Like several other folks, I have been attempting to replicate the results in the Matter webinar here, but updating to the v2.1.0 SDK and using the Nordic dev kits I have on hand. Have successfully built the Matter Lock app on an nRF5340 DK.using VS Code and tested it (at least using the app's CLI interface)
Moving on to the OpenThread Coprocessor app, I'm using an nRF52840 Dongle. But I run into multiple problems with the CLI build instructions using the west command. Have been here before, using west from the command line on my Mac installation often runs into "issues". So decided to try it using VS Code and the nRF Extension. But this creates questions:
- Should I be able to specify the overlays specified in the west command line by adding
-DOVERLAY="overlay-rcp.conf ../cli/overlay-thread_1_2.conf overlay-usb.conf" to the Extra CMake arguments field in the Build Configuration window? Tried it; didn't work. Build log attached below. I'm not sure these three overlays specified the west command line are still correct. Are they, or have the required overlays changed with SDK v 2.1.0?- Is there an updated version of the Matter demo (dated Nov 2021)? Errata or other corrections?
- A more general question about Matter: What's the Nordic strategy for configuration management of the Matter code in the NCS SDKs? Specifically, the connectedhomeip repo is open source and updated dynamically (git commits at least daily). How do NCS SDK versions synchronize with this?
Thanks for any help. Looking forward to fluid Matter development,
Mike
* Executing task: nRF Connect: Generate config nrf52840dongle_nrf52840 for /Users/mike/Nordic/SDK2.1_Apps/coprocessor Building coprocessor west build --build-dir /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build /Users/mike/Nordic/SDK2.1_Apps/coprocessor --pristine --board nrf52840dongle_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/Users/mike/Nordic/SDK2.1_Apps/lock;/Users/mike/Nordic/SDK2.1_Apps/coprocessor" -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /Users/mike/Nordic/SDK2.1_Apps/coprocessor -- Found Python3: /opt/nordic/ncs/toolchains/v2.1.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/mike/Library/Caches/zephyr -- Zephyr version: 3.1.99 (/opt/nordic/ncs/v2.1.0/zephyr) -- Found west (found suitable version "0.14.0", minimum required is "0.7.1") -- Board: nrf52840dongle_nrf52840 -- Found host-tools: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.1.0/opt/zephyr-sdk) -- Found dtc: /opt/nordic/ncs/toolchains/v2.1.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found toolchain: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.1.0/opt/zephyr-sdk) -- Found BOARD.dts: /opt/nordic/ncs/v2.1.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840.dts -- Generated zephyr.dts: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/dts.cmake warning: UART_INTERRUPT_DRIVEN (defined at boards/shields/sparkfun_sara_r4/Kconfig.defconfig:24, boards/shields/wnc_m14a2a/Kconfig.defconfig:17, soc/arm/quicklogic_eos_s3/Kconfig.defconfig:17, drivers/serial/Kconfig:72) has direct dependencies (NETWORKING && SHIELD_SPARKFUN_SARA_R4) || (NETWORKING && SHIELD_WNC_M14A2A) || (SERIAL && SOC_EOS_S3) || (SERIAL_SUPPORT_INTERRUPT && SERIAL) with value n, but is currently being y-selected by the following symbols: - OPENTHREAD_COPROCESSOR (defined at subsys/net/l2/openthread/Kconfig:212), with value y, direct dependencies NET_L2_OPENTHREAD && NETWORKING (value: y), and select condition NET_L2_OPENTHREAD && NETWORKING (value: y) error: Aborting due to Kconfig warnings Parsing /Users/mike/Nordic/SDK2.1_Apps/coprocessor/Kconfig Loaded configuration '/opt/nordic/ncs/v2.1.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840_defconfig' Merged configuration '/Users/mike/Nordic/SDK2.1_Apps/coprocessor/prj.conf' CMake Error at /opt/nordic/ncs/v2.1.0/zephyr/cmake/modules/kconfig.cmake:293 (message): command failed with return code: 1 Call Stack (most recent call first): /opt/nordic/ncs/v2.1.0/zephyr/cmake/modules/zephyr_default.cmake:121 (include) /opt/nordic/ncs/v2.