Can the standard bootloader in the nrf52840 dongle be used with the DFU Trigger library for USB firmware updates (nrfutil)?
I have the DFU Trigger code added to my application, and am using nrfutil to upload the package over USB.  If I press the reset/DFU button on the dongle the process works fine.  If I try to use the DFU Trigger, I get the following error:
2022-10-01 22:04:29,304 Serial: Device is either not in bootloader mode, or using an unsupported bootloader.
2022-10-01 22:04:29,321 Serial: Set Packet Receipt Notification 0
File "/usr/local/bin/nrfutil", line 8, in <module>
sys.exit(cli())
File "/usr/lib/python3/dist-packages/click/core.py", line 829, in __call__
return self.main(*args, **kwargs)
File "/usr/lib/python3/dist-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/usr/lib/python3/dist-packages/click/core.py", line 1259, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/lib/python3/dist-packages/click/core.py", line 1066, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/lib/python3/dist-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/nordicsemi/__main__.py", line 1032, in usb_serial
do_serial(package, port, connect_delay, flow_control, packet_receipt_notification, baud_rate, serial_number, False,
File "/usr/local/lib/python3.9/dist-packages/nordicsemi/__main__.py", line 990, in do_serial
dfu.dfu_send_images()
File "/usr/local/lib/python3.9/dist-packages/nordicsemi/dfu/dfu.py", line 127, in dfu_send_images
self._dfu_send_image(self.manifest.application)
File "/usr/local/lib/python3.9/dist-packages/nordicsemi/dfu/dfu.py", line 88, in _dfu_send_image
self.dfu_transport.open()
File "/usr/local/lib/python3.9/dist-packages/nordicsemi/dfu/dfu_transport_serial.py", line 217, in open
self.__get_mtu()
File "/usr/local/lib/python3.9/dist-packages/nordicsemi/dfu/dfu_transport_serial.py", line 366, in __get_mtu
self.mtu = struct.unpack('<H', bytearray(response))[0]
TypeError: cannot convert 'NoneType' object to bytearray
I am using USB CDC for data transfer, but I do have the COMM and DATA interfaces have been set to 1 & 2.
Is the standard bootloader (the one that comes with the dongle) compatible with the DFU Trigger?  Or do I need to add a secure or open bootloader.
If I need to replace the bootloader, do I need a settings.hes, or just merge the newly built bootloader with the softdevice (s140)?
--jeff
  • Hi Jeff
    Which SDK version are you using?
    A colleague of mine handled a similar case where the issue was related to the DFU trigger library version, possibly it could be something similar here.
    Best regards
    Torbjørn
  • We're using nRF5_SDK_15.3.0_59ac345, which should coincide with the manufacture date of the dongles I'm testing, if that matters.  Since we're close to putting hundreds of these into a large warehouse, it would be great to be able to remotely fix any issues, but because we're close to deploying, I was hoping to avoid changing the SDK version.
    It looks like the issue is a missing MTU value, which I would think would not be a factor in the USB transport (MTU is usually associated with BLE).
    --jeff
  • Hi Jeff
    Do you know which LF clock source you are using, as set through the LFCLKSRC register?
    We have seen similar issues earlier, where the choice of LF clock configuration before activating the bootloader could cause issues for the bootloader.
    Also, are you using the watchdog in your application?
    Best regards
    Torbjørn
  • I'm using the default selection of the LF CLK that was set by the example I built the project from:
    //  NRFX_CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    // <131073=> External Low Swing
    // <196609=> External Full Swing
    #ifndef NRFX_CLOCK_CONFIG_LF_SRC
    #define NRFX_CLOCK_CONFIG_LF_SRC 1
  • Hi Jeff
    Can you confirm that you are using the standard nRF52840 dongle, or have you made your own PCB?
    All the DFU trigger code is toggle the GPIO connected to the reset pin, which will cause the toggle to reset and start in bootloader mode. Would you be able to put a scope on the reset pin and see if it is actually toggled when you try to activate the DFU trigger library?
    Best regards
    Torbjørn
