Cannot flash nRF52811 (sometimes)
I have a problem regarding production flashing a nRF52811 device.
We are using a Segger Flasher Compact, but I also tried a Segger J-Link Compact.
To flash we are using a ubuntu PC with nrfjprog with the following version:
nrfjprog version: 10.17.3 external
JLinkARM.dll version: 7.70a
Sometimes, but not always I cannot flash
Using this command:
nrfjprog  --log --family NRF52 --clockspeed 800 --program firmware.hex --chiperase  --verify
The output is:
[error]: [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
Sometimes I then can recover from this state if I erase the chip:
nrfjprog -f nrf52 -e --clockspeed 100
But this does not always work.
It seemed like the --clockspeed would make a difference, sometimes it did not work if I erased the chip with --clockspeed 8000, somttimes it worked if I then tried it with 800kHz, or 100kHz
I attached the nrfjprog.log
It's getting interesting at line 173:
After the command
JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
the JLink reports an error.
What could this be?
[ info] --------------------------------------------------------------------------------
[ info] nrfjprog --log --snr 1015000641 --family NRF52 --clockspeed 800 --program firmware.hex --chiperase --verify
[ info] nrfjprog version 10.17.3 external
[ info] Load library at optnrf-command-line-toolsliblibnrfjprogdll.so.
[ info] Library loaded, loading member functions.
[ info] Member functions succesfully loaded.
[debug] [ Client] - open
[debug] [ Client] - start
[ info] [ Client] - stdout Jlinkarm nRF Worker ready. Handling sequence 8241bc77-b6ac-4310-8866-f378db4177bc.
[debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[debug] [  JLink] - Logger sink registered in JLink logger
[debug] [  nRF52] - open
[debug] [  nRF52] - just_check_family
[debug] [SeggerBackend] - open_dll
[debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[trace] [ Client] - Command open executed for 3 milliseconds with result 0
[debug] [ Client] - config
[trace] [ Client] - Command config executed for 1 milliseconds with result 0
[debug] [ Client] - enum_emu_snr
[ info] [SeggerBackend] - Load library at optSEGGERJLinklibjlinkarm.so.
[ info] [SeggerBackend] - Library loaded, loading member functions.
[ info] [SeggerBackend] - Member functions succesfully loaded.
[debug] [SeggerBackend] - Set batch mode
[debug] [SeggerBackend] - dll_version
[ info] [SeggerBackend] - Segger dll version 7.70.a loaded.
[trace] [ Worker] - Command open executed for 2 milliseconds with result 0
[debug] [  nRF52] - config
[trace] [ Worker] - Command config executed for 1 milliseconds with result 0
[debug] [  nRF52] - enum_emu_con_info
[debug] [SeggerBackend] - is_connected_to_emu
[debug] [SeggerBackend] - enum_emu_con_info
[trace] [ Client] - Command enum_emu_con_info executed for 155 milliseconds with result 0
[debug] [ Client] - connect_to_emu_with_snr
[trace] [ Worker] - Command enum_emu_con_info executed for 155 milliseconds with result 0
[debug] [  nRF52] - connect_to_emu_with_snr
[debug] [SeggerBackend] - connect_to_emu_with_snr
[debug] [SeggerBackend] - ---just_enum_emu_snr
[debug] [SeggerBackend] - ---just_get_num_emus
[debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[debug] [SeggerBackend] - Segger logging enabled.
[trace] [  JLink] - Firmware J-Link  Flasher Compact V5 compiled Aug  9 2022 132032
[trace] [  JLink] - Hardware V5.00
[trace] [  JLink] - SN 1015000641
[trace] [  JLink] - OEM SEGGER
[trace] [  JLink] - Feature(s) JFlash, GDB
[trace] [  JLink] - USB speed mode High speed (480 MBits)
[trace] [  JLink] - TELNET listener socket opened on port 19021
[trace] [  JLink] - WEBSRV WEBSRV_Init() Starting webserver thread(s)
[trace] [  JLink] - WEBSRV Webserver running on local port 19080
[trace] [  JLink] - - 8.176ms returns O.K.
[trace] [  JLink] - JLINK_HasError()
[trace] [  JLink] - JLINK_Lock()
[trace] [  JLink] - JLINK_ExecCommand(SetRestartOnClose = 0, ...).
[trace] [  JLink] - - 0.006ms returns 0x01
[trace] [  JLink] - JLINK_ExecCommand(DisableFlashDL, ...).
[trace] [  JLink] - - 0.004ms returns 0x00
[trace] [  JLink] - JLINK_ExecCommand(ExcludeFlashCacheRange 0x0-0xFFFFFFFF, ...).
[trace] [  JLink] - JLINK_SetHookUnsecureDialog
[trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[trace] [  JLink] - - 0.018ms returns 0
[trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[trace] [  JLink] - - 0.320ms returns 0x00
[trace] [  JLink] - JLINK_GetSpeedInfo()
[trace] [  JLink] - 1600000000 Hz  n, n = 32
[trace] [  JLink] - - 0.016ms
[debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 50000kHz
[trace] [  JLink] - JLINK_SetSpeed(800)
[trace] [  JLink] - - 0.050ms
[trace] [  JLink] - JLINK_GetSpeed()
[trace] [  JLink] - - 0.008ms returns 800
[debug] [SeggerBackend] - SWD clock set to 800kHz
[trace] [  JLink] - JLINK_GetSN()
[trace] [  JLink] - - 0.008ms returns 1015000641
[debug] [SeggerBackend] - read_debug_port_idr
[debug] [SeggerBackend] - read_debug_port_register
[debug] [SeggerBackend] - ---just_read_debug_port_register
[debug] [SeggerBackend] - coresight_configure
[trace] [  JLink] - JLINK_GetHWStatus(...)
