LTE Modem keeps in connected state for a long time
I'm doing a comparison between MQTT on TCP and CoAP on UDP over NB-IoT and LTE-M. The communication to the cloud works as expected for both protocols. MQTT is used with TLS and Coap is used with DTLS.
Now the next step is to get an impression of the power consumption for both protocols in certain scenarios. But what I saw on the oszilloscope is not what I expected (see screenshot below). Every time I transmitted a packet to the cloud it took more than 10s until the modem went into the sleep mode again. But the response to a request packet has been received much earlier in case a response was expected.
What I can see in the LTE Link Monitor is that the modem outputs "+CSCON: 1"  every time the high power consumption time starts and it outputs "+CSCON: 0" every time it goes into the sleep mode again (after more than 10s).
The picture below shows a screenshot of the MQTT communication but the same applies to CoAP.
For the test in the picture above I used PSM mode with the following configuration (eDRX has been deactivated)
  • CONFIG_LTE_PSM_REQ_RPTAU = 1h
  • CONFIG_LTE_PSM_REQ_RAT = 3s
From what I read in this post the reason for this behavior is that the modem is still in RRC_CONNECTED for a serveral seconds although the communication has already been finished.
https://devzone.nordicsemi.com/f/nordic-q-a/81278/early-release-assistance-indication
My questions are now:
  1. Produces the missing Release Assistance Indication the behavior I discovered in my description above?
  2. If yes, how can I solve the problem to get a much lower power consumption?
  3. How can I enable the Release Assistance Indication in combination with TLS for MQTT and DTLS for CoAP on the nRF Connect SDK? I know there is an ICMP example (see link below) but I couldn't find "SO_RAI_ONE_RESP" in the SDK. Furthermore as described above I need a solution for TLS and DTLS.
https://github.com/nrfconnect/sdk-nrf/blob/332d2d1bc4aa335673aa0738e411aff0f2195915/samples/nrf9160/modem_shell/src/ping/icmp_ping.c#L343
For my tests I used the following setup:
  • nrf9160 DK revision 1.1.0
  • ncs v2.0.0
  • modem firmware is mfw_nrf9160_1.3.2
  • MNO is Deutsche Telekom
Thanks in advance.
Christian
  • Thans again for your very helpful answers.
    For me that depends on what you mean by "cleaner". Easier because the application benefits more from messaging (do you use it just to transmit data to the cloud? Or really subscribe/publish with other devices?)?
    By "cleaner" I mean that I can't influence the MQTT behavior on packet level in the way I would need (without modifing the MQTT library). And with %XRAI it is even worser than with RAI because %XRAI is only a high level command and can not be used like RAI as you mentioned above. So in my opinion the potential of MQTT in combination with %XRAI is very limited when it comes to optimized power consumption.
    Our first step is only to transmit data to the cloud. The next step then would be to receive data from the cloud. It is not yet clear if we want to do it also asynchronously using eDRX.
    No, the text refers to a "reregistration at the network" once per PSM wakeup, so once per hour in the shown case. The text also describes the situation in summer 2022 in south Germany. Repeating those test in September 2022 showed, that now all MNO allows to use also larger times for PSM. I currently work on an update, hope I can publish this until end of next week.
    From my understandig the PSM mode performs a Tracking Area Update procedure on every PSM interval if necessary but there is no need to do a re-registration procedure at the network. Maybe I'm wrong, but I always thought it is the idea behind the PSM mode to avoid re-registrations at the network?
    Looks like in many other companies: the cloud developer wants TCP, but the device requires UDP. If the management doesn't decide to go either for larger batteries and pay a little more for the SIM-card, or to switch to use UDP, then products will never have a chance to make it to the "streets".
    Exactly, that's why I compare them with reference to our requirements.
  • > By "cleaner" I mean that I can't influence the MQTT behavior on packet level in the way I would need (without modifing the MQTT library).
    As I wrote, RAI refers to a "mobile network package layer", and with TCP that doesn't work, because TCP uses TCP-ACKs, the application is even unaware of them. Therefore I guess you even will not be able to adapt the MQTT implementation to make RAI working.
    I'm not sure about the details of %XRAI. It may be worth using it, if "SO_RAI_NO_DATA" would be working and the connection gets closed. But NRF_SO_RAI_NO_DATA does not cause RRC release seems to indicate, that it doesn't work (for now).
    Maybe "re-registration" is the wrong term. Others use "full-attach" or "re-attach". Regardless which term is used, on any PSM wakeup I measured, it requires energy. If your experience is different, let me know.
  • I found two documents, which brings some light into the used "terms".
    GSMA - TS.34 IoT Device Connection Efficiency Guidelines V8.0 see 9.11.
    "Power Saving Mode is similar to powering-off the device, but the mobile device that uses
    PSM remains registered with the network so there is no need to re-attach or re-establish the
    network connection when the device starts transmitting or receiving data."
    (I need to rewrite my page about energy consumption.)
    and
    GSMA - Improving Energy Efficiency for Mobile IoT
    Figure 1, page 11.
    "TAU / MO Data" with that, I guess, my measurements with different consumption for wake up and message exchange is caused by waiting and receiving the CoAP response. I consider to retest that once I implement "CoAP - No Server Response, RFC 7967" with my client.
    figure 2, page 12.
    "Random Access RACH - wake up scan etc."
    Not sure, when that happens.
  • OK, after a few days of bugfixing now CoAP communication with RAI works as expected. I still have to investigate time into some other issues but for now I can send a CoAP request packet to the CoAP server, wait for a ACK response and set the whole nrf9160 SiP into sleep mode (PSM) right after I have received the CoAP ACK response. The same applies if I use eDRX.
    I did it the following way in case other people need a hint how to start with RAI.
    First, I called the following sequence at the beginning of my test application.
    lte_lc_init();
    nrf_modem_at_printf("AT%%REL14FEAT=0,1,0,0,0");
    lte_lc_connect();
    nrf_modem_at_printf("AT%%RAI=1");
    Note: the sequence above is of course only a simplified description.
    After that I set the following option every time right before I sent a socket packet. Of course the "SO_RAI_ONE_RESP" option needs to be adjusted to your needs.
    setsockopt(socket, SOL_SOCKET, SO_RAI_ONE_RESP , NULL, 0);
    Note: I only tested it for NB-IoT in my region and the sequence I discribed above is not optimized.
  • Great!
    In my comment above I mixed up "%RAI" (new AS-RAI) and "%XRAI" (traditional CP-RAI). So yes, "%XRAI" only works for simple UDP message exchanges, "%RAI" is more flexible.
    One downside in the socketopt based implementation is, that with TCP, once the socket is closed, you can't use it anymore. So at that point I gave up to try to use it for TCP.
