nrf52832 ble_peripheral dfu via ble_center
I am trying to update the firmware from ble_center to ble_peripheral via BLE DFU(SDK version is "nRF5_SDK_17.0.2_d674dde"),
On the ble_peripheral side I can successfully update using the app(nRF Connect),but I have a problem when I want to update with the ble_center
first I created ble_dfu_c, after BLE_DFU_C_EVT_DISCOVERY_COMPLETE, I enable indication as follows
static uint32_t cccd_configure(ble_dfu_c_t * p_ble_dfu_c, bool enable)
    NRF_LOG_INFO("Configuring CCCD. CCCD Handle = %d, Connection Handle = %d",
                  p_ble_dfu_c->peer_dfu_db.hrm_cccd_handle,
                  p_ble_dfu_c->conn_handle);
    nrf_ble_gq_req_t dfu_c_req;
    uint8_t          cccd[BLE_CCCD_VALUE_LEN];
    uint16_t         cccd_val = enable ? BLE_GATT_HVX_INDICATION : 0;
    cccd[0] = LSB_16(cccd_val);
    cccd[1] = MSB_16(cccd_val);
    memset(&dfu_c_req, 0, sizeof(dfu_c_req));
    dfu_c_req.type                        = NRF_BLE_GQ_REQ_GATTC_WRITE;
    dfu_c_req.error_handler.cb            = gatt_error_handler;
    dfu_c_req.error_handler.p_ctx         = p_ble_dfu_c;
    dfu_c_req.params.gattc_write.handle   = p_ble_dfu_c->peer_dfu_db.hrm_cccd_handle;
    dfu_c_req.params.gattc_write.len      = BLE_CCCD_VALUE_LEN;
    dfu_c_req.params.gattc_write.p_value  = cccd;
    dfu_c_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_REQ;
    return nrf_ble_gq_item_add(p_ble_dfu_c->p_gatt_queue, &dfu_c_req, p_ble_dfu_c->conn_handle);
uint32_t ble_dfu_c_hrm_notif_enable(ble_dfu_c_t * p_ble_dfu_c)
    VERIFY_PARAM_NOT_NULL(p_ble_dfu_c);
    return cccd_configure(p_ble_dfu_c, true);
At present, no errors info are returned, and the value of reading cccd is 0x002,
Then I send 0x01 to let the ble_peripheral into dfu mode, it doesn't work.
//ble_dfu_c.c
uint32_t ble_dfu_c_string_send(ble_dfu_c_t * p_ble_dfu_c, uint8_t * p_string, uint16_t length)
    nrf_ble_gq_req_t write_req;
    memset(&write_req, 0, sizeof(nrf_ble_gq_req_t));
    if (length > NRF_SDH_BLE_GATT_MAX_MTU_SIZE - 3)
        NRF_LOG_WARNING("Content too long.");
        return NRF_ERROR_INVALID_PARAM;
    if (p_ble_dfu_c->conn_handle == BLE_CONN_HANDLE_INVALID)
        NRF_LOG_WARNING("Connection handle invalid.");
    write_req.type                        = NRF_BLE_GQ_REQ_GATTC_WRITE;
    write_req.error_handler.cb            = gatt_error_handler;
    write_req.error_handler.p_ctx         = p_ble_dfu_c;
    write_req.params.gattc_write.handle   = p_ble_dfu_c->peer_dfu_db.hrm_handle;
    write_req.params.gattc_write.len      = length;
    write_req.params.gattc_write.offset   = 0;
    write_req.params.gattc_write.p_value  = p_string;
    write_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_CMD;
    write_req.params.gattc_write.flags    = BLE_GATT_EXEC_WRITE_FLAG_PREPARED_WRITE;
    NRF_LOG_INFO("%d ", strlen(p_string));
    NRF_LOG_INFO("%d ", strlen(write_req.params.gattc_write.p_value));
    for(int i=0;i<strlen(write_req.params.gattc_write.p_value);i++ )
          NRF_LOG_INFO("%02X ", write_req.params.gattc_write.p_value[i]);
    return nrf_ble_gq_item_add(p_ble_dfu_c->p_gatt_queue, &write_req, p_ble_dfu_c->conn_handle);
// main.c
uint8_t buff[1] = {0x01};
ble_dfu_c_string_send(&m_ble_dfu_c, buff, 1);
I tried to add some logs and found that BLE_GATTS_EVT_HVC is not triggered on the ble_peripheral side,
So the BLE_GATTC_EVT_HVX of the ble_center does not receive the return data
Is there something I forgot that caused the ble_peripheral doesn't receive the data()?
    I compared how the nRF Connect for mobile app does it, and it sends a Write request, from your sniffer log, I see that a Write Command was sent instead. So you should change it so it sends a Write Request instead.
    From your sniffer log:
    So in your ble_dfu_c_string_send() function, try to change:
    to
    write_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_REQ;
    to
