Problem building OpenThread Coprocessor app in Matter demo using VS Code
Like several other folks, I have been attempting to replicate the results in the Matter webinar here, but updating to the v2.1.0 SDK and using the Nordic dev kits I have on hand.  Have successfully built the Matter Lock app on an nRF5340 DK.using VS Code and tested it (at least using the app's CLI interface)
Moving on to the OpenThread Coprocessor app, I'm using an nRF52840 Dongle.  But I run into multiple problems with the CLI build instructions using the west command.  Have been here before, using west from the command line on my Mac installation often runs into "issues".  So decided to try it using VS Code and the nRF Extension.  But this creates questions:
  • Should I be able to specify the overlays specified in the west command line by adding -DOVERLAY="overlay-rcp.conf ../cli/overlay-thread_1_2.conf overlay-usb.conf" to the Extra CMake arguments field in the Build Configuration window? Tried it; didn't work. Build log attached below.
  • I'm not sure these three overlays specified the west command line are still correct.  Are they, or have the required overlays changed with SDK v 2.1.0?
  • Is there an updated version of the Matter demo (dated Nov 2021)?  Errata or other corrections?
  • A more general question about Matter: What's the Nordic strategy for configuration management of the Matter code in the NCS SDKs?  Specifically, the connectedhomeip repo is open source and updated dynamically (git commits at least daily).  How do NCS SDK versions synchronize with this?
Thanks for any help.  Looking forward to fluid Matter development,
Mike
 *  Executing task: nRF Connect: Generate config nrf52840dongle_nrf52840 for /Users/mike/Nordic/SDK2.1_Apps/coprocessor
Building coprocessor
west build --build-dir /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build /Users/mike/Nordic/SDK2.1_Apps/coprocessor --pristine --board nrf52840dongle_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/Users/mike/Nordic/SDK2.1_Apps/lock;/Users/mike/Nordic/SDK2.1_Apps/coprocessor"
-- Application: /Users/mike/Nordic/SDK2.1_Apps/coprocessor
-- Found Python3: /opt/nordic/ncs/toolchains/v2.1.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter
-- Cache files will be written to: /Users/mike/Library/Caches/zephyr
-- Zephyr version: 3.1.99 (/opt/nordic/ncs/v2.1.0/zephyr)
-- Board: nrf52840dongle_nrf52840
-- Found host-tools: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.1.0/opt/zephyr-sdk)
-- Found dtc: /opt/nordic/ncs/toolchains/v2.1.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.1.0/opt/zephyr-sdk)
-- Found BOARD.dts: /opt/nordic/ncs/v2.1.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840.dts
-- Generated zephyr.dts: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/dts.cmake
warning: UART_INTERRUPT_DRIVEN (defined at boards/shields/sparkfun_sara_r4/Kconfig.defconfig:24, boards/shields/wnc_m14a2a/Kconfig.defconfig:17, soc/arm/quicklogic_eos_s3/Kconfig.defconfig:17, drivers/serial/Kconfig:72) has direct dependencies (NETWORKING && SHIELD_SPARKFUN_SARA_R4) || (NETWORKING && SHIELD_WNC_M14A2A) || (SERIAL && SOC_EOS_S3) || (SERIAL_SUPPORT_INTERRUPT && SERIAL) with value n, but is currently being y-selected by the following symbols:
 - OPENTHREAD_COPROCESSOR (defined at subsys/net/l2/openthread/Kconfig:212), with value y, direct dependencies NET_L2_OPENTHREAD && NETWORKING (value: y), and select condition NET_L2_OPENTHREAD && NETWORKING (value: y)
error: Aborting due to Kconfig warnings
Parsing /Users/mike/Nordic/SDK2.1_Apps/coprocessor/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.1.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840_defconfig'
Merged configuration '/Users/mike/Nordic/SDK2.1_Apps/coprocessor/prj.conf'
CMake Error at /opt/nordic/ncs/v2.1.0/zephyr/cmake/modules/kconfig.cmake:293 (message):
  command failed with return code: 1
  /opt/nordic/ncs/v2.1.0/zephyr/cmake/modules/zephyr_default.cmake:121 (include)
  /opt/nordic/ncs/v2.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /opt/nordic/ncs/v2.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:11 (find_package)
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/v2.1.0/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/v2.1.0/bin/python3 -B/Users/mike/Nordic/SDK2.1_Apps/coprocessor/build -GNinja -DBOARD=nrf52840dongle_nrf52840 -DNCS_TOOLCHAIN_VERSION:STRING=NONE '-DBOARD_ROOT:STRING=/Users/mike/Nordic/SDK2.1_Apps/lock;/Users/mike/Nordic/SDK2.1_Apps/coprocessor' -S/Users/mike/Nordic/SDK2.1_Apps/coprocessor
 *  The terminal process terminated with exit code: 1.
west build --build-dir /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build /Users/mike/Nordic/SDK2.1_Apps/coprocessor --pristine --board nrf52840dongle_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/Users/mike/Nordic/SDK2.1_Apps/lock;/Users/mike/Nordic/SDK2.1_Apps/coprocessor" -DOVERLAY="overlay-rcp.conf    ../cli/overlay-thread_1_2.conf overlay-usb.conf"
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/v2.1.0/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/v2.1.0/bin/python3 -B/Users/mike/Nordic/SDK2.1_Apps/coprocessor/build -GNinja -DBOARD=nrf52840dongle_nrf52840 -DNCS_TOOLCHAIN_VERSION:STRING=NONE '-DBOARD_ROOT:STRING=/Users/mike/Nordic/SDK2.1_Apps/lock;/Users/mike/Nordic/SDK2.1_Apps/coprocessor' '-DOVERLAY=overlay-rcp.conf    ../cli/overlay-thread_1_2.conf overlay-usb.conf' -S/Users/mike/Nordic/SDK2.1_Apps/coprocessor
  • Jørgen, et al,
    Sorry not to have replied sooner.  Actually have been busy trying different approaches to get the Open Thread Coprocessor (OTCP) example to build.  Actually moved from macOS to Windows 10 installation of NCS SDK v2.1.0 to avoid environment configuration issues I often see when running Nordic software on the Mac.  (Understandable, I suspect the tools get a lot more testing and usage on Windows).
    Bottom line is that I was successful building the app on Win10 (actually a Win10 VM running in Parallels Desktop on my MacBook Pro).  So let's close out this ticket.  Still haven't succeeded in getting a host processor (e.g., Raspberry Pi) to talk to the OCTP app on the nRF52840 Dongle, but don't have a well-formed question to post here yet.  Will open a new ticket if I have continue to have difficulties following the November, 2021, webinar.
    Looking forward to increased support for Matter development given the official release of Matter 1.0 and the Nordic press release about same.  Thanks for your support on this specific ticket.
    Mike