[trace] [  JLink] - - 0.105ms returns 0
[trace] [  JLink] - JLINK_CORESIGHT_Configure()
[trace] [  JLink] - - 102.357ms returns 0
[debug] [SeggerBackend] - ---just_select_debug_port_register
[debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[trace] [  JLink] - - 1.005ms returns -1
[error] [SeggerBackend] - JLinkARM.dll reported -1, An unknown error..
[debug] [SeggerBackend] - ---just_abort_debug_action
[debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[trace] [  JLink] - - 1.029ms returns -1
[trace] [  JLink] - - 0.947ms returns -1
[trace] [  JLink] - - 0.961ms returns -1
[trace] [  JLink] - - 0.983ms returns -1
[trace] [  JLink] - - 0.987ms returns -1
[trace] [  JLink] - - 0.902ms returns -1
[trace] [  JLink] - - 0.883ms returns -1
[trace] [  JLink] - - 0.924ms returns -1
[trace] [  JLink] - - 0.931ms returns -1
[trace] [  JLink] - - 0.912ms returns -1
[trace] [  JLink] - - 1.028ms returns -1
[trace] [  JLink] - - 1.024ms returns -1
[trace] [  JLink] - - 0.955ms returns -1
[trace] [  JLink] - - 0.868ms returns -1
[trace] [  JLink] - - 0.871ms returns -1
[trace] [  JLink] - - 0.945ms returns -1
[trace] [  JLink] - - 0.882ms returns -1
[trace] [  JLink] - - 0.918ms returns -1
[trace] [  JLink] - - 0.928ms returns -1
[trace] [  JLink] - - 0.896ms returns -1
[trace] [  JLink] - - 0.952ms returns -1
[trace] [  JLink] - - 0.917ms returns -1
[trace] [ Client] - Command connect_to_emu_with_snr executed for 601 milliseconds with result -102
[trace] [  JLink] - - 0.862ms returns -1
[trace] [  JLink] - - 0.834ms returns -1
[trace] [  JLink] - - 0.821ms returns -1
[trace] [  JLink] - - 0.865ms returns -1
[trace] [  JLink] - - 0.869ms returns -1
[trace] [  JLink] - - 0.025ms
[trace] [ Worker] - Command connect_to_emu_with_snr executed for 601 milliseconds with result -102
[debug] [  nRF52] - close
[trace] [  JLink] - JLINK_IsOpen()
[trace] [  JLink] - - 0.015ms returns 0x01
[debug] [SeggerBackend] - close
[debug] [SeggerBackend] - disconnect_from_emu
[debug] [SeggerBackend] - ---just_disconnect_from_emu
[debug] [SeggerBackend] - is_connected_to_device
[trace] [  JLink] - JLINK_IsConnected()
[trace] [  JLink] - - 0.012ms returns FALSE
[debug] [SeggerBackend] - ---just_is_debug_region_powered
[trace] [  JLink] - - 0.835ms returns -1
[trace] [  JLink] - - 0.851ms returns -1
[trace] [  JLink] - - 0.888ms returns -1
[trace] [  JLink] - - 0.929ms returns -1
[trace] [  JLink] - - 0.957ms returns -1
[trace] [  JLink] - - 0.860ms returns -1
[trace] [  JLink] - - 0.872ms returns -1
[trace] [  JLink] - - 0.839ms returns -1
[trace] [  JLink] - - 0.841ms returns -1
[trace] [  JLink] - - 0.853ms returns -1
[trace] [  JLink] - - 0.887ms returns -1
[trace] [  JLink] - - 0.897ms returns -1
[trace] [  JLink] - - 0.939ms returns -1
[trace] [  JLink] - - 0.944ms returns -1
[trace] [  JLink] - - 0.920ms returns -1
[trace] [  JLink] - - 0.893ms returns -1
[trace] [  JLink] - - 0.840ms returns -1
[trace] [  JLink] - - 0.875ms returns -1
[trace] [  JLink] - - 0.971ms returns -1
[trace] [  JLink] - - 0.880ms returns -1
[trace] [  JLink] - - 0.858ms returns -1
[trace] [  JLink] - - 0.915ms returns -1
[trace] [  JLink] - - 0.879ms returns -1
[trace] [  JLink] - - 0.043ms
[trace] [  JLink] - JLINK_Close()
[debug] [SeggerBackend] - Segger Backend closed.
[debug] [  nRF52] - nRF family DLL closed
[trace] [ Client] - Command close executed for 54 milliseconds with result 0
[debug] [ Client] - terminate
[trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[trace] [ Worker] - Command close executed for 54 milliseconds with result 0
[trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[trace] [ Worker] - Executed 6 commands for 813 milliseconds
[debug] [ Client] - Child process terminated with result 0
[debug] [ Client] - Worker process exited with code 0
[trace] [ Client] - Executed 6 commands for 814 milliseconds
    Q1: Does this issue occur on one device, or with all devices?
    Q2: If it works when using a slower clock speed, it can indicate that there's an issue electrically (long wires, high capacitance on the lines, or similar). In your design, is the SWD pins directly routed to the programming header? Ie. is there any capacitors or resistors on these lines?
    Håkon
