Changing tx power has no effect under Zephyr
Hello
I don't see any change in RSSI with different TX power values under Zephyr. 1.9.1
It used to work with Nordic SDK 3.2.0  (see table below)
The HCI  API in Zephyr  that is used to set TX power does not return any errors and query reports the saved tx power, but there is no measurable RSSI difference
API used
bt_hci_cmd_send_sync(BT_HCI_OP_VS_WRITE_TX_POWER_LEVEL,...)
to write and
bt_hci_cmd_send_sync(BT_HCI_OP_VS_READ_TX_POWER_LEVEL,...)
to read
The functions return no errors
Under Nordic SK 3.2.0 the  following RSSI was reported at 1m
TX Power
Measured Power
(1 M RSSI -dBM)
Max,Average
0 (default)
55,61
8
52,54
7
52,54
6
52,55
5
52,56
4
53,57
3
53,59
2
53,60
-4
60,60
-8
63,62
-12
68,65
-16
73,69
-20
76,72
-40
Not detected,Not detected
In Zephyr it stays the same, around -55 regardless of TX power setting
Any ideas?
Thanks
