Unable to Access SWD on nRF52840
Hi Dev Zone Team,
I have been working with the nRF series for quite sometime and I am having an issue with an nRF52840 based module that I haven't experienced before.  I debugging the nRF IC via SES and then closed that application and went to use ```nrfjprog``` to erase and put on production code.  I ran the ```nrfjprog``` command but the nRF8540 was no longer reachable via the debug port. The code on the micro is running fine as the device is functional.
I have tried updating to the latest version of ```nrfjprog``` and that didn't help.  I have included the log from ```nrfjprog```.  Is there any way to get access back to the debug port as the code running on the micro doesn't have a bootloader installed so it can't be updated.
[ info]: --------------------------------------------------------------------------------
[ info]: nrfjprog --log -f NRF52 --recover
[ info]: nrfjprog version 10.17.3 external
[ info]: Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
[ info]: Library loaded, loading member functions.
[ info]: Member functions succesfully loaded.
[debug]: [ Client] - open
[debug]: [ Client] - start
[ info]: [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence b7c69780-c6ef-4b62-88e2-d12be936ef67.
[trace]: [ Client] - Command open executed for 7 milliseconds with result 0
[debug]: [ Client] - config
[trace]: [ Client] - Command config executed for 3 milliseconds with result 0
[debug]: [ Client] - enum_emu_snr
[trace]: [ Client] - Command enum_emu_con_info executed for 4 milliseconds with result 0
[debug]: [ Client] - connect_to_emu_with_snr
[debug]: [SeggerBackend] - Logger sink registered in Segger backend logger
[debug]: [  JLink] - Logger sink registered in JLink logger
[debug]: [  nRF52] - open
[debug]: [  nRF52] - just_check_family
[debug]: [SeggerBackend] - open_dll
[debug]: [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[ info]: [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.7.66.1.dylib.
[ info]: [SeggerBackend] - Library loaded, loading member functions.
[ info]: [SeggerBackend] - Member functions succesfully loaded.
[debug]: [SeggerBackend] - Set batch mode
[debug]: [SeggerBackend] - dll_version
[ info]: [SeggerBackend] - Segger dll version 7.66.a loaded.
[trace]: [ Worker] - Command open executed for 5 milliseconds with result 0
[debug]: [  nRF52] - config
[trace]: [ Worker] - Command config executed for 3 milliseconds with result 0
[debug]: [  nRF52] - enum_emu_con_info
[debug]: [SeggerBackend] - is_connected_to_emu
[debug]: [SeggerBackend] - enum_emu_con_info
[trace]: [ Worker] - Command enum_emu_con_info executed for 4 milliseconds with result 0
[debug]: [  nRF52] - connect_to_emu_with_snr
[debug]: [SeggerBackend] - connect_to_emu_with_snr
[debug]: [SeggerBackend] - ---just_enum_emu_snr
[debug]: [SeggerBackend] - ---just_get_num_emus
[debug]: [SeggerBackend] - ---just_connect_to_emu_with_snr
[debug]: [SeggerBackend] - ---just_connect_to_emu_without_snr
[debug]: [SeggerBackend] - Segger logging enabled.
[trace]: [  JLink] - Firmware: J-Link Ultra V5-1 compiled May 18 2022 17:08:33
[trace]: [  JLink] - Hardware: V5.10
[trace]: [  JLink] - S/N: 505102150
[trace]: [  JLink] - OEM: SEGGER
[trace]: [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[trace]: [  JLink] - USB speed mode: High speed (480 MBit/s)
[trace]: [  JLink] - TELNET listener socket opened on port 19021
[trace]: [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[trace]: [  JLink] - WEBSRV Webserver running on local port 19080
[trace]: [  JLink] - - 11.489ms returns "O.K."
[trace]: [  JLink] - JLINK_HasError()
[trace]: [  JLink] - JLINK_Lock()
[trace]: [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[trace]: [  JLink] - - 0.004ms returns 0x01
[trace]: [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[trace]: [  JLink] - - 0.001ms returns 0x00
[trace]: [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[trace]: [  JLink] - - 0.002ms returns 0x00
[trace]: [  JLink] - JLINK_SetHookUnsecureDialog
[trace]: [  JLink] - JLINK_SetHookUnsecureDialog(...)
