Migrating from SDK 2.0.0 to 2.1.0, error
I'm getting the following error during migration from 2.0.0 to 2.1.0:
FAILED: zephyr/drivers/bluetooth/CMakeFiles/drivers__bluetooth.dir/hci/rpmsg.c.obj
C:\ncs\toolchains\v2.1.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -DZCBOR_ASSERT -D_FORTIFY_SOURCE=2 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -IC:/ncs/v2.1.0/zephyr/subsys/bluetooth -IC:/ncs/v2.1.0/zephyr/include/zephyr -IC:/ncs/v2.1.0/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.1.0/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/ncs/v2.1.0/zephyr/lib/libc/newlib/include -IC:/ncs/v2.1.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/include -IC:/ncs/v2.1.0/bootloader/mcuboot/boot/zephyr/include -IC:/ncs/v2.1.0/zephyr/subsys/settings/include -IC:/ncs/v2.1.0/nrf/include -IC:/ncs/v2.1.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.1.0/modules/hal/nordic/nrfx -IC:/ncs/v2.1.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.1.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.1.0/zephyr/modules/hal_nordic/nrfx/. -Imodules/libmetal/libmetal/lib/include -IC:/ncs/v2.1.0/modules/lib/open-amp/open-amp/lib/include -IC:/ncs/v2.1.0/modules/debug/segger/SEGGER -IC:/ncs/v2.1.0/modules/debug/segger/Config -IC:/ncs/v2.1.0/zephyr/modules/segger/. -IC:/ncs/v2.1.0/modules/crypto/tinycrypt/lib/include -IC:/ncs/v2.1.0/modules/lib/zcbor/include -IC:/ncs/v2.1.0/nrfxlib/softdevice_controller/include -isystem C:/ncs/v2.1.0/nrfxlib/crypto/nrf_cc312_platform/include -Og -imacros C:/xxxxxxxxrepopathxxxxxxxx/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee --sysroot=C:/ncs/toolchains/v2.1.0/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.1.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/repo/firmware-rtos=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.1.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.1.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/drivers/bluetooth/CMakeFiles/drivers__bluetooth.dir/hci/rpmsg.c.obj -MF zephyr\drivers\bluetooth\CMakeFiles\drivers__bluetooth.dir\hci\rpmsg.c.obj.d -o zephyr/drivers/bluetooth/CMakeFiles/drivers__bluetooth.dir/hci/rpmsg.c.obj -c C:/ncs/v2.1.0/zephyr/drivers/bluetooth/hci/rpmsg.c
In file included from C:/ncs/v2.1.0/zephyr/include/zephyr/toolchain/gcc.h:88,
                 from C:/ncs/v2.1.0/zephyr/include/zephyr/toolchain.h:50,
                 from C:/ncs/v2.1.0/zephyr/include/zephyr/init.h:10,
                 from C:/ncs/v2.1.0/zephyr/drivers/bluetooth/hci/rpmsg.c:7:
C:/ncs/v2.1.0/zephyr/drivers/bluetooth/hci/rpmsg.c: In function 'bt_rpmsg_open':
C:/ncs/v2.1.0/zephyr/include/zephyr/device.h:96:39: error: '__device_dts_ord_DT_CHOSEN_zephyr_bt_hci_rpmsg_ipc_ORD' undeclared (first use in this function)
   96 | #define DEVICE_NAME_GET(name) _CONCAT(__device_, name)
C:/ncs/v2.1.0/zephyr/include/zephyr/toolchain/common.h:132:26: note: in definition of macro '_DO_CONCAT'
  132 | #define _DO_CONCAT(x, y) x ## y
C:/ncs/v2.1.0/zephyr/include/zephyr/device.h:96:31: note: in expansion of macro '_CONCAT'
C:/ncs/v2.1.0/zephyr/include/zephyr/device.h:276:37: note: in expansion of macro 'DEVICE_NAME_GET'
  276 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_NAME(node_id))
C:/ncs/v2.1.0/zephyr/include/zephyr/device.h:296:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
  296 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
C:/ncs/v2.1.0/zephyr/drivers/bluetooth/hci/rpmsg.c:287:3: note: in expansion of macro 'DEVICE_DT_GET'
  287 |   DEVICE_DT_GET(DT_CHOSEN(zephyr_bt_hci_rpmsg_ipc));
C:/ncs/v2.1.0/zephyr/include/zephyr/device.h:96:39: note: each undeclared identifier is reported only once for each function it appears in
[164/379] Linking C static library app\libapp.a
