Recover from APP_UART_COMMUNICATION_ERROR
Hi, We are using SDK17 and are implementing the UART y APP_UART_FIFO_INIT. Every now and then we encounter APP_UART_COMMUNICATION_ERROR. I know this is related to buffer overrun during reception. How do we gracefully recover from this? If the data in the buffer is lost, we can handle this in an other way. But for now, the error is not cleared and the only way to get it working again is reset the device.
  • Hi Hieu,
    I am unable to answer on your last reply about using the Advanced UARTE Driver library, so I try this message instead.
    I tried to implement the Advanced UARTE Driver library in the existing application, but failed on setting the NRF_CLOCK to enable nrf_drv_clock_lfclk_request. Adding the (relevant??) defines like NRF_CLOCK_ENABLED 1 in the app_config.h, I get errors in apply_old_config.h. expected declaration specifiers or '...' before numeric constant.
    You are probably talking about adding "#define NRF_CLOCK_ENABLE 1" in sdk_config.h?
    Aside from that, did you make sure all of these configurations are setup as well?
    // <e> NRF_CLOCK_ENABLED - nrf_drv_clock - CLOCK peripheral driver - legacy layer
    #ifndef NRF_CLOCK_ENABLED
    #define NRF_CLOCK_ENABLED 1
    // <o> CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    // <131073=> External Low Swing
    // <196609=> External Full Swing
    #ifndef CLOCK_CONFIG_LF_SRC
    #define CLOCK_CONFIG_LF_SRC 1
    // <q> CLOCK_CONFIG_LF_CAL_ENABLED  - Calibration enable for LF Clock Source
    #ifndef CLOCK_CONFIG_LF_CAL_ENABLED
    #define CLOCK_CONFIG_LF_CAL_ENABLED 0
    // <o> CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef CLOCK_CONFIG_IRQ_PRIORITY
    #define CLOCK_CONFIG_IRQ_PRIORITY 6
    // </e>
    If you did and still got that error, could you please give more details? For example:
    - Which line in apply_old_config.h is giving you the error?
    - Are there any other hints in the error? Such as where or what the related numeric constant is?
    Hieu
    As soon as I add one of the below line, the error is generated
    #define UART_DEFAULT_CONFIG_HWFC 0
    #define UART_DEFAULT_CONFIG_PARITY 0
    #define UART_DEFAULT_CONFIG_BAUDRATE 30801920
    #define UART_DEFAULT_CONFIG_IRQ_PRIORITY 7
    I apologize for the late follow-up. I tried some simple solutions I thought of, but they didn't work. My direction right now is to get libuarte to work without relying on NRF_CLOCK. I will need to go deeper into the documents some more.
    By the way, are you using any other NRFX drivers in the project?
    The error comes from apply_old_config.h, as you said. It is included in nrf_glue.h and subsequently by nrfx.h, which is used in most if not all NRFX drivers.
    Hieu
    I inspected further and does not find apply_old_config.h looks like that in both nRF5 SDK v17.1.0, v17.0.2, and v15.0.0. Where did you pull this file from? What SDK version are you on?
    Anyway, if your apply_old_config.h looks like that, then the SDK you are on probably does not want NRF_DRV_CLOCK to be enabled while NRFX is being used.
    Meanwhile, libUARTE, as setup in the example, use App Timer (under the hood). The App Timer in turns relies on the LFCLK. Finally, the example uses NRF_DRV_CLOCK to enable LFCLK.
    Therefore, to avoid using NRF_DRV_CLOCK, we can just use NRFX_CLOCK to enable LFCLK instead. I cannot find an example which uses NRFX_CLOCK, so here is my code, tested and work:
    void MY_nrfx_clock_event_handler(nrfx_clock_evt_type_t event)
        // Do nothing?
        // Alternatively handle these event types as you see fit
        // typedef enum
        //     NRFX_CLOCK_EVT_HFCLK_STARTED, ///< HFCLK has been started.
        //     NRFX_CLOCK_EVT_LFCLK_STARTED, ///< LFCLK has been started.
        //     NRFX_CLOCK_EVT_CTTO,          ///< Calibration timeout.
        //     NRFX_CLOCK_EVT_CAL_DONE       ///< Calibration has been done.
        // } nrfx_clock_evt_type_t;
        NRF_LOG_INFO("MY_nrfx_clock_event_handler %d", event);
        //ret_code_t ret = nrf_drv_clock_init();
        //APP_ERROR_CHECK(ret);
        //nrf_drv_clock_lfclk_request(NULL);
        ret_code_t ret = nrfx_clock_init(MY_nrfx_clock_event_handler);
        nrfx_clock_lfclk_start();
    I apologize once again for the long wait. Please come again if you need help; and if it is urgent for certain reasons, please just note so.
    Hieu
