I am getting the following python error when building matter examples using SDK 2.1.0 and MacOS. The same code will build successfully if you open a "terminal" using the Toolchain Manager and then running "west build" on the command line. It appears that is using the wrong python3. Instead of using python in the SDK it is using the one from /usr/local/bin. Is there a way to fix this?
cd /Volumes/Projects/karetrax/matter/light_switch/build/mcuboot && /usr/local/bin/python3.10 /opt/nordic/ncs/v2.1.0/bootloader/mcuboot/scripts/imgtool.py getpub -k /opt/nordic/ncs/v2.1.0/bootloader/mcuboot/root-rsa-2048.pem > /Volumes/Projects/karetrax/matter/light_switch/build/mcuboot/zephyr/autogen-pubkey.c
File "/opt/nordic/ncs/v2.1.0/bootloader/mcuboot/scripts/imgtool.py", line 22, in <module>
main.imgtool()
File "/usr/local/lib/python3.9/site-packages/click/core.py", line 829, in __call__
return self.main(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python3.9/site-packages/click/core.py", line 1259, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/local/lib/python3.9/site-packages/click/core.py", line 1066, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/local/lib/python3.9/site-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/opt/nordic/ncs/v2.1.0/bootloader/mcuboot/scripts/imgtool/main.py", line 121, in getpub
key = load_key(key)
File "/opt/nordic/ncs/v2.1.0/bootloader/mcuboot/scripts/imgtool/main.py", line 84, in load_key
key = keys.load(keyfile)
File "/opt/nordic/ncs/v2.1.0/bootloader/mcuboot/scripts/imgtool/keys/__init__.py", line 52, in load
backend=default_backend())
File "/usr/local/lib/python3.9/site-packages/cryptography/hazmat/backends/__init__.py", line 14, in default_backend
from cryptography.hazmat.backends.openssl.backend import backend
File "/usr/local/lib/python3.9/site-packages/cryptography/hazmat/backends/openssl/__init__.py", line 6, in <module>
File "/usr/local/lib/python3.9/site-packages/cryptography/hazmat/backends/openssl/backend.py", line 113, in <module>
from cryptography.hazmat.bindings.openssl import binding
File "/usr/local/lib/python3.9/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 14, in <module>
from cryptography.hazmat.bindings._openssl import ffi, lib