[trace]: [  JLink] - - 0.007ms returns 0
[trace]: [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[trace]: [  JLink] - - 0.755ms returns 0x00
[trace]: [  JLink] - JLINK_GetSpeedInfo()
[trace]: [  JLink] - 1600000000 Hz / n, n >= 32
[trace]: [  JLink] - - 0.006ms
[debug]: [SeggerBackend] - Connected emulator supports SWD speeds up to 50000kHz
[trace]: [  JLink] - JLINK_SetSpeed(2000)
[trace]: [  JLink] - - 0.100ms
[trace]: [  JLink] - JLINK_GetSpeed()
[trace]: [  JLink] - - 0.002ms returns 2000
[debug]: [SeggerBackend] - SWD clock set to 2000kHz
[trace]: [  JLink] - JLINK_GetSN()
[trace]: [  JLink] - - 0.002ms returns 505102150
[debug]: [SeggerBackend] - read_debug_port_idr
[debug]: [SeggerBackend] - read_debug_port_register
[debug]: [SeggerBackend] - ---just_read_debug_port_register
[debug]: [SeggerBackend] - coresight_configure
[trace]: [  JLink] - JLINK_GetHWStatus(...)
[trace]: [  JLink] - - 1.174ms returns 0
[trace]: [  JLink] - JLINK_CORESIGHT_Configure()
[trace]: [  JLink] - - 100.125ms returns 0
[debug]: [SeggerBackend] - ---just_select_debug_port_register
[debug]: [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[trace]: [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[trace]: [  JLink] - - 0.474ms returns -1
[error]: [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[debug]: [SeggerBackend] - ---just_abort_debug_action
[debug]: [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[trace]: [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[trace]: [  JLink] - - 0.411ms returns -1
[trace]: [  JLink] - - 0.423ms returns -1
[trace]: [  JLink] - - 0.484ms returns -1
[trace]: [  JLink] - - 0.476ms returns -1
[trace]: [  JLink] - - 0.463ms returns -1
[trace]: [  JLink] - - 0.455ms returns -1
[trace]: [  JLink] - - 0.424ms returns -1
[trace]: [  JLink] - - 0.435ms returns -1
[trace]: [  JLink] - - 0.413ms returns -1
[trace]: [  JLink] - - 0.429ms returns -1
[trace]: [ Client] - Command connect_to_emu_with_snr executed for 157 milliseconds with result -102
[trace]: [  JLink] - - 0.466ms returns -1
[trace]: [  JLink] - - 0.412ms returns -1
[trace]: [  JLink] - - 0.410ms returns -1
[trace]: [  JLink] - - 0.449ms returns -1
[trace]: [  JLink] - - 0.375ms returns -1
[trace]: [  JLink] - - 0.447ms returns -1
[trace]: [  JLink] - - 0.406ms returns -1
[trace]: [  JLink] - - 0.453ms returns -1
[trace]: [  JLink] - - 0.404ms returns -1
[trace]: [  JLink] - - 0.387ms returns -1
[trace]: [  JLink] - - 0.401ms returns -1
[trace]: [  JLink] - - 0.418ms returns -1
[trace]: [  JLink] - - 0.448ms returns -1
[trace]: [  JLink] - - 0.408ms returns -1
[trace]: [  JLink] - - 0.393ms returns -1
[trace]: [  JLink] - - 0.452ms returns -1
[trace]: [  JLink] - - 0.009ms
[trace]: [ Worker] - Command connect_to_emu_with_snr executed for 157 milliseconds with result -102
[debug]: [  nRF52] - close
[trace]: [  JLink] - JLINK_IsOpen()
[debug]: [SeggerBackend] - close
[debug]: [SeggerBackend] - disconnect_from_emu
[debug]: [SeggerBackend] - ---just_disconnect_from_emu
[debug]: [SeggerBackend] - is_connected_to_device
[trace]: [  JLink] - JLINK_IsConnected()
[trace]: [  JLink] - - 0.002ms returns FALSE
[debug]: [SeggerBackend] - ---just_is_debug_region_powered
[trace]: [  JLink] - - 0.436ms returns -1
[trace]: [  JLink] - - 0.397ms returns -1
[trace]: [  JLink] - - 0.428ms returns -1
[trace]: [  JLink] - - 0.433ms returns -1
[trace]: [  JLink] - - 0.414ms returns -1
[trace]: [  JLink] - - 0.438ms returns -1
[trace]: [  JLink] - - 0.419ms returns -1
[trace]: [  JLink] - - 0.430ms returns -1
[trace]: [  JLink] - - 0.421ms returns -1
[trace]: [  JLink] - - 0.390ms returns -1
[trace]: [  JLink] - - 0.367ms returns -1
[trace]: [  JLink] - - 0.409ms returns -1
[trace]: [  JLink] - - 0.450ms returns -1
[trace]: [  JLink] - - 0.439ms returns -1
[trace]: [  JLink] - - 0.391ms returns -1
[trace]: [  JLink] - - 0.402ms returns -1
[trace]: [  JLink] - - 0.010ms
[trace]: [  JLink] - JLINK_Close()
[debug]: [SeggerBackend] - Segger Backend closed.
