nrf9160 : LTE connection issue
modem fw.: 1.3.2
sdk: 1.6.0
SIM: ibasis
We recently switched to iBasis sims (previously using Bell) and i have been seeing some behavior on LTE connection attempt that I am trying to figure out.
LTE connection timeout is set to 120 seconds.
Trying to connect
LTE cell changed: Cell ID: -1, Tracking area: -1
LTE cell changed: Cell ID: 141267985, Tracking area: 55012
RRC mode: Connected
RRC mode: Idle
lte_lc_init_and_connect failed: -116
Questions:
1. What does RRC mode: connected mean ? Very often (even with Bell and Rogers) I see RRC mode: connected but then the connection attempt times out and lte_lc_init_and_connect returns -116 after 120 seconds.
2. On many occassions i see LTE cell changed: Cell ID message even in RRC Idle mode. What causes this behavior? Is the modem trying to look for a better signal or connection? our device when idle will not send messages for a few hours but in between it will change cell towers many times while on PSM. How can I manage or disable this to not drain the battery prematurely?
3. What can I do to make the connection attempt faster, stable and reliable? Right now on a 10 minute connection cycle test (where I disconnect and reconnect every 10 minutes) sometimes I can connect within 5 seconds, at other time it will take 30-60 seconds, while occassionly it fails to connect. All of this while the device is on a desk and LTE signal stregnth is excellent in the office.
4. Do newer SDKs (2.1) and the modem lib that comes with it improves the LTE connection? Will switching to newer SDK provide me any improvement on this aspect?
Thank you in advance for all the help and support
Noaman
