Sending a complete file at once from SD card to Mobile App using NRF52840.
Hello Nordic Family. I hope this post finds you well.
I am working on a project where I have connected multiple sensors to the NRF52840. I have collected all the sensor's data and saved it on the SD card as a CSV file. The file size is about 240MB which has 60 Hours of data from all the sensors(client requirements). Now I want to send this complete file at once from the SD card to the Mobile App in the fastest possible way. I have run the below program on my board
/cfs-file/__key/communityserver-discussions-components-files/4/8204.ble_5F00_app_5F00_uart_5F00_fatfs_5F00_send_5F00_sdk_5F00_16.0.0.zip.
but this program reads data one by one byte from the SD card and sends it byte by byte to the mobile app which I don't want. I want to send the whole file at once in the fastest possible way not byte by byte. Any help regarding this will be highly appreciated.
Best Regards,
Sami
  • Hi Sami,
    Sniffer trace was good, thanks for sharing this one.
    The PHY is changed successfully to 2MBit in frame #867.
    What is the throughput you're seeing now?
    From the traces it seems that the central (phone) does not poll the peripheral (nrf), which can indicate that it is doing something else. The problem with using a phone is that most bluetooth chipsets there are combo-chipsets, and also uses the same radio to server multiple services.
    Håkon
  • Hi Hakan, thanks for the reply.
    Yes sir, it is. My mobile phone responded unknown to the PHY update request, so I tried with another mobile and it worked.
    Unfortunately, the throughput is still the same(220KB per 3-4 seconds).
    What do you mean by "the central doesn't poll the peripheral"? If you scroll down the Sniffer file (I shared with you), you will see the data has been exchanged correctly( the green lines in the Sniffer file).
    Seems like sending the data file chunk by chunk won't be the best solution to send a large file (about 240MB). Have you watched this video where they are sending images from nRF52 to the mobile app in a single capture and in stream mode like a video? I want to achieve exactly the same of sending the file in bursts, not in chunks. Is it possible with the CSV file or only for the images?
    Best Regards,
    Sami
  • Hi Sami,
    The data is exchanged properly, but the overall throughput it limited by the central.
    The phone has "radio silence" for smaller periods (< 50 ms), which indicates that the phone itself is servicing other bluetooth devices or similar on its end.
    Even though the peripheral has more data to send, and is signalling this to the central, the central ends the current connection interval earlier than usual.
    The transport both your case, and this video is similar. Data is streamed from a source and over the bluetooth layer, in packets of >200 bytes per payload.
    If you're using the same phone as previous test, it will highly likely give you similar throughput.
    Håkon
  • Thanks Hakan for the quick reply.
    Okay got it, what will be the solution for this? Is it depend on the phone?
    But my phone is only connected to the UART inside the nRF toolbox app and it is only receiving the data from the nRF52. How can I check whether the phone is servicing other Bluetooth devices?
    The sniffer file I have shared with you is the result of a Samsung mobile. It doesn't change(increase) the throughput.
    Another thing I have noticed, if you look at the actual data in the Sniffer file you will see that the data is some like:
    UART Rx [truncated]: 6152,15433,36722,45008,23274,41643,855,475,15158,6906,13015,19129,40270,38062,17184,20220111121250\r\n23784,38793,36320,49942,19511,34148,1653,45854,26109,10248,6625,7790,46092,40673,18648,4132,31523,20220111121250\r\
    What does [truncated] mean?
    How to send 2 lines (about 243Bytes) of the CSV file per chunk and when the \r\n of every 2nd line comes then send the chunk (in short I want to send 2 lines per chunk).
    Best Regards,
    Sami
    Yes, it will depend on the phone.
    It could be as simple as the phone needs time to scan for new devices in the background, or that it has a wifi/BLE combo-chipset, where wifi takes priority. It is hard to say exactly what is the issue, unfortunately.
    From the log, there's a field called "more data" - this indicates to the central that the peripheral has more data to send.
    I have highlighted it here:
    From the trace, this field will always be set to true, meaning that the peripheral always tries to send more data to the central.
    If you look at frame #1226 for instance, where the central uses 27 ms to ask for new data:
    There's several of these timing gaps within the trace, which limits your overall throughput, and these are driven by the phone side.
    Truncated means that the wireshark view basically does not show all your data, ie. the graphical view stops listing the data. The data is being sent, it is just a graphical feature of wireshark.
    The "\r\n" are line-endings in a file. You will need to parse the datastream before sending it through the bluetooth link to remove or detect these.
    Håkon
