I've been suffering from the same issue as in the above post. Except with SDK17.0.2
I find that if i have nrf_drv_power included, this results in an observer being registered for SD state change events, (line ~313 of the aforementioned file), the observer registered is: nrf_drv_power_sdh_state_evt_handler
When i then enable the soft device, this handler is called (soft device state changes when enabled), the action of this function call when the NRF_SDH_EVT_STATE_ENABLED event is received, is to call the function: nrf_drv_power_on_sd_enable();
This function checks the validity of "m_initialized" and subsequently asserts an error. (line 357).
Some of the legacy aspects to the code i am working with used a call to "app_usbd_init" before the soft device was enabled. I noticed this solved the error asserted by the aforementioned call.
I beleive this is because this function calls "nrf_drv_power_init" which in turn, sets m_initialised to true. Thus i can see why this function previously prevented the error.This all seems a bit sporadic and confusing. Additionally i no longer wish to use the USB driver and subsequently have no need for the legacy code. But of course, if i comment out the function and leave the file included. the observer is still registered and subsequently the error is still asserted.
Q1: I could just disclude the file. But I want to know why a power driver file would register an observer for softdevice events?
Q2: If i dont register this observer, if i disclude the nrf_drv_power file from the build this solves my issue, but what if i later want to use some other aspect of the nrf_drv_power file, i need to make sure the m_initialised variable is true? What function must i call do acheive this.
Q3: Upon searching for the m_initialised variable throughout the SDK i found it is declared across several files? How is it i dont see any symbol conflict errors from this?
