I have 2 DK boards neither of which is working.
The first is a PCA10040 V1.2.1. When I plug it into my Window 10 computer with a data cable, Windows says it's an unrecognized device. I tried uninstalling the driver in Windows Device Manager but that did not fix the problem. The green LED is flickering. No matter which computer or USB port I try to plug into, it always behaves the same way. If I hold the IF BOOT/RESET button down when I slide the power switch to on, the green LED will start blinking, but there is still no USB connection.
The second is a PCA10056 2.0.2. When I plug in to either USB port on the board and switch the power on, nothing happens, even while holding IF BOOT/RESET down. No LED's are lit. If I measure between the 5V and GND pads on the back of the board with a voltmeter I get 5V. I tried switching between VDD and USB for the nRF power source, but it didn't make a difference either.
Is there a way to restore both of these boards so that I can use them again. They were both working at one time. I was using them for power profiling.
Alec
