that I modified the nRF UART example to have 2 looped TX characteristics. When you make a write on RX you will receive notifications on 2 TX.
    ble_app_uart - Looped - Copy.rar
