I'm having trouble getting the echo_bot example running over uart1 using an nRF52840 DK with nRF Connect SDK v2.1.0. I've configured a device overlay to configure uart1, enabled the interrupt driven config for uart1 and modified main.c to use the uart1 device. The main changes I made were:
nrf52840dk_nrf52840.overlay - Added suggested config from the Using UART 1 section of the Zephyr nRF52840 DK docs to ./echo_bot/boards/
&pinctrl { uart1_default: uart1_default { group1 { psels = <NRF_PSEL(UART_TX, 0, 14)>, <NRF_PSEL(UART_RX, 0, 16)>; }; }; /* required if CONFIG_PM_DEVICE=y */ uart1_sleep: uart1_sleep { group1 { psels = <NRF_PSEL(UART_TX, 0, 14)>, <NRF_PSEL(UART_RX, 0, 16)>; low-power-enable; }; }; }; &uart1 { compatible = "nordic,nrf-uarte"; current-speed = <115200>; status = "okay"; pinctrl-0 = <&uart1_default>; pinctrl-1 = <&uart1_sleep>; pinctrl-names = "default", "sleep"; };
prj.conf - Added CONFIG_UART_1_INTERRUPT_DRIVEN=y
CONFIG_SERIAL=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_1_INTERRUPT_DRIVEN=y
main.c - Modified example to use uart1 instead of uart0.
// static const struct device *uart_dev = DEVICE_DT_GET(DT_NODELABEL(uart0)); static const struct device *uart_dev = DEVICE_DT_GET(DT_NODELABEL(uart1));
I'm able to debug the code and it runs without crashing, but I see no data when scoping the configured output pin P0.14 configured in the overlay. It is always pulled high. Running the program with uart0 works and I can see the data on the scope on pin P0.06.
Here is the full example project with my modifications. I suspect I've got the overlay and/or config not quite right. I'd appreciate any insights into what the issue may be.
echo_bot_uart1_not_working.zip
— Jeremy
