nRF51822 Sniffer FW for Microcontroller
Dear Developerzone Board
Does the nRF51822 Sniffer just start with the conversion over all advertising channels or do I need to send a start command? Which command set can I use to configure the chip (set advertising channel, get RSSI Infos etc)?
Thanks in Advance for Answers
Greetings Roger
  • The sniffer will by default be listening on channels 37 - 38 - 39, changing channels once it receives a packet on the current channel.
    The order can be modified using the nRF-Sniffer application or using the Sniffer Python API.
    The python API provided in the sniffer download zip-file exposes the API that is available to the sniffer.
    The RSSI info can be found in the packet metadata (open Wireshark if using the nRF-Sniffer application or see Packet.py in the SnifferAPI zip file).
