Add DFU support to your application walk-through
devzone.nordicsemi.com/.../ncs-dfu
Serial DFU chapter
Fails on a nRF52840 DK (with one HW change)
With error 3 on image confirm using mcumgr
All the previous steps seem fine.
nrf connect sdk 2.1.0
I tried increasing stack sizes with no success.
I ensured that the flash is fully erased before the first flash in case
Like in the walk-through, I did just rebuild the hello world sample to change the signature
The change I did to the nRF52840 DK, in case this could be of any effect
HW : disconnect the 32.768Khz quartz, reroute the wires so that P0.00 and P0.01 are the new USART0, pass through USB CDC
FW :
create an overlay to set the uart0 on P0.00 and P0.01
add to the prj.conf to run without the quartz 32.768Khz
# No 32.768Khz Quartz
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
I was able to run several other samples with this config with no problems.
Looking at the mcumgr source code
Error 3 seems to be LOG_MGMT_ERR_EINVAL in the mcumgr source code. May have to do with cbor_read_object or cbor_write_attr
Here are the logs
D:\ndapp\serial_dfu\build\zephyr>mcumgr --conntype serial --connstring "COM7,baud=115200" image test 636ec254a624a4dd554ea46c4f04a7bda19b8f1fa88f374b701d9421b8712b96Images: image=0 slot=0 version: 0.0.0 bootable: true flags: active confirmed hash: 74ec5b3cb343075a73fe5f179e94c80cd2c8bf886a8687ac32828fbb23e6906e image=0 slot=1 version: 0.0.0 bootable: true flags: pending hash: 636ec254a624a4dd554ea46c4f04a7bda19b8f1fa88f374b701d9421b8712b96Split status: N/A (0)
D:\ndapp\serial_dfu\build\zephyr>mcumgr --conntype serial --connstring "COM7,baud=115200" resetDone
// NRF Connect RTT properly logs the Hello World, with a new compilation time, confirming that the active slot is the one we wanted
D:\ndapp\serial_dfu\build\zephyr>mcumgr --conntype serial --connstring "COM7,baud=115200" image listImages: image=0 slot=0 version: 0.0.0 bootable: true flags: active hash: 636ec254a624a4dd554ea46c4f04a7bda19b8f1fa88f374b701d9421b8712b96 image=0 slot=1 version: 0.0.0 bootable: true flags: confirmed hash: 74ec5b3cb343075a73fe5f179e94c80cd2c8bf886a8687ac32828fbb23e6906eSplit status: N/A (0)
D:\ndapp\serial_dfu\build\zephyr>mcumgr --conntype serial --connstring "COM7,baud=115200" image confirmError: 3
// NRF Connect VSCode or no NRF connect connected, same problem.
// yep, no change
I am stuck.
