I have been trying to resolve an issue for a few days now. Here is what I'm trying to do.
1. initialize gpiote and tie a pin to an interrupt handler
static void peripherial_init(void)
ret_code_t err_code;
nrf_drv_gpiote_in_config_t vl_int_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
err_code = nrf_drv_gpiote_in_init(VL_INT, &vl_int_config, vl_int_pin_handler);
nrf_drv_gpiote_in_event_enable(VL_INT, true);
2. initialize a gpio as an input and read it from an application timer every 50ms.
//Digital Inputs nrf_gpio_cfg(BTN_MSTR, NRF_GPIO_PIN_DIR_INPUT, NRF_GPIO_PIN_INPUT_CONNECT, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_S0S1, NRF_GPIO_PIN_SENSE_LOW);
The GPIOTE pin (P0.06) is different from the gpio input pin (P0.13). The gpio input pin is connected to a button. I use the button to turn the device on and off. This works great if I don't call peripherial_init(). If I call peripherial_init() and then push the button. The processor hangs. If I hold the button down, the processor hangs until my watchdog times out, then the device resets.
The GPIOTE interrupt works as expected.
I am using SDK 17.1 with softdevice S132_nRF52_7.2.0 nRF52832 with RC 32.768kHz (no external 32.768kHz Oscillator)
John
