Settings subsystem init fails (NVS backend)
Working with nRF5340 in NCS 1.9.2, I've overridden weak usb_update_sn_string_descriptor function to set iSerialNumber at runtime.
I wanted to read the actual serial number from settings subsystem, backend-ed in internal flash (NVS).
Code looks like this
/** @brief Overriding weak function to set iSerialNumber at runtime.
 *  @return either original or default serial number string.
static uint8_t sn[sizeof(CONFIG_USB_DEVICE_SN) + 1];
uint8_t *usb_update_sn_string_descriptor(void)
	int rc;
	uint32_t val = COSMED_SN_DEFAULT;
	memset(sn, 0, sizeof(sn));
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		rc = settings_subsys_init();
		if (rc) {
			LOG_ERR("error initializing settings subsys [%d]", rc);
		} else {
			rc = load_immediate_value("id/sn", &val, sizeof(val));
			if (rc == -ENOENT) {
			} else if (rc == 0) {
				LOG_DBG("<id/sn> = %u", val);
			} else {
				LOG_ERR("error loading sn from settings [%d]", rc);
		LOG_WRN("TODO: manage to store sn in settings from user input");
		rc = settings_save_one("id/sn", (const void *)&val, sizeof(val));
		if (rc) {
			LOG_ERR("error saving sn in settings [%d]", rc);
	snprintk(sn, sizeof(sn), "%u", val);
	return sn;
Unfortunately last call of the chain settings_subsys_init() -> settings_backend_init() -> device_get_binding("NRF_FLASH_DRV_NAME") returns NULL.
Settings subsystem initialization at the beginning of main() doesn't rise this exception.
Is there any explanation or workaround ?
