Hi Friends,
- kit dev NF52840-DK
- IDE : segger studio IDE
- SDK nRF52 16.0.0
I want to port the nfc_writable_ndef_msg NFC example to freeRTOS.
I use the NFC Tools app to write on the tag.
the concern I have a problem every time it updates the NDEF message in the flash file (error on NFC Tools application, hardfault in the ndef_file_update())
I think the problem is how I used app_scheduler and freeRTOS .
Do you have examples of using the app_schedule.h library and freeRTOS?
could you please help me
Thank you and best regards.
Lora
* Copyright (c) 2017 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup nfc_writable_ndef_msg_example_main main.c
* @ingroup nfc_writable_ndef_msg_example
* @brief The application main file of NFC writable NDEF message example.
#include <stdint.h>
#include <stdbool.h>
#include "FreeRTOS.h"
#include "task.h"
#include "app_error.h"
#include "app_scheduler.h"
#include "boards.h"
#include "nfc_t4t_lib.h"
#include "nrf_log_ctrl.h"
#include "ndef_file_m.h"
#include "nfc_ndef_msg.h"
#include "nrf_log.h"
#define APP_SCHED_MAX_EVENT_SIZE 0 /**< Maximum size of scheduler events. */
#define APP_SCHED_QUEUE_SIZE 4 /**< Maximum number of events in the scheduler queue. */
#define APP_DEFAULT_BTN BSP_BOARD_BUTTON_0 /**< Button used to set default NDEF message. */
#define TASK_DELAY_LED0 200 /**< Task delay. Delays a LED0 task for 200 ms */
#define TASK_DELAY_LED1 1000 /**< Task delay. Delays a LED1 task for 1000 ms */
static uint8_t m_ndef_msg_buf[NDEF_FILE_SIZE]; /**< Buffer for NDEF file. */
static uint8_t m_ndef_msg_len; /**< Length of the NDEF message. */
TaskHandle_t led_toggle_task_handle_0; /**< Reference to LED0 toggling FreeRTOS task. */
TaskHandle_t led_toggle_task_handle_1; /**< Reference to LED1 toggling FreeRTOS task. */
TaskHandle_t scheduler_task_handle; /**< Reference to LED1 toggling FreeRTOS task. */
/* @Function : Function used as callback Common application error handler */
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
//printf("Received a fault! id: 0x%08x, pc: 0x%08x, info: 0x%08x\r\n", id, pc, info);
for (;;)
bsp_board_led_invert(3);
/**@brief LED0 task entry function.
* @param[in] pvParameter Pointer that will be used as the parameter for the task.
static void led0_toggle_task_function (void * pvParameter)
printf("led0_toggle_task_function START \n\r");
UNUSED_PARAMETER(pvParameter);
while (true)
bsp_board_led_invert(BSP_BOARD_LED_0);
/* Delay a task for a given number of ticks */
vTaskDelay(TASK_DELAY_LED0);
/* Tasks must be implemented to never return... */
static void led1_toggle_task_function (void * pvParameter)
printf("led1_toggle_task_function START \n\r");
while (true)
bsp_board_led_invert(BSP_BOARD_LED_1);
vTaskDelay(TASK_DELAY_LED1);
* @brief Function for updating NDEF message in the flash file.
static void scheduler_ndef_file_update(void * p_event_data, uint16_t event_size)
//printf("scheduler_ndef_file_update START \n\r");
ret_code_t err_code;
UNUSED_PARAMETER(p_event_data);
UNUSED_PARAMETER(event_size);
// Update flash file with new NDEF message.
err_code = ndef_file_update(m_ndef_msg_buf, m_ndef_msg_len + NLEN_FIELD_SIZE);
static void scheduler_init()
/* Initialize App Scheduler. */
APP_SCHED_INIT(APP_SCHED_MAX_EVENT_SIZE, APP_SCHED_QUEUE_SIZE);
static void scheduler_thread(void * pvParameter)
NRF_LOG_INFO("Starting scheduler thread")
while(1)
app_sched_execute();
//vTaskSuspend(NULL);
* @brief Callback function for handling NFC events.
static void nfc_callback(void * context,
nfc_t4t_event_t event,
const uint8_t * data,
size_t dataLength,
uint32_t flags)
(void)context;
switch (event)
case NFC_T4T_EVENT_FIELD_ON:
bsp_board_led_on(BSP_BOARD_LED_0);
case NFC_T4T_EVENT_FIELD_OFF:
bsp_board_leds_off();
case NFC_T4T_EVENT_NDEF_READ:
bsp_board_led_on(BSP_BOARD_LED_3);
case NFC_T4T_EVENT_NDEF_UPDATED:
if (dataLength > 0)
bsp_board_led_on(BSP_BOARD_LED_1);
// Schedule update of NDEF message in the flash file.
m_ndef_msg_len = dataLength;
err_code = app_sched_event_put(NULL, 0, scheduler_ndef_file_update);
*@brief Function for initializing logging.
static void log_init(void)
* @brief Function for application main entry.
log_init();
/* Configure LED-pins as outputs */
bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
scheduler_init();
/* Initialize FDS. */
err_code = ndef_file_setup();
/* Load NDEF message from the flash file. */
err_code = ndef_file_load(m_ndef_msg_buf, sizeof(m_ndef_msg_buf));
// Restore default NDEF message.
if (bsp_board_button_state_get(APP_DEFAULT_BTN))
uint32_t size = sizeof(m_ndef_msg_buf);
err_code = ndef_file_default_message(m_ndef_msg_buf, &size);
err_code = ndef_file_update(m_ndef_msg_buf, NDEF_FILE_SIZE);
NRF_LOG_DEBUG("Default NDEF message restored!");
/* Set up NFC */
err_code = nfc_t4t_setup(nfc_callback, NULL);
/* Run Read-Write mode for Type 4 Tag platform */
err_code = nfc_t4t_ndef_rwpayload_set(m_ndef_msg_buf, sizeof(m_ndef_msg_buf));
NRF_LOG_INFO("Writable NDEF message example started.");
/* Start sensing NFC field */
err_code = nfc_t4t_emulation_start();
/* Create task for LED0 blinking with priority set to 2 */
//UNUSED_VARIABLE(xTaskCreate(led0_toggle_task_function, "LED0", configMINIMAL_STACK_SIZE + 200, NULL, 2, &led_toggle_task_handle_0));
/* Create task for LED1 blinking with priority set to 3 */
//UNUSED_VARIABLE(xTaskCreate(led1_toggle_task_function, "LED1", configMINIMAL_STACK_SIZE + 200, NULL, 3, &led_toggle_task_handle_1));
/* Create task for Scheduler with priority set to 1 */
UNUSED_VARIABLE(xTaskCreate(scheduler_thread, "Scheduler", configMINIMAL_STACK_SIZE + 200, NULL, 1, &scheduler_task_handle));
/* Start FreeRTOS scheduler. */
vTaskStartScheduler();
while (1)
void vApplicationIdleHook()
//vTaskResume(scheduler_task_handle);