[debug]: [  nRF52] - nRF family DLL closed
[trace]: [ Client] - Command close executed for 51 milliseconds with result 0
[debug]: [ Client] - terminate
[trace]: [ Client] - Command terminate executed for 0 milliseconds with result 0
[trace]: [ Worker] - Command close executed for 51 milliseconds with result 0
[trace]: [ Worker] - Command terminate executed for 0 milliseconds with result 0
[trace]: [ Worker] - Executed 6 commands for 220 milliseconds
[debug]: [ Client] - Child process terminated with result 0
[trace]: [ Client] - Executed 6 commands for 222 milliseconds
[ info]: nrfjprog --log -f NRF52 -p
[ info]: [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 12a7f812-88a4-46b5-993c-572736fbc3f2.
[trace]: [ Client] - Command open executed for 8 milliseconds with result 0
[trace]: [  JLink] - - 11.098ms returns "O.K."
[trace]: [  JLink] - - 0.008ms returns 0
[trace]: [  JLink] - - 0.630ms returns 0x00
[trace]: [  JLink] - - 0.097ms
[trace]: [  JLink] - - 0.003ms returns 505102150
[trace]: [  JLink] - - 0.190ms returns 0
[trace]: [  JLink] - - 99.952ms returns 0
[trace]: [  JLink] - - 0.456ms returns -1
[trace]: [  JLink] - - 0.475ms returns -1
[trace]: [  JLink] - - 0.417ms returns -1
[trace]: [  JLink] - - 0.441ms returns -1
[trace]: [  JLink] - - 0.432ms returns -1
[trace]: [  JLink] - - 0.425ms returns -1
[trace]: [  JLink] - - 0.427ms returns -1
[trace]: [  JLink] - - 0.426ms returns -1
[trace]: [  JLink] - - 0.457ms returns -1
[trace]: [  JLink] - - 0.477ms returns -1
[trace]: [  JLink] - - 0.415ms returns -1
[trace]: [  JLink] - - 0.443ms returns -1
[trace]: [  JLink] - - 0.445ms returns -1
[trace]: [  JLink] - - 0.400ms returns -1
[trace]: [  JLink] - - 0.003ms returns 0x01
[trace]: [  JLink] - - 0.420ms returns -1
[trace]: [  JLink] - - 0.459ms returns -1
[trace]: [  JLink] - - 0.394ms returns -1
[trace]: [  JLink] - - 0.405ms returns -1
[trace]: [  JLink] - - 0.396ms returns -1
[trace]: [  JLink] - - 0.399ms returns -1
[trace]: [  JLink] - - 0.407ms returns -1
[trace]: [  JLink] - - 0.416ms returns -1
[trace]: [  JLink] - - 0.395ms returns -1
[trace]: [  JLink] - - 0.437ms returns -1
[trace]: [  JLink] - - 0.446ms returns -1
[trace]: [  JLink] - - 0.444ms returns -1
[trace]: [  JLink] - - 0.020ms
[trace]: [ Client] - Command close executed for 41 milliseconds with result 0
[trace]: [ Worker] - Command close executed for 41 milliseconds with result 0
[trace]: [ Worker] - Executed 6 commands for 210 milliseconds
[debug]: [ Client] - Worker process exited with code: 0
[trace]: [ Client] - Executed 6 commands for 213 milliseconds
