OS in development environment :Windows10
HARD :(Taiyo Yuden)EBSHSN Series Evaluation Board : Central / Peripherals
CPU :(Nordic) nRF52832 / ARMR Cortex-M4F 32 bit processor 28-pin Land Grid Array / 15GPIOs / SWD
builder :SEGGER Embedded Studio for ARM Release 3.34a Build 2018022300.35192 Windows x64
2014-2018 SEGGER Microcontroller GmbH & Co. KG
1997-2018 Rowley Associates Ltd.
GCC/BINUTILS: Built using the GNU ARM Embedded Toolchain version 6-2017-q2-update source distribution
Clang/LLVM: Built using the version 5.0.0 source distribution
Soft Ver:nRF5_SDK_15.3.0_59ac345
When I tried to check the PWM output using "pwm_library", it was not output. Do you need to make settings other than the sample program?
[PWM prot]
BSP_LED_0 = P0.09/NFC
BSP_LED_1 = P0.10/NFC
thank you
