Sending a complete file at once from SD card to Mobile App using NRF52840.
Hello Nordic Family. I hope this post finds you well.
I am working on a project where I have connected multiple sensors to the NRF52840. I have collected all the sensor's data and saved it on the SD card as a CSV file. The file size is about 240MB which has 60 Hours of data from all the sensors(client requirements). Now I want to send this complete file at once from the SD card to the Mobile App in the fastest possible way. I have run the below program on my board
/cfs-file/__key/communityserver-discussions-components-files/4/8204.ble_5F00_app_5F00_uart_5F00_fatfs_5F00_send_5F00_sdk_5F00_16.0.0.zip.
but this program reads data one by one byte from the SD card and sends it byte by byte to the mobile app which I don't want. I want to send the whole file at once in the fastest possible way not byte by byte. Any help regarding this will be highly appreciated.
Best Regards,
Sami
  • Thank you Hakan, for the thorough explanation.
    It concluded that the problem is with the mobile app side(central ) not the peripheral, am I right?
    One last question and sorry for taking your precious time. I want to read a large file (about 240MB) from the SD card but the problem is that when I increase the #define FILE_SIZE_MAX (Maximum size in bytes of the file to be read from SDCARDgreater than 220000, while the following;
                    static uint8_t file_buffer[FILE_SIZE_MAX];
                  ff_result = f_read(&file, file_buffer, FILE_SIZE_MAX, (UINT *) &bytes_read);
     Then it gives the following error:
                  .bss is too large to fit in RAM1 memory segment
                  .heap is too large to fit in RAM1 memory segment
                   section .heap overlaps absolute placed section .stack
                   section .stack VMA [000000002003e000,000000002003ffff] overlaps section .bss VMA
                     [0000000020002c64,0000000020224b08]
    I don't know how to solve this. Simply I want to read the whole file (234MB) from the SD card at once and then send it in chunks to the mobile app, Is this possible or do I have to read in chunks from the SD card too?
    Kind Regards,
    Sami
  • Hi Sami,
    Yes, it is the central that drives the communication and essentially sets all the rules. A peripheral can ask for certain parameters, but it is the central that eventually grants permissions.
    You are running out of RAM by trying to buffer ~220kB of data. You must handle this in a smaller buffer.
    Håkon
  • Thanks Hakan for helping.
    Okay Sir, I understand, and thank you for the thorough explanation.
    Can you please refer me to a thread/blog where they have accessed and read large data from SD in small chunks/buffer? I have tried but I am unable to read the large file in a small buffer. I will be very thankful to you.
    Best Regards,
    Sami
    I do not think we have a blog/thread for this scenario.
    What you need to handle is a arbitrary byte stream going into a buffer, which again is passed through your bluetooth link. You should not need to buffer many kilobytes of data from the SD card, you need to read SD-data out into your buffer and pass the data through the bluetooth link.
    Håkon
  • Hi Hakan, thanks for the suggestion.
    Yes exactly I have done the same and now I am able to read data from the SD card and send it to the mobile app continuously.  Below code snippet is my approach;
    #define FILE_SIZE_MAX                   BLE_NUS_MAX_DATA_LEN  // file size is same as the packet size
    ff_result = f_open(&file, FILE_NAME, FA_READ);
    for (;;)
            if(file_send_to_peripheral)
               file_actual_read_size = (f_size(&file));
               uint32_t remaining_bytes = file_actual_read_size;
               uint16_t chunk_length = BLE_NUS_MAX_DATA_LEN;
               ret_code_t err_code;
                if(file_actual_read_size > 0)
                while(remaining_bytes > 0)
                 ff_result = f_read(&file, file_buffer, sizeof(file_buffer), (UINT *) &bytes_read);
                 err_code= ble_nus_data_send(&m_nus, file_buffer, &chunk_length, m_conn_handle);
                    if (err_code != NRF_ERROR_RESOURCES)
                       remaining_bytes -= chunk_length;
                       if(remaining_bytes < chunk_length)
                         chunk_length = remaining_bytes;
                        NRF_LOG_INFO("Remaining bytes to send: %d", remaining_bytes);
                file_send_to_peripheral = false;
            idle_state_handle();
    Is this the efficient way of reading from the SD card and sending it to the Mobile App?
    Best Regards,
    Sami
