Kconfig.board command failed with return code: 1
I am trying to configure a visible symbol in the Kconfig.board file of my project.
This is what the Kconfig file looks like:
config BOARD_NRF52840_HUME
	bool "nRF52840 HUME"
	depends on SOC_NRF52840_QIAA
config HAS_VALENCELL
    bool "valencell sensor present"
Where the new thing I want to add is the HAS_VALENCELL.
Then in the nrf52840_defconfig file I define it like that:
CONFIG_HAS_VALENCELL=y
The error when I try to build the code is the following:
Any help on how this can be fixed or what is causing the problem would be helpful.
    It seems like your board name ''BOARD_NRF52840_HUME''. You are trying to add  HAS_VALENCELL (CONFIG_HAS_VALENCELL=y) into the deconfig file.
    What board you are building for? Could you please share your board files and full build log?
    Thanks.
    Best Regards,
    Kazi Afroza Sultana
    The board is nRF52840.
    This is the build log that I have.
    ====================[ Build | zephyr_final | ZDebug-Zephyr ]====================
    /usr/bin/cmake --build /home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr --target zephyr_final
    [0/1] Re-running CMake...
    Including boilerplate (Zephyr base (cached)): /home/svetoslav/zephyrproject/zephyr/cmake/app/boilerplate.cmake
    -- Application: /home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware
    -- Zephyr version: 2.7.1 (/home/svetoslav/zephyrproject/zephyr), build: zephyr-v2.7.1
    -- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
    -- Board: nrf52840_hume_v2r4
    -- Cache files will be written to: /home/svetoslav/.cache/zephyr
    -- Using toolchain: zephyr 0.13.1 (/home/svetoslav/zephyr-sdk-0.13.1)
    -- Found dtc: /home/svetoslav/zephyr-sdk-0.13.1/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/hume-boards/boards/arm/nrf52840_hume_v2r4/nrf52840_hume_v2r4.dts
    node '/soc/i2c@40003000/performtek@45' compatible 'valencell,performtek' has unknown vendor prefix 'valencell'
    -- Generated zephyr.dts: /home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: /home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: /home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr/zephyr/dts.cmake
    Parsing /home/svetoslav/zephyrproject/zephyr/Kconfig
    Loaded configuration '/home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/hume-boards/boards/arm/nrf52840_hume_v2r4/nrf52840_hume_v2r4_defconfig'
    Merged configuration 'prj.common.conf'
    Merged configuration 'prj.ZDebug.conf'
    No change to configuration in '/home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr/zephyr/.config'
    No change to Kconfig header in '/home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr/zephyr/include/generated/autoconf.h'
    CMake Warning at /home/svetoslav/zephyrproject/zephyr/CMakeLists.txt:730 (message):
      No SOURCES given to Zephyr library: drivers__dac
      Excluding target from build.
    CMake Warning at /home/svetoslav/zephyrproject/zephyr/CMakeLists.txt:1652 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr
    [195/202] Linking C executable zephyr/zephyr_prebuilt.elf
    FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map /home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr/zephyr/zephyr_prebuilt.map
    : && ccache /home/svetoslav/zephyr-sdk-0.13.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc   zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr/zephyr_prebuilt.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_prebuilt.cmd  -Wl,-Map=/home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr/zephyr/zephyr_prebuilt.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/newlib/liblib__libc__newlib.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/boards/boards/arm/nrf52840_hume_v2r4/lib..__..__CLionProjects__zephyr-senti-firmware__zephyr-senti-firmware__hume-boards__boards__arm__nrf52840_hume_v2r4.a  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a  zephyr/subsys/fs/libsubsys__fs.a  zephyr/subsys/mgmt/mcumgr/libsubsys__mgmt__mcumgr.a  zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a  zephyr/subsys/net/libsubsys__net.a  zephyr/drivers/adc/libdrivers__adc.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/i2c/libdrivers__i2c.a  zephyr/drivers/led/libdrivers__led.a  zephyr/drivers/pwm/libdrivers__pwm.a  zephyr/drivers/spi/libdrivers__spi.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/bluetooth/libdrivers__bluetooth.a  zephyr/drivers/timer/libdrivers__timer.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/littlefs/lib..__modules__fs__littlefs.a  modules/mcuboot/libmcuboot_util.a  modules/mcumgr/lib..__modules__lib__mcumgr.a  modules/segger/libmodules__segger.a  modules/tinycbor/lib..__modules__lib__tinycbor__zephyr.a  modules/zephyr-drivers/dac/mcp47a1_dac/lib..__..__CLionProjects__zephyr-senti-firmware__zephyr-senti-firmware__zephyr-drivers__dac__mcp47a1_dac.a  modules/zephyr-drivers/sensor/lc709205f_fuel_gauge/lib..__..__CLionProjects__zephyr-senti-firmware__zephyr-senti-firmware__zephyr-drivers__sensor__lc709205f_fuel_gauge.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/svetoslav/zephyr-sdk-0.13.1/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/thumb/v7e-m/nofp"  -L/home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -no-pie  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -lm  -Wl,-lc  -L"/home/svetoslav/zephyr-sdk-0.13.1/arm-zephyr-eabi/arm-zephyr-eabi"/lib/thumb/v7e-m/nofp  -Wl,-lgcc  -lc  -specs=nano.specs && cd /home/svetoslav/CLionProjects/zephyr-senti-firmware/zephyr-senti-firmware/cmake-build-zdebug-zephyr/zephyr && /usr/bin/cmake -E echo
    /home/svetoslav/zephyr-sdk-0.13.1/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: Undefined initialization levels used.
    /home/svetoslav/zephyr-sdk-0.13.1/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/bluetooth/libdrivers__bluetooth.a(rpmsg.c.obj): in function `bt_rpmsg_init':
    /home/svetoslav/zephyrproject/zephyr/drivers/bluetooth/hci/rpmsg.c:260: undefined reference to `bt_rpmsg_platform_init'
    /home/svetoslav/zephyr-sdk-0.13.1/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/bluetooth/libdrivers__bluetooth.a(rpmsg.c.obj): in function `bt_rpmsg_send':
    /home/svetoslav/zephyrproject/zephyr/drivers/bluetooth/hci/rpmsg.c:224: undefined reference to `bt_rpmsg_platform_send'
    /home/svetoslav/zephyr-sdk-0.13.1/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/bluetooth/libdrivers__bluetooth.a(rpmsg.c.obj): in function `bt_rpmsg_open':
    /home/svetoslav/zephyrproject/zephyr/drivers/bluetooth/hci/rpmsg.c:238: undefined reference to `bt_rpmsg_platform_endpoint_is_bound'
    collect2: error: ld returned 1 exit status
    You can see in the no:8 line of build log your board name is nrf52840_hume_v2r4.
    You have not share the board files. You can find it here:
    We also would like to know your NCS version.
    Thanks.
    Best Regards,
    Kazi Afroza Sultana
