Correct way to override a zephyr git using another fork and build failure?
I need to make a small change one of the Zephyr git modules.
At the moment my Git has a west.yml and imports the nrfconnect SDK; which in tern imports the nrfconnect zephyr fork and all underlying modules.
Now the module I need to replace is one of the modules in the zephyr git west.yml.
My code all builds fine if I just locally change the one file in the module and all refs still point to original zephyr module git (not overrriden).
I now clone the modules git; and try and override the use of the original zephyr copy with my own; referring to the SAME commit number from my own west.yml.
My builds now fail.
I have checked the output of the "west update" when swapping between the two variants; this looks good.
I have compared the module sources; this looks identical.
I have tried to compare the build output for successful and failed builds; this is difficult for the two builds as the build order seems to differ.
But I can see there are differences in the two builds WRT compilation of segger related code; primarily subsys/logging/log_backend_rtt.c and subsys/shell/shell_rtt.c.
And final link error is related to Segger RTT.
I attach the build output that I try to compare.
But this does not contain the detail I need to see why one build fails; I think the correct toolchain is being used (2.1.0); but I want to see the complete build line for each target so I can try and work out why the one build fails.
buildlogBad.txtbuildlogGood.txt
    Which module is this?
    The nRF Connect SDK does not import all modules imported by Zephyr, only the ones explicitly listed in name-allowlist: https://github.com/nrfconnect/sdk-nrf/blob/v2.1.0/west.yml#L66.
    I see that the build error is related to SEGGER_RTT_WriteSkipNoLock, and that you are also getting some warnings about SEGGER_RTT_HasDataUp in the failing build. Have you made any changes to the Segger module?
    Marte
  • There is a issue compiling tracealyzer into latest builds due to a namespace issue.  trcKernelPort.h includes a "version.h" to get the kernel version so to force the build to break if kernel is not correct version; problem is in my build variant it pulls in mbedtls stuff and that too contains a "version.h".
    So trcKernelPort.h picks wrong version.h and bombs out as it doen't get good kernel version.
    Hence my need to swap to a fork of the tracealyzer libs (modules/debug/TraceRecorder); where I can patch the one file.
    But as soon as I modify my west,yml to pull in my copy of libs the build breaks. Something I m missing here.
  • Looking at the compile error there looks to be some kind of magic to do with compiler versions/architecures in SEGGER_RTT_Conf.h and SEGGER_RTT.h; looks as if RTT_USE_ASM has been given value 1 (or not defined); and the C implemenetation in SEGGER_RTT.c of that function is not included.
    But no ASM version of the function is included in the build either.
    Can you share your west.yml file?
    Marte
  • Hi Marte,
    We are building from standard repos; avoiding the conflicting kernel version.h and mbedtls kernel.h issue by kludging our build to inject kernel version int build from top lvel project CMakeLists.txt.
    add_definitions(-DKERNEL_VERSION_MAJOR=3)
    This mean when tracealyzer includes version.h; picking up wrongly mbledtls version and bombig out due to the kernel version not being know; it just proceeds through and works.
    The west.yml that gave us issues was...
    manifest:
      remotes:
        - name: ncs
          url-base: https://github.com/nrfconnect
        - name: incus
          url-base: https://github.com/INCUS-Performance
        - name: zeph
          url-base: https://github.com/zephyrproject-rtos
        - name: ublox
          url-base: https://github.com/u-blox
      projects:
        - name: nrf
          repo-path: sdk-nrf
          remote: ncs
          revision: v2.1.0
          import: true
        - name: TraceRecorderSource
          repo-path: TraceRecorderSource
          remote: incus
          revision: 6999859769c108533a3718f24bffef3da4f63e9b
          path: modules/debug/TraceRecorder
          groups:
           - debug
        - name: ubxlib
          repo-path: ubxlib
          remote: ublox
          revision: fb63a1f22333c840464a658c708327c04191826e
          path: ubxlib
      self:
        path: nova
    This overrides the standard trace recorder stuff with the kernel version check commented out.
    But as said we have worked round the issue for now.
    Owain
