ncs_add_partition_manager_config not working
ncs_add_partition_manager_config does not appear to be working.  I am using ncs 2.1.0 and doing a build with MCUboot.  Am I doing something wrong below?
I am using the following in a CMakeLists.txt to add a region to use for storage:
message("adding wynd_storage via pm.yml.storage")
ncs_add_partition_manager_config(pm.yml.storage)
The pm.yml.storage file containss:
wynd_storage:
  placement:
    before: end
When I build I see the message "adding wynd_storage via pm.yml.storage", so it appears ncs_add_partition_manager_config(pm.yml.storage) is executed.  However, I don't see wynd_storage in the ninja partition_manager_report:
flash_primary (0x100000 - 1024kB):
| 0x0: mcuboot (0xc000 - 48kB) |
+---0xc000: mcuboot_primary (0x7a000 - 488kB)-----+
| 0xc000: mcuboot_pad (0x200 - 512B) |
+---0xc200: mcuboot_primary_app (0x79e00 - 487kB)-+
| 0xc200: app (0x79e00 - 487kB) |
| 0x86000: mcuboot_secondary (0x7a000 - 488kB) |
sram_primary (0x40000 - 256kB):
| 0x20000000: sram_primary (0x40000 - 256kB) |
Parents Reply
  • Great suggestion, thank you! I ran into the same problem, and this was the only way I could find to add dynamic partitions in a standalone project without modifying the SDK:
    # This is a hack to work around ncs_add_partition_manager_config() behavior
    # Without this, we have to modify the partition manager subsystem in
    # github.com/.../CMakeLists.txt
    # to add a custom partition.
    # See discussion here:
    # devzone.nordicsemi.com/.../ncs_add_partition_manager_config-not-working
    function(my_ncs_add_partition_manager_config config_file)
    get_filename_component(pm_path ${config_file} REALPATH)
    get_filename_component(pm_filename ${config_file} NAME)
    if (NOT EXISTS ${pm_path})
    message(FATAL_ERROR
    "Could not find specified partition manager configuration file "
    "${config_file} at ${pm_path}"
    endif()
    set_property(GLOBAL APPEND PROPERTY
    PM_SUBSYS_PATHS
    ${pm_path}
    PM_SUBSYS_OUTPUT_PATHS
    ${CMAKE_CURRENT_BINARY_DIR}/${pm_filename}
    endfunction()
    my_ncs_add_partition_manager_config(pm.yml.flash_audio_buffer)
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
