sd_ble_gap_tx_power_set() failed with errCode 0x3004
What is meaning of error code 0x3004?
The following is source code of calling sd_ble_gap_tx_power_set().
int _gapTxPowerSet(const int8_t txPwr) {
    ret_code_t errCode;
    errCode = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, 0, txPwr);
    if (errCode != NRF_SUCCESS) {
        NRF_LOG_WARNING("sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, 0, %d) failed, errCode=0x%x", txPwr, errCode);
        return ERROR_GAP_TX_POWER_FAIL;
    errCode = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, 0, txPwr);
        NRF_LOG_WARNING("sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, 0, %d) failed, errCode=0x%x", txPwr, errCode);
    return 0;
The following is log messages of nRF52832 device.
<warning> app: sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, 0, -20) failed, errCode=0x3004
  • #include "sdk_config.h"
    #include "ble.h"
    #include "ble_conn_params.h"
    #include "ble_gap.h"
    #include "gap.h"
    #include "error.h"
    #include "nrf_log.h"
    #define DEVICE_NAME       "ANCS4"                         /**< Name of the device. Will be included in the advertising data. */
    #define STATIC_PASSKEY    "123456"                        /**< Static passkey. */
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY     0                               /**< Slave latency. */
    #define CONN_SUP_TIMEOUT  MSEC_TO_UNITS(3000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
    #define GAP_TX_POWER      -20
    #if PEER_MANAGER_ENABLED
    static ble_opt_t _gStaticPasskeyOption;	/**< Pointer to the struct containing static pin option. */
        ret_code_t errCode;
        return 0;
    /**@brief Function for initializing GAP connection parameters.
     * @details Use this function to set up all necessary GAP (Generic Access Profile)
     *          parameters of the device. It also sets the permissions and appearance.
    int gapParamsInit(void) {
        ret_code_t              errCode;
        ble_gap_conn_params_t   gapConnParams;
        ble_gap_conn_sec_mode_t secMode;
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&secMode);
        errCode = sd_ble_gap_device_name_set(&secMode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
            NRF_LOG_WARNING("sd_ble_gap_device_name_set() failed, errCode=0x%x", errCode);
            return ERROR_GAP_INITIALIZE_FAIL;
        memset(&gapConnParams, 0, sizeof(gapConnParams));
        gapConnParams.min_conn_interval = MIN_CONN_INTERVAL;
        gapConnParams.max_conn_interval = MAX_CONN_INTERVAL;
        gapConnParams.slave_latency     = SLAVE_LATENCY;
        gapConnParams.conn_sup_timeout  = CONN_SUP_TIMEOUT;
        errCode = sd_ble_gap_ppcp_set(&gapConnParams);
            NRF_LOG_WARNING("sd_ble_gap_ppcp_set() failed, errCode=0x%x", errCode);
        uint8_t passkey[] = STATIC_PASSKEY;
    	_gStaticPasskeyOption.gap_opt.passkey.p_passkey = passkey;
    	errCode = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &_gStaticPasskeyOption);
            NRF_LOG_WARNING("sd_ble_opt_set() failed, errCode=0x%x", errCode);
        _gapTxPowerSet(GAP_TX_POWER);
        return 0;
    0x3004 here is BLE_ERROR_INVALID_ADV_HANDLE, so this means that you have provided an invalid handle value to sd_ble_gap_tx_power_set(). You call this function twice, both for a connection, and for the advertising role. For a connection, you need to pass the connection handle of an active connection. And for advertising, you need to pass the advertising set handle that you got from the call to sd_ble_gap_adv_set_configure(). From the code you have posted it does not seem like you have any of these yet, and in that case this cannot be set (it is premature).
