Configure lsm6dso using sensor.h and lsm6dso.h API
From zephyr/samples/sensor/lsm6dso, I found the following code using sensor_channel_get(). API from sensor.h.
static void fetch_and_display(const struct device *dev)
    struct sensor_value x, y, z;
    static int trig_cnt;
    trig_cnt++;
    /* lsm6dso accel */
    sensor_sample_fetch_chan(dev, SENSOR_CHAN_ACCEL_XYZ);
    sensor_channel_get(dev, SENSOR_CHAN_ACCEL_X, &x);
    sensor_channel_get(dev, SENSOR_CHAN_ACCEL_Y, &y);
    sensor_channel_get(dev, SENSOR_CHAN_ACCEL_Z, &z);
    printf("accel x:%f ms/2 y:%f ms/2 z:%f ms/2\n",
           out_ev(&x), out_ev(&y), out_ev(&z));
    /* lsm6dso gyro */
    sensor_sample_fetch_chan(dev, SENSOR_CHAN_GYRO_XYZ);
    sensor_channel_get(dev, SENSOR_CHAN_GYRO_X, &x);
    sensor_channel_get(dev, SENSOR_CHAN_GYRO_Y, &y);
    sensor_channel_get(dev, SENSOR_CHAN_GYRO_Z, &z);
    printf("gyro x:%f dps y:%f dps z:%f dps\n",
    printf("trig_cnt:%d\n\n", trig_cnt);
However, there are more driver API in zephyr/drivers/sensor/lsm6dso
For example
static int lsm6dso_gyro_config(const struct device *dev,
			       enum sensor_channel chan,
			       enum sensor_attribute attr,
			       const struct sensor_value *val)
I could not find the corresponding sensor_gyro_config() API in sensor.h.
What is the proper way to use API to configure the lsm6dso chip ??
JC