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) /opt/nordic/ncs/v2.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:11 (find_package) -- Configuring incomplete, errors occurred! FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/v2.1.0/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/v2.1.0/bin/python3 -B/Users/mike/Nordic/SDK2.1_Apps/coprocessor/build -GNinja -DBOARD=nrf52840dongle_nrf52840 -DNCS_TOOLCHAIN_VERSION:STRING=NONE '-DBOARD_ROOT:STRING=/Users/mike/Nordic/SDK2.1_Apps/lock;/Users/mike/Nordic/SDK2.1_Apps/coprocessor' -S/Users/mike/Nordic/SDK2.1_Apps/coprocessor * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it. * Executing task: nRF Connect: Generate config nrf52840dongle_nrf52840 for /Users/mike/Nordic/SDK2.1_Apps/coprocessor Building coprocessor west build --build-dir /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build /Users/mike/Nordic/SDK2.1_Apps/coprocessor --pristine --board nrf52840dongle_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/Users/mike/Nordic/SDK2.1_Apps/lock;/Users/mike/Nordic/SDK2.1_Apps/coprocessor" -DOVERLAY="overlay-rcp.conf ../cli/overlay-thread_1_2.conf overlay-usb.conf" -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /Users/mike/Nordic/SDK2.1_Apps/coprocessor -- Found Python3: /opt/nordic/ncs/toolchains/v2.1.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/mike/Library/Caches/zephyr -- Zephyr version: 3.1.99 (/opt/nordic/ncs/v2.1.0/zephyr) -- Found west (found suitable version "0.14.0", minimum required is "0.7.1") -- Board: nrf52840dongle_nrf52840 -- Found host-tools: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.1.0/opt/zephyr-sdk) -- Found dtc: /opt/nordic/ncs/toolchains/v2.1.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found toolchain: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.1.0/opt/zephyr-sdk) -- Found BOARD.dts: /opt/nordic/ncs/v2.1.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840.dts -- Generated zephyr.dts: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: /Users/mike/Nordic/SDK2.1_Apps/coprocessor/build/zephyr/dts.cmake warning: UART_INTERRUPT_DRIVEN (defined at boards/shields/sparkfun_sara_r4/Kconfig.defconfig:24, boards/shields/wnc_m14a2a/Kconfig.defconfig:17, soc/arm/quicklogic_eos_s3/Kconfig.defconfig:17, drivers/serial/Kconfig:72) has direct dependencies (NETWORKING && SHIELD_SPARKFUN_SARA_R4) || (NETWORKING && SHIELD_WNC_M14A2A) || (SERIAL && SOC_EOS_S3) || (SERIAL_SUPPORT_INTERRUPT && SERIAL) with value n, but is currently being y-selected by the following symbols: - OPENTHREAD_COPROCESSOR (defined at subsys/net/l2/openthread/Kconfig:212), with value y, direct dependencies NET_L2_OPENTHREAD && NETWORKING (value: y), and select condition NET_L2_OPENTHREAD && NETWORKING (value: y) error: Aborting due to Kconfig warnings Parsing /Users/mike/Nordic/SDK2.1_Apps/coprocessor/Kconfig Loaded configuration '/opt/nordic/ncs/v2.1.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840_defconfig' Merged configuration '/Users/mike/Nordic/SDK2.1_Apps/coprocessor/prj.conf' CMake Error at /opt/nordic/ncs/v2.1.0/zephyr/cmake/modules/kconfig.cmake:293 (message): command failed with return code: 1 Call Stack (most recent call first): /opt/nordic/ncs/v2.1.0/zephyr/cmake/modules/zephyr_default.cmake:121 (include) /opt/nordic/ncs/v2.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) /opt/nordic/ncs/v2.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:11 (find_package) -- Configuring incomplete, errors occurred! FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/v2.1.0/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/v2.1.0/bin/python3 -B/Users/mike/Nordic/SDK2.1_Apps/coprocessor/build -GNinja -DBOARD=nrf52840dongle_nrf52840 -DNCS_TOOLCHAIN_VERSION:STRING=NONE '-DBOARD_ROOT:STRING=/Users/mike/Nordic/SDK2.1_Apps/lock;/Users/mike/Nordic/SDK2.1_Apps/coprocessor' '-DOVERLAY=overlay-rcp.conf ../cli/overlay-thread_1_2.conf overlay-usb.conf' -S/Users/mike/Nordic/SDK2.1_Apps/coprocessor * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
Code
