BLE_GAP_EVT_ADV_REPORT generation for Active Scan
I'm a newbie here.
I have a device using NRF52840 running SDK17 with SD v7 configured as a Central/Observer device doing Active Scan.
I have a few questions:
  • When will BLE_GAP_EVT_ADV_REPORT event gets generated when communicating with a scannable device?
    • Is it generated twice: 1st is when receiving the ADV_IND and the 2nd is when receiving the SCAN_RSP?
    • Or, is it only once after receiving the SCAN_RSP? Is there risk of data in the scan buffer getting overwritten if the event is only generated once?
    • Or, it depends on the timing - could be once or twice?
  • What is the timeout duration to wait for the SCAN_RSP from the peripheral? Is this a configurable setting?
  • Are there error events generated when SCAN_RSP is not received? Are there configurable settings related to the SCAN_RSP handling?
    You will get the event BLE_GAP_EVT_ADV_REPORT, and in the event here there is a flag called scan_response that is set to 1 if it's a scan response packet.https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.s140.api.v7.2.0/structble__gap__adv__report__type__t.html
    You will get this event when the SoftDevice sends the scan response request packet, and the peer responds with the scan response packet. As far as I can recall, there is an algorithm in the SoftDevice that decides how often it will request this packet.
    No timeout. If the SoftDevice request this packet, but does not receive it, a new request will later be sent.
    No.
  • Hi  ,
    Thanks for the explanation.
    A couple more question on this statement:
    • Will the SoftDevice wait for another ADV_IND from that same device to send a new request?
    • What is the behaviour of the SoftDevice when it receives an ADV_IND from another device while waiting for the SCAN_RSP from the first device (especially when it has been missed/lost)?
    Yes. If a advertiser is doing scannable advertising, it will transmit the normal advertising packet first, and after it have done that, it will for a short period of time stay in RX mode, listening for a scan response request from a potential scanner. The scanner needs to send the request in this window.
    If it has sent a scan response request, and waiting for the scan response, I believe it will discard other ADV_IND received in this window.
