Correct way to override a zephyr git using another fork and build failure?
I need to make a small change one of the Zephyr git modules.
At the moment my Git has a west.yml and imports the nrfconnect SDK; which in tern imports the nrfconnect zephyr fork and all underlying modules.
Now the module I need to replace is one of the modules in the zephyr git west.yml.
My code all builds fine if I just locally change the one file in the module and all refs still point to original zephyr module git (not overrriden).
I now clone the modules git; and try and override the use of the original zephyr copy with my own; referring to the SAME commit number from my own west.yml.
My builds now fail.
I have checked the output of the "west update" when swapping between the two variants; this looks good.
I have compared the module sources; this looks identical.
I have tried to compare the build output for successful and failed builds; this is difficult for the two builds as the build order seems to differ.
But I can see there are differences in the two builds WRT compilation of segger related code; primarily subsys/logging/log_backend_rtt.c and subsys/shell/shell_rtt.c.
And final link error is related to Segger RTT.
I attach the build output that I try to compare.
But this does not contain the detail I need to see why one build fails; I think the correct toolchain is being used (2.1.0); but I want to see the complete build line for each target so I can try and work out why the one build fails.
buildlogBad.txtbuildlogGood.txt
  • Last time round I had this issue upgrading to ncs2.1.0; but it mystically disappeared.
    I now find myself being force to upgrade to ncs2.2.0 and the issue has raised itself again.
    It looks as if the wrong copy of SEGGER_RTT_conf.h is being pulled in.
    It appears that there are multiple copies of segger RTT related code littering the codebase; due to the fact that many third party libraies use segger RTT.
    Copies exist under....
    modules/debug/segger
    modules/debug/TraceRecorder
    modules/lib/matter
    modules/lib/openthread
    and its a bit of a lottery which copies get picked up depending on search include paths; in my case the build of the modules/debug/segger appears to pick up SEGGER_RTT_Conf.h from TraceRecorder; and TraceRecorder picks up its own copy. And as the integrations use different Segger libraies....bang.
